Page 7 of 14
Re: Python Plugin: GoodWe solar inverter via SEMS API
Posted: Friday 20 August 2021 11:52
by vinjon
it' sworking now, but only for one inverter (i have two in one powerstation)
2021-08-20 11:46:40.623 Error: (GoodWe PV) 'onHeartbeat' failed 'ValueError':'not enough values to unpack (expected 2, got 1)'.
2021-08-20 11:46:40.623 Error: (GoodWe PV) ----> Line 455 in '/home/user/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function onHeartbeat
2021-08-20 11:46:40.623 Error: (GoodWe PV) ----> Line 393 in '/home/user/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function onHeartbeat
2021-08-20 11:46:40.623 Error: (GoodWe PV) ----> Line 133 in '/home/user/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function startDeviceUpdateV2
2021-08-20 11:46:40.623 Error: (GoodWe PV) ----> Line 164 in '/home/user/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function updateDevices
Posted: Friday 20 August 2021 13:57
by SolarShed
vinjon wrote: Friday 20 August 2021 11:52 it' sworking now, but only for one inverter (i have two in one powerstation)
Hetzelfde bij mij :-) Ik heb maar 1 inverter dus ga voorlopig de errors in de log gewoon negeren ;-)
2021-08-20 13:56:24.859 Error: Inverter: (Inverter) 'onStart' failed 'ValueError':'not enough values to unpack (expected 2, got 1)'.
2021-08-20 13:56:24.859 Error: Inverter: (Inverter) ----> Line 426 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function onStart
2021-08-20 13:56:24.859 Error: Inverter: (Inverter) ----> Line 206 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function onStart
2021-08-20 13:56:24.859 Error: Inverter: (Inverter) ----> Line 133 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function startDeviceUpdateV2
2021-08-20 13:56:24.859 Error: Inverter: (Inverter) ----> Line 164 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function updateDevices
Posted: Friday 20 August 2021 14:43
by JanJaap
OK well at least it's working. I'll have a look after my holiday. To get this properly fixed, I do need the complete response of the second call to the Goodwe API, which is too big to fit into the Domoticz loglines (it'll be truncated). This can be retrieved using Postman. If you can send me these response then I can fix it (when I return from holiday....).
Posted: Friday 20 August 2021 19:49
OK, this morning my plugin failed too. I updated and put the Plant ID in the mandatory fiel but get errors.
I updated python requests (nothing to update...)
Plugin debug logging giving InvalidURL
 2021-08-20 19:47:02.068 Goodwe Solar: (Goodwe Solar) startDeviceUpdate, token availability: 'False'
2021-08-20 19:47:02.068 Goodwe Solar: (Goodwe Solar) build tokenRequest with UN: '[email protected]', pwd: 'MyPassword'
2021-08-20 19:47:02.068 Goodwe Solar: (Goodwe Solar) build apiRequestHeaders with token: '{"client": "web", "version": "v3.1", "language": "en-GB"}'
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) 'onHeartbeat' failed 'InvalidURL'.
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) ----> Line 461 in '/home/udoox86/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py'
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) ----> Line 399 in '/home/udoox86/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py'
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) ----> Line 129 in '/home/udoox86/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py'
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) ----> Line 327 in '/home/udoox86/domoticz/plugins/domoticz-GoodWeSEMS/GoodWe.py'
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) ----> Line 117 in '/usr/local/lib/python3.8/dist-packages/requests/api.py'
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) ----> Line 61 in '/usr/local/lib/python3.8/dist-packages/requests/api.py'
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) ----> Line 528 in '/usr/local/lib/python3.8/dist-packages/requests/sessions.py'
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) ----> Line 456 in '/usr/local/lib/python3.8/dist-packages/requests/sessions.py'
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) ----> Line 316 in '/usr/local/lib/python3.8/dist-packages/requests/models.py'
2021-08-20 19:47:02.070 Error: Goodwe Solar: (Goodwe Solar) ----> Line 384 in '/usr/local/lib/python3.8/dist-packages/requests/models.py'
Posted: Friday 20 August 2021 20:41
by jan54
The plugin is failing since 17-8-2021.
Already pulled the latest plugin and filled in my serial number, but still no readings.
This are debug messages:
2021-08-20 20:35:24.091 Goodwe: (Goodwe) onHeartbeat called, starting device update.
2021-08-20 20:35:24.091 Goodwe: (Goodwe) startDeviceUpdate, token availability: 'True'
2021-08-20 20:35:24.092 Goodwe: (Goodwe) build stationDataRequest for 1 station, attempt: 1
2021-08-20 20:35:24.092 Goodwe: (Goodwe) build apiRequestHeaders with token: '{"uid": "efcb23f0-9130-43be-bee2-8b3e0ab05a35", "timestamp": 1629483335639, "token": "8a9ed6d8551f6aaffb34bd1d42a5525f", "client": "web", "version": "v3.1", "language": "en-GB"}'
2021-08-20 20:35:24.289 Goodwe: (Goodwe) building station data request on URL: https://eu.semsportal.com/api/v2/PowerS ... rstationId which returned status code: 200 and response length = 414
Posted: Friday 20 August 2021 23:35
waltervl wrote: Friday 20 August 2021 19:49 OK, this morning my plugin failed too. I updated and put the Plant ID in the mandatory fiel but get errors.
SOLVED!
I had to do an upgrade of python urllib3:
sudo pip3 install urllib3 --upgrade
Posted: Saturday 21 August 2021 19:08
by pvdgulik
Same problem here, although it's one inverter, two strings. The second string is not working anymore.
I made a issue on https://github.com/JanJaapKo/domoticz-G ... S/issues/4.
2021-08-21 11:02:26.054 GoodWe GW5000-DT: (GoodWe GW5000-DT) onHeartbeat called, starting device update.
2021-08-21 11:02:26.054 GoodWe GW5000-DT: (GoodWe GW5000-DT) startDeviceUpdate, token availability: 'True'
2021-08-21 11:02:26.054 GoodWe GW5000-DT: (GoodWe GW5000-DT) build stationDataRequest for 1 station, attempt: 1
2021-08-21 11:02:26.054 GoodWe GW5000-DT: (GoodWe GW5000-DT) build apiRequestHeaders with token: '{"uid": "****************************", "timestamp": 1629495111054, "token": "*****************", "client": "web", "version": "v3.1", "language": "en-GB"}'
2021-08-21 11:02:26.265 GoodWe GW5000-DT: (GoodWe GW5000-DT) building station data request on URL: https://eu.semsportal.com/api/v2/PowerStation/GetMonitorDetailByPowerstationId which returned status code: 200 and response length = 28114
2021-08-21 11:02:26.267 GoodWe GW5000-DT: (GoodWe GW5000-DT) create station with id: '***************' and inverters: 1
2021-08-21 11:02:26.267 GoodWe GW5000-DT: (GoodWe GW5000-DT) inverter created: '*************'
2021-08-21 11:02:26.267 GoodWe GW5000-DT: (GoodWe GW5000-DT) PowerStation created: '*****************'
2021-08-21 11:02:26.267 GoodWe GW5000-DT: (GoodWe GW5000-DT) inverter found with SN: '****************'
2021-08-21 11:02:26.267 GoodWe GW5000-DT: (GoodWe GW5000-DT) Status of GoodWe inverter (SN: ****************): '1 generating'
2021-08-21 11:02:26.277 GoodWe GW5000-DT: (GoodWe GW5000-DT) inverter generating, log temp
2021-08-21 11:02:26.285 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Goodwe solar - Current: nValue 0 - sValue 3.4A - BatteryLevel 255
2021-08-21 11:02:26.293 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Goodwe solar - Voltage: nValue 0 - sValue 234.7V - BatteryLevel 255
2021-08-21 11:02:26.301 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Zonnepanelen: nValue 0 - sValue 2397W;11055800.0 - BatteryLevel 255
2021-08-21 11:02:26.308 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Goodwe solar - string 1 Voltage: nValue 0 - sValue 215V - BatteryLevel 255
2021-08-21 11:02:26.315 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Goodwe solar - string 1 Current: nValue 0 - sValue 5.8A - BatteryLevel 255
2021-08-21 11:02:26.334 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Goodwe solar - string 1 Power: nValue 0 - sValue 1247.0;0 - BatteryLevel 255
2021-08-21 11:02:26.335 Error: GoodWe GW5000-DT: (GoodWe GW5000-DT) 'onHeartbeat' failed 'ValueError':'not enough values to unpack (expected 2, got 1)'.
2021-08-21 11:02:26.335 Error: GoodWe GW5000-DT: (GoodWe GW5000-DT) ----> Line 461 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function onHeartbeat
2021-08-21 11:02:26.335 Error: GoodWe GW5000-DT: (GoodWe GW5000-DT) ----> Line 399 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function onHeartbeat
2021-08-21 11:02:26.335 Error: GoodWe GW5000-DT: (GoodWe GW5000-DT) ----> Line 133 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function startDeviceUpdateV2
2021-08-21 11:02:26.335 Error: GoodWe GW5000-DT: (GoodWe GW5000-DT) ----> Line 164 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function updateDevices
2021-08-21 11:02:36.059 GoodWe GW5000-DT: (GoodWe GW5000-DT) onHeartbeat called, starting device update.
2021-08-21 11:02:36.059 GoodWe GW5000-DT: (GoodWe GW5000-DT) startDeviceUpdate, token availability: 'True'
2021-08-21 11:02:36.059 GoodWe GW5000-DT: (GoodWe GW5000-DT) build stationDataRequest for 1 station, attempt: 1
2021-08-21 11:02:36.059 GoodWe GW5000-DT: (GoodWe GW5000-DT) build apiRequestHeaders with token: '{"uid": "**************************", "timestamp": 1629495111054, "token": "***********************", "client": "web", "version": "v3.1", "language": "en-GB"}'
2021-08-21 11:02:36.286 GoodWe GW5000-DT: (GoodWe GW5000-DT) building station data request on URL: https://eu.semsportal.com/api/v2/PowerStation/GetMonitorDetailByPowerstationId which returned status code: 200 and response length = 28114
2021-08-21 11:02:36.288 GoodWe GW5000-DT: (GoodWe GW5000-DT) create station with id: '************' and inverters: 1
2021-08-21 11:02:36.288 GoodWe GW5000-DT: (GoodWe GW5000-DT) inverter created: '************'
2021-08-21 11:02:36.288 GoodWe GW5000-DT: (GoodWe GW5000-DT) PowerStation created: '***************'
2021-08-21 11:02:36.288 GoodWe GW5000-DT: (GoodWe GW5000-DT) inverter found with SN: '**************'
2021-08-21 11:02:36.288 GoodWe GW5000-DT: (GoodWe GW5000-DT) Status of GoodWe inverter (SN: **************): '1 generating'
2021-08-21 11:02:36.298 GoodWe GW5000-DT: (GoodWe GW5000-DT) inverter generating, log temp
2021-08-21 11:02:36.306 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Goodwe solar - Current: nValue 0 - sValue 3.4A - BatteryLevel 255
2021-08-21 11:02:36.313 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Goodwe solar - Voltage: nValue 0 - sValue 234.7V - BatteryLevel 255
2021-08-21 11:02:36.321 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Zonnepanelen: nValue 0 - sValue 2397W;11055800.0 - BatteryLevel 255
2021-08-21 11:02:36.328 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Goodwe solar - string 1 Voltage: nValue 0 - sValue 215V - BatteryLevel 255
2021-08-21 11:02:36.336 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Goodwe solar - string 1 Current: nValue 0 - sValue 5.8A - BatteryLevel 255
2021-08-21 11:02:36.355 GoodWe GW5000-DT: (GoodWe GW5000-DT) Update Goodwe solar - string 1 Power: nValue 0 - sValue 1247.0;0 - BatteryLevel 255
2021-08-21 11:02:36.355 Error: GoodWe GW5000-DT: (GoodWe GW5000-DT) 'onHeartbeat' failed 'ValueError':'not enough values to unpack (expected 2, got 1)'.
2021-08-21 11:02:36.355 Error: GoodWe GW5000-DT: (GoodWe GW5000-DT) ----> Line 461 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function onHeartbeat
2021-08-21 11:02:36.355 Error: GoodWe GW5000-DT: (GoodWe GW5000-DT) ----> Line 399 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function onHeartbeat
2021-08-21 11:02:36.355 Error: GoodWe GW5000-DT: (GoodWe GW5000-DT) ----> Line 133 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function startDeviceUpdateV2
2021-08-21 11:02:36.355 Error: GoodWe GW5000-DT: (GoodWe GW5000-DT) ----> Line 164 in
Can you help?
Posted: Sunday 22 August 2021 0:33
Jan Jaap is on holiday so it will take some time to resolve the remaing issues....
Posted: Wednesday 25 August 2021 11:37
by HansOtten
For those like me not knowing what "Power station ID' is,
- login via a web browser to semsportal.com
- look at the url when the portal is running, something like:
https://www.semsportal.com/powerstation ... /XXXX-xxxx
- the station ID is the number part after powerstatussnmin/ a long numbr
Fill that in in the hardware and things start working, some real info yet, still errors on the log.
So i disabled the plugin waiting for the end of the well deserved vacation of Jan Jaap!
2021-08-25 11:35:24.764 Error: Solar: (Solar) 'onHeartbeat' failed 'ValueError':'not enough values to unpack (expected 2, got 1)'.
2021-08-25 11:35:24.764 Error: Solar: (Solar) ----> Line 461 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function onHeartbeat
2021-08-25 11:35:24.764 Error: Solar: (Solar) ----> Line 399 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function onHeartbeat
2021-08-25 11:35:24.764 Error: Solar: (Solar) ----> Line 133 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function startDeviceUpdateV2
2021-08-25 11:35:24.764 Error: Solar: (Solar) ----> Line 164 in '/home/pi/domoticz/plugins/domoticz-GoodWeSEMS/plugin.py', function updateDevices
Hans
Posted: Wednesday 25 August 2021 13:49
by JanJaap
All,
I see the errors occur as well when reading in the separate input strings. Output values like power etc work correctly, I assume this is what most people look at daily (at least I do ;) ) so the basic function still works.....
As for the station IID the plugin setup page also describes how to obtain this.
As said, I 'll fix it on return
Posted: Wednesday 25 August 2021 15:42
by HansOtten
Indeed the description is on the configuration part!
I was confused by the Power Station ID prompt versus the description 'station ID' as a string of characters, where I saw a string of digits only.
Posted: Thursday 26 August 2021 13:56
by Brutus
The timings of the refresh interval are not working the way it needs to be.
When setting the refresh interval to 10 seconds the script pulls every second...
When setting the refresh interval to 30 seconds the script pulls the first time after 30 seconds after that it puls every second...
When setting the refresh interval to 1 minute the script pulls every 10 seconds.
When setting the refresh interval to 5 minutes the script pulls the first time after 5 minutes after that it pulls every 10 seconds...
Greetings
Posted: Thursday 26 August 2021 16:24
Brutus wrote: Thursday 26 August 2021 13:56 The timings of the refresh interval are not working the way it needs to be.
Greetings
I can confirm, did not notice it yet, was happy that it worked again at last.
Posted: Monday 30 August 2021 8:52
by Brutus
Im trying to make some scripts but im getting stuck at the output from the GoodWe.
Why is there a W (watt) behind the first number (svalues)?
When using this line of code i get an error because I need only numbers. But not there is a number and a letter.
EnergyImportLow, EnergyImportHigh, EnergyExportLow, EnergyExportHigh, PowerImport, PowerExport = otherdevices_svalues[P1MeterDeviceName]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
Lua doesn't like that. I also think its not needed because the actual sensor adds this on its own.
Is it possible to remove the W after the number?
Posted: Monday 30 August 2021 9:05
Brutus wrote: Monday 30 August 2021 8:52 Why is there a W (watt) behind the first number? When using this line of code i get an error because i need only numbers. But not there is a number and a letter. Lua doesn't like that. I also think its not needed because the actual sensor adds this on its own.
Good questions that @JanJaap can answer but he is on holiday now. So be patient.
Posted: Saturday 04 September 2021 13:38
by Theop
Is er ook ergens een handleiding (stappenplan) te vinden om mijn Goodwe succesvol in Domoticz zichtbaar te krijgen?
Posted: Monday 06 September 2021 11:51
by rdas
Theop wrote: Saturday 04 September 2021 13:38 Is er ook ergens een handleiding (stappenplan) te vinden om mijn Goodwe succesvol in Domoticz zichtbaar te krijgen?
See https://github.com/janjaapko/domoticz-GoodWeSEMS
Posted: Monday 06 September 2021 22:04
by JanJaap
Right so I'm back ;)
I've added a couple of improvements to the plugin, as version 2.0.4 (a restart of Domoticz is required to see the new config description in Domoticz):
- handling the expected exceptions much neater so they do only add 1 logline
- added a fix for the 'unpack' error reported by multiple people which caused the plugin to fail before it would read in data of the second (and 3rd and 4th if available) input strings
- I improved the configuration page of the plugin a bit, so it should be a bit more clear what to do. Still, this requires users not be afraid of computer stuff 8-)
Hope all is fine now again. I will look into dealing with more than 1 inverter later. I will describe how to fetch the API response using postman in the Wiki pages of the plugin.
Posted: Monday 06 September 2021 22:25
by Brutus
Hi there,
Hope you had a nice vacation.
What about the things I noticed? The unwanted W in de svalues en de script running not at the given time option?
Greetings
Posted: Monday 06 September 2021 22:44
by JanJaap
Right, so the W(att) is not something the plugin does but that comes from how Domoticz deals with these devices, so can't help you there (and I try to avoid lua because python is much nicer). This topic is about the plugin, not about anything you can do with the data in domoticz.
I'll have a look at the updates later, although they look OK on my RPi.
