[Plugin now available in Beta] Help with Yeelight Bulb
Derik
Re: Help with Yeelight Bulb
Post by Derik »
farhanito wrote:Does the script works in terminal? Maybe nc isn't installed
how do i try that?
My hue scripts [ and much others ] work fine...
corbin
Re: [Plugin now available in Beta] Help with Yeelight Bulb
Post by corbin »
open terminal
type or paste the command in and hit enter
If that works to control the light, then you can put it in the bash script and run from Domoticz
corbin
Post by corbin »
I've tested to confirm it works:
contents of bright.sh:
#!/bin/bash
echo -ne '{"id":1,"method":"set_bright","params":[50, "smooth", 500]}\r\n' | nc -w1 192.168.5.29 55443
bright.sh is located in the Domoticz scripts folder:
corbin
Post by corbin »
Also with your bash command, using start_cf requires the bulb to already be on. if you want to run from off state, replace start_cf with set_scene
corbin
Post by corbin »
one more thing I just saw in your setup, you have 3 slashes. Change to two:
script:///home
change to
script://home
Derik
Post by Derik »
corbin wrote:one more thing I just saw in your setup, you have 3 slashes. Change to two:
script:///home
change to
script://home
Make no different...
corbin
Post by corbin »
does the command work in terminal for you?
corbin
Post by corbin »
weiweipossible wrote: Besides that, if we implement the same form of API, we may receive a letter from Philips' lawyer ... just like when we develop this bulb using the everyone-is-using PWM technique ...
Are you able to talk about this PWM lawyer letter? Interested to know what it was about?
Derik
Post by Derik »
Terminal:
linaro@cubie:~$ cd /home/linaro/domoticz/scripts/bash/yeelight
linaro@cubie:~/domoticz/scripts/bash/yeelight$ echo -ne '{"id":1,"method":"set_s                            cene", "params": ["color", 65280, 70]}\r\n' | nc -w1 192.168.5.30 55443
{"id":1, "result":["ok"]}
{"method":"props","params":{"power":"on"}}
{"method":"props","params":{"color_mode":1,"bright":70,"rgb":65280}}
Light was off..
And after this on wih a green light...
Other things i try:
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ^C
linaro@cubie:~/domoticz/scripts/bash/yeelight$ echo -ne '{"id":1, "method":"start_cf", "params":[3,1,"50,1,16731392,1,360000,2,1700,10,540000,2,2700,100"]}\r\n' | nc -w1 192.168.5.30 55443
{"method":"props","params":{"flowing":1}}
{"method":"props","params":{"flow_params":"3,1,50,1,16731392,1,360000,2,1700,10,540000,2,2700,100"}}
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ./start_1.sh
{"id":(null), "error":{"code":-1, "message":"invalid command"}}
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ./ start_1.sh
-bash: ./: Is a directory
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ./sunrise_1.sh
Think the script is not ok.
corbin
Post by corbin »
Can you upload your start_1.sh file please?
Derik
Post by Derik »
#!/bin/sh
echo -ne '{"id":1,"method":"set_scene", "params": ["color", 65280, 70]}\r\n' | nc -w1 192.168.5.30 55443
And then:
Working with the portal..
weiweipossible
Post by weiweipossible »
Derik wrote:Terminal:
Light was off..
Other things i try:
You missed the "id" field which is mandatory.
Derik
Post by Derik »
linaro@cubie:~/domoticz/scripts/bash/yeelight$ echo -ne '{"id":1,"method":"set_scene", "params": ["color", 65280, 70]}\r\n' | nc -w1 192.168.5.30 55443
{"method":"props","params":{"color_mode":1}}
{"method":"props","params":{"bright":70}}
Te correct way....
Looks
Light was chancing
Only i still get the script in the document not working...
corbin
Post by corbin »
So it looks like there is a problem with your bash file. are you able to execute other bash files?
Derik
Post by Derik »
corbin wrote:So it looks like there is a problem with your bash file. are you able to execute other bash files?
Yes other scripts are working fine.
Derik
Post by Derik »
strange:
the scripts ..when i try to run them
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ./start.sh
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ./sunrise.sh
There are 2 things.
1 says ok, only there is no thing happend with the bulb.
1 error.
When i use start in the terminal
The light is working ok.
is there perhaps a other type of script necessary..?
My Hue is ussing without the extention .sh
While there is in the the same, start.
#!/bin/bash
corbin
Post by corbin »
Did you create your Hue script file the same way you created the Yeelight file? Same text editor, file permissions exactly the same etc? Maybe try a Cubieboard forum and see if someone else can run the script ok.
Can you also post up more information about your Cubieboard setup?
Derik
Post by Derik »
corbin wrote:Did you create your Hue script file the same way you created the Yeelight file? Same text editor, file permissions exactly the same etc? Maybe try a Cubieboard forum and see if someone else can run the script ok.
everything the same
CB2 is the same setup as a Rpi.. so that cannot be the problem.
Is there perhaps someone else that have a script working in a Linux board?
farhanito
Post by farhanito »
This is my test script..
#!/bin/bash
toggle="{\"id\":1,\"method\":\"toggle\",\"params\":[]}\r\n"
on="{\"id\":1,\"method\":\"set_power\",\"params\":[\"on\",\"smooth\",500]}\r\n"
off="{\"id\":1,\"method\":\"set_power\",\"params\":[\"off\",\"smooth\",500]}\r\n"
b="{\"id\":1,\"method\":\"set_bright\",\"params\":[$2,\"smooth\",500]}\r\n"
ct="{\"id\":1,\"method\":\"set_ct_abx\",\"params\":[$2,\"smooth\",500]}\r\n"
exec 3<> /dev/tcp/192.168.31.101/55443
# echo $1
case $1 in
	toggle)
		printf "$toggle" >&3
	on)
		printf "$on" >&3
	off)
		printf "$off" >&3
	b)
		printf "$b" >&3
	ct)
		printf "$ct" >&3
esac
Only has few functions. Toggle, on, off, brightness (b), and color temperature (ct).
Change the IP according to yours.
Usage:
./toggle.sh toggle
./toggle.sh on
./toggle.sh off
./toggle.sh b [1-100]
./toggle.sh ct [2700-6500]
Derik
Post by Derik »
@ Farhanito
Thanks for the script..
Only .....
./ is the command for the portal?
Do you use separate scriptfiles?
How do you make them excuteble?
And please a screendump of your script command in the Domoticz button.
What hardware do you use?
