domoticz in synology as package! Available now.
jumbotroll
Re: domoticz in synology as package! Available now.
Post by jumbotroll »
Gravityz wrote: Saturday 30 September 2017 18:53 Hi Jumbotroll,
installed 8153 stable version on the DS718+(apollolake)
restored a backup from the DS112+ version
aparently USB A was the top one which i got right the first time.
seems to runs without any problems
now with the DS718+ i can run docker and homebridge.
i need homebridge for interfacing my Zwave devices to Homekit.
Great!
I was a little unsure if I had compiled the USB drivers correctly, as this was not tested with this Linux kernel.
Thank you for your feedback.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
PieterS
Domoticz version: 2024.7
Post by PieterS »
jumbotroll wrote: Monday 31 July 2017 19:40 After careful consideration, I have now made a decision.
I'm just going to update/build stable versions of Domoticz to Synology in the future.
There are often changes to the source code that make the beta versions need to be tested carefully before I can post them, and this requires allot of time I do not have ...
I think that docker or raspberry pi are better suited for beta testing.
Url's for beta versions will eventually be removed from my server, so please follow the update here on the forum or on my website for future url's.
Dear Sir,
What about other packages you made in the past? I think you served me a package for Netcat V 0.7.1 for DSM 5.2-5967 in the Synocommunity by adding an entry in Packagecenter, Settings, Packagesources. (http://www.jadahl.com/synology/)
It's too bad that I can't get that spk-file any more after an fresh install of my Syno. I need Netcat to send TCP-commands from Domoticz to a relayboard.
The backup I made by copying the files from the directory in @appstore and restoring didn't work. :cry:
Is it still possible to get it elsewhere?
Thanks in advance.
Synology with Domoticz build (V2024.7) in Docker
jumbotroll
PieterS wrote: Saturday 30 September 2017 23:42 Dear Sir,
Thanks in advance.
I have stop build these packages, but have not deleted the Netcat packages.
What Nas do you have and what DSM version do you looking for 5.2 or 6.1?
Maybe there is a Netcat on my server 8-)
Jumbotroll
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
Thanks again.
since i noticed you also made the stable version(8153)and i was running that same version on my DS112+ i figured better save then sorry.
I have send you a donation(should have done that a long time ago) because you are making it easy for us synology users.
Also the timeouts i had on the DS112+ are a lot less(i suspected this came from the USB port and not the Zwave signal since that is very strong)
Thanks again.
jumbotroll wrote: Saturday 30 September 2017 20:06
Great!
PieterS
Post by PieterS »
jumbotroll wrote: Sunday 01 October 2017 0:03
Thanks in advance.
You are my Hero! Thank you very much!!
I have a DS-710 running with DSM 5.2-5967 update 4 and looking for Netcat v 0.7.1!
:D
jumbotroll
PieterS wrote: Sunday 01 October 2017 10:00 You are my Hero! Thank you very much!!
:D
Here you go:
http://www.jadahl.com/synospk/netcat_x8 ... .7.1-1.spk
Jumbotroll
PieterS
Post by PieterS »
You made my day, week, month, year!!!! Tool works as in the past!! Thanks a lot!
Now I got the spk-file. My good old Nas is running for another few years! No need for upgrade the Syno for me. As long as people like you help me out! :?
Ady92100
Domoticz version: >V3.6796
Post by Ady92100 »
Hello everybody
I have searched everywhere, but maybe not in the right place.
For a Synology DS212, I have tried to change the location of the DZ log.
Usually it's done by modyfying the domoticz.sh script.
But i was unable to find it.
Do yo know how to change the dz log from ...domoticz/var/ to xx/yy/zz ?
Thanks for your help.
regards
Synology DS212 + RFXTrx433 + AEon Stick S2
Oregon - Thgr122Nx / Chacon - module 1000w - détecteur de fumée 34131 / OWL -CM180 / Greenwave Multiprise
jumbotroll
Ady92100 wrote: Sunday 01 October 2017 18:05 Hello everybody
regards
It's located in: /var/packages/domoticz/scripts
Edit: start-stop-status
Jumbotroll
Ady92100
Post by Ady92100 »
Hello Jumbotroll
I may have been not clear.
I know that the logfile is i located in /var/packages/domoticz/scripts
What i would like to do, it's to change the location of the logfile
In domotics.sh you have these lines
USERNAME=pi
DAEMON=/home/$USERNAME/domoticz/$NAME
#DAEMON_ARGS="-daemon -www 8080 -log /tmp/domoticz.txt"
#DAEMON_ARGS="-daemon -www 8080 -syslog"
DAEMON_ARGS="-daemon -www 8080"
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
I want to change the parameter -log (/tmp/domoticz.txt) of the line #DAEMON_ARGS="-daemon -www 8080 -log /tmp/domoticz.txt"
to write the log somewhere else.
but I haven't found the file domoticz.sh to modify this parameter.
How can I do that ?
jumbotroll
Ady92100 wrote: Sunday 01 October 2017 20:36 Hello Jumbotroll
USERNAME=pi
How can I do that ?
There is no domoticz.sh in use on synology
In the start-stop-status script you can change the location for the log file.
Edit start-stop-status script and then stop/start domoticz from package center.
# Package
PACKAGE="domoticz"
DNAME="Domoticz"
# Others
INSTALL_DIR="/usr/local/${PACKAGE}"
PATH="${INSTALL_DIR}/bin:${PATH}"
RUNAS="root"
#USER="domoticz"
DOMOTICZ="${INSTALL_DIR}/bin/domoticz"
WWWROOT="${INSTALL_DIR}/www/"
PID_FILE="${INSTALL_DIR}/var/domoticz.pid"
LOGFILE="${INSTALL_DIR}/var/domoticz.log"
#LOGFILE="/volumeUSB1/domoticz.log"
DB_FILE="${INSTALL_DIR}/var/domoticz.db"
#DB_FILE="/volumeUSB1/domoticz.db"
PORT="8084"
Jumbotroll
Ady92100
Post by Ady92100 »
@Jumbotroll
Oups sorry. I did not understand your previous message.
Thanks a lot for your help
jumbotroll
New Beta for synology!
Beta versions will be compiled once in a while and not regularly!
Only for Manual download and install.
Beta versions should only be installed by experienced users.
Be sure to backup database and scripts before installation.
These versions have not been tested by me and are installed at your own risk.
http://www.jadahl.com/domoticz_beta_6.1/
Compiled with Python Plugin.
http://www.jadahl.com/domoticz_beta_6.1_python/
Jumbotroll
ednl
Domoticz version: 3.8875
Post by ednl »
Thank You .. very much appreciated :)
lampje25
Post by lampje25 »
Why do not I get any new beta versions anymore?
Last version is V3.0.8143
On site from jadahl: 3.0.8552.
Link in packege centre: http://www.jadahl.com/domoticz_beta_6.1/
EdwinK
Post by EdwinK »
lampje25 wrote: Friday 06 October 2017 21:53 Why do not I get any new beta versions anymore?
Read this post. It's explained there.
lampje25
Post by lampje25 »
Can i use: http://www.jadahl.com/synology6/ in packege centre for the stable versions?
I have "DSM 6.1.3-15152 Update 6"
EdwinK
Post by EdwinK »
Maybe. I just download the file and then install it myself.
Hi jumbotroll,
any chance you will have the beta package with python for DSM 6.2 (916+ architecture) any time soon ?
will
jumbotroll wrote: Friday 06 October 2017 20:40 New Beta for synology!
jumbotroll
waaren wrote: Saturday 07 October 2017 10:52 Hi jumbotroll,
There is no new kernel or toolchain for DSM6.2.
You can use DSM6.1 version.
domoticz_braswell-6.1_3.0.8552-7.spk
http://www.jadahl.com/domoticz_beta_6.1 ... 8552-7.spk
Jumbotroll
