Python plugin: UPS Monitor
Matthias
Re: Python plugin: UPS Monitor
Post by Matthias »
Thank you for this plugin.
It works perfectly.
But i have a problem with blocky.
What is the parameters i have to use for Status mode in a condition ?
I try "OL", "OB", "ONBATTERY DISCHARGING", panic, alarm...
Nothing works
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
On my APC UPS the status is "ONLINE"
Matthias
Post by Matthias »
I d'ont understand why it doesn't work.
I try with everything in my blocky :
  • ONLINE CHARGING
  • ONLINE
  • OL
  • 0
  • 1
  • 2
  • 3
  • 4...
  • ON
  • OFF
  • OPEN
  • CLOSE
  • ALARM
  • PANIC...
What is the parameter to do a condition for my UPS EATON ?
madpatrick
It appears that a text input is not working in Blocky
See also:
viewtopic.php?f=62&t=28388&p=217446&hil ... ly#p217438
You can better use a Dzvents script.
I've tried a simplte test script and this is working
local scriptVar     = '-=# TEST #=-'
local testswitch    =   290
return
    on       = {
                devices         = {testswitch,},
    logging = {
                level = domoticz.LOG_ERROR,
                marker = scriptVar,
    execute = function(dz, item)
local UPS_status   = dz.devices(560)
            if UPS_status.text == 'ONLINE'  then
            dz.log('APS UPS is : ' ..UPS_status.text, dz.LOG_FORCE)
I think for your example it looks like this
You need to change the ID number of your devices (290 and 300) in this script
local UPS_status    =   290  -- fill in your device ID of the EATON
local Light         =   300  -- fill in your device ID of the Le Bureau
return
    on       = {
                devices         = {UPS_status,},
    logging = {
                marker = scriptVar,
    local UPS_status   = dz.devices(UPS_status)
    local Light   		= dz.devices(Light)
            if UPS_status.text == 'ONLINE CHARGING'  or UPS_status.text == 'ONBATTERY DISCHARGING'  then
            Light.switchOn().checkFirst()
tarmacalastair
Post by tarmacalastair »
Notifications
Well I've only just bought a UPS (Tecnoware) and installed this plugin so let's start by saying a big thanks to the author!
But, as others have reported here, I could not get notifications to work when power was lost/restored with the "NUT - UPS Status Mode" changing between ONLINE and ONBATTERY.
One of the recent comments mentioned using blockly so I started out by looking in there and I noticed (when you look at the current values of devices) that there is a column for the "State" and another for the "Value" for each device.
For my UPS the status mode shows the following:
State as "ONLINE" and Value as "1/ONLINE" when there is AC power (top line below):
Screenshot 2022-12-01 at 11-32-19 Domoticz.png (36.54 KiB) Viewed 2388 times
or
State as "ONBATTERY" and Value as "4/ONBATTERY" when running on battery:
Screenshot 2022-12-01 at 11-39-47 Domoticz.png (15.26 KiB) Viewed 2388 times
So, under the Domoticz "Utility" tab I went into the Notifications for the "UPS Status Mode" and tried using the numeric "Value" instead of the text status. I powered off my UPS and a minute or so later I powered it back on and both times I received a notification (Pushbullet and Telegram in my case). See screenshot and note below:
Screenshot 2022-12-01 at 11-41-32 Domoticz.png (94.84 KiB) Viewed 2388 times
Important - Make sure you change the "Ignore Interval" to on (green) so that the status change will always send out a notification. (I forgot to show this in the above screenshot)
For testing purposes I lowered the polling interval by editing the plugin.py to 20 seconds but will now increase it back to 1 minute.
Just need to decide now whether to set this to ring the (battery) doorbell when power is lost and risk waking the household at night!
Hope this helps people like me who were struggling with notifications.
Running Domoticz and Dashticz beta on Raspberry Pi OS 32 bit - has anyone had success with 64 bit?
Desktop access from Ubuntu Linux
betogar
Post by betogar »
tarmacalastair wrote: Thursday 01 December 2022 12:54 Notifications
or
Sorry for the question, where can I see that?
Screenshot 2022-12-01 at 11-32-19 Domoticz.png (36.54 KiB) Viewed 2363 times
tarmacalastair
You get to it by clicking on Setup, More Options, Events. This takes you to the automation scripts page where you can see device statuses.
You can also get there with http or https://ipaddress:8080/#/Events (substitute your IP address and change the port if you don't use 8080).
Good luck. I found the device statuses by accident. I'd seen them before but completely forgotten.
betogar
Post by betogar »
tarmacalastair wrote: Sunday 11 December 2022 0:37 You get to it by clicking on Setup, More Options, Events. This takes you to the automation scripts page where you can see device statuses.
oh i see, thanxs ;)
ssk17051980
Domoticz version: 2023.2
Post by ssk17051980 »
so, this plugin is working whit any UPS ?
i see that the plugin is for EATON, but another forum member use this for a UPS Tecnoware.
can i use any USB cable to monitor the UPS ?
thx
barkerg
Post by barkerg »
The plugin works well using simple notifications sent out on Pushover, however I'm trying to write a Blocky script to report the UPS Backup Time whenever the UPS status mode is offline. When constructing an if statement, only the Backup Time device shows up when clicking Devices>Utility and not Status Mode. Both these devices as well as the UPS Charge device show up when I click the current states icon. Is this a bug or am I doing something wrong? I am using Domoticz 2024/7 on a Raspberry Pi 4B. The UPS is a Cyberpower 1500AVR.
Domoticz version: 2025.1
That UPS status device is probably a selector switch and can be found under light/switches.
barkerg
Post by barkerg »
Thanks for the quick reply. Nothing was found under switches but ironically it was under Zwave Alarms even though it is not a Zwave device. Sorry for the tunnel vision.
