Page 7 of 20
Re: Dashticz - Feature Requests
Posted: Monday 29 May 2017 9:22
by robgeerts
This function is working in latest beta!
Example config:
var _AUTO_SWIPEBACK_TO	= 1;
var _AUTO_SWIPEBACK_TIME	= 0; //seconds
var _SLIDE_PAGES			= 5;
Posted: Monday 29 May 2017 18:36
by Clemen
Nice working great..! 8-)
Posted: Tuesday 30 May 2017 20:42
by Swifty
@robgeerts - Any luck with adding iCal support for the garbage module?
I'm not hassling - just been away for a week or so, and trying to catch up on the board, so wondering if I missed it as i can't see it in the first post :)
Posted: Tuesday 30 May 2017 21:44
by niceandeasy
I have two windows with motorized blinds on them, not compatible with Domoticz. I control them via Domoticz, by using a KAKU remote switch. Switch type is set to 'Blinds'. LUA scripting takes care of sending the appropriate commands to a Mediola gateway which sends it to the motors.
In Domoticz, these blinds switches have an open and a close button. They can be stopped by pressing a button again.
In Dashticz, these blinds switches have an open, a close and a stop button. Off course, Stop is not working.
Can I make this Stop button disappear in the Dashticz switches? Preferably by adding something to the blocks{}section of config.js.
Thank you.
Posted: Tuesday 30 May 2017 22:31
by htilburgs
blocks[IDX]['hide_stop'] = true;
Posted: Tuesday 30 May 2017 23:01
by niceandeasy
htilburgs wrote:blocks[IDX]['hide_stop'] = true;
Thanks! Works perfectly.
Posted: Tuesday 30 May 2017 23:14
by robgeerts
Swifty wrote:@robgeerts - Any luck with adding iCal support for the garbage module?
No sorry... didnt have much time in the last couple of days... could you send me an example ical? (Or did you already?)
Posted: Tuesday 30 May 2017 23:24
by Swifty
No problem, as I say - not hassling just wasn't sure if I'd missed it :)
I already sent a PM with ical link (sent 12th May) let me know if you need it again.
Posted: Friday 02 June 2017 10:43
by htilburgs
Feature requests:
1. Is it possible to choose between icon or image, so we can use our own image (like F1 in Formule1 Calendar) like in example??
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', icon: 'fa-calendar ',icalurl: 'https://calendar.google.com/.../xx/basic.ics' }
OR
calendars.f1 = { maxitems: 5, title: 'F1 Calendar', image: 'img/calendar.png',icalurl: 'https://calendar.google.com/.../xx/basic.ics' }
2. Present the Domoticz Log in the 'Domoticz Layout' - With the current URL it's not easy to read
buttons.domoticz = {width:12, icon:'fa-microchip', title: 'Domoticz Log', url: 'http://192.168.0.100:8088/json.htm?type ... loglevel=2'}
Posted: Saturday 03 June 2017 16:12
by Teunissm
Just curious,
What is the state of an rgb switch posibility in Dashticz.
it is the only basic thing i am missing here.
Marcel
Posted: Sunday 04 June 2017 13:12
by HansieNL
Teunissm wrote:Just curious,
Marcel
You can check here... https://github.com/robgeerts/dashticz_v2/issues/48
Posted: Sunday 04 June 2017 13:18
by gielie
Is it possible to create the air pressure from the weather tab, it is now a on/off and id like to display the pressure.
This is the output
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "Barometer" : 1015,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "19.0 C, 58 %, 1015 hPa",
         "Description" : "",
         "DewPoint" : "10.55",
         "Favorite" : 1,
         "Forecast" : 1,
         "ForecastStr" : "Sunny",
         "HardwareID" : 7,
         "HardwareName" : "Weer station",
         "HardwareType" : "Weather Underground",
         "HardwareTypeVal" : 14,
         "HaveTimeout" : false,
         "Humidity" : 58,
         "HumidityStatus" : "Comfortable",
         "ID" : "0001",
         "LastUpdate" : "2017-06-04 13:11:56",
         "Name" : "Barometer",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "THB1 - BTHR918, BTHGN129",
         "Temp" : 19.0,
         "Timers" : "false",
         "Type" : "Temp + Humidity + Baro",
         "TypeImg" : "temperature",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "forecast_url" : "aHR0cDovL3d3dy53dW5kZXJncm91bmQuY29tL2NnaS1iaW4vZmluZHdlYXRoZXIvZ2V0Rm9yZWNhc3Q/cXVlcnk9UFdTJTNBSU5PT1JESE8yNTM=",
         "idx" : "15"
Posted: Sunday 04 June 2017 13:27
by gielie
Is it possible to create buttons instead a dropdown menu.
Posted: Sunday 04 June 2017 19:24
by robgeerts
gielie wrote:Is it possible to create the air pressure from the weather tab, it is now a on/off and id like to display the pressure.
This is the output
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "Barometer" : 1015,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 1,
         "Forecast" : 1,
         "HardwareID" : 7,
         "Humidity" : 58,
         "ID" : "0001",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Temp" : 19.0,
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "15"
Check your config because, I just testen with your output and works as expected!
Posted: Sunday 04 June 2017 20:13
by gielie
Yes, tanks, i used the wrong idx, i fixed it now, thanks.
Posted: Wednesday 07 June 2017 9:08
by EddyG
I really love the work that has been done on this Dashboard.
I have some conflicts with Wunderground, they keep sending me emails and counting on raindrops(???)
I think that this is the part which could work with a var.
setTimeout(function(){
loadWeather(_WEATHER_CITY,_WEATHER_COUNTRY);
}, (60000*30));
Could the timeout on refresh be a var in CONFIG.js?
Posted: Wednesday 07 June 2017 9:19
by EdwinK
It looks you are running the script too often. Do you also use another script that uses this API?
Raindrops are some sort of credit. You start out with 29 of them, and everytime you go over the max allowed number of calls you lose one raindrop.
Posted: Wednesday 07 June 2017 14:05
by EddyG
I know. I am in the process of retuning the layout of Dashticz.
So when ever I want to look at a change, I refresh the screen.
Temporary I disabled Weather Underground, but still it would be nice if the refresh of Weather Underground could be controlled by a parameter.
I have some other programs calling Weather Underground.
Posted: Wednesday 07 June 2017 14:25
by Hesmink
EddyG wrote:I know. I am in the process of retuning the layout of Dashticz.
I lost a few when trying to get my android tablet to work full screen. If I do that, dashtics keeps refreshing the screen, including the weather. Some sort of stop to WU refreshes would be welcome.
Posted: Wednesday 07 June 2017 21:25
by Derik
A webcam as background.
And background switching on month or day or season with pictures from from the web as extra...[ like andriod options ]
And if possible different to choose by screen
screen 1 webcam
screen 2 season
screen 3 static
etc
Think that should be great
