It could be a regression, what version of the plugin are you using? Could you post the content of http://IPOfEbusD:8889/data?def ?
Python Plugin: ebusd
Barberousse
Re: Python Plugin: ebusd
Barberousse
I think I see where the problem is, I can't access my github account right now, but you can replaceBarberousse wrote: Thursday 24 January 2019 10:30It could be a regression, what version of the plugin are you using? Could you post the content of http://IPOfEbusD:8889/data?def ?
if bWritable:
#sTypeName = "Selector Switch"
iMainType = 0xF4
iSubtype = 0x3E
if bWritable:
iSwitchtype = 18
iMainType = 0xF4
iSubtype = 0x3E
Gertschi
- Domoticz version: 2020.2
thanks for your answer!
This is my Version of the ebus deamon:
"version": "3.3.v3.3-10-gfa434e5",
Thit is from http://IPOfEbusD:8889/data?def ?: So I got it to work now!!! I do the upgrade in the plugin.py as you said. Thanks a lot!!
It wasn´t as easy as you would think, because I used the PPM for the ebusd bridge, so I couldn´t find the plugin.py. Now I installed the plugin manually, with the result that I have to fill in 2 entries in the plugin. But it works.
- plugin.JPG (48.78 KiB) Viewed 2908 times
Barberousse
You shouldn't have twice entries! Probably an interaction problem with PPM. I will integrate the correction in next version, in a few days.Gertschi wrote: Thursday 24 January 2019 15:48 It wasn´t as easy as you would think, because I used the PPM for the ebusd bridge, so I couldn´t find the plugin.py. Now I installed the plugin manually, with the result that I have to fill in 2 entries in the plugin. But it works.![]()
Gertschi
Thank you for this great work and for your help!!
Barberousse
I had some spare time this evening, the correction is integrated in version 1.3.7 of the plugin.
Gertschi
Thank you for this!!! I updated now to the new version 1.3.7.Barberousse wrote: Thursday 24 January 2019 21:03I had some spare time this evening, the correction is integrated in version 1.3.7 of the plugin.
But with no success: The 2 inputfields was still there.
Now I deleted the PP-MANAGER plugin and the ebusd plugin installed from the PP-M plugin. Then I also deleted the DomoticzEbusd plugin, and restarted Domoticz.
cd domoticz/plugins
sudo rm -r PP-MANAGER
sudo rm -r ebusd
sudo systemctl restart domoticz.serviceI dont installed the PP-MANAGER again , because I only used it to test some plugins.
Now it works pretty good for me!
hanskenpensken
- Target OS: -
Goodmorning all,
First and foremost. Congratz with this plugin.
I have a question. As the plugin seems to be unable to read certain values. Especially the z1roomtemp would come in handy
What seems strange to me is that the http output of ebusd gives me (via http://192.168.0.1xx:8889/data/
which is very similar to z1NightTemp in terms of fields, and that one IS getting read by the plugin
Any ideas?
2019-02-02 08:18:03.616 (Heating) Device Heating - 700:z1nighttemp - tempv unit 27 and deviceid 700:z1nighttemp detected: night setpoint for zone 1
2019-02-02 08:18:03.617 (Heating) Device Heating - bai:waterpressure - press unit 28 and deviceid bai:waterpressure detected: Wasserdruck
2019-02-02 08:18:03.597 Error: (Heating) Device 700:hwcflowtemp is declared as ignore type in ebusd configuration
2019-02-02 08:18:03.598 Error: (Heating) Device 700:hcstoragetempbottom is declared as ignore type in ebusd configuration
2019-02-02 08:18:03.598 Error: (Heating) Device 700:hcstoragetemptop is declared as ignore type in ebusd configuration
2019-02-02 08:18:03.599 Error: (Heating) Device 700:hc1actualflowtempdesired is declared as ignore type in ebusd configuration
2019-02-02 08:18:03.600 Error: (Heating) Device 700:displayedoutsidetemp is declared as ignore type in ebusd configuration
2019-02-02 08:18:03.601 Error: (Heating) Device 700:z1roomtemp is declared as ignore type in ebusd configuration
2019-02-02 08:18:03.601 Error: (Heating) Device 700:hc1flowtemp is declared as ignore type in ebusd configuration
2019-02-02 08:18:03.609 Error: (Heating) Device 700:systemflowtemp is declared as ignore type in ebusd configuration
2019-02-02 08:18:03.612 Error: (Heating) Device 700:waterpressure is declared as ignore type in ebusd configurationCode: Select all
"z1RoomTemp": {
"name": "z1RoomTemp",
"passive": false,
"write": false,
"lastup": 1549093848,
"zz": 21,
"fields": {
"tempv": {"value": 19.1875}
}Code: Select all
"z1NightTemp": {
"name": "z1NightTemp",
"passive": false,
"write": false,
"lastup": 1549093958,
"zz": 21,
"fields": {
"tempv": {"value": 17}
Barberousse
What do you get with http://ipofebusd:8889/data?def&write ?
hanskenpensken
- Target OS: -
At first i didn't get a value for z1RoomTemp.
Which i found strange, so i put the bashcommand "ebusctl read z1RoomTemp" out, resulted in a " ERR: CRC Error."
However, then, i tried again, and got a useful result (18.8125)
So finally,
z1RoomTemp": {
"passive": false,
"write": false,
"lastup": 1549287748,
"zz": 21,
"id": [181, 36, 2, 0, 3, 0, 15, 0],
"fields": {
"tempv": {"value": 18.8125}
"fielddefs": [
{ "name": "", "slave": true, "type": "IGN", "isbits": false, "length": 4, "unit": "", "comment": ""},
{ "name": "tempv", "slave": true, "type": "EXP", "isbits": false, "length": 4, "unit": "°C", "comment": "aktuelle Raumtemperatur in Zone 1"}
"z1NightTemp": {
"passive": false,
"write": false,
"lastup": 1549287371,
"zz": 21,
"id": [181, 36, 2, 0, 3, 0, 9, 0],
"fields": {
"fielddefs": [
{ "name": "tempv", "slave": true, "type": "EXP", "isbits": false, "length": 4, "unit": "°C", "comment": "night setpoint for zone 1"}
},[/code]
So finally,
z1RoomTemp": {
"passive": false,
"write": false,
"zz": 21,
"fields": {
"fielddefs": [
"z1NightTemp": {
"passive": false,
"write": false,
"zz": 21,
"fields": {
"fielddefs": [
},[/code]
Barberousse
You should specify 700:z1RoomTemp:tempv in plugin configuration, or 700:z1RoomTemp:1 to ignore field 0. I will try to not count useless fields for fields index in a future release, so 700:z1RoomTemp:1 will not work anymore (but 700:z1RoomTemp:0 or 700:z1RoomTemp will), 700:z1RoomTemp:tempv should work in any cases.
hanskenpensken
- Target OS: -
Thank you for the specification!
Barberousse
What surprises me now is that your z1NightTemp works...
Barberousse
Do you have a z1NightTemp-w in your http://ipofebusd:8889/data?def&write output? It would explain the difference.
Barberousse
Version 1.3.8 should make configuration easier: IGN fielddefs (meaning useless fields) are ignored automatically for index counting and name searching, for instance with this:
700:z1RoomTemp, 700:z1RoomTemp:0 and 700:z1RoomTemp:tempv will bring the Zone 1 temperature.
Or
bai:SetMode:4 and bai:SetMode:disablehc will bring the same registers.
z1RoomTemp": {
"passive": false,
"write": false,
"zz": 21,
"fields": {
"fielddefs": [
Or
"SetMode": {
"name": "SetMode",
"passive": true,
"write": true,
"lastup": 1549308254,
"zz": 8,
"id": [181, 16, 0],
"fields": {
"hcmode": {"value": "auto"},
"flowtempdesired": {"value": 60.5},
"hwctempdesired": {"value": 55.0},
"hwcflowtempdesired": {"value": null},
"disablehc": {"value": 0},
"disablehwctapping": {"value": 0},
"disablehwcload": {"value": 0},
"remoteControlHcPump": {"value": 0},
"releaseBackup": {"value": 0},
"releaseCooling": {"value": 0}
"fielddefs": [
{ "name": "hcmode", "slave": false, "type": "UCH", "isbits": false, "length": 1, "values": { "0": "auto", "1": "off", "2": "water" }, "unit": "", "comment": "Boiler Modus"},
{ "name": "flowtempdesired", "slave": false, "type": "D1C", "isbits": false, "length": 1, "unit": "°C", "comment": "Temperatur"},
{ "name": "hwctempdesired", "slave": false, "type": "D1C", "isbits": false, "length": 1, "unit": "°C", "comment": "Temperatur"},
{ "name": "hwcflowtempdesired", "slave": false, "type": "UCH", "isbits": false, "length": 1, "unit": "°C", "comment": "Temperatur"},
{ "name": "", "slave": false, "type": "IGN", "isbits": false, "length": 1, "unit": "", "comment": ""},
{ "name": "disablehc", "slave": false, "type": "BI0", "isbits": true, "length": 1, "unit": "", "comment": ""},
{ "name": "disablehwctapping", "slave": false, "type": "BI1", "isbits": true, "length": 1, "unit": "", "comment": ""},
{ "name": "disablehwcload", "slave": false, "type": "BI2", "isbits": true, "length": 1, "unit": "", "comment": ""},
{ "name": "remoteControlHcPump", "slave": false, "type": "BI0", "isbits": true, "length": 1, "unit": "", "comment": ""},
{ "name": "releaseBackup", "slave": false, "type": "BI1", "isbits": true, "length": 1, "unit": "", "comment": ""},
{ "name": "releaseCooling", "slave": false, "type": "BI2", "isbits": true, "length": 1, "unit": "", "comment": ""}
Piacco
Hello, thank you for this great plugin
I'm looking for the temperature of my roomthermostat but i can't find it, do you no what i doing wrong
I have included the content of http://IPOfEbusD:8889/data?def ?
- Ebusd.txt
- (32.41 KiB) Downloaded 100 times
Barberousse
Hi,Piacco wrote: Thursday 07 February 2019 17:44 Hello, thank you for this great plugin![]()
I'm looking for the temperature of my roomthermostat but i can't find it, do you no what i doing wrong![]()
What are your hardware models (boiler, remote control, mixing circuit, etc)? Could you send your data definition in a more complete format (keeping json separators) ? It is not easy to read as text only format without indentation.
Jumper3126
Ok, this was a stupid remark
Sorry
Sorry
Last edited by Jumper3126 on Wednesday 20 February 2019 21:15, edited 1 time in total.
fantom
First is not plugin to domoticz. This is full daemon for eBus
Fantom
Fantom
Piacco
I find out that there are no configuration files available for my hardware.
I have a controler wich is an examaster SBX00 and my roomthermostat is a exacontrol E7C00 (the configuration file for de wirelles version E7f unfortunately didn't work
version: ebusd 3.3.v3.3
signal: acquired
symbol rate: 23
max symbol rate: 113
min arbitration micros: 1147
max arbitration micros: 3566
min symbol latency: 5
max symbol latency: 6
reconnects: 0
masters: 4
conditional: 0
poll: 0
update: 9
address 03: master #11
address 08: slave #11, scanned "MF=Vaillant;ID=HMU01;SW=0302;HW=8802", loaded "vaillant/08.hmu.csv"
address 10: master #2
address 15: slave #2, scanned "MF=Vaillant;ID=SBX00;SW=0326;HW=4802"
address 30: master #3
address 31: master #8, ebusd
address 35: slave #3, scanned "MF=Vaillant;ID=E7C00;SW=0206;HW=7402"
address 36: slave #8, ebusd
address e8: slave, scanned "MF=Vaillant;ID=FMU00;SW=0202;HW=6502"
"scan.35": {
"messages": {
"name": "",
"passive": false,
"write": false,
"lastup": 1550913272,
"zz": 53,
"id": [7, 4],
"fields": {
"MF": {"value": "Vaillant"},
"ID": {"value": "E7C00"},
"SW": {"value": "0206"},
"HW": {"value": "7402"}
"fielddefs": [
{ "name": "MF", "slave": true, "type": "UCH", "isbits": false, "length": 1, "values": { "6": "Dungs", "15": "FH Ostfalia", "16": "TEM", "17": "Lamberti", "20": "CEB", "21": "Landis-Staefa", "22": "FERRO", "23": "MONDIAL", "24": "Wikon", "25": "Wolf", "32": "RAWE", "48": "Satronic", "64": "ENCON", "80": "Kromschroeder", "96": "Eberle", "101": "EBV", "117": "Graesslin", "133": "ebm-papst", "149": "SIG", "165": "Theben", "167": "Thermowatt", "181": "Vaillant", "192": "Toby", "197": "Weishaupt", "253": "ebusd.eu" }, "unit": "", "comment": ""},
{ "name": "ID", "slave": true, "type": "STR", "isbits": false, "length": 5, "unit": "", "comment": ""},
{ "name": "SW", "slave": true, "type": "PIN", "isbits": false, "length": 2, "unit": "", "comment": ""},
{ "name": "HW", "slave": true, "type": "PIN", "isbits": false, "length": 2, "unit": "", "comment": ""}
"id": {
"name": "id",
"passive": false,
"write": false,
"lastup": 1550913273,
"zz": 53,
"id": [181, 9],
"fields": {
"prefix": {"value": "21"},
"year": {"value": "14"},
"week": {"value": "16"},
"product": {"value": "0020118080"},
"supplier": {"value": "0082"},
"counter": {"value": "005471"},
"suffix": {"value": "N1"}
"fielddefs": [
{ "name": "", "slave": true, "type": "IGN", "isbits": false, "length": 1, "unit": "", "comment": ""},
{ "name": "prefix", "slave": true, "type": "STR", "isbits": false, "length": 2, "unit": "", "comment": ""},
{ "name": "year", "slave": true, "type": "STR", "isbits": false, "length": 2, "unit": "", "comment": ""},
{ "name": "week", "slave": true, "type": "STR", "isbits": false, "length": 2, "unit": "", "comment": ""},
{ "name": "product", "slave": true, "type": "STR", "isbits": false, "length": 10, "unit": "", "comment": ""},
{ "name": "supplier", "slave": true, "type": "STR", "isbits": false, "length": 4, "unit": "", "comment": ""},
{ "name": "counter", "slave": true, "type": "STR", "isbits": false, "length": 6, "unit": "", "comment": ""},
{ "name": "suffix", "slave": true, "type": "STR", "isbits": false, "length": 2, "unit": "", "comment": ""}
},Who is online
