Page 6 of 9
Re: Python Plugin: Life 360 Presence Detection
Posted: Wednesday 30 January 2019 12:42
by EddyG
It would be nice that some Internet errors where catched.
Like a http 502 error and some more, because those have followup errors like:
2019-01-29 23:59:30.345 (Life 360) Life360 HTTPError code: 502
2019-01-29 23:59:30.346 (Life 360) No Token Received; Please Check Life360 Username and Password
2019-01-29 23:59:30.347 (Life 360) Error Authenticating Life360 or Connection Problem...
2019-01-29 23:59:30.347 (Life 360) Please Use Correct Credentials and Restart The Plugin!!!
or
2019-01-29 23:51:20.080 (Life 360) Life360 HTTPError code: 502
2019-01-29 23:51:20.081 Error: (Life 360) 'onHeartbeat' failed 'TypeError':'string indices must be integers'.
2019-01-29 23:51:20.082 Error: (Life 360) ----> Line 291 in '/home/pi/domoticz/plugins/DomoticzLife360/plugin.py', ...
2019-01-29 23:51:20.082 Error: (Life 360) ----> Line 188 in '/home/pi/domoticz/plugins/DomoticzLife360/plugin.py', ...
It looks that those errors make the plugin less stable and eventually make the plugin crash
Posted: Sunday 03 February 2019 17:28
by georon
First: thanks for the effort in creating this plugin
Installed current version today from GitHub.
Enabled debug.
The logs show the creation of the devices, without errors.
No devices show up though.
Every run there is a new entry of device creation.
Plugin v2.2.0
Domoticz v4.10078
Python Version: 3.5.3
Posted: Sunday 03 February 2019 17:54
by febalci
Pls stop the plugin, delete deviceorder.txt from plugin directory and start plugin again. See if this makes any difference...
Posted: Sunday 03 February 2019 18:23
by georon
Removing this file did not result in the devices being created.
Log extract:
2019-02-03 18:05:57.947 (Life360) Member Count = 2
2019-02-03 18:05:57.947 (Life360) Creating device 'Ron Presence'.
2019-02-03 18:05:57.948 (Life360) Creating device 'Ron Location'.
2019-02-03 18:05:57.948 (Life360) Creating device 'Ron Battery'.
2019-02-03 18:05:57.948 (Life360) Creating device 'Ron Distance'.
2019-02-03 18:05:57.948 (Life360) Creating device 'Bianca Presence'.
2019-02-03 18:05:57.949 (Life360) Creating device 'Bianca Location'.
2019-02-03 18:05:57.949 (Life360) Creating device 'Bianca Battery'.
2019-02-03 18:05:57.949 (Life360) Creating device 'Bianca Distance'.
2019-02-03 18:05:57.949 (Life360) ['Ron', 'Bianca']
2019-02-03 18:05:57.951 (Life360) Devices created.
2019-02-03 18:05:57.951 (Life360) 'Mode6':'Debug'
2019-02-03 18:05:57.951 (Life360) 'HardwareID':'10'
2019-02-03 18:05:57.951 (Life360) 'Name':'Life360'
2019-02-03 18:05:57.951 (Life360) 'Password':'*******'
2019-02-03 18:05:57.951 (Life360) 'DomoticzHash':'*********'
2019-02-03 18:05:57.952 (Life360) 'Key':'Life360'
2019-02-03 18:05:57.952 (Life360) 'Username':'[email protected]'
2019-02-03 18:05:57.952 (Life360) 'Author':'febalci'
2019-02-03 18:05:57.952 (Life360) 'Mode4':'TM'
2019-02-03 18:05:57.952 (Life360) 'DomoticzBuildTime':'2018-10-18 08:54:38'
2019-02-03 18:05:57.953 (Life360) 'Version':'2.2.0'
2019-02-03 18:05:57.953 (Life360) 'Port':'0'
2019-02-03 18:05:57.953 (Life360) 'Mode2':'8'
2019-02-03 18:05:57.953 (Life360) 'HomeFolder':'/usr/local/share/domoticz/plugins/Life360/'
2019-02-03 18:05:57.953 (Life360) 'DomoticzVersion':'4.10078'
2019-02-03 18:05:57.953 (Life360) 'Mode3':'********************************'
2019-02-03 18:05:57.954 (Life360) Device count: 0
2019-02-03 18:05:57.954 (Life360) Pushing 'PollIntervalDirective' on to queue
2019-02-03 18:05:57.954 (Life360) Processing 'PollIntervalDirective' message
2019-02-03 18:05:57.954 (Life360) Heartbeat interval set to: 10.
I have tried replacing the plugin by an earlier release.
That does not change things either...
Am I missing something stupid???
Posted: Sunday 03 February 2019 18:27
by georon
georon wrote: Sunday 03 February 2019 18:23
Yes I was!
Check in the system settings if new hardware devices are allowed...
Allowed it, restarted plugin.
Great! There they are!
Posted: Sunday 03 February 2019 19:29
by febalci
georon wrote: Sunday 03 February 2019 18:27
Yes I was!
I could have never guessed
Good job...
Posted: Wednesday 13 February 2019 15:28
by sach
Plugin works Great....Thank you.
I use Life 360 to make sure my son makes it into school and back OK.
I notice that the Location is shown as 'Home' when he is home, but is there a way it can be displayed as School when he is at school instead of the address?
This works fine when in the App itself. I have a number of locations setup and it doesn't appear to show the tagged location in Domoticz.
Thanks in advance.
Sach
Posted: Wednesday 13 February 2019 16:05
by Minglarn
Hi!
Love the plugin... However... my phyton knowlege is kinda zero..
How do I trunc the text to just contain the first sentence before the first "," ...
I just want the "Sicklatunneln" ... the rest is just to much info
- 0.JPG (18.39 KiB) Viewed 5104 times
Posted: Wednesday 13 February 2019 16:58
by febalci
Minglarn wrote: Wednesday 13 February 2019 16:05
Hi!
Looks easy. Open the plugin.py in a text editor go to:
Line 212:
Under
currentstat2, currentloc = a.getaddress(self.tomtomapikey,self.circleLatitude,self.circleLongitude)
add:
currentloc = currentloc.split(',',1)[0]
and the same on line 217. This assumes all your addresses are in the format like xxxx, xxxx, xxxx, xxxx and so theis command gets the first text before the first comma. Also these added lines should start on the same column with their previus lines and you should go there by pressing space bar, not tab... Like:
if self.tomtomapikey != 'Empty':
currentstat, currentmin = a.getdistance(self.tomtomapikey,self.circleLatitude,self.circleLongitude,self.myHomelat,self.myHomelon)
Posted: Wednesday 13 February 2019 17:05
by febalci
sach wrote: Wednesday 13 February 2019 15:28
Thanks in advance.
Sach
Try deleting line 230 on plugin.py. So, instead of:
if self.selectedMap == "TM":
else:
should be:
else:
Don't know why i added that line there, should have a reason which i don't remember now
This will only work if your locations are defined in Life360 app.
Posted: Thursday 14 February 2019 14:39
by febalci
UPDATE 2.3.0
Since Life360 won't allow to name your frequent use locations without paying for subscription, i added this to the plugin.
Create a location.txt file in your Life360 plugin folder. The first line should always be the following:
Then, each line should represent one location as in header line:
Name,Latitude,Longitude,Radius
Work,10.123456,20.543210,250
School,XX.XXXXXX,XX.XXXXX,100
Mall,XX.XXXXX,XX.XXXX,900
John's House,XX.XXXXX,XX.XXXXX,150
The name as you would like to appear on Location Device,Latitude,Longitude,Radius in meters for the fence
As in Radius, the plugin will accept you as you are in that location if your current distance to the given lat,lon is within this much meters.
Please inform me of any bugs. Enjoy...
Posted: Thursday 14 February 2019 15:00
by sach
febalci wrote: Wednesday 13 February 2019 17:05
Thanks in advance.
Sach
else:
should be:
else:
Thanks this worked a treat.
Posted: Friday 22 February 2019 14:25
by febalci
IMPORTANT!!!
It seems that the Tomtom API returns a string instead of integer on some certain conditions (When the API page is not 200), and that causes the plugin thread to end unexpectedly together with all other python plugins. You can update to 2.3.1 from git page to handle this problem (Hopefully).
Posted: Saturday 23 February 2019 15:31
by EddyG
Sorry to say, but I still have the same errors:
2019-02-21 21:38:48.717 Error: Life 360 hardware (32) thread seems to have ended unexpectedly
2019-02-21 21:38:48.718 Error: Zigbee hardware (33) thread seems to have ended unexpectedly
2019-02-21 21:39:02.727 Error: Life 360 hardware (32) thread seems to have ended unexpectedly
2019-02-21 21:39:02.727 Error: Zigbee hardware (33) thread seems to have ended unexpectedly
2019-02-21 21:39:16.730 Error: Life 360 hardware (32) thread seems to have ended unexpectedly
2019-02-21 21:39:16.730 Error: Zigbee hardware (33) thread seems to have ended unexpectedly
2019-02-21 21:39:30.733 Error: Life 360 hardware (32) thread seems to have ended unexpectedly
2019-02-21 21:39:30.734 Error: Zigbee hardware (33) thread seems to have ended unexpectedly
2019-02-21 21:39:44.740 Error: Life 360 hardware (32) thread seems to have ended unexpectedly
2019-02-21 21:39:44.740 Error: Zigbee hardware (33) thread seems to have ended unexpectedly
2019-02-21 21:40:00.872 Error: dzVents: Info: getErrorLoging: Threaderror(s) found:
2019-02-21 21:40:00.872 2019-02-21 21:39:44.740 Error: Zigbee hardware (33) thread seems to have ended unexpectedly
2019-02-21 21:40:00.872 2019-02-21 21:39:44.740 Error: Life 360 hardware (32) thread seems to have ended unexpectedly
2019-02-21 21:40:00.872 2019-02-21 21:39:30.734 Error: Zigbee hardware (33) thread seems to have ended unexpectedly
2019-02-21 21:40:00.872 2019-02-21 21:39:30.733 Error: Life 360 hardware (32) thread seems to have ended unexpectedly
2019-02-21 21:40:00.872 2019-02-21 21:39:16.730 Error: Zigbee hardware (33) thread seems to have ended unexpectedly
2019-02-21 21:40:00.872 2019-02-21 21:39:16.730 Error: Life 360 hardware (32) thread seems to have ended unexpectedly
2019-02-21 21:40:00.872 2019-02-21 21:39:02.727 Error: Zigbee hardware (33) thread seems to have ended unexpectedly
2019-02-21 21:40:00.872 2019-02-21 21:39:02.727 Error: Life 360 hardware (32) thread seems to have ended unexpectedly
2019-02-21 21:40:00.872 2019-02-21 21:38:48.718 Error: Zigbee hardware (33) thread seems to have ended unexpectedly
2019-02-21 21:40:00.872 2019-02-21 21:38:48.717 Error: Life 360 hardware (32) thread seems to have ended unexpectedly
Posted: Saturday 23 February 2019 15:39
by febalci
EddyG wrote: Saturday 23 February 2019 15:31
Dear Eddy, i need the cause of the error; So:
1. Domoticz version?
1.5 Python version?
2. Are you using Tomtom Api?
3. How many people in your circle?
4. What is the poll period in mins of the life360 plugin?
5. There should be a Python error most probably at the beginning of the thread errors; you can find it looking at your domoticz.log file. That will give a more precise idea.
For debug purposes, you can disable life360 plugin and check if other plugins are causing the issue...
Thanks...
Posted: Saturday 23 February 2019 16:31
by EddyG
1. 4.10427
1.5 3.5.3
2. Yes
3. 2 people
4. 2 minutes
5. Sorry there is no Python error
I will disable the life360 plugin and keep the zigbee running
Let see what happens next.
Posted: Saturday 23 February 2019 17:14
by capman
Also still this errors in my log
Domoticz beta 4.10447 / Python V3.5.3 / 2 people / poll 2
- Spoiler: show
- 2019-02-23 17:00:52.857 Error: (Life 360) 'onHeartbeat' failed 'timeout'.
2019-02-23 17:00:52.857 Error: (Life 360) ----> Line 294 in '/home/domoticz/plugins/DomoticzLife360/plugin.py', function onHeartbeat
2019-02-23 17:00:52.857 Error: (Life 360) ----> Line 167 in '/home/domoticz/plugins/DomoticzLife360/plugin.py', function onHeartbeat
2019-02-23 17:00:52.857 Error: (Life 360) ----> Line 51 in '/home/domoticz/plugins/DomoticzLife360/life360.py', function authenticate
2019-02-23 17:00:52.857 Error: (Life 360) ----> Line 38 in '/home/domoticz/plugins/DomoticzLife360/life360.py', function make_request
2019-02-23 17:00:52.857 Error: (Life 360) ----> Line 163 in '/usr/lib/python3.5/urllib/request.py', function urlopen
2019-02-23 17:00:52.857 Error: (Life 360) ----> Line 466 in '/usr/lib/python3.5/urllib/request.py', function open
2019-02-23 17:00:52.857 Error: (Life 360) ----> Line 484 in '/usr/lib/python3.5/urllib/request.py', function _open
2019-02-23 17:00:52.857 Error: (Life 360) ----> Line 444 in '/usr/lib/python3.5/urllib/request.py', function _call_chain
2019-02-23 17:00:52.857 Error: (Life 360) ----> Line 1297 in '/usr/lib/python3.5/urllib/request.py', function https_open
2019-02-23 17:00:52.857 Error: (Life 360) ----> Line 1260 in '/usr/lib/python3.5/urllib/request.py', function do_open
2019-02-23 17:00:52.858 Error: (Life 360) ----> Line 1215 in '/usr/lib/python3.5/http/client.py', function getresponse
2019-02-23 17:00:52.858 Error: (Life 360) ----> Line 297 in '/usr/lib/python3.5/http/client.py', function begin
2019-02-23 17:00:52.858 Error: (Life 360) ----> Line 258 in '/usr/lib/python3.5/http/client.py', function _read_status
2019-02-23 17:00:52.858 Error: (Life 360) ----> Line 579 in '/usr/lib/python3.5/socket.py', function readinto
2019-02-23 17:00:52.858 Error: (Life 360) ----> Line 937 in '/usr/lib/python3.5/ssl.py', function recv_into
2019-02-23 17:00:52.858 Error: (Life 360) ----> Line 807 in '/usr/lib/python3.5/ssl.py', function read
2019-02-23 17:00:52.858 Error: (Life 360) ----> Line 583 in '/usr/lib/python3.5/ssl.py', function
I try to find out of it is a python issue or maybe 'onheartbeat'.
- Spoiler: show
- 2019-02-23 17:06:54.425 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:06:57.275 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:06:57.275 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:06:57.275 (Life 360) onHeartBeat called:0/12
2019-02-23 17:07:07.279 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:07:10.151 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:07:10.151 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:07:10.151 (Life 360) onHeartBeat called:1/12
2019-02-23 17:07:19.653 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:07:22.487 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:07:22.487 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:07:22.488 (Life 360) onHeartBeat called:2/12
2019-02-23 17:07:31.990 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:07:32.007 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:07:32.007 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:07:32.008 (Life 360) onHeartBeat called:3/12
2019-02-23 17:07:44.828 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:07:47.681 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:07:47.681 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:07:47.681 (Life 360) onHeartBeat called:4/12
2019-02-23 17:07:57.183 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:07:57.204 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:07:57.204 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:07:57.204 (Life 360) onHeartBeat called:5/12
2019-02-23 17:08:09.612 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:08:09.640 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:08:09.640 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:08:09.641 (Life 360) onHeartBeat called:6/12
2019-02-23 17:08:22.440 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:08:25.292 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:08:25.292 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:08:25.292 (Life 360) onHeartBeat called:7/12
2019-02-23 17:08:34.798 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:08:34.820 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:08:34.822 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:08:34.822 (Life 360) onHeartBeat called:8/12
2019-02-23 17:08:47.158 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:08:49.980 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:08:49.980 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:08:49.980 (Life 360) onHeartBeat called:9/12
2019-02-23 17:09:00.514 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:09:00.532 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:09:00.532 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:09:00.532 (Life 360) onHeartBeat called:10/12
2019-02-23 17:09:12.874 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:09:12.895 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:09:12.896 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:09:12.897 (Life 360) onHeartBeat called:11/12
2019-02-23 17:09:25.205 (Life 360) Pushing 'onHeartbeatCallback' on to queue
2019-02-23 17:09:28.020 (Life 360) Processing 'onHeartbeatCallback' message
2019-02-23 17:09:28.020 (Life 360) Calling message handler 'onHeartbeat'.
2019-02-23 17:09:28.020 (Life 360) onHeartBeat called:12/12
2019-02-23 17:09:28.020 (Life 360) Checking Life360 Circle...
The plugin is working but always the errors in the log
Posted: Sunday 24 February 2019 1:04
by febalci
capman wrote: Saturday 23 February 2019 17:14
Capman, these errors refer to an https connection url error to life360 server. This could be due to:
1. Invalid life360 username-password (username should be your email address)
2. Intermittent internet disconnections of your modem.
3. Your https ssl profile?
4. Python 3.5.3 (Who knows?)
I never had this type of problem under 4.10224 and python 3.6.4. Also, that reminds me to do the thing i hate most: Better error handling and messages...
Posted: Sunday 24 February 2019 9:54
by EddyG
Unfortunately I took and looked at the wrong part of the log file.
It seems that my problem is solved after all with version 2.3.1
Sorry for the mistake.
Posted: Tuesday 26 February 2019 9:07
by Minglarn
Great work!
Really, really liked the location.txt file ... Suits my dash panel PERFECT!
