Page 51 of 52
Re: Controlicz - Easy Domoticz to Alexa Integration
Posted: Monday 14 October 2019 11:06
by Madgeni
so, something like:
Create a dummy sensor
then something in blockly like:
if window = closed
set dummy sensor = off
else if window = open
set dummy sensor = on after 60 mins
Then follow the Alexa Routines - Sensors info in the Controlicz FAQs. You can also contact me via support in your Controlicz profile
Posted: Friday 08 November 2019 11:22
by firesfinx
After years controling domoticz by ha-bridge, it recently refused to discover any new devices, so I stepped to Controlicz. I got my lights, switches, sensors working and even selector switches, great functionality!
Since I am new to Controlicz (and after a week messing with ha-bridge i do not trust my alexa for 100%) I would like to know if others can brighten/dim their lights with Controlicz. I can turn them on and off or set them to a certain percentace (by saying "set Light to 67%"). However when i say "Dim light" or "Increase Livingroom temperature" Alexa responds with "Ok" but nothing changes in the app or in real life. When issuing such a command before (with ha-bridge) Alexa would change the light or temprature by a few percent or degrees. Is this functionallity available with Controlicz or not?
Also alternative names for switches would be great, is this possible or how do you all solve this (with a dimmer switch)?
Posted: Friday 08 November 2019 12:47
by Madgeni
Hi - i'm glad you're enjoying Controlicz.
You should be ok to just say "Alexa, dim the front room lights" and it will decrement the lights by a small amount, so if it's not working for you can i ask you ping me a support mail from your Controlicz profile, and i'll investigate.
You can set friendly names for your devices also. Go into the device description, and put Alexa_Name: friendlyname - where friendlyname is the alternative - e.g for front room lights - Alexa_Name: main room lights
Discover your devices again, and they will change
Posted: Sunday 10 November 2019 16:25
by Norton
i tried to set notifications but i have a problem they don't work. i got this status message in domoticz log:
Status: Notification: A|372|Open|Contact
and then this error:
I set everything as it is in the FAQ.
Had someone a similar problem?
Thanks for help.
The others things works OK, switching lights, got temperature etc...
Only notification dont work.
Posted: Sunday 10 November 2019 16:31
by Madgeni
Hi -
under Settings>Setup>Notifications, have you put the Custom HTTP/Action?
Posted: Sunday 10 November 2019 18:09
by Norton
yes. here is my config:
Posted: Sunday 10 November 2019 20:33
by Madgeni
ok - it does seem that Domoticz is sending the http request, which is then working fine with Alexa, however i'm guessing something has changed with the expected response, hence the error (i'm getting the same).
This won't affect the request to Alexa for a routine to work, as the trigger is the request you send.
Are you seeing the motion/contact sensors in your Alexa app under Routines?
Posted: Sunday 10 November 2019 20:56
by Norton
yes i see the sensors in my Alexa routines. I tried it now and it work. The routines is triggered. But in domoticz log i still getting the error messages.
Thanks for your help.
Posted: Sunday 10 November 2019 20:57
by Madgeni
ok, am working on the response now, just for completeness
Posted: Monday 11 November 2019 20:34
by Norton
no more errors in domoticz logs. Many thanks to excellent support.
Posted: Thursday 02 January 2020 19:35
by Madgeni
Just to let everyone know logging of commands is now available in your profiles
Posted: Sunday 09 February 2020 11:53
by martijnm01
Since a couple of days i experience issues turning scenes on and of with Alexa/Controlicz. They just won't work.
Turning a switch on and of via Alexa/Controlicz works fine, but a scene somehow won't be enabled. In the Controlicz logs i see the correct messages:
IDX action message status timestamp
-198 SetScene Scene set to On Success Sun Feb 09 2020 10:23:18 GMT+0000 (Coordinated Universal Time)
-199 SetScene Scene set to Off Success Sun Feb 09 2020 10:01:44 GMT+0000 (Coordinated Universal Time)
In Domoticz i have the following log entry for enabling a scene:
2020-02-09 11:35:51.640 Status: Incoming connection from: 35.178.[x].[x] ( <-- AWS controlicz IP )
But when i enable a switch via Alexa/Controlicz, i see the normal entries:
2020-02-09 11:42:33.057 Status: User: controlicz initiated a switch command (16/Badkamer/On)
2020-02-09 11:42:33.066 Status: Incoming connection from: 35.178.[x].[x]
2020-02-09 11:42:51.433 Status: User: controlicz initiated a switch command (16/Badkamer/Off)
2020-02-09 11:42:51.443 Status: Incoming connection from: 35.178.[x].[x]
Any ideas?
Posted: Sunday 09 February 2020 13:03
by Madgeni
Hi - can you rediscover your devices and try again?
Posted: Sunday 09 February 2020 13:45
by martijnm01
Madgeni wrote: Sunday 09 February 2020 13:03
Hi Madgeni,
That -and removing/renaming some old scenes- seems to work! Thanks.
Posted: Sunday 09 February 2020 13:47
by Madgeni
great
Posted: Sunday 22 March 2020 19:03
by levynger
suddenly, I have a situation, I have Temp sensor that passes Celsius,
I have 2 Alexa devices, both set for Celsius in the Alexa App,
when i ask alexa for sensor termperatore, it translate it,
For instance the temp sensor is 68.5C, the alexa would say 22C (more or less)
when change in the alexa App to Farenheit, it will report the correct value from the Domoticz, however the rest will be farenheit (for instance, what is the temperature today..)
any ideas?
Posted: Sunday 22 March 2020 19:48
by Madgeni
Weird - can you send a message from your Controlicz profile and I’ll investigate
Posted: Sunday 22 March 2020 21:06
by levynger
Madgeni wrote: Sunday 22 March 2020 19:48
thanks,
Done...
Posted: Sunday 29 March 2020 14:13
by BennY
I have a issue with the controlicz skill. Alexa don't find any device. It was working with my old setup before, now i have a fresh system.
- Raspbian Buster
- Domticz 2020.1
- have Remote Access
- have controlicz connection
- all devices are in Rooms
- all devices showing up in controlicz.com
- Skill is active
- paid
What can I do?
Thanks...
Posted: Sunday 29 March 2020 15:16
by Madgeni
Message me from your Controlicz profile and I’ll look into it asap
