You can see it after you log in at https://my.domoticz.com/.sclk34 wrote:Hello!
I'm a novice. And I did not understand the information from Wikipedia about my.domoticz.com.
I share the instance, but how to use it ? How to see the Web Interface of domoticz server?
MyDomoticz - Testers wanted!
- chimit
- Domoticz version: master
Re: Testers wanted!
sclk34
Re: Testers wanted!
All that I can see on this site (see the attachment). how can I go to my devices?
- 2.png (355.13 KiB) Viewed 3250 times
- 1.png (363.45 KiB) Viewed 3250 times
- chimit
Re: Testers wanted!
You can click on the green icon and you will have access to your Domoticz.sclk34 wrote:All that I can see on this site (see the attachment)
Something to include on the Wiki pages.
sclk34
Re: Testers wanted!
chimit wrote:You can click on the green icon and you will have access to your Domoticz.sclk34 wrote:All that I can see on this site (see the attachment)
Its work))) but it is not obvious. Thank you!
JC38
Re: Testers wanted!
It is checked (on the slave) so I've unchecked and checked it again. Still the same error :To solve this: Check the "Shared Domoticz Allowed" checkbox on the slave instance.
2016-01-24 11:43:07.299 Error: PROXY: Shared Server access disallowed, denying receive data request.Raspberry Pi 3 Domoticz latest public beta + RFXComm Usb + Aeon Labs Z-Stick + Weather Underground
Windows 2012R2 with Essentials + Domoticz Windows (latest) + Open Hardware Monitor
ImperiHome with mdat / Domoticz for Android
JC38
Re: Testers wanted!
I have four Dz into the dashboard. I will check again at the next update.chimit wrote:Does this occur when you have two Domoticz's in your roster (dashboard)? I've seen this before, when one (or both) use the login page.
The cookie path is set wrong in Domoticz for use with MyDomoticz. I will try to submit a patch soon. Meanwhile, trying one or two times more helps for me in such a case.
As you can see https://github.com/domoticz/domoticz/commits/master, some changes had been published for the update feature 2 days ago.
- chimit
Re: Testers wanted!
Even though master/slave communication via MyDomoticz is (very) experimental, it should work.JC38 wrote:It is checked (on the slave) so I've unchecked and checked it again. Still the same error :To solve this: Check the "Shared Domoticz Allowed" checkbox on the slave instance.Code: Select all
I assume you get this error on the slave, right? Maybe the checkbox on the UI doesn't work anymore since a change from another contributor. Need to check when I get the time.
- chimit
Re: Testers wanted!
As requested, I am giving an update about a new update of the MyDomoticz service.
Angular is now used to render your roster (dashboard) and many other things have changed internally.
The update was not supposed be deployed online yet. But since there was a casual bug in the current version that made the service seem to stop working, I decided in favor of this step.
Please continue to report bugs and also please allow for some time to get a response from me due to a busy schedule.
== Rene
EDIT: I reverted to the previous version again due to some persistent problem unknown. Will update later.
== Rene
JC38
Re: Testers wanted!
René, maybe a simple way to keep us informed of a new version would be to add something in the login page below the actual footer
Adding date + time of your latest compilation would be nice and also the duration since the last start of your service.("Online for" like you do with the clients)
Note: This is a beta service and not meant for production use. Use at your own risk.
For a description, see the Domoticz Wiki.
By using this page, you agree to our Terms & Conditions.
Compiled on yyyy/mm/dd
MyDomoticz service is online for xxxx Raspberry Pi 3 Domoticz latest public beta + RFXComm Usb + Aeon Labs Z-Stick + Weather Underground
- chimit
Re: Testers wanted!
Nice idea. We already have the online time on our admin pages. Will put it on the list as well.JC38 wrote:René, maybe a simple way to keep us informed of a new version would be to add something in the login page below the actual footerAdding date + time of your latest compilation would be nice and also the duration since the last start of your service.("Online for" like you do with the clients)Code: Select all
Note: This is a beta service and not meant for production use. Use at your own risk. For a description, see the Domoticz Wiki. By using this page, you agree to our Terms & Conditions. Compiled on yyyy/mm/dd MyDomoticz service is online for xxxx
erik4281
Re: Testers wanted!
I made a mistake myself. I was running 2 Raspberry Pi's with a copy of the Domoticz database at the same time. This also means the Instance ID, API and password were the same. I guess there might have been some conflicts on the MyDomoticz service because of this.
I actually needed only one of them to connect to the MyDomoticz service. Now I removed the MyDomoticz settings in Domoticz on the second Pi, but I still cannot connect.
The MyDomoticz website says my Domoticz has been online for almost 21 hours, but if I connect (click the green icon), an empty page shows up. If I check the logging in Domoticz I see the following message: "Error: PROXY: Connect failed, reconnecting: Connection refused". I get this message every 10 seconds.
If I switch om MyDomoticz on the second Pi, I get the following message: "Error: PROXY: Connect failed, reconnecting: Network is unreachable".
How can I fix this? Or is this an actual bug and something I cannot fix myself?
ukwebfx
Re: Testers wanted!
I would like to use my domoticz, I have just in the last week build an automation system to control my lights and have created an account on my domotica, but I am having problems and i have noticed on the wiki that i need to ask chimit if I can be added to the alpa testing, I am unable to pm chimit as I have only just created my account on here as have not needed to ask for help up until now and pm are unavailble to me. thanks in advance.
ps, i love domoticz its brilliant and allows me so much flexibility
thanks
thanks
- michaldobrotka
Re: Testers wanted!
Hi Guys,
I know that my.domoticz is Beta, but since 22.1. I cant connect to this service. Yesterday I made new account but same result - "my green Buddy" is still red! Its general problem or its in my Beta version of Domoticz?
PS:
Its my favorite feature for Domoticz, I love it, great job!
Thanks for help.
PS:
Thanks for help.
Domoticz on Raspi 3 and slave on ZeroW (running only with Broadlink plugin), Serial Mysensors GW on Arduino nano, Broadlink RM2, Rehau CO2 USB Stick, RF link 433 MHz, 2x Amazon Echo Dot (Controlicz), ESP2866 witk Espeasy, Sonoff
- Varazir
Re: Testers wanted!
Any error on your Domoticz ? Could sometime help to disable/enable the service on Domoticz.michaldobrotka wrote:Hi Guys,
PS:
Thanks for help.
Skickat från min Nexus 5 via Tapatalk
- michaldobrotka
Re: Testers wanted!
Thanks man!
Its working now.
Its working now.
raym
Re: Testers wanted!
Hi guys. I'm just wondering if it will be possible to route ImperiHome app users via this service to the MDAH gateway? If anyone has done it already, I'd appreciate the steps needed to set this up. http://domoticz.com/wiki/ImperiHome
- Varazir
Re: Testers wanted!
As they say, apps isn't supported yet.raym wrote:Hi guys. I'm just wondering if it will be possible to route ImperiHome app users via this service to the MDAH gateway? If anyone has done it already, I'd appreciate the steps needed to set this up. http://domoticz.com/wiki/ImperiHome
raym
Re: Testers wanted!
Oh sorry. Ok, thanks.Varazir wrote:As they say, apps isn't supported yet.raym wrote:Hi guys. I'm just wondering if it will be possible to route ImperiHome app users via this service to the MDAH gateway? If anyone has done it already, I'd appreciate the steps needed to set this up. http://domoticz.com/wiki/ImperiHome
- Varazir
Re: Testers wanted!
Just keep a eye up.raym wrote:Oh sorry. Ok, thanks.Varazir wrote:As they say, apps isn't supported yet.raym wrote:Hi guys. I'm just wondering if it will be possible to route ImperiHome app users via this service to the MDAH gateway? If anyone has done it already, I'd appreciate the steps needed to set this up. http://domoticz.com/wiki/ImperiHome
- chimit
Re: Testers wanted!
To keep you updated a bit: Meanwhile I find time for a newer update, I put online just some fixes that prevents the web server part from responding at certain times.
It will be active after the next restart. I will be monitoring, so I can revert back in case of anomalies.
== Rene
== Rene
