Page 6 of 55
Re: [MyDomoAtHome] Support thread
Posted: Sunday 06 September 2015 13:09
by epierre
Bikey wrote:Bikey wrote:
I did an update, but it is still there. Now every group is found 9 times as an DevGenericSensor...
The groups also appear in the first page of the App "Actuators", but I can't activate them, the button shows "N/A".
@epierre can you fix it so that I can use the on/off button for the Group (so no more "N/A" )? Do you need additional input?
ok so the issue was the mixed status you can show but not select :
A group can has 3 states (as far as i have seen): On, off, mixed
The last one is the one you are looking for. If all lights are off, it says 'off', but if even 1 light is on, it will say the status of the group is 'mixed'.
fixed in last commit, but mixed has an issue raised to imperihome team, I'me made a tracker to follow it
Posted: Sunday 06 September 2015 22:24
by Bikey
I did an update, and now for the first time the groups had no longer the label "N/A", but "Off". After selecting the group I could select "On", "Off" or "Mixed". That worked: I could switch the groups on and off a couple of times, hurray!
(still not exactly how I would like it: I would like the that a group switch can be set "On" or "Off" in 1 click. So no extra menu with choices.)
However after a while the buttons are "frozen", they show the state "Mixed" or "Off" but nothing happens if I push them. If I check http://gateway-IP:port/Devices I see that the first time the groups where each only present 1 time, but after the switching the groups on/of a couple of times, the device list has again multiple instances of each group.
"name":"7-Wake-up-Group--","type":"DevGenericSensor","id":"S4","room":"noroom"},{"params":[{"unit":"","value":"unk","graphable":"false","key":"Value"}],....,
"name":"7-Wake-up-Group--","type":"DevGenericSensor","id":"S9","room":"noroom"},{"params":[{"unit":"","value":"unk","graphable":"false","key":"Value"}]
This is repeated 13 times... (everytime with a different id?)
If I restart the service it initially looks good, but after 1 action I get the repeating groups again.
The last page with the "unk" devices is gone in the App by the way, so that's ok.
Posted: Sunday 06 September 2015 22:28
by Bikey
The "push-on" and "push-off" buttons are also still mixed up in this last update.
Posted: Sunday 06 September 2015 22:37
by epierre
@bikey don't get confused by the unknown list, I've just disabled it because it cause misuderstanding.
for the grouyp scenes, you have to ask imperihome for the on / off on the same display. I have to display Mixed although it has no behaviour at all, not showing it would not allow to display the status...
Bikey wrote:However after a while the buttons are "frozen", they show the state "Mixed" or "Off" but nothing happens if I push them.
this is more on domoticz side that it hangs... scenes are quite cpu consuming so time unresponsive...
Bikey wrote:The "push-on" and "push-off" buttons are also still mixed up in this last update.
what do you mean there ?
Posted: Sunday 06 September 2015 22:38
by epierre
@all I did greatly improve the graphing capacities in last commit, please update and report if this is actually good for you !
Posted: Sunday 06 September 2015 22:51
by Bikey
Yeah, no problem.
To me it is more important to be able to switch the group on/off with a single click then to show the status, so I would be fine for me If you "translate" these to a single switch in ImperiHome.
No, I really mean that they do not work anymore, even after 10 minutes. In the Domoticz web interface they work within 2 seconds.
I think that has to do with the fact that after 1 activation the gateway has a bug and "finds" each group multiple times and mixes up Id's like I described. Something wrong there.
what do you mean there ?[/quote]
Like explained earlier: a "push-on" button should be "Off" in the interface. If you push it, it should send an "On" signal and show an "On" state in the interface temporarily and then turn back to the "Off" state in the interface. Currently it is just the other way around: it is "On" in the interface and send an "Off" command if you push it.
Posted: Sunday 06 September 2015 22:56
by Bikey
epierre wrote:@all I did greatly improve the graphing capacities in last commit, please update and report if this is actually good for you !
Mmm, I get " Error no graph data to display" for my thermo/hygro-meters.
For my (virtyual Wheater Underground) meters I get only a graph for the last 24 hours. If I select another period, only the last 24 hours is actually plotted.
Posted: Sunday 06 September 2015 23:11
by epierre
Bikey wrote:epierre wrote:@all I did greatly improve the graphing capacities in last commit, please update and report if this is actually good for you !
ok last commit for I did a mistake now corrected
Bikey wrote:For my (virtyual Wheater Underground) meters I get only a graph for the last 24 hours. If I select another period, only the last 24 hours is actually plotted.
yes this is something I need to think on, domoticz provides daily, monthly or yearly data, granularity is poor for that...
Posted: Tuesday 08 September 2015 8:29
by mxpwr
I updated to the latest version, but now I can't access the server anymore.
I also did a fresh install, but still no luck. There are no errors shown.
Any way to figure out what the problem is?
Posted: Tuesday 08 September 2015 8:41
by Bikey
I had the same issue, but running the update script again and a reboot did help.
Group switches still giving trouble unfortunately.
Posted: Tuesday 08 September 2015 8:59
by epierre
for a fresh install default port is now 3001 to clear the 5001used by sinology and MQTT. You shouldn't be affected unless you still use the start.sh script or used the run-once.sh again. If so, change in imperihome client the port to 3001 and if you're using nginx too.
group switch should be ok, it takes some time to (here it is for me with one on and one mixed)get the good value. Mixed cannot be chosen, it is a state not an actuator. I've discussed about that with imperihome team yesterday but I don't have an idea when they could push that forward, the latest to have something will be iOS for the Apple validation is very long.
Posted: Tuesday 08 September 2015 20:30
by Doler
mxpwr wrote:I updated to the latest version, but now I can't access the server anymore.
I had the same problem and solved it by running run-once (sh ./run-once.sh) and update (sh ./update-mdah.sh) and performed a reboot. Mind that the default port is now 3001 (check with http://gateway_ip:gateway_port/devices). Changed the port in Imperihome app and I was up and running again. No clue for the cause but ok, it is working again.
Posted: Tuesday 08 September 2015 21:01
by epierre
are you ok now ?
Posted: Tuesday 08 September 2015 21:56
by Doler
epierre wrote:Hello,
Group switch is ok, I can see On, Off and Mixed. Still not happy with the extra action for choosing On or Off. Could you take a look at the Composite global switch widget that does exactly that group switching with a 'direct' On/Off (and the icon capable of showing a mixed state so the widget is three-state aware). Is it possible to use this widget?
Posted: Tuesday 08 September 2015 22:10
by Doler
I have a weird situation: one of my switches is showing strange behaviour in Imperihome, when Off it shows okay but when turned On (doesn't matter in Domoticz or Imperihome) it will show the On-state on refresh but immediately after that show an Off-state (while the switch is On). So it keeps flashing On and Off on every refresh. In Domoticz the switch acts normally. Anybody seen something like this in Imperihome?
Posted: Tuesday 08 September 2015 22:13
by epierre
Doler wrote:epierre wrote:Hello,
This widget is display only, not linked to the ISS, I guess they do a multiple On/Off in imperihome. I see you're on dev imperihome version too, there's been no ISS update for it.
Posted: Wednesday 09 September 2015 9:55
by epierre
Doler wrote:I have a weird situation: one of my switches is showing strange behaviour in Imperihome, when Off it shows okay but when turned On (doesn't matter in Domoticz or Imperihome) it will show the On-state on refresh but immediately after that show an Off-state (while the switch is On). So it keeps flashing On and Off on every refresh. In Domoticz the switch acts normally. Anybody seen something like this in Imperihome?
is that a push-on or push-off button in domoticz ? then this is normal, I restested this yesterday
Posted: Wednesday 09 September 2015 10:00
by Bikey
@epierre: did you find the bug that results in the groups getting found multiple times?
If I check with http://gatewayip:port/devices I can see all my groups being found 43 times (same groupname all with different Id's), and still increasing!
Posted: Wednesday 09 September 2015 10:21
by epierre
Bikey wrote:@epierre: did you find the bug that results in the groups getting found multiple times?
I cannot reproduce this, I had a look at the code and there is no way this should happen.
Can you stop imperihome app (kill it somehow or restart your phone) and test it again ?
http://domoticzip:port/json.htm?type=scenes should be the reference on one per one
Posted: Wednesday 09 September 2015 10:46
by Bikey
I killed the imperiohome App (although I don't see why that should help, because it is an error in the gateway) and even rebooted my RPI. Unfortunately that does not help.
After switching the groups on/off a couple of times, the groups start to multiply in the /devices message again.
If I check with http://domoticzip:port/json.htm?type=scenes I see all the scenes/groups only once per scene.
