Page 6 of 33
Re: Python Plugin : Broadlink RM2 V4
Posted: Wednesday 07 March 2018 18:42
by Lars65
I have just installed an Broadlink A1, and try to use this plugin.
Everything seems to be fine, except that I get no values for temp and Hum:
2018-03-07 18:40:18.991 (Livingroom Temperature) Updating device from 0:'0.0' to have values 0:'0.0'.
2018-03-07 18:40:18.997 (Broadlink) Update 0:'0.0' (Livingroom Temperature)
Anyone who knows what possibly could be wrong?
Posted: Wednesday 07 March 2018 19:20
by zak45
Lars65 wrote: Wednesday 07 March 2018 18:42
do you have selected the right type:
- Capture.JPG (11.44 KiB) Viewed 4562 times
Posted: Wednesday 07 March 2018 19:53
by Lars65
Yes, I have choosen the A1 sensor. It have found all the sensors, temp, hum, air, noice and lux. But it don't update the values.
Posted: Wednesday 07 March 2018 22:23
by Lars65
Got it working. It was needed to be set in AP mode.
Posted: Wednesday 14 March 2018 9:59
by Alcloud
Velly wrote: Tuesday 13 February 2018 14:16
Anybody with MP1 on V4 (Raspberry, Python 3.4):
are your MP1 plugs POWER STATE synced well with Domoticz?
No, actually, i have the same error..
Posted: Thursday 15 March 2018 1:12
by Legster
Hello everyone.
First off I dont know if its allowed to ask question on this topic when its allready open so delete me if I offend.
setup information:
Domoticz: 3.8975
pip --version: pip 9.0.1 from /usr/lib/python2.7/site-packages
Python 2.7 and 3.5.1 installed on NAS aswell as Python module.
manually exectuted (after following wiki it was not working so found missing items and installed):
python3.5 get-pip.py
python -m pip install pyaes
pip install pycryptodomex
python -m Cryptodome.SelfTest
My problem (and I found many with same error but not a solution for me):
I have a Synology Nas and have installed Domoticz there.
I also have a broadlink mini. But since it did not work natively i bought a Xiaomi universal remote controller. total nightmare. so back to Broadlink.
I use it alot on my phone to control led lamps but i want it intergrated so installed your awesome script!
I can add the Broadlink in Domotics now and filled in IP and MAC adres of the device.
folder to store ini /usr/local/domoticz/var/plugins/BroadlinkRM2 (all py files i put there including plugin.py as read on wiki).
so far so good.
but the item wont do anything so I check log file in NAS and see:
2018-03-12 15:40:42.872 Domoticz V3.8975 (c)2012-2018 GizMoCuz
2018-03-12 15:40:42.872 Build Hash: 63d0d07-modified, Date: 2018-02-28 08:26:48
2018-03-12 15:40:42.873 Startup Path: /usr/local/domoticz/
2018-03-12 15:40:42.910 EventSystem: reset all events...
2018-03-12 15:40:43.024 PluginSystem: Started, Python version '3.5.1'.
2018-03-12 15:40:43.034 Active notification Subsystems: pushover (1/14)
2018-03-12 15:40:43.036 WebServer(HTTP) started on address: :: with port 8084
2018-03-12 15:40:43.042 WebServer(SSL) started on address: :: with port 8443
2018-03-12 15:40:43.044 Proxymanager started.
2018-03-12 15:40:43.045 Camera: settings (re)loaded
2018-03-12 15:40:43.046 Starting shared server on: :::6144
2018-03-12 15:40:43.046 TCPServer: shared server started...
2018-03-12 15:40:43.047 RxQueue: queue worker started...
2018-03-12 15:40:45.052 ToonThermostat: Worker started...
2018-03-12 15:40:45.052 XiaomiGateway: will listen on 9898 for hardware id 3
2018-03-12 15:40:45.053 XiaomiGateway: Delaying worker startup...
2018-03-12 15:40:50.054 XiaomiGateway: Worker started...
2018-03-12 15:40:50.054 (Broadlink RM ) Started.
2018-03-12 15:40:50.054 XiaomiGateway: Using 192.168.1.114 for local IP address.
2018-03-12 15:40:50.054 EventSystem: reset all events...
2018-03-12 15:40:50.055 EventSystem: reset all device statuses...
2018-03-12 15:40:50.102 XiaomiGateway: RGB Gateway Detected
2018-03-12 15:40:50.159 Python EventSystem: Initalizing event module.
2018-03-12 15:40:50.159 EventSystem: Started
2018-03-12 15:40:50.160 EventSystem: Queue thread started...
2018-03-12 15:40:50.430 PluginSystem: Entering work loop.
2018-03-12 15:40:50.733 [1;31mError: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/BroadlinkRM2/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.[0;0m
2018-03-12 15:40:50.733 [1;31mError: (Broadlink RM ) Module Import failed, exception: 'ImportError'[0;0m
2018-03-12 15:40:50.733 [1;31mError: (Broadlink RM ) Module Import failed: ' Name: broadlink'[0;0m
2018-03-12 15:40:50.733 [1;31mError: (Broadlink RM ) Error Line details not available.[0;0m
2018-03-12 15:40:51.642 (Thermos Jorn) Thermostat (Toon)
2018-03-12 15:40:51.647 (Thermos Jorn) Temp (Temperatuur)
2018-03-12 15:40:51.648 (Thermos Jorn) P1 Smart Meter (Unknown)
2018-03-12 15:40:51.649 (Thermos Jorn) P1 Smart Meter (Unknown)
2018-03-12 15:41:52.714 Incoming connection from: 192.168.1.100
2018-03-12 15:41:52.715 (Broadlink RM ) Stop directive received.
2018-03-12 15:41:52.716 (Broadlink RM ) Stopping threads.
2018-03-12 15:41:52.716 (Broadlink RM ) Stopped.
2018-03-12 15:41:52.716 (Broadlink RM ) Started.
2018-03-12 15:41:52.937 [1;31mError: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/BroadlinkRM2/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.[0;0m
2018-03-12 15:41:52.937 [1;31mError: (Broadlink RM ) Module Import failed, exception: 'ImportError'[0;0m
2018-03-12 15:41:52.938 [1;31mError: (Broadlink RM ) Module Import failed: ' Name: broadlink'[0;0m
2018-03-12 15:41:52.938 [1;31mError: (Broadlink RM ) Error Line details not available.[0;0m
2018-03-12 15:43:00.462 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:43:30.531 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:44:00.604 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:44:30.665 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:45:00.754 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:45:30.822 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:46:00.899 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:46:30.969 [1;31mError: Broadlink RM hardware (7) thread seems to have ended unexpectedly[0;0m
2018-03-12 15:46:56.016 [1;31mError: ToonThermostat: retrieveToonState request not successful, restarting..
Posted: Thursday 22 March 2018 4:26
by JesusArmy
I am new here, so first a great thanks to zak45 for this nice Broaklink plugin!
Unfortunately I am having some problems running it on my Domoticz setup (under Windows 7).
I had some difficulty to make the plugin work, but after downgrading Python to 3.5.3 I could finally make it run and add my broadlink hardware (with last 3.6.x I could add Broaklink hardware but plugin was crashing and not adding any device as expected).
Now I have two issues:
1/ I can not use the "Learn" feature
As soon as I click the learn button, the system immediatly gave up in the same second:
2018-03-22 12:09:44.063 (BroadlinkRM2) All plugin system is on pause for 5s...
2018-03-22 12:09:44.063 (BroadlinkRM2) When Broadlink led is lit press the button on your remote within 5 seconds
2018-03-22 12:09:44.063 Error: (BroadlinkRM2) Not able to learn command
I will try to see if I can succeed in getting ini files from Android offical app and copy these to the server tonight as a workaround.
2/ Temperature is not working (RM2)
I have seen other posts saying that temp is not reliable. Anyway mine is showing always "0" in Domoticz. I have also many communication errors that might probably be related...
2018-03-22 12:10:11.214 Error: (BroadlinkRM2) Error Connecting to Broadlink device....192.168.11.31
2018-03-22 12:12:11.215 Error: (BroadlinkRM2) Error Connecting to Broadlink device....192.168.11.31
2018-03-22 12:14:11.217 Error: (BroadlinkRM2) Error Connecting to Broadlink device....192.168.11.31
2018-03-22 12:16:11.252 Error: (BroadlinkRM2) Error Connecting to Broadlink device....192.168.11.31
2018-03-22 12:18:11.253 Error: (BroadlinkRM2) Error Connecting to Broadlink device....192.168.11.31
Detection of the device itself is working. I already know IP and mac but just to see I have set discovery mode and it as properly detected everything including type of device. So I guess that communication on network side seems ok... (Windows firewall, but if the rest is going through I guess that this too should isn't it ?)
Official device is also reporting temperature normally.
Thanks for any lead that could help me solve this!
Posted: Thursday 22 March 2018 15:56
by JesusArmy
Just tried import from apps. Import feature itself is working, but triggering the action does not seem to broadcast proper IR signal...
2018-03-22 23:54:20.148 User: Admin initiated a switch command (17/BroadlinkRM2 - 7-10 Sort in order Light off/On)
2018-03-22 23:54:20.151 (BroadlinkRM2) Calling message handler 'onCommand'.
2018-03-22 23:54:20.151 (BroadlinkRM2) onCommand called for Unit 10: Parameter 'On', Level: 0 , Connected : False
2018-03-22 23:54:20.151 (BroadlinkRM2) Generate on Command for learned code stored on unit/ini :10
2018-03-22 23:54:20.153 (BroadlinkRM2) Code loaded : 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
2018-03-22 23:54:20.156 (BroadlinkRM2) Command line : "C:\Program Files (x86)\Domoticz\plugins\BroadlinkRM2\plugin_send.py" D:\Scripts\Domoticz\BroadlinkRM2/BroadlinkRM2-7-10.ini
2018-03-22 23:54:20.156 (BroadlinkRM2 - 7-10 Sort in order Light off) Updating device from 1:'On-13' to have values 1:'On-14'.
2018-03-22 23:54:20.423 (BroadlinkRM2) Update 1:'On-14' (BroadlinkRM2 - 7-10 Sort in order Light off)
2018-03-22 23:54:31.651 (BroadlinkRM2) Calling message handler 'onHeartbeat'.
Posted: Thursday 22 March 2018 16:48
by zak45
JesusArmy wrote: Thursday 22 March 2018 15:56
can you give the output of this cmd :
pip show broadlink
Posted: Thursday 22 March 2018 17:43
by JesusArmy
Is it good?
D:\>pip show broadlink
Version: 0.8
Summary: Python API for controlling Broadlink IR controllers
Home-page: http://github.com/mjg59/python-broadlink
Author: Matthew Garrett
Author-email: [email protected]
License: UNKNOWN
Location: c:\program files (x86)\python35-32\lib\site-packages
Requires: pycryptodome, PyCRC
You are using pip version 9.0.1, however version 9.0.2 is available.
You should consider upgrading via the 'python -m pip install --upgrade pip' comm
and.
Posted: Thursday 22 March 2018 17:54
by zak45
JesusArmy wrote: Thursday 22 March 2018 17:43
Is it good?
Version: 0.8
and.
Version 0.8 is the problem, this is the last one but not work as expected.
You need to do that :
pip uninstall pycryptodome
pip uninstall broadlink
download python-broadlink-master-06.zip from dropbox
unzip it somewhere
go to this folder until you find setup.py
open another cmd and go to this folder
type this command
pip install .
--> do not forget the dot '.' at the end
this should install broadlink v0.6
restart Domoticz
EDIT : all of that with admin right .. of course.
Posted: Thursday 22 March 2018 18:21
by JesusArmy
Thanks a lot for the instructions.
Uninstall went both well.
But unfortunately install has ended with an error
Not sure if it could be a path issue or something like this?
Full output here:
D:\downloads\temp\python-broadlink-master>pip install .
Processing d:\downloads\temp\python-broadlink-master
Collecting pycrypto==2.6.1 (from broadlink==0.6)
Downloading pycrypto-2.6.1.tar.gz (446kB)
100% |################################| 450kB 419kB/s
Installing collected packages: pycrypto, broadlink
Running setup.py install for pycrypto ... error
Complete output from command "c:\program files (x86)\python35-32\python.exe"
-u -c "import setuptools, tokenize;__file__='C:\\Users\\User\\AppData\\Local\\T
emp\\pip-build-n5nf_jpp\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(_
_file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file
__, 'exec'))" install --record C:\Users\User\AppData\Local\Temp\pip-v83lnfyf-rec
ord\install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build\lib.win32-3.5
creating build\lib.win32-3.5\Crypto
copying lib\Crypto\pct_warnings.py -> build\lib.win32-3.5\Crypto
copying lib\Crypto\__init__.py -> build\lib.win32-3.5\Crypto
creating build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\hashalgo.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\HMAC.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD2.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD4.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD5.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\RIPEMD.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA224.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA256.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA384.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA512.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\__init__.py -> build\lib.win32-3.5\Crypto\Hash
creating build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\AES.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\ARC2.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\ARC4.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\blockalgo.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\Blowfish.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\CAST.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\DES.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\DES3.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_OAEP.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_v1_5.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\XOR.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\__init__.py -> build\lib.win32-3.5\Crypto\Cipher
creating build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\asn1.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\Counter.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\number.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\py3compat.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\randpool.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\RFC1751.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\winrandom.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\_number_new.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\__init__.py -> build\lib.win32-3.5\Crypto\Util
creating build\lib.win32-3.5\Crypto\Random
copying lib\Crypto\Random\random.py -> build\lib.win32-3.5\Crypto\Random
copying lib\Crypto\Random\_UserFriendlyRNG.py -> build\lib.win32-3.5\Crypto\
Random
copying lib\Crypto\Random\__init__.py -> build\lib.win32-3.5\Crypto\Random
creating build\lib.win32-3.5\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaAccumulator.py -> build\lib.win32-3
copying lib\Crypto\Random\Fortuna\FortunaGenerator.py -> build\lib.win32-3.5
copying lib\Crypto\Random\Fortuna\SHAd256.py -> build\lib.win32-3.5\Crypto\R
andom\Fortuna
copying lib\Crypto\Random\Fortuna\__init__.py -> build\lib.win32-3.5\Crypto\
Random\Fortuna
creating build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\fallback.py -> build\lib.win32-3.5\Crypto\Ra
ndom\OSRNG
copying lib\Crypto\Random\OSRNG\nt.py -> build\lib.win32-3.5\Crypto\Random\O
SRNG
copying lib\Crypto\Random\OSRNG\posix.py -> build\lib.win32-3.5\Crypto\Rando
m\OSRNG
copying lib\Crypto\Random\OSRNG\rng_base.py -> build\lib.win32-3.5\Crypto\Ra
ndom\OSRNG
copying lib\Crypto\Random\OSRNG\__init__.py -> build\lib.win32-3.5\Crypto\Ra
ndom\OSRNG
creating build\lib.win32-3.5\Crypto\SelfTest
copying lib\Crypto\SelfTest\st_common.py -> build\lib.win32-3.5\Crypto\SelfT
est
copying lib\Crypto\SelfTest\__init__.py -> build\lib.win32-3.5\Crypto\SelfTe
st
creating build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\common.py -> build\lib.win32-3.5\Crypto\S
elfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_AES.py -> build\lib.win32-3.5\Crypto
\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC2.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC4.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_Blowfish.py -> build\lib.win32-3.5\C
copying lib\Crypto\SelfTest\Cipher\test_CAST.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES.py -> build\lib.win32-3.5\Crypto
\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES3.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_15.py -> build\lib.win32-3.5\C
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_oaep.py -> build\lib.win32-3.5
copying lib\Crypto\SelfTest\Cipher\test_XOR.py -> build\lib.win32-3.5\Crypto
\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\__init__.py -> build\lib.win32-3.5\Crypto
\SelfTest\Cipher
creating build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\common.py -> build\lib.win32-3.5\Crypto\Sel
fTest\Hash
copying lib\Crypto\SelfTest\Hash\test_HMAC.py -> build\lib.win32-3.5\Crypto\
SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD2.py -> build\lib.win32-3.5\Crypto\S
elfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD4.py -> build\lib.win32-3.5\Crypto\S
elfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD5.py -> build\lib.win32-3.5\Crypto\S
elfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_RIPEMD.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA.py -> build\lib.win32-3.5\Crypto\S
elfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA224.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA256.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA384.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA512.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\__init__.py -> build\lib.win32-3.5\Crypto\S
elfTest\Hash
creating build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_AllOrNothing.py -> build\lib.win32
copying lib\Crypto\SelfTest\Protocol\test_chaffing.py -> build\lib.win32-3.5
copying lib\Crypto\SelfTest\Protocol\test_KDF.py -> build\lib.win32-3.5\Cryp
copying lib\Crypto\SelfTest\Protocol\test_rfc1751.py -> build\lib.win32-3.5\
copying lib\Crypto\SelfTest\Protocol\__init__.py -> build\lib.win32-3.5\Cryp
creating build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_DSA.py -> build\lib.win32-3.5\Cry
copying lib\Crypto\SelfTest\PublicKey\test_ElGamal.py -> build\lib.win32-3.5
copying lib\Crypto\SelfTest\PublicKey\test_importKey.py -> build\lib.win32-3
copying lib\Crypto\SelfTest\PublicKey\test_RSA.py -> build\lib.win32-3.5\Cry
copying lib\Crypto\SelfTest\PublicKey\__init__.py -> build\lib.win32-3.5\Cry
creating build\lib.win32-3.5\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_random.py -> build\lib.win32-3.5\Cry
pto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_rpoolcompat.py -> build\lib.win32-3.
copying lib\Crypto\SelfTest\Random\test__UserFriendlyRNG.py -> build\lib.win
copying lib\Crypto\SelfTest\Random\__init__.py -> build\lib.win32-3.5\Crypto
\SelfTest\Random
creating build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaAccumulator.py -> bui
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaGenerator.py -> build
copying lib\Crypto\SelfTest\Random\Fortuna\test_SHAd256.py -> build\lib.win3
copying lib\Crypto\SelfTest\Random\Fortuna\__init__.py -> build\lib.win32-3.
creating build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_fallback.py -> build\lib.win32
copying lib\Crypto\SelfTest\Random\OSRNG\test_generic.py -> build\lib.win32-
copying lib\Crypto\SelfTest\Random\OSRNG\test_nt.py -> build\lib.win32-3.5\C
copying lib\Crypto\SelfTest\Random\OSRNG\test_posix.py -> build\lib.win32-3.
copying lib\Crypto\SelfTest\Random\OSRNG\test_winrandom.py -> build\lib.win3
copying lib\Crypto\SelfTest\Random\OSRNG\__init__.py -> build\lib.win32-3.5\
creating build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_asn1.py -> build\lib.win32-3.5\Crypto\
SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_Counter.py -> build\lib.win32-3.5\Cryp
to\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_number.py -> build\lib.win32-3.5\Crypt
o\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_winrandom.py -> build\lib.win32-3.5\Cr
ypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\__init__.py -> build\lib.win32-3.5\Crypto\S
elfTest\Util
creating build\lib.win32-3.5\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_15.py -> build\lib.win32-3.
copying lib\Crypto\SelfTest\Signature\test_pkcs1_pss.py -> build\lib.win32-3
copying lib\Crypto\SelfTest\Signature\__init__.py -> build\lib.win32-3.5\Cry
creating build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\AllOrNothing.py -> build\lib.win32-3.5\Crypto\Pr
otocol
copying lib\Crypto\Protocol\Chaffing.py -> build\lib.win32-3.5\Crypto\Protoc
ol
copying lib\Crypto\Protocol\KDF.py -> build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\__init__.py -> build\lib.win32-3.5\Crypto\Protoc
ol
creating build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\DSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\ElGamal.py -> build\lib.win32-3.5\Crypto\Public
Key
copying lib\Crypto\PublicKey\pubkey.py -> build\lib.win32-3.5\Crypto\PublicK
ey
copying lib\Crypto\PublicKey\RSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_DSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_RSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_slowmath.py -> build\lib.win32-3.5\Crypto\Publ
icKey
copying lib\Crypto\PublicKey\__init__.py -> build\lib.win32-3.5\Crypto\Publi
cKey
creating build\lib.win32-3.5\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_PSS.py -> build\lib.win32-3.5\Crypto\Sign
ature
copying lib\Crypto\Signature\PKCS1_v1_5.py -> build\lib.win32-3.5\Crypto\Sig
nature
copying lib\Crypto\Signature\__init__.py -> build\lib.win32-3.5\Crypto\Signa
ture
Skipping optional fixer: buffer
Skipping optional fixer: idioms
Skipping optional fixer: set_literal
Skipping optional fixer: ws_comma
running build_ext
warning: GMP or MPIR library not found; Not building Crypto.PublicKey._fastm
ath.
building 'Crypto.Random.OSRNG.winrandom' extension
error: Microsoft Visual C++ 14.0 is required. Get it with "Microsoft Visual
C++ Build Tools": http://landinghub.visualstudio.com/visual-cpp-build-tools
Command ""c:\program files (x86)\python35-32\python.exe" -u -c "import setuptool
s, tokenize;__file__='C:\\Users\\User\\AppData\\Local\\Temp\\pip-build-n5nf_jpp\
\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().r
eplace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --
record C:\Users\User\AppData\Local\Temp\pip-v83lnfyf-record\install-record.txt -
-single-version-externally-managed --compile" failed with error code 1 in C:\Use
rs\User\AppData\Local\Temp\pip-build-n5nf_jpp\pycrypto\
and.
I guess problem is in one of these errors/warning?
ath.
But should I really need to install VC++ 14.0 ? Broadlink 0.8 did installed properly like this... Or should I upgrade Python version ? I did downgrade from 3.6.4 to 3.5.3 to make the plugin works yesterday...
Posted: Thursday 22 March 2018 18:55
by zak45
JesusArmy wrote: Thursday 22 March 2018 18:21
C++ Build Tools":
http://landinghub.visualstudio.com/visu ... uild-tools
ath.[/code]
You do not need VC++ and you need to stay on python 3.5
Just download pycrypto-2.6.1-cp35-none-win32.whl from dropbox and type this command:
pip install pycrypto-2.6.1-cp35-none-win32.whl
after, you need to go to D:\downloads\temp\python-broadlink-master>
and type
pip install .
Posted: Thursday 22 March 2018 23:27
by JeremyM
Hello Everyone !
I am currently trying to install the broadlink plugin with no success ! I always have the same issue
Using the beta version 3.9052
2018-03-22 23:08:12.573 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Broadlink/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-03-22 23:08:12.573 Error: (TV Controller) Module Import failed, exception: 'ImportError'
Anyone has manage this problem ? I tried to find something on the forum but the answer is no clear regarding this Wrong Python Path.
Thanks for you help
Posted: Friday 23 March 2018 3:39
by JesusArmy
zak45 wrote: Thursday 22 March 2018 18:55
and type
pip install .
Wonderfull, big big thanks! It went well and I am almost sure that it is working now!
I am actually doing that remotely so I cannot confirm the actions but I do not have anymore communication errors in the logs, and temperature is reported correctly now! So it's a good sign, if think the rest should follow and be ok.
The day you stop supporting the plugin we are doomed.
Thanks again for the great plugin and support!
Posted: Saturday 24 March 2018 21:01
by JeremyM
JeremyM wrote: Thursday 22 March 2018 23:27
Hello Everyone !
Thanks for you help
Up ! Anyone can help me ?
