Page 6 of 123
Posted: Tuesday 27 December 2016 11:27
by ERRORR2
corbin wrote: Cool! Please compile from https://github.com/corbinmunce/domoticz again and you (hopefully) will have control of your socket. As usual you will need to fully refresh your browser cache, and then add the Xiaomi Gateway again with the gateway settings (password, ip, port - only the password needs to be correct).
Also door sensors should now continue to detect as open, when they are left open.
Temp and battery sensors are not quite done yet.
Compiled again) After clearing browser cache, added gateway with correct password and ip and random port 777. Now I can see my socket, but still can not control it. Nothing happens after switching on/off.
Posted: Tuesday 27 December 2016 17:20
by corbin
There is a problem with the key encryption in my code, have confirmed by using another system. Was working well on my development system
Posted: Tuesday 27 December 2016 17:37
by arkoko
Can anybody else confirm that with last beta notifications does not work anymore?
2016-12-27 18:35:50.540  Error: Pushover:
2016-12-27 18:35:50.541  Error: Notification sent (pushover) => Failed
2016-12-27 18:35:50.560  Active notification Subsystems: email, http, pushover (3/12)
2016-12-27 18:35:55.279  Error: HTTP:
2016-12-27 18:35:55.280  Error: Notification sent (http) => Failed
2016-12-27 18:35:55.299  Active notification Subsystems: email, http, pushover (3/12)
Or it related to the mentioned key encryption problem?
Posted: Tuesday 27 December 2016 17:59
by corbin
I hadn't saved the key properly! so the smart plug is working on my Windows system, using the latest beta.
double check your key, should be like "v4ld4aq908mg77tb"
Posted: Tuesday 27 December 2016 18:56
by arkoko
Open door sensor now detected fine. Thanks!
Problem with wall plug control remains. They visible and they reports own status:
2016-12-27 19:38:32.525  (Xiaomi GW) Light/Switch (Xiaomi Smart Plug)
2016-12-27 19:38:32.529  {"cmd":"report","model":"plug","sid":"158d00010*****","short_id":59987,"data":"{\"status\":\"off\"}"}
But trying to control it get a unknown command and nothing hapened:
2016-12-27 19:53:58.503  User: Admin initiated a switch command (2/Xiaomi Smart Plug/Off)
2016-12-27 19:53:58.504  010C577E
2016-12-27 19:53:58.656  (Xiaomi GW) Light/Switch (Xiaomi Smart Plug)
2016-12-27 19:54:14.991  User: Admin initiated a switch command (2/Xiaomi Smart Plug/On)
2016-12-27 19:54:14.992  010C577E
2016-12-27 19:54:14.992  Unknown command 1
2016-12-27 19:54:15.143  (Xiaomi GW) Light/Switch (Xiaomi Smart Plug)
Posted: Tuesday 27 December 2016 21:37
by pavelbor
Hello, i also have something to add, now in log-file i see my Xiaomi temp/hum sensors:
2016-12-27 22:29:53.824 XiaomiGateway: unhandled model: sensor_ht
2016-12-27 22:29:53.824 {"cmd":"report","model":"sensor_ht","sid":"158d0001xxxxxx","short_id":37795,"data":"{\"temperature\":\"1886\"}"}
2016-12-27 22:29:53.845 XiaomiGateway: unhandled model: sensor_ht
2016-12-27 22:29:53.845 {"cmd":"report","model":"sensor_ht","sid":"158d0001xxxxxx","short_id":37795,"data":"{\"humidity\":\"4366\"}"}
That's looks good ;) Believe, soon we'll get them used too...
I think, for control of ZigBee power socket's we have to set somewhere in Gateway's settings encryption key, given by MiHome apps (developer mode).
Posted: Tuesday 27 December 2016 21:42
by corbin
arkoko wrote: But trying to control it get a unknown command and nothing hapened:
I see the problem - still had the my own IP address in my code, sorry! I'm doing some testing and should have a new pull request soon.
Posted: Tuesday 27 December 2016 21:44
by arkoko
After giving control command to the switch notifications becomes broken:
2016-12-27 21:56:32.738  Notification sent (email) => Success
2016-12-27 21:56:32.750  Active notification Subsystems: email, http, pushover (3/12)
2016-12-27 21:57:42.209  Notification sent (http) => Success
2016-12-27 21:57:41.707  (Xiaomi GW) Light/Switch (Xiaomi Door Sensor (test))
2016-12-27 21:57:42.214  {"cmd":"report","model":"magnet","sid":"158d00011*****","short_id":1082,"data":"{\"status\":\"open\"}"}
2016-12-27 21:57:48.201  (Xiaomi GW) Light/Switch (Xiaomi Door Sensor (test))
2016-12-27 21:57:48.211  {"cmd":"report","model":"magnet","sid":"158d00011*****","short_id":1082,"data":"{\"status\":\"close\"}"}
2016-12-27 21:59:01.855  Notification sent (http) => Success
2016-12-27 21:59:01.571  (Xiaomi GW) Light/Switch (Xiaomi Door Sensor (test))
2016-12-27 21:59:01.858  {"cmd":"report","model":"magnet","sid":"158d00011*****","short_id":1082,"data":"{\"status\":\"open\"}"}
2016-12-27 21:59:06.315  (Xiaomi GW) Light/Switch (Xiaomi Door Sensor (test))
2016-12-27 21:59:06.326  {"cmd":"report","model":"magnet","sid":"158d00011*****","short_id":1082,"data":"{\"status\":\"close\"}"}
2016-12-27 22:01:43.686  User: Admin initiated a switch command (6/Xiaomi Smart Plug Z3/On)
2016-12-27 22:01:43.687  010DD669
2016-12-27 22:01:43.688  Unknown command 1
2016-12-27 22:01:43.841  (Xiaomi GW) Light/Switch (Xiaomi Smart Plug Z3)
2016-12-27 22:01:55.901  User: Admin initiated a switch command (6/Xiaomi Smart Plug Z3/Off)
2016-12-27 22:01:55.902  010DD669
2016-12-27 22:01:56.053  (Xiaomi GW) Light/Switch (Xiaomi Smart Plug Z3)
2016-12-27 22:02:08.443  (Xiaomi GW) Light/Switch (Xiaomi Door Sensor (test))
2016-12-27 22:02:08.452  {"cmd":"report","model":"magnet","sid":"158d00011*****","short_id":1082,"data":"{\"status\":\"open\"}"}
2016-12-27 22:02:14.180  Error: HTTP:
2016-12-27 22:02:14.181  Error: Notification sent (http) => Failed
2016-12-27 22:02:14.551  Error: Pushover:
2016-12-27 22:02:14.551  Error: Notification sent (pushover) => Failed
2016-12-27 22:02:14.127  (Xiaomi GW) Light/Switch (Xiaomi Door Sensor (test))
2016-12-27 22:02:14.556  {"cmd":"report","model":"magnet","sid":"158d00011*****","short_id":1082,"data":"{\"status\":\"close\"}"}
And after domoticz daemon restart I have:
2016-12-27 22:03:22.149  Wunderground: Worker started...
2016-12-27 22:03:22.150  EventSystem: reset all events...
2016-12-27 22:03:22.151  EventSystem: reset all device statuses...
2016-12-27 22:03:22.153  EventSystem: Started
2016-12-27 22:03:22.191  Error: Domoticz received fatal signal 6 !...
2016-12-27 22:03:22.194  Error:   /home/pi/domoticz/domoticz() [0x1a8330]
2016-12-27 22:03:22.195  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1a83e8]
2016-12-27 22:03:22.195  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76a7e180]
Doing Raspberry restart helps to bring working notifications back.
corbin wrote:I'm doing some testing and should have a new pull request soon.
OK, we can wait :)
Posted: Wednesday 28 December 2016 2:30
by corbin
pavelbor wrote:Hello, i also have something to add, now in log-file i see my Xiaomi temp/hum sensors:
Would you prefer separate devices for humidity and temperature, or a combined device? I currently have the devices seperate -
Posted: Wednesday 28 December 2016 3:25
by Coldman
Cool, how it will look when you combine?
Posted: Wednesday 28 December 2016 3:53
by corbin
This is how it would look, however as the temperature and humidity are reported from the gateway in separate messages, I don't see a good way to combine them. It would be possible by querying the database, but I prefer to keep things simple.
Posted: Wednesday 28 December 2016 5:15
by ERRORR2
corbin wrote: Would you prefer separate devices for humidity and temperature, or a combined device? I currently have the devices seperate -
Separate looks good!
Posted: Wednesday 28 December 2016 6:25
by corbin
I've updated my pull request with temperature and humidity sensors handled.
Posted: Wednesday 28 December 2016 11:28
by ERRORR2
corbin wrote: I've updated my pull request with temperature and humidity sensors handled.
Compiled new version. Now I can control socket and see temperature sensor! Great work! But can't see humidity.
Posted: Wednesday 28 December 2016 11:41
by tiboo86
ERROR2, Wait a few minutes, they go up again.
Posted: Wednesday 28 December 2016 12:10
by ERRORR2
tiboo86 wrote:ERROR2, Wait a few minutes, they go up again.
Thanks! After some time I can see humidity sensor too.
Posted: Wednesday 28 December 2016 12:37
by arkoko
Perfect!
Temperature and huminidy sensors works. Power socket control works. Big thanks.
But still something wrong with notifications. After sending control command to the power socket futher notifications (any of them, including e-mail) failed.
2016-12-28 13:28:59.151  Domoticz V3.6258 (c)2012-2016 GizMoCuz
2016-12-28 13:28:59.151  Build Hash: 91f4555, Date: 2016-12-28 11:38:47
2016-12-28 13:28:59.152  System: Raspberry Pi
2016-12-28 13:28:59.152  Startup Path: /home/pi/domoticz/
2016-12-28 13:30:09.157  Incoming connection from: 192.168.1.1
2016-12-28 13:30:19.051  Notification sent (http) => Success
2016-12-28 13:30:19.070  Active notification Subsystems: email, http, pushover (3/12)
2016-12-28 13:30:51.400  User: Admin initiated a switch command (6/Xiaomi Smart Plug Z3/On)
2016-12-28 13:30:51.401  010DD669
2016-12-28 13:30:51.469  (Xiaomi GW) Light/Switch (Xiaomi Smart Plug Z3)
2016-12-28 13:30:51.477  {"cmd":"report","model":"plug","sid":"158d00010*","short_id":42960,"data":"{\"status\":\"on\"}"}
2016-12-28 13:30:51.490  (Xiaomi GW) Light/Switch (Xiaomi Smart Plug Z3)
2016-12-28 13:30:51.498  {"cmd":"report","model":"plug","sid":"158d00010*","short_id":42960,"data":"{\"status\":\"on\"}"}
2016-12-28 13:30:51.554  XiaomiGateway: response {"cmd":"write_ack","model":"plug","sid":"158d00010*","short_id":42960,"data":"{\"status\":\"off\"}"}
2016-12-28 13:30:51.555  (Xiaomi GW) Light/Switch (Xiaomi Smart Plug Z3)
2016-12-28 13:31:03.183  Error: HTTP:
2016-12-28 13:31:03.183  Error: Notification sent (http) => Failed
2016-12-28 13:31:03.202  Active notification Subsystems: email, http, pushover (3/12)
Posted: Wednesday 28 December 2016 12:44
by pavelbor
Thank you,
had to refresh cache, and then updated Gateway settings with ip address and key.
But now i have problem with notification too:
2016-12-28 14:00:19.376 Error: HTTP:
2016-12-28 14:00:19.377 Error: Notification sent (http) => Failed
Posted: Wednesday 28 December 2016 13:49
by tiboo86
Corbin, you then planned to be able to retrieve the consumption information of the zigbee plugs?
Posted: Wednesday 28 December 2016 14:13
by pavelbor
I have both splitted and combined Xiaomi temp/hum sensors listed in devices:
93	Gateway	804D	77	Xiaomi Temperature	Temp	LaCrosse TX3	21.7 C	-	100
97	Gateway	804D	1	Xiaomi Humidity	Humidity	LaCrosse TX3	Humidity 42 %	-	-
102	Gateway	804D	2	Xiaomi Temperature	Temp + Humidity	LaCrosse TX3	21.7 C, 43 %	-	-
And good news: looks like battery level is present (100), but only in splitted Temp device.
