Coldman
Post by Coldman »
With theme "Dark th3me" does not fit
deennoo
Post by deennoo »
Coldman wrote:With theme "Dark th3me" does not fit
That why that à beta.
I thing rolling liste is better. Those option have to be use on event or scène not on point and Click, who is agree?
http://domo-attitude.fr
Coldman
Post by Coldman »
It's just a "note", I agree :)
aldodemi
Domoticz version: 3.8275
Post by aldodemi »
New device detected, "Xiaomi Gateway Alarm Ringtone", "Xiaomi Gateway Alarm Clock" and "Xiaomi Gateway Doorbell" but none seem works...
"Xiaomi Gateway Lux" updated only after discovered.
Server Domoticz 3.7243 (usually the last beta) on Debian Linux (Jessie) - Hw homemade with Atom CPU/4 GB RAM
RFXCom and ZWave Stick (Aeon)
deennoo
Post by deennoo »
aldodemi wrote:New device detected, "Xiaomi Gateway Alarm Ringtone", "Xiaomi Gateway Alarm Clock" and "Xiaomi Gateway Doorbell" but none seem works...
Linux Windows Synology ?? Acadabra i can't see it
mvveelen
Post by mvveelen »
What are the criteria to get it in the 'official beta' of Domoticz? Are all changes tested by you (corbin) and then added to the latest beta release?
Ofcourse I can't wait to get these newest additions :)
doelle4
Post by doelle4 »
How can i install Corbins latest Version https://github.com/corbinmunce/domoticz at Raspberry manual?
Greetings Hans
Coldman
Post by Coldman »
doelle4 wrote:Problem...
My Domotics V3.5877 runs at a Raspberry. When in i click Update to new Beta, Domoticz is after installing update offline (Failure) :-(
How can i install Corbins Version https://github.com/corbinmunce/domoticz at Raspberry manual?
Greetings Hans
backup your database and move Domoticz folder to other
sudo service domoticz stop
mv ~/domoticz ~/domoticz_backup
https://www.domoticz.com/wiki/Installin ... spberry_PI
Domoticz - the hard way (manual install)
change the repository to https://github.com/corbinmunce/domoticz
restore your database backup
aldodemi
Post by aldodemi »
You are right @deennoo, sorry, linux Atom p, it is a test pc only for Xiaomi gateway with domoticz
doelle4
Post by doelle4 »
Sorry, when i type : sudo curl -L https://github.com/corbinmunce/domoticz.git | sudo bash
Follows this :
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 178 100 178 0 0 257 0 --:--:-- --:--:-- --:--:-- 257
bash: Zeile 7: Syntaxfehler beim unerwarteten Wort `newline'
bash: Zeile 7: `<!DOCTYPE html>'
curl: (23) Failed writing body (394 != 1370)
Same with sudo curl -L https://github.com/corbinmunce/domoticz or sudo curl -L -k https://github.com/corbinmunce/domoticz.git
Works not :-(
Greetings Hans
Coldman
Post by Coldman »
doelle4 wrote:Sorry, when i type : sudo curl -L https://github.com/corbinmunce/domoticz.git | sudo bash
Follows this :
Works not :-(
Greetings Hans
doelle4
Post by doelle4 »
To heavy for me ,i use Raspberry only for Domotics and want not crash them. (only Windows Experience)
Have anyone a working File? - [email protected]
Greetings Hans
deennoo
Post by deennoo »
doelle4 wrote:To heavy for me ,i use Raspberry only for Domotics and want not crash them. (only Windows Experience)
Greetings Hans
Sorry, but if your not able to do this you can wait for a merge to official beta (having à beta for Real use is a bad Bad Bad Idea)
corbin
Post by corbin »
Can you show me a picture of a rolling list? I'm not familiar with it.
corbin
Post by corbin »
Double check you have entered the correct IP address and password for the gateway. Also in my current github code the log will output the request and response which can help with troubleshooting:
2017-04-05 19:11:27.175 User: Admin initiated a switch command (91/Xiaomi Gateway Doorbell/Set Level)
2017-04-05 19:11:27.176 XiaomiGateway: level 10
2017-04-05 19:11:27.327 XiaomiGateway: request {"cmd":"write","model":"gateway","sid":"f0b4299ae4b8","short_id":0,"data":"{\"mid\":10,\"key\":\"160A62533C40CB7D6B244222ADD5CAC8\"}" }
2017-04-05 19:11:27.327 XiaomiGateway: response {"cmd":"write_ack","model":"gateway","sid":"f0b4299ae4b8","short_id":0,"data":"{\"rgb\":0,\"illumination\":340,\"proto_version\":\"1.0.6\"}"}
deennoo
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by deennoo »
Select type 1 when you create sélector switch, that on my pull request
chrispazz
Post by chrispazz »
Corbin, just updated to 7253 beta....does it include your recent modifications?
Thank you very much
Christian
corbin
Post by corbin »
not in the beta yet, the only way to get it right now is to compile from https://github.com/corbinmunce/domoticz
I expect to submit it to the main beta in 1-2 days.
bertbigb
Post by bertbigb »
I agree also
Best regards Bert
Synology DS1517+ - DSM 6.2
Jumper3126
Post by Jumper3126 »
cocapic wrote:Hi,
I read only the half of the full post sorry ... But i want to share my worries on the plug !
As I find that plugs are dangerous with an adapter I easely opened 3 of them and replaced pin with cable and trying to directly integrated in the outlet box in the wall. But range of mi plugs are a nightmare, out of there casing and specially when a charge on the ouptut
So did someone figure out the range or open plugs to integrate it ?
I taken some pics of the network board in the plug who can easely be moved from one plug to another keeping the association, also we can see a classic zigbee component http://www.nxp.com/documents/data_sheet/JN5169.pdf so plug should work as a repeter
Hi Cocapic,
How did you open the plugs? Is there some hidden screw or clip, or did you have to cut through the plastic?
