How to monitor your internet connection with virtual custom sensors
safi78
Domoticz version: LastBeta
Re: How to monitor your internet connection with virtual custom sensors
Post by safi78 »
I created a fairly similar script for a differtent purpose, maybe you guys like it as well: viewtopic.php?f=21&t=14591
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
johan99
Post by johan99 »
I try to get this working on my Dometicz installed at a Windows 2012-server.
I get Speedtest working and I got python installed and working.
But when running this scrip, I get this error message:
File "speedtest2.sh", line 15
ping=$(cat output.txt | sed -ne 's/^Ping: \([0-9]*\.[0-9]*\).*/\1/p')
SyntaxError: invalid syntax
Any idea on what I do wrong?
mikeoo
Post by mikeoo »
johan99 wrote:Hi,
Place your script and the command you use also here so we can check.
gjaa
Post by gjaa »
I've made some icons (I don't like the default Icon ;) )
One for up and download (speed)
and one for ping (ping)
ping.zip
ping
(19.61 KiB) Downloaded 267 times
Speed.zip
Up- and download
(14.4 KiB) Downloaded 245 times
johan99
Post by johan99 »
mikeoo wrote:
johan99 wrote:Hi,
Ok, here is first the code and after that is the command line.
#!/bin/bash
#setup
port=8080
username=xxxx
password=xxxx
host=localhost
pingidx=239
downloadidx=241
uploadidx=240
# no need to edit
speedtest-cli --simple > output.txt
download=$(cat output.txt | sed -ne 's/^Download: \([0-9]*\.[0-9]*\).*/\1/p')
upload=$(cat output.txt | sed -ne 's/^Upload: \([0-9]*\.[0-9]*\).*/\1/p')
#output if you run it manually
echo "ping = $ping ms"
echo "download = $download Mbps"
echo "upload =  $upload Mbps"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command&param=udevice&idx=$pingidx&svalue=$ping"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command&param=udevice&idx=$downloadidx&svalue=$download"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command&param=udevice&idx=$uploadidx&svalue=$upload"
command in windows (cmd runned in admin mode): python speedtest.sh
mikeoo
Post by mikeoo »
johan99 wrote:
mikeoo wrote:
johan99 wrote:Hi,
#!/bin/bash
#setup
port=8080
username=xxxx
password=xxxx
host=localhost
pingidx=239
downloadidx=241
uploadidx=240
# no need to edit
Try to change host=localhost to host=ip-adres of domoticz and test if that change something.
mikeoo
Post by mikeoo »
gjaa wrote:I've made some icons (I don't like the default Icon ;) )
Nice one's :mrgreen:
Tip
I did not see them when i try to change them for the Custum Sensor afther uploading the icons in Domoticz.
I reboot did not solve the problem.
You need the do a browser refresh and then you can see them.
johan99
Post by johan99 »
mikeoo wrote:
johan99 wrote:
mikeoo wrote: Try to change host=localhost to host=ip-adres of domoticz and test if that change something.
When i use the IP I get this error:
File "speedtest2.sh", line 7
host=192.168.0.188
I says the zero in the adress is the problem, dont know why, the adress is correct. When I edit the file i use a Windows PC and notepad++ and choose unix EOL.
mikeoo
Post by mikeoo »
johan99 wrote:
host=192.168.0.188
You can try the use a different editor. Lot of Windows editors give problems with linux files and to be sure try an other one. Because it say that er is a problem it looks like notepad++ does something with the file. Try Sublime Text https://sublimetext.com/3 that one is working fine with linux files
Create a new file again, don't copy and past the old one because then you can copy the strange characters in to the new file.
If it still not working maybe a pyhton version problem, try to run it without python command and just speedtest
viewtopic.php?f=21&t=13814&p=100190&hil ... ws#p100190
johan99
Post by johan99 »
I tried sublimetext now aswell and get the same issues.
I think I set a Raspberry Pi up (have one not used for anything) and use that for this instead. Using it as a 2:nd Domoticz server. When reading this forum I realize that most of you use RP and most guides are written for RP.
Thanks for the help though. And I'll keep on using the Windows server as my main server for Domoticz and are intrested to hear from you who got everything working fine with Win and Domoticz.
dtech
Re: RE: Re: How to monitor your internet connection with virtual custom sensors
Post by dtech »
How this icons can be added ?
sincze
Domoticz version: 2024.4
Post by sincze »
I found the solution in the wiki
http://www.domoticz.com/wiki/Custom_ico ... binterface
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Trigun
Domoticz version: 4.10717
Post by Trigun »
Hi all, first of all, great feature!! i carried out all the steps bit for some reason the custom sensors don't show the values. When I run the script I do get the correct info, but the sensors are not showing anything. Does anyone have an idea where I went wrong?
EdwinK
Post by EdwinK »
I like this script a lot. One small thing though.
After the data, I get a '0' instead of the right value (ms, Mbp/s). Can this be fixed?
Forget about the first tile, that is from another script.
koowee
Post by koowee »
EdKo66 wrote:I like this script a lot. One small thing though.
I think that you need to modify those, Device (Ping, Download and Upload) > Edit > Axis label (add ms or Mbp/s depending device)
EdwinK
Post by EdwinK »
Ah.. Of course. Thanks :)
Trigun
Post by Trigun »
Hey guys,
Really like the script! its working well when manually run. but for some reason I can't seem to get the output in domoticz.
does anyone have an idea?
I am running it on a Synology NAS.
Thnx in advance!
EdwinK
Post by EdwinK »
Running this on a Synology NAS too, and had it working in matter of minutes.
Synology doesn't have apt-get, so you need to find another way to get the files. I used easy_install, but can't quite remember how I did install that.
Search for easy_install and Synology on the Google.
EdwinK
Post by EdwinK »
Thanks for those icons ;)
Trigun
Post by Trigun »
Hi Edko66,
is there a chance you can help me out here?
since I have no username and password for domoticz, this is my script.
#!/bin/bash
#setup
host=192.168.10.21
port=8084
pingidx=8
downloadidx=6
uploadidx=7
# no need to edit
/volume1/homes/admin/Speedtest/speedtest-cli --server 5302 > output.txt
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command&param=udevice&idx=$pingidx&svalue=$ping"
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command&param=udevice&idx=$downloadidx&svalue=$download"
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command&param=udevice&idx=$uploadidx&svalue=$upload"
I can see the output.txt file it not in the same directory where thie stdomo.sh and speedtest-cli are in. shoudl this be?
