Plugin - Homewizard
smaus
Re: Plugin - Homewizard
Post by smaus »
:D top its working :lol:
MrPenthouse
Post by MrPenthouse »
Wow, this did not even cost me more than a minute and it worked straight away! Excellent job and now my HomeWizard has an extended live, much thanks!
webmagic
Post by webmagic »
I like this plug-in very much! Will there be support for the Smartware XQ-lite Led lamps which are using 868 mhz. I would like to set the lamp dim setting via Domoticz.
WWortel
Post by WWortel »
This plugin looks very promising!!! I hope you can help me getting the plugin up-and-running.
Version: Linux raspberrypi 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
Beta Domoticz Version: 3.9389-
dzVents Version: 2.4.5
Python Version: 3.5.3
Platform: Raspberry 3B+
I’ve installed the plugin and did a setup of the hardware Homewizard. I get this message: ‘Homewizard created, devices can be found …’ :D
When I go to devices, I get this message: ‘Problem retrieving devices!’ :?
When I go back to hardware, the homewizard I just created is not shown anymore and Homewizard can’t be selected anymore for a new setup of hardware.
To be able to start it correctly again I did: mv plugin.py plugin.py.old Now I can start and remove the created hardware of homewizard in domotics. Next I do a Restart and I’m back to where I started.
Note when I start it via ./domotics, then I see this message:
2018-05-06 14:52:09.993 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2018-05-06 14:52:09.993 Error: WebServer(SSL) check privileges for opening ports below 1024
(I don’t see this message in logs when starting via sudo service domoticz.sh start)
I also tried running the stable version (3.8153). However then I’m not able to setup the Homewizard hardware.
I hope somebody has a clue what is going wrong.
Regards,
WWortel
TheCub3
Post by TheCub3 »
hi,
i did the steps:
cd domoticz/plugins
git clone https://github.com/rvdvoorde/domoticz-homewizard.git
sudo systemctl restart domoticz
and i see in my raspbian,
but i dont see in in Hardware antthing of homewizard ?,i already try a reset in domoticz
i use the beta version that is needed but i see in the log
2018-06-11 19:33:36.208 Status: Domoticz V3.9625 (c)2012-2018 GizMoCuz
2018-06-11 19:33:36.209 Status: Build Hash: 529bd73d, Date: 2018-06-11 06:30:28
2018-06-11 19:33:36.209 Status: Startup Path: /home/pi/domoticz/
2018-06-11 19:33:36.390 Status: EventSystem: reset all events...
2018-06-11 19:33:36.391 Status: PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
i think that is the problem but how can i make sure that the library is running correct ?
what am I doing wrong ?
update,
solved the problem, if you also got the same error like above go to Putty and install manual Python with the commando sudo apt-get install python3-pip
tnx,
A,
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
I don't want to double post but I am having problems with the HomeWizard plugin since I rebooted my device this morning. Please refer to this post (viewtopic.php?f=6&t=24623) for more information.
Can anyone shed some light on this issue?
TIA
Greetz,
Sjonnie
EDIT
Got the latest version from git and replaced it with old plugin.py. Problem solved :mrgreen:
YouLess Energy meter
Sjonnie2017
Got another question for the more experienced (then me :roll: ) HomeWizard-Domoticz users: I have added a switch (code disks) to my HomeWizard. It works and can be controlled by it. Unfortunately the switch does not show up in Domoticz. Even though I changed the full update interval to once every 15 minutes.
Any ideas?
Greetz,
Sjonnie
Sjonnie2017
Friendly bump :)
Anyone any idea?
EDIT: I have been investigating all possibilities to get the device list updated. Unfortunately I could not get that to work. Finally decided to remove the HomeWizard from Domoticz and added it again; knowing I would have to recreate the devices and configurations :cry: The missing device is now added. So for now I will think twice before adding extra devices to the HomeWizard ;)
micronikje
Post by micronikje »
Can anyone tell me how to install the homewizard plugin on a qnap nas ts-453a?
I use domoticz V4.9701
Build Hash: b47a877f
Build Date: 2018-06-23 16:27:56
I am a newbie to this.
Sjonnie2017
SSH into your QNAP and find the Domoticz folder. If found, you can place the plugin in the plugin folder. That should do the trick.
Refer to the posts in this thread for folder naming convention and other tips.
HTH
ngauruhoe
Post by ngauruhoe »
Hi, I installed domoticz on my synology nas (using the wiki 'easy way') and subsequently added the Homewizard plugin. Sole purpose to try to use my GoogleHome for voice control as follows: GoogleHome->Controlicz->Domoticz->HomeWizard Plugin-> Device. For now it's more an experiment to see if I can get this working.
So, I have not connected any 433 hardware to my NAS for Domoticz's use since, for now/time being, I only want to use the HomeWiz plugin.
From the start of this post I understand I should now be able to see (most) of my Homewiz connected devices. Right? I'm not able to find them. In the add light/switch window I cannot find anything that looks like my devices.
I'm probably missing something here. Please help me out.
Thanks a bunch!
Mike
Sjonnie2017
Hi Mike,
Don't want to be rude but that problem has been covered in this thread. You should place the plug-in in the appropriate folder (try to ssh into your Syno) and make sure you give the folder the proper name.
Edit: see my first post on page 4
Restart Domoticz and you should see your devices.
Good luck!
Regards,
Sjonnie
ngauruhoe
Post by ngauruhoe »
No offence taken. Apparently my 'and subsequently added the Homewizard plugin' wasn't clear enough. But what I meant was that I followed the install instructions here: https://github.com/rvdvoorde/domoticz-homewizard. As a result 'plugin.py' is already located in /usr/local/domoticz/var/plugins/domoticz-homewizard$. I also restarted the package a couple of times.
That is what you meant, right?
So, unfortunately, that's not the solution for this.
Cheers, Mike
ngauruhoe
Post by ngauruhoe »
Update...... what I didn't realize (until 5 minutes ago) is that I actually had to add the HomeWiz as 'hardware' to domoticz. In hindsight maybe obvious.... Anyway, it works (better) now. At least I see a lot of devices. Only my heatlink seems to get interpreted a bit strange (as 4 separate devices I think). But during my scan of this post I came across a few heatlink entries so I'll have a look there first.
Thanks for the feedback.
Cheers, Mike
ngauruhoe
Post by ngauruhoe »
For the benefit (I hope :-)) of others/all. This was my goal: Voice control of my HomeWiz attached devices using the following 'tool'-chain:
Works like a charm! 'Hey google, schakel de lampen in de huiskamer aan'.........en jawel hoor.......licht in de duisternis :-).
Just still have to figure out my Heatlink. And I don't see my Smartwares radiator thermostats yet.
But I'm pretty happy so far :-)
Cheers, Mike
ngauruhoe
Post by ngauruhoe »
Maybe someone can shed some light on this. Like I mentioned, I don't see my Smartware 433 radiators in the Domoticz device list. Below the output of a HomeWiz /get-status. They appear under category switches with a type of 'radiator' (ID's 10,11,15,16,23). In the HomeWiz app they properly show up as Heating devices and can be controlled as such. Is there anything special I need to do to get these in the Domoticz Device list?
"status": "ok",
"version": "3.403",
"request": {
"route": "/get-status"
"response": {
"preset": 0,
"time": "2019-03-17 17:09",
"switches": [
"id": 0,
"type": "switch",
"status": "off"
"id": 1,
"type": "switch",
"status": "off"
"id": 2,
"type": "switch",
"status": "off"
"id": 3,
"type": "switch",
"status": "off"
"id": 4,
"type": "switch",
"status": "off"
"id": 5,
"type": "switch",
"status": "off"
"id": 6,
"type": "switch",
"status": "off"
"id": 7,
"type": "switch",
"status": "on"
"id": 8,
"type": "switch",
"status": "off"
"id": 9,
"type": "switch",
"status": "off"
"id": 10,
"type": "radiator",
"tte": 15.1
"id": 11,
"type": "radiator",
"tte": 15
"id": 12,
"type": "switch",
"status": "off"
"id": 13,
"type": "switch",
"status": "off"
"id": 14,
"type": "switch",
"status": "off"
"id": 15,
"type": "radiator",
"tte": 28
"id": 16,
"type": "radiator",
"tte": 15
"id": 17,
"type": "switch",
"status": "off"
"id": 19,
"type": "switch",
"status": "off"
"id": 20,
"type": "switch",
"status": "off"
"id": 21,
"type": "dimmer",
"status": "off",
"dimlevel": 0
"id": 22,
"type": "switch",
"status": "off"
"id": 23,
"type": "radiator",
"tte": 15.1
"uvmeters": [],
"windmeters": [],
"rainmeters": [],
"thermometers": [
"id": 0,
"te": 8.7,
"hu": 58,
"favorite": "no"
"weatherdisplays": [],
"energymeters": [],
"energylinks": [],
"heatlinks": [
"id": 0,
"pump": "on",
"heating": "on",
"dhw": "off",
"rte": 20.378,
"rsp": 20.5,
"tte": 0,
"ttm": null,
"wp": 1.796,
"wte": 59.847,
"ofc": 0,
"odc": 0
"kakusensors": [
"id": 0,
"status": "yes",
"timestamp": "13:34"
"id": 1,
"status": null,
"timestamp": "13:01"
"id": 2,
"status": "no",
"timestamp": "09:01"
"id": 3,
"status": "yes",
"timestamp": "13:35"
"id": 4,
"status": "no",
"timestamp": "11:01"
"id": 5,
"status": "no",
"timestamp": "13:51"
"id": 6,
"status": "no",
"timestamp": "15:26"
"id": 7,
"status": "no",
"timestamp": "16:23"
Thank you, Mike
ngauruhoe
Post by ngauruhoe »
gijsje wrote: Saturday 19 August 2017 15:55 i have just done the update but i can not see the heatlink.
I can also not see the water detection sensors http://www.homewizard.nl/smartwares-868 ... elder.html
And also not the thermostat for the radiators http://www.homewizard.nl/smartwares-dra ... kraan.html
And from the Energylink it only shows the Electricity and the gas that are connected to P1 but not the water that is connected to S2 http://www.homewizard.nl/homewizard-energylink-102.html
The radiator thermostat was raised some time ago....Was it ever added to the HW plugin?
Thanks, Mike
Hemera
Post by Hemera »
I have just pushed an created a pull request for adding the functionality of HL thermostat.
Also I have "fixed" the Power and gas usage
Wobbles
Domoticz version: 3.8153
Post by Wobbles »
committed and thanks for the work!
Raspberry PI 1, Raspberry PI 2 & Raspberry PI 3, RFXCom, Z-Wave(Aeotec ZW090 Z-Stick Gen5), Philips HUE and using the premium android app
smaus
Post by smaus »
I dont see my S1 from my energielink
