Page 6 of 12
Re: Mi-Light / LimitlessLED / Applamp
Posted: Thursday 20 April 2017 14:50
by Jarn
After sniffing my network yesterday. (With wireshark) I've noticed that the app of "Mi-Light" send everything towards the broadcast address.
I'll try to compare the commands (or add some screenshots of them)
I'm having a busy day today, so I have no idea when I'm going to post these images your asking of.
But I'll definitly post them later on (this) week?
Posted: Thursday 20 April 2017 14:55
by Jarn
Attachment 1:
Is the UDP "Data" that my cellphone send towards the "ipbox" via the broadcast address.
I'm going to take pictures of the hardware I bought.
Posted: Thursday 20 April 2017 15:09
by Jarn
Attachment 1 is one of the Four zones In have. Attachment 2 is the bridge.
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
Posted: Thursday 20 April 2017 23:28
by Nautilus
Thanks, seems very legit hardware. I don't have FUT039 (well, I have it but not in use yet) but FUT038 is a similar unit and works fine paired with both types RGBW and RGBWW.
There has been some discussion earlier on using the broadcast address, at least with the scripts, see e.g:
https://www.domoticz.com/forum/viewtopi ... 40#p123027 So you could try that as well. But all in all, I'm pretty much out of ideas at this point
Have you been able to capture what kind of packages Domoticz / scripts are sending, do they look similar to those coming from the app?
Posted: Friday 21 April 2017 16:19
by Jarn
It seems that the UDP data is totally diffrent then the one that I find on the interwebs.
It'll take some time for me to figure out what the difference are with the FUT038, Its been a while that I've used wireshark (and I still need to learn the ways how "Mi-light" transfers it data.
I'll keep you guys posted.
Posted: Friday 21 April 2017 17:17
by Nautilus
The bridge does not know which hardware you are controlling with it so it should send (to my understanding) the same packets dependant of the "target". Only the remote model you choose in the app affects which Milight type (RGB, RGBW, RGBWW) you need to select in Domoticz to send the same command. Clearly there is something funny going on, which version of Domoticz are you know running? Well, if even the 3rd party scripts are not working it shouldn't be anything limited to Domoticz anyway. How about trying to send to the broadcast address directly, with either the scripts or Domoticz?
Posted: Friday 21 April 2017 20:14
by Jarn
I'm currently working with Domoticz Version "V3.7320".
It doesn't seem that changing the ip to the broadcast seems to work...
Posted: Saturday 29 April 2017 7:09
by marcotrumpet
Someone experiencing promblem like this? Everythink worked fine before and I made no change (no domoticz update)
Inviato dal mio SM-G950F utilizzando Tapatalk
Posted: Saturday 29 April 2017 10:06
by Jarn
seems like an IP problem on first sight. Check if the bridge still has the same ip. or give it a static one.
Re: RE: Re: Mi-Light / LimitlessLED / Applamp
Posted: Saturday 29 April 2017 10:23
by marcotrumpet
Jarn wrote:seems like an IP problem on first sight. Check if the bridge still has the same ip. or give it a static one.
I've assigned a static one the first day. The box was unreachable from the app too. If I power off and than on again everything gone right for a little bit (maybe hours or minutes) and than offline again
Posted: Saturday 29 April 2017 10:45
by Jarn
Can you try to connect to the bridge directly when the problem occurs?
Posted: Saturday 29 April 2017 10:56
by marcotrumpet
Done.. it's offline or a kind of.. if I enter the ip when it's off I can't connect. If I unplug the power cord and plug again it goes ok
Posted: Saturday 29 April 2017 11:00
by marcotrumpet
Real time error
Posted: Saturday 29 April 2017 14:25
by Jarn
Did it accidently change from "STA" mode to "AP" mode?
Posted: Saturday 29 April 2017 17:15
by marcotrumpet
Jarn wrote:Did it accidently change from "STA" mode to "AP" mode?
No. I double checked all settings. Now I tried changing ip in router roules, milight box settings and domoticz. It's working now, see how long it last
Posted: Saturday 29 April 2017 18:06
by Jarn
marcotrumpet wrote:Jarn wrote:Did it accidently change from "STA" mode to "AP" mode?
Why would you change the ip rules? Normally when it has a static ip, your bridge doesn't need any interaction with the router. (unless it has its ip set to DHCP)
Re: RE: Re: RE: Re: Mi-Light / LimitlessLED / Applamp
Posted: Saturday 29 April 2017 18:09
by marcotrumpet
Jarn wrote:marcotrumpet wrote:Jarn wrote:Did it accidently change from "STA" mode to "AP" mode?
Only to be sure the problem wasn't. By the way it did it againg.. an hour or so after light doesn't work
Posted: Saturday 29 April 2017 18:23
by Jarn
Can you show me your settings before it occurs and after?
Posted: Saturday 29 April 2017 18:25
by marcotrumpet
Jarn wrote:Can you show me your settings before it occurs and after?
Settings in 192.168.1.xxx or in domoticz? Sure I can but I need time beacause I don't know when error occurs
Posted: Saturday 29 April 2017 18:51
by Jarn
Settings on your wifibridge
