Home Theatre Controller (Pioneer AVR + USB PowerMate)
HNBC84
Re: Home Theatre Controller (Pioneer AVR + USB PowerMate)
Post by HNBC84 »
Still no (good) luck.
Butt for now sleep well
pi@domoticz ~/htc $ git pull
remote: Counting objects: 4, done.
remote: Compressing objects: 100% (2/2), done.
remote: Total 4 (delta 2), reused 4 (delta 2), pack-reused 0
Unpacking objects: 100% (4/4), done.
From https://github.com/nayrnet/domoticz-htc
   3752f25..ff0772b  master     -> origin/master
Updating 3752f25..ff0772b
Fast-forward
 hardware/pioneeravr.js |    8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
pi@domoticz ~/htc $ ./server.js
Pioneer: connected
AVR CONNECTION CLOSED! try reconnect every 30s
Domoticz MQTT: connected
AVR ERROR: Connection not avilable, dropping request
^Z
[18]+  Stopped                 ./server.js
Pioneer: connected
POWER: true
INPUT: 5
VOLUME: 13
DOMO: {"Battery":255,"RSSI":12,"dtype":"Light/Switch","id":"000140C4","idx":117,"name":"VSX Sound Modus","nvalue":1,"stype":"Selector Switch","svalue1":"0","switchType":"Selector","unit":1}
DOMO: {"Battery":255,"RSSI":12,"dtype":"Light/Switch","id":"000140C3","idx":116,"name":"VSX Input","nvalue":2,"stype":"Selector Switch","svalue1":"20","switchType":"Selector","unit":1}
DOMO: {"Battery":255,"RSSI":12,"dtype":"Light/Switch","id":"000140CB","idx":124,"name":"VSX Volume","nvalue":2,"stype":"Switch","svalue1":"12","switchType":"Dimmer","unit":1}
VOLUME: 13
Pioneer: connected
^Z
[19]+  Stopped                 ./server.js
Pioneer: connected
POWER: true
INPUT: 5
VOLUME: 13
VOLUME: 13
nayr
Domoticz version: github
Post by nayr »
Thanks for the help, I am pretty sure I got it fixed now.. Ive tested it by unplugging my Pioneer, waiting a few moments and plugging it back in.. it eventually recovered on its own, I expect it to behave faster when the receiver cleanly closes the connection instead of just disappearing and waiting for a socket failure.
steppi
Post by steppi »
I just installed htc Raspberry on but does not work anymore :(
pi@domoticz:~/htc $ ./server.js
module.js:340
    throw err;
Error: Cannot find module '/home/pi/htc/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node'
    at Function.Module._resolveFilename (module.js:338:15)
    at Function.Module._load (module.js:280:25)
    at Module.require (module.js:364:17)
    at require (module.js:380:17)
    at Object.<anonymous> (/home/pi/htc/node_modules/serialport/serialport.js:14:25)
    at Module._compile (module.js:456:26)
    at Object.Module._extensions..js (module.js:474:10)
    at Module.load (module.js:356:32)
    at Function.Module._load (module.js:312:12)
nayr
Post by nayr »
run 'npm install', your missing required modules.. if you moved from an x86 to a ARM platform you'll have to reinstall the NodeJS modules as some code will be platform specific.
HNBC84
Post by HNBC84 »
nayr wrote:Thanks for the help, I am pretty sure I got it fixed now.. Ive tested it by unplugging my Pioneer, waiting a few moments and plugging it back in.. it eventually recovered on its own, I expect it to behave faster when the receiver cleanly closes the connection instead of just disappearing and waiting for a socket failure.
Yeah men! It is working! 8-)
Pioneer: connected
POWER: true
INPUT: 5
VOLUME: 53
DOMO: {"Battery":255,"RSSI":12,"dtype":"Light/Switch","id":"000140CB","idx":124,"name":"VSX Volume","nvalue":2,"stype":"Switch","svalue1":"52","switchType":"Dimmer","unit":1}
VOLUME: 53
DOMO: Mute ON
DOMO: {"Battery":255,"RSSI":12,"dtype":"Light/Switch","id":"000140CB","idx":124,"name":"VSX Volume","nvalue":0,"stype":"Switch","svalue1":"0","switchType":"Dimmer","unit":1}
MUTE: true
DOMO: Volume 44
DOMO: {"Battery":255,"RSSI":12,"dtype":"Light/Switch","id":"000140CB","idx":124,"name":"VSX Volume","nvalue":2,"stype":"Switch","svalue1":"43","switchType":"Dimmer","unit":1}
MUTE: false
VOLUME: 44
DOMO: Power Off
DOMO: {"Battery":255,"RSSI":12,"dtype":"Light/Switch","id":"000140C3","idx":116,"name":"VSX Input","nvalue":0,"stype":"Selector Switch","svalue1":"0","switchType":"Selector","unit":1}
	UNKNOWN ERROR: ReferenceError: receiver is not defined
	Pioneer: connected
	POWER: true
INPUT: 5
VOLUME: 13
VOLUME: 13
HNBC84
Post by HNBC84 »
Btw how is the powermate working?
nayr
Post by nayr »
the power mate is pretty epic, wife and son both love it.. and show it off there friends.. my old lady told me last night I did a pretty good job on the volume knob, I am more likely to get a bug report out of her than a compliment, so that was really nice feedback. (better than you guys getting it working hehe)
The USB Extension cable I ran up behind the Sofa has two ports on it, so I said screw it and got some USB Powered speakers that act as a USB Sound card and I am setting up voice announcements right now.. I could even do some sound effects when powering up or down the home theatre or have it turn the volume down a bit for the announcment. :D
I got my powermate new old stock off ebay for under $30 shipped, great lil Gizmo and I want moar of em :lol:
I ordered some outdoor speakers for zone 2, I swear they are half the price now in the winter then when I priced them out last summer.. figured better not wait for the back yard weather to come.. $50 shipped for a factory refurbished pair of White Polk Atrium 5's, just enough for the back patio, I do have neighbors.. the subwoofer inside is still audible if I want it to be :)
HNBC84
Post by HNBC84 »
Sound good! With some good plans!
The wife is the best bug reporter that there is haha, build it wife-proof and everybody can use it
HNBC84
Post by HNBC84 »
Just a suggestion,
Mayb you can build in for the tekst sensors when there is no connection or the pioneer is of that its says someting like "Pioneer is off" or just a custom field in the config.js.
nayr
Post by nayr »
implemented, plus it will power off all the switches when the connection is lost.
steppi
Post by steppi »
Hello everyone .. I have just installed the Raspberry.
I reinstalled both Domoticz that HTC ..
But now I get back an error:
pi@raspberrypi:~/htc $ ./server.js
module.js:340
    throw err;
nayr
Post by nayr »
try: npm install serialport
steppi
Post by steppi »
No.. :(
pi@raspberrypi:~/htc $ npm install serialport
> [email protected] install /home/pi/htc/node_modules/serialport
> node-pre-gyp install --fallback-to-build
make: Entering directory '/home/pi/htc/node_modules/serialport/build'
  CXX(target) Release/obj.target/serialport/src/serialport.o
  CXX(target) Release/obj.target/serialport/src/serialport_unix.o
  CXX(target) Release/obj.target/serialport/src/serialport_poller.o
  SOLINK_MODULE(target) Release/obj.target/serialport.node
  COPY Release/serialport.node
  COPY /home/pi/htc/node_modules/serialport/build/Release/node-v46-linux-arm/serialport.node
  TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/home/pi/htc/node_modules/serialport/build'
[email protected] node_modules/serialport
├── [email protected]
├── [email protected] ([email protected])
├── [email protected] ([email protected], [email protected])
└── [email protected]
module.js:340
    throw err;
nayr
Post by nayr »
ok thats messed up, hrmm try:
cd /home/pi/htc/node_modules/serialport/build/Release/
ln -s node-v46-linux-arm node-v11-linux-arm
steppi
Post by steppi »
pi@raspberrypi:~ $ cd /home/pi/htc/node_modules/serialport/build/Release/
pi@raspberrypi:~/htc/node_modules/serialport/build/Release $ ln -s node-v46-linux-arm node-v11-linux-arm
module.js:356
  Module._extensions[extension](this, filename);
Error: /home/pi/htc/node_modules/serialport/build/Release/node-v46-linux-arm/serialport.node: undefined symbol: node_module_register
nayr
Post by nayr »
dunno whats unique to your setup HNBC84 got it going on a Pi,
try:
rm -Rf ~/htc/node_modules
cd ~/htc
git pull
npm install
also whats your:
nodejs --version
steppi
Post by steppi »
OK perfect! Now it works great!
One thing that I still can not do is Blockly .. I created many many Blockly of Domoticz, as the security system ....
I can not create an event so Blockly:
If switch "I'm home"
- I turn on the lights (ok works well ..)
- I turn on Pioneer "Internet Radio" (the problem is set up Internet Radio on Blockly there is the possibility to choose from ..)
Thanks bye!
nayr
Post by nayr »
its a Selector State device, here is an example from the Original thread talking about it.. I dont use Blocky so you might go there for guidance.
to change the switch you have to use: Set Level XX change the switch state
HNBC84
Post by HNBC84 »
Not been very much online.
Don't have logging at the moment...
But somehow the reconnect in the morning seems not to work. Don't know why not been looking for it.
Looks like the daemon stops somewhere and the cronjob fails to start. Comming back on it :)
But for shore it work great! Still need to teach myself to put the remote away.
HNBC84
Post by HNBC84 »
Somehow the cronjob fails?! Don't know why did try every possible situation. First think i saw, i forgot was /pi/ 8-)
But for now the vsx ping switch starts the daemon back on when not in use.
