Page 7 of 12
Re: Python Plugin: Python Plugin Manager
Posted: Sunday 04 November 2018 20:19
by misko903
ycahome wrote: Tuesday 30 October 2018 13:20
misko903 wrote: Monday 29 October 2018 8:15 what about updates of plugins?
after every restart, my RPi is telling me, that update for ebusd plugin is available. How can i update it?
Thank you,
Michal
Read the very first post for usage:
"Auto Update" Options (After every change press "Update")
"All": Continuously update all plugins
"Selected":Continuously update selected plugin (You should first select desired plugin from "Domoticz Plugin" field)
"All (NotifyOnly)": Check all plugins for updates and generate notification email.
"Selected (NotifyOnly)":Check selected plugin for updates and generate notification email. (You should first select desired plugin from "Domoticz Plugin" field)
Thanks, I am using Slovak translation of DZ, it is partially translated, therefor I was confused. Now setted up correctly and it does not bother me again...
Posted: Thursday 08 November 2018 8:10
by dextm80
dextm80 wrote: Saturday 03 November 2018 16:45
2018-11-03 16:45:10.005 Error: Python Plugin Manager hardware (13) thread seems to have ended unexpectedly
why?
i've already this error, anyone who known this error mean?
Posted: Thursday 08 November 2018 9:10
by ycahome
dextm80 wrote: Thursday 08 November 2018 8:10
why?
This is a generic Domoticz alert. Can you post your settings in order to see if there is something wrong? Have you set "Data Timeout" to "Disabled"?
Posted: Friday 09 November 2018 10:21
by ycahome
Version 1.5.13 is out
v.1.5.13
Added: "eQ-3 MAX!" plugin (Thanks to @mvzut)
Added: "SmogTok Air Quality monitor" plugin (Thanks to @smogtok)
Posted: Sunday 11 November 2018 18:45
by dextm80
ycahome wrote: Thursday 08 November 2018 9:10
why?
yes, data timeout is disabled, other settings are default. i've upgrade 1.5.13 but the error stay here yet
Posted: Sunday 11 November 2018 19:06
by ycahome
PP-Manager is Hardware Idx 13?
Posted: Monday 12 November 2018 17:00
by nono212
this is not working with Synology
I tryed to install eq-3 max
I had some errors
I can be a beta tester for Synology if needed
To make it work I had to launch the command my self ... but in sudo mode
Posted: Monday 12 November 2018 18:14
by mvzut
nono212 wrote: Monday 12 November 2018 17:00 this is not working with Synology
I had some errors
Others have successfully installed the plugin (directly) on Synology. So I assume your errors have to do with the Plugin Manager. If there is anything I can do (as eQ-3 Max! plugin author) please let me know.
Posted: Tuesday 13 November 2018 11:41
by ycahome
ok,
maybe we found something here.
So, the question is:
"is there anyone that had -even a single- plugin installed on Synology Based Domoticz via PP-Manager (or without sudo?)?"
Posted: Tuesday 13 November 2018 15:53
by nono212
Sorry the name is not correct in the image ...
the name MaxCube is not correct it should be pp_manager
Posted: Wednesday 14 November 2018 22:44
by dextm80
ycahome wrote: Sunday 11 November 2018 19:06 PP-Manager is Hardware Idx 13?
yes
Posted: Monday 10 December 2018 19:26
by RickU09
How can I uninstall PP-Manager?
I'm new to Domoticz/RPi
I tried
-Cd domoticz/plugins
-pip uninstall PP-MANAGER
No result, Domoticz stopped working after installing this plugin manager.
Cannot switch to python 3.4 (Which should solve the problem??)
pi@raspberrypi:~ $ sudo apt-get install python3.4
Reading package lists... Error!
E: Splitting of file /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_InRelease failed as it doesn't contain all expected parts 0 1 0
E: The package lists or status file could not be parsed or opened.
Also tried
pi@raspberrypi:~ $ sudo apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Err:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Splitting up /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_InRelease into data and signature faile d
Err:2 http://archive.raspberrypi.org/debian stretch InRelease
Splitting up /var/lib/apt/lists/archive.raspberrypi.org_debian_dists_stretch_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will b e used. GPG error: http://raspbian.raspberrypi.org/raspbian stretch InRelease: Splitting up /var/lib/apt/lists/raspbian.r aspberrypi.org_raspbian_dists_stretch_InRelease into data and signature failed
W: An error occurred during the signature verification. The repository is not updated and the previous index files will b e used. GPG error: http://archive.raspberrypi.org/debian stretch InRelease: Splitting up /var/lib/apt/lists/archive.raspb errypi.org_debian_dists_stretch_InRelease into data and signature failed
W: Failed to fetch http://raspbian.raspberrypi.org/raspbia ... /InRelease Splitting up /var/lib/apt/lists/rasp bian.raspberrypi.org_raspbian_dists_stretch_InRelease into data and signature failed
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... /InRelease Splitting up /var/lib/apt/lists/archive .raspberrypi.org_debian_dists_stretch_InRelease into data and signature failed
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: Splitting of file /var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_InRelease failed as it doesn't co ntain all expected parts 0 1 0
Then did this:
pi@raspberrypi:~ $ sudo apt-get clean
pi@raspberrypi:~ $ sudo rm-vf /var/lib/apt/lists/*
sudo: rm-vf: command not found
pi@raspberrypi:~ $ sudo rm -vf /var/lib/apt/lists/*
removed '/var/lib/apt/lists/archive.raspberrypi.org_debian_dists_stretch_InRelease'
removed '/var/lib/apt/lists/archive.raspberrypi.org_debian_dists_stretch_main_binary-armhf_Packages'
removed '/var/lib/apt/lists/archive.raspberrypi.org_debian_dists_stretch_ui_binary-armhf_Packages'
removed '/var/lib/apt/lists/lock'
rm: cannot remove '/var/lib/apt/lists/partial': Is a directory
removed '/var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_contrib_binary-armhf_Packages'
removed '/var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_InRelease'
removed '/var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_main_binary-armhf_Packages'
removed '/var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_non-free_binary-armhf_Packages'
removed '/var/lib/apt/lists/raspbian.raspberrypi.org_raspbian_dists_stretch_rpi_binary-armhf_Packages'
pi@raspberrypi:~ $ sudo rm -vf /var/lib/apt/lists/partial/*
Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
Get:4 http://archive.raspberrypi.org/debian stretch/main armhf Packages [200 kB]
Get:5 http://archive.raspberrypi.org/debian stretch/ui armhf Packages [40.3 kB]
Get:6 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages [56.9 kB]
Get:7 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages [95.5 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian stretch/rpi armhf Packages [1,360 B]
Fetched 12.1 MB in 36s (329 kB/s)
Reading package lists... Done
pi@raspberrypi:~ $ sudo apt-get upgrade
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages will be upgraded:
base-files geany geany-common gtk2-engines-clearlookspix libbasicusageenvironment1 libgroupsock8 libgs9 libgs9-common liblivemedia57 libobrender32v5 libobt2v5 libperl5.24
libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 libsmbclient libssl1.1 libtiff5 libusageenvironment3 libwbclient0 openbox openssl perl perl-base
perl-modules-5.24 pi-greeter pipanel policykit-1 python-rpi.gpio python3-rpi.gpio raspberrypi-sys-mods raspberrypi-ui-mods raspi-config rp-prefapps rpi-chromium-mods
samba-common samba-libs zenity zenity-common
39 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 39.8 MB of archives.
After this operation, 155 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.raspberrypi.org/debian stretch/ui armhf rpi-chromium-mods armhf 20181204 [9,174 kB]
Get:2 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf base-files armhf 9.9+rpi1+deb9u6 [67.5 kB]
Get:3 http://mirror.proserve.nl/raspbian/raspbian stretch/main armhf libperl5.24 armhf 5.24.1-3+deb9u5 [2,837 kB]
Get:4 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf perl armhf 5.24.1-3+deb9u5 [219 kB]
Get:6 http://mirror.transip.net/raspbian/raspbian stretch/main armhf perl-modules-5.24 all 5.24.1-3+deb9u5 [2,722 kB]
Get:8 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libsmbclient armhf 2:4.5.12+dfsg-2+deb9u4 [144 kB]
Get:5 http://mirror.proserve.nl/raspbian/raspbian stretch/main armhf perl-base armhf 5.24.1-3+deb9u5 [1,198 kB]
Get:9 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf samba-libs armhf 2:4.5.12+dfsg-2+deb9u4 [4,379 kB]
Get:7 http://mirror.proserve.nl/raspbian/raspbian stretch/main armhf libwbclient0 armhf 2:4.5.12+dfsg-2+deb9u4 [121 kB]
Get:11 http://mirror.proserve.nl/raspbian/raspbian stretch/main armhf libssl1.1 armhf 1.1.0j-1~deb9u1 [1,115 kB]
Get:10 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf samba-common all 2:4.5.12+dfsg-2+deb9u4 [172 kB]
Get:12 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libbasicusageenvironment1 armhf 2016.11.28-1+deb9u1 [19.7 kB]
Get:14 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libtiff5 armhf 4.0.8-2+deb9u4 [220 kB]
Get:13 http://mirror.transip.net/raspbian/raspbian stretch/main armhf libgroupsock8 armhf 2016.11.28-1+deb9u1 [24.8 kB]
Get:15 http://mirror.nl.leaseweb.net/raspbian/raspbian stretch/main armhf libgs9 armhf 9.26~dfsg-0+deb9u1 [1,863 kB]
Get:16 http://mirror.transip.net/raspbian/raspbian stretch/main armhf libgs9-common all 9.26~dfsg-0+deb9u1 [5,140 kB]
Get:17 http://mirror.nl.leaseweb.net/raspbian/raspbian stretch/main armhf liblivemedia57 armhf 2016.11.28-1+deb9u1 [265 kB]
Get:20 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libpolkit-backend-1-0 armhf 0.105-18+deb9u1 [39.8 kB]
Get:21 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libpolkit-gobject-1-0 armhf 0.105-18+deb9u1 [37.8 kB]
Get:22 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf libusageenvironment3 armhf 2016.11.28-1+deb9u1 [12.2 kB]
Get:23 http://mirror.serverius.net/raspbian/raspbian stretch/main armhf openssl armhf 1.1.0j-1~deb9u1 [712 kB]
Get:24 http://archive.raspberrypi.org/debian stretch/ui armhf geany armhf 1.29-1+rpt2 [1,224 kB]
Get:18 http://mirror.transip.net/raspbian/raspbian stretch/main armhf policykit-1 armhf 0.105-18+deb9u1 [61.7 kB]
Get:19 http://mirror.transip.net/raspbian/raspbian stretch/main armhf libpolkit-agent-1-0 armhf 0.105-18+deb9u1 [22.3 kB]
Get:25 http://archive.raspberrypi.org/debian stretch/ui armhf geany-common all 1.29-1+rpt2 [2,461 kB]
Get:26 http://archive.raspberrypi.org/debian stretch/ui armhf gtk2-engines-clearlookspix armhf 1:2.20.7 [66.0 kB]
Get:27 http://archive.raspberrypi.org/debian stretch/ui armhf libobt2v5 armhf 3.6.1-4+rpi8 [62.3 kB]
Get:28 http://archive.raspberrypi.org/debian stretch/ui armhf libobrender32v5 armhf 3.6.1-4+rpi8 [69.7 kB]
Get:29 http://archive.raspberrypi.org/debian stretch/ui armhf openbox armhf 3.6.1-4+rpi8 [281 kB]
Get:30 http://archive.raspberrypi.org/debian stretch/ui armhf pi-greeter armhf 0.9 [40.8 kB]
Get:31 http://archive.raspberrypi.org/debian stretch/ui armhf zenity-common all 3.28.1-1.1~bpo9+rpt1 [4,126 kB]
Get:32 http://archive.raspberrypi.org/debian stretch/ui armhf zenity armhf 3.28.1-1.1~bpo9+rpt1 [268 kB]
Get:33 http://archive.raspberrypi.org/debian stretch/ui armhf pipanel armhf 20181126~094616 [19.2 kB]
Get:34 http://archive.raspberrypi.org/debian stretch/main armhf python-rpi.gpio armhf 0.6.5~stretch-1 [23.5 kB]
Get:35 http://archive.raspberrypi.org/debian stretch/main armhf python3-rpi.gpio armhf 0.6.5~stretch-1 [23.6 kB]
Get:36 http://archive.raspberrypi.org/debian stretch/main armhf raspberrypi-sys-mods armhf 20181127 [10.2 kB]
Get:37 http://archive.raspberrypi.org/debian stretch/ui armhf rp-prefapps armhf 0.5 [175 kB]
Get:38 http://archive.raspberrypi.org/debian stretch/ui armhf raspberrypi-ui-mods all 1.20181206 [318 kB]
Get:39 http://archive.raspberrypi.org/debian stretch/ui armhf raspi-config all 20181118 [20.2 kB]
Fetched 39.8 MB in 12s (3,302 kB/s)
Reading changelogs... Done
Extracting templates from packages: 100%
Preconfiguring packages ...
dpkg: unrecoverable fatal error, aborting:
files list file for package 'openvpn' is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
And then:...
The following additional packages will be installed:
libpython3.4-minimal libpython3.4-stdlib python3.4-minimal
Suggested packages:
python3.4-venv python3.4-doc binfmt-support
The following NEW packages will be installed:
libpython3.4-minimal libpython3.4-stdlib python3.4 python3.4-minimal
0 upgraded, 4 newly installed, 0 to remove and 39 not upgraded.
Need to get 0 B/4,049 kB of archives.
After this operation, 20.7 MB of additional disk space will be used.
Selecting previously unselected package libpython3.4-minimal:armhf.
pi@raspberrypi:~ $ compgen -c python
python3.5-config
python3.5m
python2.7
python3.5
python3-config
python
python3
python2.7-config
python2-config
python3.5m-config
python3m
python3m-config
python-config
python2
pi@raspberrypi:~ $
Still no Python3.4????
Not getting it to work properly...
Posted: Monday 10 December 2018 20:31
by ycahome
RickU09 wrote: Monday 10 December 2018 19:26 How can I uninstall PP-Manager?
I tried
Just like any other plugin. Delete plugin folder(PP-Manager).
Posted: Wednesday 12 December 2018 19:51
by RickU09
I've tried again with a new fresh install.
I've managed to install 3.4 and remove 3.5.
After installing Python Plugin Manager again I cannot find it in domoticz. Like there is not running any version of python anymore?
Also my Sony Bravia plugin is not working anymore.
My last tries:
pi@raspberrypi:~ $ sudo update-alternatives --install /usr/bin/python python /usr/bin/python3.4 4
update-alternatives: using /usr/bin/python3.4 to provide /usr/bin/python (python) in auto mode
pi@raspberrypi:~ $ sudo update-alternatives --config python
There is only one alternative in link group python (providing /usr/bin/python): /usr/bin/python3.4
Nothing to configure.
Posted: Wednesday 12 December 2018 20:30
by ycahome
check for the prerequisites of python framework.
You need the also relative python3-dev
Posted: Thursday 10 January 2019 14:33
by sylar
Hi there,
Like many others, I have multiple lines of "Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly" in my logs (PP manager idx is 10). For instance, for today from 00:00:00 to 05:00:00 (and it continues like that in the next hours):
2019-01-10 00:07:07.638 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 00:07:21.642 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 00:37:46.269 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 00:38:00.272 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 01:08:14.000 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 01:08:28.146 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 01:38:52.809 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 01:39:06.813 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 02:09:20.901 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 02:09:34.905 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 02:39:45.056 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 02:39:59.059 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 03:10:13.189 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 03:10:27.191 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 03:10:41.195 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 03:40:50.748 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 03:41:04.753 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 04:11:17.919 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 04:11:31.923 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 04:41:55.491 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2019-01-10 04:42:09.495 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
Any ideas where this could come from? It doesn't seem to have any effect, just wondering what's happening there.
I'm using: Python Plugin Manager v.1.5.16
Posted: Sunday 20 January 2019 4:25
by ben53252642
@remb0 I think plugin management should be a top priority for Domoticz in 2019.
We need a new interface for managing the growing number of built in plugins and for easily installing Python Plugins (build the Python Plugin Manager into Domoticz)?
Posted: Tuesday 05 February 2019 7:23
by madhusree
reetings! Very helpful advice in this particular article! It's the little changes that produce the greatest changes. Many thanks for sharing!
Posted: Friday 08 February 2019 19:00
by Carthman
I tried yesterday evenin to install the PP Manager on my Domoticz 4.97, but no way !
I got Raspbian updated, I installed all the Python libraries, even the -dev ones, I made the plugin.py executable, I rebooted Domoticz, and finally it was possible to add a Python Plugin in Hardwares, but no switches were added on the devices, and each time I tried to remove the created Hardware, Domoticz got freezed.
On the logs, there was a lot of "Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly"
I had to uninstall the PP Manager folder !
I was really interested in the Yamaha Receiver Plugin, I installed it without the manager and it's working fine ! No bugs !
Is there something I've missed ?
Posted: Saturday 09 February 2019 16:14
by cobra045
Hallo,
I tried to install the Python PP Plugin Manager today on my Domoticz 4.97
According to the information on the screen there should be a new buton with devices, unfortunately nothing to find on the devices tab.
However, the plugin seems to work according to the log file.
Some error messages are given at the start of the plugin. see the log file
2019-02-09 15:20:26.451 Error: (Python Plugin Manager) Git ErrorNo:2
2019-02-09 15:20:26.451 Error: (Python Plugin Manager) Git StrError:No such file or directory: '/home/pi/domoticz/plugins/PP-MANAGER'
2019-02-09 15:20:26.462 Error: (Python Plugin Manager) Git ErrorNo:2
2019-02-09 15:20:26.462 Error: (Python Plugin Manager) Git StrError:No such file or directory: '/home/pi/domoticz/plugins/PP-MANAGER'
The question now is of course where is the devices buton
and what is wrong (see the error) and how can I solve these problems?
2019-02-09 15:20:26.440 (Python Plugin Manager) Plugin is stopping.
2019-02-09 15:20:26.441 (Python Plugin Manager) Self Update Initiated
2019-02-09 15:20:26.451 (Python Plugin Manager) Updating Plugin:PP-MANAGER
2019-02-09 15:20:26.462 (Python Plugin Manager) Debug logging mask set to: NONE
2019-02-09 15:20:26.985 (Python Plugin Manager) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2019-02-09 15:20:26.985 (Python Plugin Manager) 'Mode4':'All'
2019-02-09 15:20:26.985 (Python Plugin Manager) 'Mode6':'Debug'
2019-02-09 15:20:26.985 (Python Plugin Manager) 'Key':'PP-MANAGER'
2019-02-09 15:20:26.985 (Python Plugin Manager) 'HomeFolder':'/home/pi/domoticz/plugins/pp-manager-master/'
2019-02-09 15:20:26.985 (Python Plugin Manager) 'DomoticzHash':'a3a45906'
2019-02-09 15:20:26.985 (Python Plugin Manager) 'Port':'0'
2019-02-09 15:20:26.985 (Python Plugin Manager) 'DomoticzVersion':'4.9700'
2019-02-09 15:20:26.985 (Python Plugin Manager) 'Mode2':'Idle'
2019-02-09 15:20:26.985 (Python Plugin Manager) 'Version':'1.5.16'
2019-02-09 15:20:26.985 (Python Plugin Manager) 'Author':'ycahome'
2019-02-09 15:20:26.986 (Python Plugin Manager) 'Name':'Python Plugin Manager'
2019-02-09 15:20:26.986 (Python Plugin Manager) 'Mode5':'False'
2019-02-09 15:20:26.986 (Python Plugin Manager) 'HardwareID':'4'
2019-02-09 15:20:26.986 (Python Plugin Manager) 'DomoticzBuildTime':'2018-06-23 16:24:51'
2019-02-09 15:20:26.986 (Python Plugin Manager) Device count: 0
2019-02-09 15:20:26.995 (Python Plugin Manager) Domoticz Node Name is:raspberrypi
2019-02-09 15:20:26.995 (Python Plugin Manager) Domoticz Platform System is:Linux
2019-02-09 15:20:26.995 (Python Plugin Manager) Domoticz Platform Release is:4.14.79-v7+
2019-02-09 15:20:26.995 (Python Plugin Manager) Domoticz Platform Version is:#1159 SMP Sun Nov 4 17:50:20 GMT 2018
2019-02-09 15:20:26.995 (Python Plugin Manager) Default Python Version is:3.5.3.
2019-02-09 15:20:26.995 (Python Plugin Manager) Checking for Exception file on:/home/pi/domoticz/plugins/PP-MANAGER/exceptions.txt
2019-02-09 15:20:26.995 (Python Plugin Manager) self.ExceptionList:[]
2019-02-09 15:20:26.995 (Python Plugin Manager) Updating All Plugins!!!
2019-02-09 15:20:26.995 (Python Plugin Manager) UpdatePythonPlugin called
2019-02-09 15:20:26.995 (Python Plugin Manager) Updating Plugin:BatteryLevel
2019-02-09 15:20:26.996 (Python Plugin Manager) Calling:LANG=en_US /usr/bin/git pull --force on folder /home/pi/domoticz/plugins/BatteryLevel
2019-02-09 15:20:26.394 Status: (Python Plugin Manager) Stop directive received.
2019-02-09 15:20:26.594 Status: (Python Plugin Manager) Stopping threads.
2019-02-09 15:20:26.606 Status: (Python Plugin Manager) Exiting work loop.
2019-02-09 15:20:26.606 Status: (Python Plugin Manager) Stopped.
2019-02-09 15:20:26.606 Status: (Python Plugin Manager) Started.
2019-02-09 15:20:26.983 Status: (Python Plugin Manager) Entering work loop.
2019-02-09 15:20:26.983 Status: (Python Plugin Manager) Initialized version 1.5.16, author 'ycahome'
2019-02-09 15:20:27.782 (Python Plugin Manager) Git Response:b'Already up-to-date.\n'
2019-02-09 15:20:27.782 (Python Plugin Manager) Plugin BatteryLevel already Up-To-Date
2019-02-09 15:20:27.782 (Python Plugin Manager) Plugin:pp-manager-master cannot be managed with PP-Manager!!.
2019-02-09 15:20:27.782 (Python Plugin Manager) Plugin:examples cannot be managed with PP-Manager!!.
2019-02-09 15:20:27.782 (Python Plugin Manager) Plugin:AwoxSMP cannot be managed with PP-Manager!!.
2019-02-09 15:20:27.782 (Python Plugin Manager) Plugin Idle
2019-02-09 15:20:27.782 (Python Plugin Manager) Pushing 'PollIntervalDirective' on to queue
2019-02-09 15:20:27.832 (Python Plugin Manager) Processing 'PollIntervalDirective' message
2019-02-09 15:20:27.832 (Python Plugin Manager) Heartbeat interval set to: 60.
2019-02-09 15:20:36.484 (Python Plugin Manager) Pushing 'onHeartbeatCallback' on to queue
2019-02-09 15:20:36.500 (Python Plugin Manager) Processing 'onHeartbeatCallback' message
2019-02-09 15:20:36.500 (Python Plugin Manager) Calling message handler 'onHeartbeat'.
2019-02-09 15:20:36.500 (Python Plugin Manager) onHeartbeat called
2019-02-09 15:20:36.500 (Python Plugin Manager) Current time:15:20
2019-02-09 15:21:36.493 (Python Plugin Manager) Pushing 'onHeartbeatCallback' on to queue
2019-02-09 15:21:36.506 (Python Plugin Manager) Processing 'onHeartbeatCallback' message
2019-02-09 15:21:36.506 (Python Plugin Manager) Calling message handler 'onHeartbeat'.
2019-02-09 15:21:36.506 (Python Plugin Manager) onHeartbeat called
2019-02-09 15:21:36.506 (Python Plugin Manager) Current time:15:21
2019-02-09 15:22:36.502 (Python Plugin Manager) Pushing 'onHeartbeatCallback' on to queue
2019-02-09 15:22:36.508 (Python Plugin Manager) Processing 'onHeartbeatCallback' message
2019-02-09 15:22:36.508 (Python Plugin Manager) Calling message handler 'onHeartbeat'.
2019-02-09 15:22:36.508 (Python Plugin Manager) onHeartbeat called
2019-02-09 15:22:36.508 (Python Plugin Manager) Current time:15:22
Thank you for your help
Cobra045
