Python plugin: Battery Level for Z-Wave Devices
- heggink
- Domoticz version: 12451
Re: Python plugin: Battery Level for Z-Wave Devices
Plugin works great but sometimes, after changing batteries, the old battery level persists and does not get updated (not even after reboot). Thoughts?
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
Logread
The plugin reads the battery level from openzwave. Indeed openzwave sometimes takes time to update it. This is unrelated to the plugin.heggink wrote: Monday 13 August 2018 20:58 Plugin works great but sometimes, after changing batteries, the old battery level persists and does not get updated (not even after reboot). Thoughts?
multinet
Hello i have the same trouble (no battery update after changing them)
I change the battery 2 weeks ago, I think there is a pb in openzwave because indeed the openzwave xml file does not have the correct battery level
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
6 sondes DS18B20
Martinq
- Domoticz version: 3.8153
Great plugin!!
Somehow Notifications are not working. In the Utility page I have a sensor with a battery level from 90%. So I made a notification like this:
Type: Usage
When: Less
Value: 81
Ignore Interval: Enabled
But no notifications.
Also tried to make a dzVents script, but no luck with it. It seems the Battery level from the plugin is in the sValue field. But I can't find how to extract this in dzVents. Tried it with this:
But this gives an error:
Somebody knows how to get notifications working with this plugin?
Type: Usage
When: Less
Value: 81
timer = {'Every minute'}
execute = function(domoticz)
if (domoticz.devices('Battery - Deursensor Berging').sValue < 80) then
domoticz.log(domoticz.devices('Battery - Deursensor Berging').sValue)
}Code: Select all
Status: dzVents: Error (2.4.6): An error occured when calling event handler Testbat
Status: dzVents: Error (2.4.6): ...o/domoticz/scripts/dzVents/generated_scripts/Testbat.lua:6: attempt to compare nil with number
Status: dzVents: Info: ------ Finished Testbat-
Logread
@Martinq,
I remember reading somewhere (on the forum or on GitHub) that devices created by python plugins do not work well with notifications (or dzvents ?). Or possibly because these are « custom » type of devices that show the battery levels.
Anyway, there is a global setting in domoticz for low battery that works with notifications (I am using this). Alternatively you could write a script that polls the battery level devices for levels, at regular intervals ?
Martinq
I just got a notification from the sensors in Domoticz. Changed the When from Less to Less or Equal. Don't know why it was not working with only Less, but will wait a little bit longer.
The Low Battery function in the Domoticz settings doesn't work well. Many times the device battery is already empty without giving a warning. This script is the first one that gives the correct level. For instance I have a smoke detector. In Domoticz device page the battery level is still 100%. But in the zwcfxxxx.xml the level is 80%. So Domoticz still thinks the battery is full. Also when I check on the Nodes page the Control Page I see the level is 80%.
I am still trying to get the level in dzvents.
Martinq
Oke, got it working in both Notifications from the Custom Sensor as in the dzVents.
In dzVents you can use the .state attribute to get the Battery Level, like this:
It's important to use the "tonumber". State returns a string, otherwise you get an error: attempt to compare string with number
local LEVEL = tonumber(domoticz.devices('Battery - Deursensor Berging').state)
if (LEVEL < 95) then
domoticz.log('Battery level Low!! Level = ' .. LEVEL)
domoticz.log('Battery Level = ' .. LEVEL)
madvisionz
- Domoticz version: 4.10327
I can't get this plugin to work unfortunately.
I'm running Domoticz on Synology and the install commandlines doesn't work in Putty (in Windows) so I downloaded and copied the files with WinSCP to the BatteryLevel folder on my Syno manually, but I guess that isn't enough.
What am I missing here?
Domoticz 4.10007
DSM 6.2.1
Next day...Battery Monitoring still not visible in Hardware.
Domoticz 4.10007
DSM 6.2.1
Logread
@madvisionz, I have no clue about where domoticz python plugins should reside in a synology install so difficult for me to assess if you chose the right location... do you successfully use other python plugins ?
Also, did you make the plugin.py file executable (sudo chmod +x plugin.py) ?
Last, did you restart domoticz ?
madvisionz
@Logread, this is my first python plugin.. the location is /volume1/@appstore/domoticz/var/plugins. I created the "BatteryLevel" folder with mkdir and copied the files to this folder manually (apt-get and git clone isn't working). After that I did run the commandline to make plugin.py executable and restart Domoticz and Synology.
Also running Python 3.5.1.
Any ideas?
##Edit##
I installed another Domoticz incl. Python and now I can add the Battery Monitoring. Thx!!
No zwave devices found, but ok... we're getting somewhere.
Any ideas?
##Edit##
dextm80
- Domoticz version: 4.10159
i've this error sometimes:
can you help me ?
2018-11-14 12:13:24.602 Error: (Battery Level Zwave Devices) Ignoring controller ./Config/zwcfg_0xef422f8f.xml since presumed dead (not updated for more than 2 hours)
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
Logread
If it is only from time to time then it is no big deal... It just means your zwave controller has not been updating its data for a while. Not sure why but I assume your zwave network does not poll devices that often.dextm80 wrote: Wednesday 14 November 2018 22:46 i've this error sometimes:
can you help me ?Code: Select all
dextm80
Hi @Logread, my plugin stopped his work!
what appened?
tnx
2018-12-10 18:09:11.798 Error: (Battery Level ZWave) Error reading openzwave file ./Config/zwcfg_0xcc2f1a61.xml
2018-12-10 18:10:21.726 Error: (Battery Level ZWave) Enable to find a zwave controller configuration file !
tnx
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
Logread
Can you see the file in the Config directory ? Can you read it with a text editor ?dextm80 wrote: Monday 10 December 2018 18:17 Hi @Logread, my plugin stopped his work!![]()
First time this error is reported (it could be a malformed xml format but this would be strange)...
dextm80
yes it's into config directory and i'm reading it normally
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
Logread
Then it could be that since you are running a very recent beta the open wave config file format has changed ?dextm80 wrote: Monday 10 December 2018 18:37 yes it's into config directory and i'm reading it normally
Did you successfully run the plugin with prior versions ? Did the plugin stop when you last upgraded ?
dextm80
yes, after 25 november 18 the plugin stopsLogread wrote: Monday 10 December 2018 21:23Then it could be that since you are running a very recent beta the open wave config file format has changed ?dextm80 wrote: Monday 10 December 2018 18:37 yes it's into config directory and i'm reading it normally
1x Fibaro Wall Plug
Philips Hue Bridge
1x Fibaro Wall Plug
Philips Hue Bridge
Logread
You have to bear with me... just too busy to check what when wrong with recent Domoticz betas
Logread
dextm80, can you send your openzwave config file to me by pm (you might have to change its extension to .txt) ? I might then try to see if breaking changes have been Introduced recently.
alanlsmith
- Domoticz version: Latest β
If it helps: I'm on beta 4.10267 and the battery plugin is working fine
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
