Page 7 of 12
Re: Python Plugin: Broadlink RM2
Posted: Tuesday 16 May 2017 9:03
by ilpier
Perfect!thx!
Posted: Wednesday 17 May 2017 16:06
by StanHD
Hi @zak45
I have been using the plug-in under Windows for some time now and it works really well. So thank you very much for your work.
Even though the actions are always carried out, I get the following error messages:-
- Spoiler: show
- 2017-05-16 14:12:05.591 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 16:40:07.990 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 16:44:08.041 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 17:36:08.891 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 17:44:08.991 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 18:04:09.390 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 18:32:09.641 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 19:09:54.138 Error: (Broadlink Kitchen) Unit unknown
2017-05-16 20:40:11.741 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 20:56:14.888 Error: (Broadlink Kitchen) Unit unknown
2017-05-16 20:56:18.138 Error: (Broadlink Kitchen) Unit unknown
2017-05-16 21:12:12.191 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 21:28:12.390 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 22:16:12.990 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-16 23:20:06.553 Error: (Broadlink Kitchen) Error Connecting to Broadlink device....
2017-05-16 23:24:14.040 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-17 00:16:14.840 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-17 02:48:16.740 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-17 06:01:24.891 Error: (Broadlink Bedroom) Unit unknown
2017-05-17 06:40:19.892 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-17 07:16:12.990 Error: (Broadlink Kitchen) Error Connecting to Broadlink device....
2017-05-17 08:48:21.490 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-17 08:52:21.541 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-17 10:00:22.291 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-17 11:20:23.237 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-17 12:00:23.792 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-17 12:04:23.790 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
2017-05-17 13:20:17.490 Error: (Broadlink Kitchen) Error Connecting to Broadlink device....
2017-05-17 14:20:25.841 Error: (Broadlink Bedroom) Error Connecting to Broadlink device....
The "error connecting" seems to occur randomly, however, the "Unit Unknown" occurs when a command is issued. (the command still works though)
It really isn't a big problem to me but just wondered if I could fix easily?
Thanks for any help.
Posted: Wednesday 17 May 2017 17:37
by zak45
@StanHD
Hi, happy to make you happy (more or less) !!!
for the Unit unknown error:
this one occur when check device ID during Set Level command.
Do you have replaced any pre-generated device (push button) by a selector ?? this could explain that.
for the Error Connecting to Broadlink device error:
plugin try to do regular connection to the broadlink device:
every 2 minutes if you manage the temperature device otherwise every 5 minutes. check & try to see if any network failure occur at this time !!
Re: RE: Re: Python Plugin: Broadlink RM2
Posted: Wednesday 17 May 2017 23:09
by StanHD
zak45 wrote:@StanHD
Thanks for the fast reply. I haven't changed any of the push buttons, but I will check everything through. I have a "Sky Q" Wifi network which uses a dual band router with a mesh of 4 repeaters meshed throughout the house to move hdtv around using proprietary hardware / software. This is very reliable but maybe the errors are in some way caused by the Broadlink swapping between the connection points. (The system presents as a single ssid).
Must stress though that the plugin works really well so a few log errors aren't a problem
Posted: Friday 19 May 2017 21:44
by ilpier
Hi to all..
Windows 10 x64,Python 3.5.3 and problem with setup.exe!
- problem.jpg (121.93 KiB) Viewed 4424 times
someone help me please!
Posted: Saturday 20 May 2017 9:21
by zak45
ilpier wrote:Hi to all..
the version on pypi (0.4) is buggy , not able to be installed automatically with python v 3.x.
You need to take one from dropbox (0.3) and install it manually.
Broadlink RM2 webimport
Posted: Sunday 21 May 2017 23:49
by kingoifsnake74
First of all respect for the pluganators and all the forum info. Had problems on the syn domoticz package, now on the rpi2 debian works flawless. Only troubled with the webimport function. Did the usual stuff chmod 777 and chmod +x, does anyone know how to open the webserver. The broadlink import switch was succesfully added btw.
2017-05-21 23:07:35.006 Error: (broadlink) /home/pi/domoticz/plugins/BroadlinkRM2/plugin_http.sh 0.0.0.0 9000 /home/pi/domoticz/plugins/
2017-05-21 23:07:35.006 Error: (broadlink) None
2017-05-21 23:07:35.006 Error: (broadlink) Not able to start Web server
Posted: Monday 22 May 2017 10:45
by ilpier
zak45 wrote:ilpier wrote:Hi to all..
Sorry Zak,which version from Dropbox?
Posted: Monday 22 May 2017 19:39
by zak45
this one :
python-broadlink-master.zip; you should be able to find on the forum how to install it.
Re: Broadlink RM2 webimport
Posted: Monday 22 May 2017 19:42
by zak45
kingoifsnake74 wrote:First of all respect for the pluganators and all the forum info. Had problems on the syn domoticz package, now on the rpi2 debian works flawless. Only troubled with the webimport function. Did the usual stuff chmod 777 and chmod +x, does anyone know how to open the webserver. The broadlink import switch was succesfully added btw.
this is related to no-windows OS;
Have updated plugin_http.py on Dropbox; just download and replace the one in plugin directory.
let me know.
Posted: Monday 22 May 2017 20:28
by kingoifsnake74
I skipped the web import and did it manually with jsonbutton jsoncode and jaonsublr. Succesfull import. Some devices from the import work but most don't. Even if i execute the code in ssh. Changed all the rights, Is the code to long? Is it double? Wrong format? Last step 2 make me happy , thanx
2017-05-22 19:36:21.817 User: Admin initiated a switch command (197/broadlink - 5-139 keukendimmer dimmen/On)
2017-05-22 19:36:21.820 (broadlink) Calling message handler 'onCommand'.
2017-05-22 19:36:21.820 (broadlink) onCommand called for Unit 139: Parameter 'On', Level: 0 , Connected : True
2017-05-22 19:36:21.820 (broadlink) Generate on Command for learned code stored on unit :139
2017-05-22 19:36:21.826 (broadlink) Code loaded : 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
2017-05-22 19:36:21.858 (broadlink) Connected to Broadlink device.
2017-05-22 19:36:21.859 (broadlink) b'\xe9\x04\x84\x03\x05\x06\x05\x05\x06\x05\x05\x06\x05\x06\x06\t\x0b\x0b\x05\x05\x06\x05\x0b\x0b\n\x06\x05\n\x0b\x0b\n\x06\x05\x0b\x05\x05\x05\x06\x13\x04\x05\x06\x05\x06\x05\x05\x05\x06\x05\x05\x06\x0c\t\x0b\x05\x06\x06\x04\x0b\x0b\n\x06\x05\x0b\n\x0b\x0b\x05\x05\x0b\x05\x05\x05\x06\x13\x05\x05\x05\x05\x07\x06\x04\x06\x06\x04\x06\x05\x0b\n\x0b\x06\x05\x05\x05\x0b\x0b\n\x06\x05\x0c\n\n\x0b\x05\x05\x0b\x06\x05\x05\x05\x12\x06\x05\x06\x05\x05\x05\x07\x04\x05\x06\x05\x06\n\x0b\x0b\x05\x05\x06\x05\n\x0b\x0b\x05\x05\x0b\x0b\n\x0b\x06\x05\n\x07\x04\x05\x05\x13\x05\x07\x04\x05\x05\x06\x06\x04\x06\x06\x06\x04\x0b\n\x0b\x05\x05\x06\x05\x0b\x0b\n\x05\x06\x0b\n\x0b\n\x06\x05\x0b\x05\x05\x06\x04\x13\x05\x06\x05\x05\x06\x05\x05\x05\x06\x05\x06\x05\x0b\x0b\n\x06\x04\x06\x05\x0b\n\x0b\x06\x05\x0b\n\x0b\x0b\x06\x04\x0b\x05\x06\x05\x05\x12\x07\x04\x06\x04\x06\x06\x04\x06\x05\x06\x06\x05\n\x0b\n\x06\x05\x06\x04\x0c\x0b\n\x05\x05\x0b\n\x0c\n\x05\x05\x0b\x06\x04\x06\x05\x12\x06\x05\x06\x05\x05\x05\x06\x05\x05\x07\x04\x05\x0b\x0b\n\x06\x06\x05\x05\x0b\n\x0b\x05\x05\x0b\x0b\n\x0b\x06\x05\n\x06\x05\x05\x06\x12\x05\x05\x06\x05\x05\x06\x05\x05\x06\x05\x05\x05\x0b\x0b\n\x06\x05\x06\x05\x0b\n\x0b\x05\x06\n\x0c\n\n\x06\x06\n\x05\x05\x05\x06\x12\x05\x05\x06\x06\x04\x06\x06\x05\x05\x05\x06\x05\n\x0b\x0b\x05\x05\x07\x05\n\x0b\n\x06\x05\x0b\n\x0b\x0b\x05\x05\x0b\x05\x05\x05\x06\x12\x06\x05\x05\x06\x05\x05\x06\x05\x05\x05\x06\x05\x0b\n\x0b\x06\x05\x06\x04\x0b\x0b\x0b\x05\x06\x0b\t\x0b\x0b\x05\x05\x0b\x05\x05\x06\x05\x13\x06\x04\x05\x06\x06\x05\x05\x05\x05\x06\x05\x05\x0b\x0b\n\x06\x05\x06\x05\x0b\n\x0b\x06\x05\x0b\x0b\n\x0c\x04\x05\n\x06\x05\x05\x07\x11\x05\x05\x06\x05\x07\x04\x05\x05\x06\x05\x05\x07\t\x0b\x0b\x05\x07\x04\x05\x0b\x0b\n\x05\x07\t\x0b\x0b\n\x07\x04\x0b\x05\x06\x04\x06\x12\x05\x05\x06\x05\x06\x05\x05\x05\x07\x05\x05\x05\n\x0b\x0b\x05\x05\x06\x05\x0b\x0b\n\x07\x04\x0b\x0b\n\x0b\x05\x05\x0b\x05\x05\x06\x05\x12\x06\x05\x05\x05\x06\x05\x06\x06\x04\x05\x06\x05\x0b\x0b\n\x06\x05\x05\x06\n\x0b\n\x06\x05\x0b\x0b\n\x0b\x05\x06\n\x06\x05\x05\x05\x12\x06\x05\x07\x04\x05\x05\x06\x05\x06\x05\x06\x04\r\t\n\x06\x05\x06\x05\n\x0b\x0b\x07\x04\x0c\n\n\x0b\x06\x05\x0b\x05\x05\x05\x07\x11\x05\x05\x06\x06\x05\x05\x05\x05\x06\x05\x06\x05\n\x0b\x0b\x05\x06\x06\x05\n\n\x0b\x06\x06\t\x0b\x0b\x0b\x05\x05\x0b\x05\x06\x04\x06\x12\x07\x04\x05\x05\x06\x05\x06\x05\x05\x05\x06\x05\x0b\n\x0b\x06\x05\x05\x05\x0b\x0b\n\x06\x05\x0b\x0c\t\x0c\x05\x04\x0b\x06\x05\x06\x04\x12\x06\x05\x05\x06\x06\x04\x06\x05\x05\x06\x05\x05\x0b\x0b\n\x06\x05\x06\x04\x0b\x0b\x0b\x05\x06\n\x0c\t\x0b\x06\x05\n\x06\x05\x05\x05\x13\x05\x05\x06\x06\x05\x04\x06\x06\x06\x04\x05\x06\n\x0b\x0c\x05\x04\x06\x05\x0b\x0b\n\x05\x06\n\x0b\x0b\n\x06\x05\x0b\x05\x06\x05\x04\x13\x06\x04\x06\x05\x06\x05\x06\x05\x06\x05\x05\x05\n\x0c\n\x05\x05\x06\x05\x0b\x0b\n\x06\x05\x0b\x0b\x0b\n\x05\x05\x0b\x05\x07\x04\x07\x11\x05\x06\x05\x05\x06\x05\x05\x06\x05\x06\x05\x05\x0b\n\x0b\x06\x05\x05\x05\x0b\x0b\x0b\x05\x06\n\n\x0b\x0c\x04\x05\x0b\x05\x06\x05\x05\x12\x06\x05\x05\x07\x04\x05\x06\x05\x05\x06\x05\x05\x0b\x0b\x0b\x05\x06\x06\x04\n\x0b\x0b\x05\x05\x0b\x0b\x0b\n\x06\x05\x0c\x04\x05\x05\x05\x13\x06\x04\x06\x05\x06\x05\x05\x05\x06\x05\x06\x05\x0c\n\n\x05\x05\x07\x04\n\r\t\x06\x05\n\x0b\x0b\n\x06\x05\x0b\x05\x05\x05\x07\x11\x05\x05\x06\x05\x06\x05\x05\x06\x05\x05\x06\x06\t\x0b\x0b\x05\x05\x06\x05\x0b\x0b\n\x06\x05\x0b\n\x0b\x0b\x05\x05\x0b\x05\x05'
2017-05-22 19:36:21.862 Error: (broadlink) Code Sent WARNING....Probably timeout
2017-05-22 19:36:21.862 (broadlink) Command line : "/home/pi/domoticz/plugins/BroadlinkRM2/plugin_send.py" /home/pi/domoticz/plugins//BroadlinkRM2-5-139.ini
2017-05-22 19:36:21.862 (broadlink - 5-139 keukendimmer dimmen) Updating device from 1:'On-78' to have values 1:'On-123'.
2017-05-22 19:36:21.868 (broadlink) Update 1:'On-123' (broadlink - 5-139 keukendimmer dimmen)
Posted: Monday 22 May 2017 20:29
by kingoifsnake74
Oh and will try the updated import soon. Thanx for the effort!
Posted: Monday 22 May 2017 23:06
by zak45
@kingoifsnake74
woaww... yes , long code. this can made some problem.
attached updated version of broadlink, you can try to see if this solve your problem.
you need to replace existing __init__.py file with this one on your broadlink folder: here, we speak about module, not plugin.
Do not forget to make a backup before, of course.
Posted: Wednesday 24 May 2017 23:08
by kingoifsnake74
Great module! Had problems with livolo codes and learned them again, much shorter code now and it works. Ok i miss one from the kitchen but thats livolo bit buggy. Thanx again for the effort and help. This noob has the broadlink module and the ha bridge for alexa works like a charm. Now a good backup
Posted: Sunday 28 May 2017 18:58
by letmein
Hello everybody,
i'm tryind few hours now to install RM2 to rpi without success, i've already installed it on another rpi some time ago without a lot hassle, but this time it wont get installed i tried few things that i found here but nothing. The error i get when i try "sudo pip3 install broadlink" is this:
Downloading/unpacking broadlink
Downloading broadlink-0.4.tar.gz
Running setup.py (path:/tmp/pip-build-06i1bqfv/broadlink/setup.py) egg_info for package broadlink
File "<string>", line 17, in <module>
File "/tmp/pip-build-06i1bqfv/broadlink/setup.py", line 12
except ImportError, e:
SyntaxError: invalid syntax
Complete output from command python setup.py egg_info:
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-06i1bqfv/broadlink
Storing debug log for failure in /root/.pip/pip.log
Posted: Sunday 28 May 2017 19:09
by Phantom
Posted: Sunday 28 May 2017 23:30
by zak45
letmein wrote:Hello everybody,
Cleaning up...
the version on pypi have a problem with python 3. download the version 0.3 on the dropbox : python-broadlink-master.zip
and install it :
just decompress on some folder, go to the folder and enter : pip3 install .
do not forget the dot at the end
Posted: Sunday 28 May 2017 23:32
by zak45
I would say yes.. some have tried if I'm not wrong. But could not confirm as I do not own it.
Posted: Sunday 28 May 2017 23:46
by Phantom
Alright thanks, il try it out then
Posted: Monday 29 May 2017 21:29
by letmein
zak45 wrote:letmein wrote:Hello everybody,
Cleaning up...
and install it :
Thank you zak, after some cleanup it worked great!
