Page 53 of 55
Re: [MyDomoAtHome] Support thread
Posted: Tuesday 09 June 2020 8:44
by mcwieger
I still have nightly crashes, which is getting annoying. I checked usage.log and see the following:
{"level":"info","message":"Refreshing version cache: v0.2.39","timestamp":"2020-02-09T14:40:48.501Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8084/json.htm","timestamp":"2020-05-27T12:57:03.723Z"}
{"level":"info","message":"Node version: 12.14.0","timestamp":"2020-05-27T12:57:03.816Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.39","timestamp":"2020-05-27T12:57:03.816Z"}
{"level":"info","message":"OS version: Linux linux 3.2.40","timestamp":"2020-05-27T12:57:03.818Z"}
{"level":"info","message":"Hostname: NAS 192.168.2.201 in /root /root","timestamp":"2020-05-27T12:57:03.874Z"}
{"level":"info","message":"Refreshing version cache: v0.2.41","timestamp":"2020-05-27T12:57:06.694Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8084/json.htm","timestamp":"2020-05-28T07:18:22.463Z"}
{"level":"info","message":"Node version: 12.14.0","timestamp":"2020-05-28T07:18:23.993Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.39","timestamp":"2020-05-28T07:18:23.994Z"}
{"level":"info","message":"OS version: Linux linux 3.2.40","timestamp":"2020-05-28T07:18:23.996Z"}
{"level":"info","message":"Hostname: NAS 192.168.125.1 in /root /root","timestamp":"2020-05-28T07:18:24.108Z"}
Two things I notice:
- Hostname: NAS 192.168.125.1: this is from my address range I configured for OpenVPN and is the starting IP address that's assigned when connecting to my Synology via VPN. Why is it appearing in the MDAH log? I haven't used VPN to connect to MDAH or even Domoticz recently.
- Version cache says v0.2.41 while I'm on version 0.2.39. How did this happen?
Posted: Sunday 28 June 2020 9:48
by teo1966
this version node-mydomoathome-0.2.42 dont start on my ds916+
Posted: Wednesday 01 July 2020 11:46
by Sopalin
I'm currently migrating to Archlinux and i was wondering if MyDomoAtHome will work on this OS.
Thanks.
Posted: Monday 31 August 2020 14:51
by epierre
yes this is pure nodejs.
IP is the one answered by the OS, fon't know if multiple is well managed.
Cache version is the latest available based on github
Posted: Friday 01 January 2021 13:55
by Micha
Happy new year,
I'm trying to install mydomoathome and I'm getting following:
pi@raspberrypi:~ $ wget -qO - http://www.e-nef.com/domoticz/mdah/gpg.mykey | sudo apt-key add -
OK
pi@raspberrypi:~ $ sudo apt-get update
Ign:1 http://www.e-nef.com/domoticz/mdah InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Err:3 http://www.e-nef.com/domoticz/mdah Release
404 Not Found [IP: 164.132.235.17 80]
Hit:4 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists... Done
E: The repository 'http://www.e-nef.com/domoticz/mdah Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Does anybody have an idea? I tried with http and https
Kind Regards
Posted: Thursday 14 January 2021 21:52
by epierre
try this instead:
deb https://www.e-nef.com/domoticz/mdah/ buster contrib
Posted: Monday 24 January 2022 17:41
by Knight
Hello, i need support with a new install. I have installed Bulleseye on a new Rasp 4 with the newest domoticz
When i try to install MyDomoAtHome a get this problem.
I get this error "MyDomoAtHome not found" when i type sudo apt-get install MyDomoAtHome
pi@raspberrypi:~ $ sudo apt-get install MyDomoAtHome
Läser paketlistor… Färdig
Bygger beroendeträd… Färdig
Läser tillståndsinformation… Färdig
E: Kunde inte hitta paketet MyDomoAtHome
I also tried to install by download the package but I can't find the execute command to install it,
Open Terminal
Extract the .tar.gz or (.tar.bz2) file with the following commands
tar xvzf MyDomoAtHome-0.2.45.tar.gz
Navigate to the extracted folder using cd command
cd MyDomoAtHome-0.2.45
Now run the following command to install the tarball
./configure (When i type this i get error "File not found" )
make
sudo make install
Can someone help me?
Posted: Monday 24 January 2022 17:44
by epierre
if you have the .deb in local it is :
sudo dpkg -i MyDomoAtHome-xxxxx.deb
Posted: Monday 24 January 2022 18:39
by Knight
epierre wrote: Monday 24 January 2022 17:44 if you have the .deb in local it is :
Where can i download MyDomoAtHome-xxxxx.deb ?
I only found these https://github.com/empierre/MyDomoAtHom ... ag/v0.2.45
Thank you !
Posted: Monday 24 January 2022 18:47
by epierre
Posted: Monday 24 January 2022 18:54
by Knight
I Found where the Deb files are
http://e-nef.com/domoticz/mdah/dists/bu ... ary-armhf/
But when I run "sudo dpkg -i node-mydomoathome-0.2.45.deb"
pi@raspberrypi:~ $ sudo dpkg -i node-mydomoathome-0.2.45.deb
(Läser databasen ... 103577 filer och kataloger installerade.)
Förbereder att packa upp node-mydomoathome-0.2.45.deb ...
dpkg: fel vid hantering av arkivet node-mydomoathome-0.2.45.deb (--install):
conffile name 'etc/mydomoathome/config.json' is not an absolute pathname
Fel uppstod vid hantering:
Posted: Monday 24 January 2022 19:01
by epierre
hmmm...surprising, try this one (should be the same cannot test it...)
https://www.e-nef.com/domoticz/mdah/dis ... ary-armhf/
Posted: Monday 24 January 2022 19:10
by Knight
Can it be a problem with "bullseye"? with rasp 4 ( I have a Rasp2 with working mydomoathome)
I have problem with the first steps.
nodejs is already the newest version (12.22.5~dfsg-2~11u1).
(Updated)
manage to update to nodejs 14.18.3-deb-1nodesource1
same problem :cry:
Posted: Monday 24 January 2022 19:11
by epierre
I would have to install a pi with it to check...
Posted: Monday 24 January 2022 19:35
by Knight
Im stuck. I broke the OS so i have to reinstall the Debian Bullseye
I really want it to work..
I have found a solution "work around" with ImperieHome
Download it from https://oceanofapk.com/imperihome-smart ... -download/
and restore an old backup then you are in :D
Posted: Thursday 27 January 2022 16:27
by Knight
epierre wrote: Monday 24 January 2022 19:11 I would have to install a pi with it to check...
Hello, did you get it to work? :?
Posted: Sunday 30 January 2022 22:51
by Knight
I think there's a compatibility issue with debian bullseye. I have installed a new fresh version of bullesyes with desktop. You can install .deb files directly on the desktop. However, the operating system does not approve this .deb file and I get an error message.
I will try to install the deb file on a fresh iso "buster with desktop"
Posted: Monday 31 January 2022 22:59
by Knight
It works flawlessly to install it on a newly installed version of Buster.
Code
sudo apt update
sudo apt upgrade
sudo apt install nodejs npm
Installs the latest versions of both nodejs and nom
then download mydomoathome
wget http://www.e-nef.com/domoticz/mdah/node-mydomoathome-latest.deb
install domoathome
sudo dpkg -i node-mydomoathome-latest.deb
Bulleyes.... no luck there. Error "conffile name 'etc/mydomoathome/config.json' is not an absolute pathname"
empierre, if you have time over. I can place a donation true paypal
Posted: Wednesday 02 March 2022 18:02
by epierre
can try testing it, writing the sdcard on a pi 3.
Are you running a lite or with ui and recommended ?
Posted: Thursday 03 March 2022 9:56
by epierre
For Debian 11/Bullseye here is the procedure
curl -fsSL https://deb.nodesource.com/setup_12.x | sudo -E bash -
sudo apt-get install -y nodejs
wget https://www.e-nef.com/domoticz/mdah/dis ... 0.2.49.deb
sudo dpkg -i node-mydomoathome-0.2.49.deb
