Page 57 of 123
Posted: Tuesday 04 April 2017 16:56
by Coldman
With theme "Dark th3me" does not fit
Posted: Tuesday 04 April 2017 17:17
by deennoo
Coldman wrote:With theme "Dark th3me" does not fit
That why that à beta.
I thing rolling liste is better. Those option have to be use on event or scène not on point and Click, who is agree?
Posted: Tuesday 04 April 2017 18:52
by Coldman
It's just a "note", I agree :)
Posted: Tuesday 04 April 2017 19:44
by aldodemi
New device detected, "Xiaomi Gateway Alarm Ringtone", "Xiaomi Gateway Alarm Clock" and "Xiaomi Gateway Doorbell" but none seem works...
"Xiaomi Gateway Lux" updated only after discovered.
Posted: Tuesday 04 April 2017 19:57
by deennoo
aldodemi wrote:New device detected, "Xiaomi Gateway Alarm Ringtone", "Xiaomi Gateway Alarm Clock" and "Xiaomi Gateway Doorbell" but none seem works...
Linux Windows Synology ?? Acadabra i can't see it
Posted: Tuesday 04 April 2017 21:06
by mvveelen
What are the criteria to get it in the 'official beta' of Domoticz? Are all changes tested by you (corbin) and then added to the latest beta release?
Ofcourse I can't wait to get these newest additions :)
Posted: Tuesday 04 April 2017 22:31
by doelle4
How can i install Corbins latest Version https://github.com/corbinmunce/domoticz at Raspberry manual?
Greetings Hans
Posted: Tuesday 04 April 2017 22:45
by Coldman
doelle4 wrote:Problem...
My Domotics V3.5877 runs at a Raspberry. When in i click Update to new Beta, Domoticz is after installing update offline (Failure) :-(
How can i install Corbins Version https://github.com/corbinmunce/domoticz at Raspberry manual?
Greetings Hans
backup your database and move Domoticz folder to other
sudo service domoticz stop
mv ~/domoticz ~/domoticz_backup
https://www.domoticz.com/wiki/Installin ... spberry_PI
Domoticz - the hard way (manual install)
change the repository to https://github.com/corbinmunce/domoticz
restore your database backup
Posted: Tuesday 04 April 2017 23:04
by aldodemi
You are right @deennoo, sorry, linux Atom p, it is a test pc only for Xiaomi gateway with domoticz
Posted: Tuesday 04 April 2017 23:38
by doelle4
Sorry, when i type : sudo curl -L https://github.com/corbinmunce/domoticz.git | sudo bash
Follows this :
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 178 100 178 0 0 257 0 --:--:-- --:--:-- --:--:-- 257
bash: Zeile 7: Syntaxfehler beim unerwarteten Wort `newline'
bash: Zeile 7: `<!DOCTYPE html>'
curl: (23) Failed writing body (394 != 1370)
Same with sudo curl -L https://github.com/corbinmunce/domoticz or sudo curl -L -k https://github.com/corbinmunce/domoticz.git
Works not :-(
Greetings Hans
Posted: Tuesday 04 April 2017 23:49
by Coldman
doelle4 wrote:Sorry, when i type : sudo curl -L https://github.com/corbinmunce/domoticz.git | sudo bash
Follows this :
Works not :-(
Greetings Hans
Posted: Wednesday 05 April 2017 0:30
by doelle4
To heavy for me ,i use Raspberry only for Domotics and want not crash them. (only Windows Experience)
Have anyone a working File? - [email protected]
Greetings Hans
Posted: Wednesday 05 April 2017 0:52
by deennoo
doelle4 wrote:To heavy for me ,i use Raspberry only for Domotics and want not crash them. (only Windows Experience)
Greetings Hans
Sorry, but if your not able to do this you can wait for a merge to official beta (having à beta for Real use is a bad Bad Bad Idea)
Posted: Wednesday 05 April 2017 11:10
by corbin
Can you show me a picture of a rolling list? I'm not familiar with it.
Posted: Wednesday 05 April 2017 11:13
by corbin
Double check you have entered the correct IP address and password for the gateway. Also in my current github code the log will output the request and response which can help with troubleshooting:
2017-04-05 19:11:27.175 User: Admin initiated a switch command (91/Xiaomi Gateway Doorbell/Set Level)
2017-04-05 19:11:27.176 XiaomiGateway: level 10
2017-04-05 19:11:27.327 XiaomiGateway: request {"cmd":"write","model":"gateway","sid":"f0b4299ae4b8","short_id":0,"data":"{\"mid\":10,\"key\":\"160A62533C40CB7D6B244222ADD5CAC8\"}" }
2017-04-05 19:11:27.327 XiaomiGateway: response {"cmd":"write_ack","model":"gateway","sid":"f0b4299ae4b8","short_id":0,"data":"{\"rgb\":0,\"illumination\":340,\"proto_version\":\"1.0.6\"}"}
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Posted: Wednesday 05 April 2017 12:05
by deennoo
Select type 1 when you create sélector switch, that on my pull request
Posted: Wednesday 05 April 2017 12:06
by chrispazz
Corbin, just updated to 7253 beta....does it include your recent modifications?
Thank you very much
Christian
Posted: Wednesday 05 April 2017 12:13
by corbin
not in the beta yet, the only way to get it right now is to compile from https://github.com/corbinmunce/domoticz
I expect to submit it to the main beta in 1-2 days.
Posted: Wednesday 05 April 2017 12:17
by bertbigb
I agree also
Posted: Wednesday 05 April 2017 13:29
by Jumper3126
cocapic wrote:Hi,
I read only the half of the full post sorry ... But i want to share my worries on the plug !
As I find that plugs are dangerous with an adapter I easely opened 3 of them and replaced pin with cable and trying to directly integrated in the outlet box in the wall. But range of mi plugs are a nightmare, out of there casing and specially when a charge on the ouptut
So did someone figure out the range or open plugs to integrate it ?
I taken some pics of the network board in the plug who can easely be moved from one plug to another keeping the association, also we can see a classic zigbee component http://www.nxp.com/documents/data_sheet/JN5169.pdf so plug should work as a repeter
Hi Cocapic,
How did you open the plugs? Is there some hidden screw or clip, or did you have to cut through the plastic?
