Page 6 of 12
Re: Python Plugin: Python Plugin Manager
Posted: Monday 04 June 2018 20:41
by Derik
ycahome wrote: Monday 04 June 2018 20:39 my suggestion will re-apply your installation files even if your version is the same.
Another test you can make is to backup your database and reinstall your Domoticz.
Seems that your installation has some problems..
mmm did install last weekend a clean and new setup on a new RpiB+...
So i think.... there is something else wrong..:-)?
Posted: Monday 04 June 2018 22:13
by Derik
What version of python do i need?? in your opinion
Perhaps there is something to see?
Posted: Monday 04 June 2018 22:18
by ycahome
I think 3.4.4 is ok.
I have installed a lot of raspberry pies with domoticz and various plugins over the time. It's quite straight forward (except from raspbian stretch that requires libssl to start domoticz).
If you have reinstalled your domoticz and don't work from the very beginning, then sorry but, you are doing something wrong :roll: :cry:
Posted: Monday 04 June 2018 22:20
by Derik
ycahome wrote: Monday 04 June 2018 22:18 I think 3.4.4 is ok.
I have installed a lot of raspberry pies with domoticz and various plugins over the time. It's quite straight forward (except from raspbian jessie that requires libssl to start domoticz).
I run stretch perhaps there is something different??
How can i check or install?
Is it possible to use multiple python versions @ the same time?
Posted: Monday 04 June 2018 22:28
by ycahome
sorry I meant "stretch", the latest version not "Jessie".
Did you installed libssl in order to start Domoticz? Is it starting automatically?
Posted: Monday 04 June 2018 22:35
by Derik
ycahome wrote: Monday 04 June 2018 22:28 sorry I meant "stretch", the latest version not "Jessie".
Dear I am a bricklayer...
With a nice hobby Domoticz..
Only linux love only i cannot understand some things
I did install Domoticz with the bash script from the wiki
When you tell me what i mst do..
I do the things you ask..
The question how do i now/can i see what i install?
Posted: Monday 04 June 2018 22:51
by Derik
ycahome wrote: Monday 04 June 2018 22:18 I think 3.4.4 is ok.cry:
I run:
pi@raspberrypi:~ $ sudo apt-get install python3
Pakketlijsten worden ingelezen... Klaar
Boom van vereisten wordt opgebouwd
De statusinformatie wordt gelezen... Klaar
python3 is reeds de nieuwste versie (3.5.3-1).
Perhaps the 3.4.4 is to old?
This running on my pi:
pi@raspberrypi:~ $ python --version
Python 2.7.13
pi@raspberrypi:~ $ python3 --version
Python 3.5.3
Posted: Tuesday 05 June 2018 20:13
by IDANIT
at Domoticz check the log (Setup/Log/Status) You should see
 PluginSystem: Started, Python version '3.4.4'.
if not or different version number (3.5.5)
sudo apt-get remove python 3.5
it should did the trick
Posted: Monday 09 July 2018 18:26
by blauwebuis
Another nice theme:
http://domoticz.com/forum/viewtopic.php?f=8&t=24084
Time to dust-of the idea of letting this plugin install themes too?
Posted: Tuesday 10 July 2018 8:59
by landaisbenj
blauwebuis wrote: Monday 09 July 2018 18:26 Another nice theme:
:!: Really good idea
Posted: Sunday 12 August 2018 16:35
by Furiousz23
@ycahome: great work. Just followed the Wiki and everything works fine!
Would really love to see the Ziggo Mediabox XL plugin in the PP manager, and also the Bose Libsoundtouch (https://github.com/CharlesBlonde/libsoundtouch)
Posted: Tuesday 21 August 2018 22:11
by Gianni
get not managed to work.
Follow the wiki and my domoticz hangs after a few sec after restart.
so a fresh install of lite.
New install of domoticz
Install php;msq etc
install domoticz
Folow the wiki to install PP MAnager
remove python 3.5 and install 3.4
Go to hardware select give it a name and click add at the botom.
Restart domoticz sudo sytemctl restart ......
take a long time to restart all devices are gone,log is blanc and domoticz freeze
Made a second attempt reflashd lite and start all over
just the same problems
But now i managed to get buienradar install but again domoticz hangs but i got a log
    All
    Status
	Filter: X
2018-08-21 21:48:34.151 Active notification Subsystems: gcm, http (2/13)
2018-08-21 21:48:34.165 Starting shared server on: :::
2018-08-21 21:48:34.005 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2018-08-21 21:48:34.005 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2018-08-21 21:48:34.005 Status: Startup Path: /home/gianni/domoticz/
2018-08-21 21:48:34.145 Status: PluginSystem: Started, Python version '3.4.4'.
2018-08-21 21:48:34.153 Status: WebServer(HTTP) started on address: :: with port
2018-08-21 21:48:34.162 Status: WebServer(SSL) started on address: :: with port
2018-08-21 21:48:34.164 Status: Proxymanager started.
2018-08-21 21:48:34.165 Status: TCPServer: shared server started...
2018-08-21 21:48:34.165 Status: RxQueue: queue worker started...
2018-08-21 21:48:36.919 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-08-21 21:48:36.920 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
2018-08-21 21:48:36.920 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2018-08-21 21:48:36.921 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2018-08-21 21:48:36.921 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2018-08-21 21:48:36.921 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Burglar, Instance: 1
2018-08-21 21:48:36.922 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2018-08-21 21:48:36.923 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2018-08-21 21:48:36.924 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2018-08-21 21:48:36.924 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2018-08-21 21:48:36.925 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2018-08-21 21:48:36.925 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Access Control, Instance: 1
2018-08-21 21:48:36.925 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2018-08-21 21:48:36.165 Status: (buienradar) Started.
2018-08-21 21:48:36.166 Status: EventSystem: reset all events...
2018-08-21 21:48:36.167 Status: EventSystem: reset all device statuses...
2018-08-21 21:48:36.303 Status: Python EventSystem: Initalizing event module.
2018-08-21 21:48:36.304 Status: EventSystem: Started
2018-08-21 21:48:36.304 Status: EventSystem: Queue thread started...
2018-08-21 21:48:36.560 Status: PluginSystem: Entering work loop.
2018-08-21 21:48:36.666 Status: OpenZWave: using config in: /home/gianni/domoticz/Config/
2018-08-21 21:48:36.713 Status: OpenZWave: Starting...
2018-08-21 21:48:36.713 Status: OpenZWave: Version: 1.4-2888-g54682370-dirty
2018-08-21 21:48:36.905 Status: OpenZWave: Driver Ready
2018-08-21 21:48:45.250 Status: OpenZWave: Awake Nodes queried
it's say buienradar started but i did not find any trace of buienrader under devices
remove the plugin and everything works again.
So short
install the plugin
reboot
add hardware pp mananger and click add ad the botom
domticz restart
domoticz hangs
remove plugin
What do i wrong?
install a plugin manual works
Posted: Wednesday 19 September 2018 14:43
by Kender
Hi !!
is it normal that I have this message in the logs sometimes: "Error: Python Plugin Manager hardware (26) thread seems to have ended unexpectedly"
Thank you for the help !!
Andrea
Posted: Saturday 27 October 2018 10:01
by sylar
Kender wrote: Wednesday 19 September 2018 14:43 Hi !!
Andrea
I can see the very same error message very often in the logs:
2018-10-27 09:56:02.271 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
2018-10-27 09:56:16.276 Error: Python Plugin Manager hardware (10) thread seems to have ended unexpectedly
Everything seems to work well, but I'm wondering if this is an error we should be worried about?
Posted: Monday 29 October 2018 8:15
by misko903
what about updates of plugins?
after every restart, my RPi is telling me, that update for ebusd plugin is available. How can i update it?
Thank you,
Michal
Posted: Tuesday 30 October 2018 10:22
by misko903
plus I can't see the latest published zigbee2mqqt plugin. Is there way to update?
Posted: Tuesday 30 October 2018 13:20
by ycahome
misko903 wrote: Monday 29 October 2018 8:15 what about updates of plugins?
Thank you,
Michal
Read the very first post for usage:
"Auto Update" Options (After every change press "Update")
"All": Continuously update all plugins
"Selected":Continuously update selected plugin (You should first select desired plugin from "Domoticz Plugin" field)
"All (NotifyOnly)": Check all plugins for updates and generate notification email.
"Selected (NotifyOnly)":Check selected plugin for updates and generate notification email. (You should first select desired plugin from "Domoticz Plugin" field)
Posted: Tuesday 30 October 2018 13:23
by ycahome
misko903 wrote: Tuesday 30 October 2018 10:22 plus I can't see the latest published zigbee2mqqt plugin. Is there way to update?
zigbee2mqqt plugin just added.
In order to add plugin to PP Manager you should raise a "Pull Request" on github
TO CONTRIBUTE YOUR PLUGINS:
In order to add your plugins to PP-Manager, make a "pull request" with your lines added:
Under 'label="Domoticz Plugin"' in alphabetical order by 'label' and
Under 'self.plugindata' in alphabetical order by 'pluginText'
Posted: Saturday 03 November 2018 16:45
by dextm80
2018-11-03 16:45:10.005 Error: Python Plugin Manager hardware (13) thread seems to have ended unexpectedly
why?
Posted: Sunday 04 November 2018 20:17
by misko903
ycahome wrote: Tuesday 30 October 2018 13:23
repeated the steps to install PPManager. Now I can see zigbee2mqtt!
thanks
