can't get domoticz_updateDevice working
Number8
Domoticz version: 2022.1
Post by Number8 »
I setup a LUA script as explained here: https://www.domoticz.com/wiki/Inserting ... ua_parsers.
The callback works fine, domoticz log file reports:
2016-08-05 08:18:25.194 CLuaHandler (updateDevice from LUA) : idx=266 nvalue=0 svalue=228.4 invalue=0 signallevel=12 batterylevel=255
which is what is expected.
However the dummy voltage sensor never gets updated.
If I use the following json command, it is updated
http://192.168.21.240:8080/json.htm?type=command&param=udevice&idx=266&nvalue=0&svalue=200
Here is the LUA parser code:
local tensionAC = uri['tensionAC']
domoticz_updateDevice(266,0,tensionAC)
Thank you
Debian buster on NUC and three RPi with buster.
Number8
Re: can't get domoticz_updateDevice working
Post by Number8 »
Should have added I'm running v3.5259 on a RaspPI. Just updated to the last beta 5406. No change
Number8
Post by Number8 »
Anybody?
SweetPants
Post by SweetPants »
The example in the documentation talks about:
Callback : http://<domoticz ip>:<domoticz port>/json.htm?type=command&param='''udevices'''&script='''yoctopuce_meteo.lua'''&
If domoticz_updateDevice uses that, it won;t work.
Domoticz needs &param=udevice (no s), and as you already noticed, that works.
Number8
Post by Number8 »
Thanks SweetPants.
Indeed the Wiki is wrong. The callback that I setup is not as per Wiki, it is the following and so far is correct. To me the "s" is needed
IPAddress:port/json.htm?type=command&param=udevices&script=yoctopuce.lua&
since Domoticz log reports
However the idx device 266 never gets updated.
Is it a bug of domoticz_updateDevice function, or am I missing something?
SweetPants
Well i still see the extra 's' in your callback.(IPAddress:port/json.htm?type=command&param=udevices&script=yoctopuce.lua&).
And as the JSON works, i tend to believe it's a problem of domoticz_updateDevice
Number8
Post by Number8 »
it is indeed needed, or the callback is not fired.
Number8
Post by Number8 »
I dig a bit into LuaHandler.cpp. It seems to me that ID should be selected in the DB instead of DeviceID
int CLuaHandler::l_domoticz_updateDevice(lua_State* lua_state)
	int nargs = lua_gettop(lua_state);
	if (nargs >= 3 && nargs <= 5)
		// Supported format ares :
		// - deviceId (integer), svalue (string), nvalue (string), [rssi(integer)], [battery(integer)]
		// - deviceId (integer), svalue (string), nvalue (integer), [rssi(integer)], [battery(integer)]
		if (lua_isnumber(lua_state, 1) && (lua_isstring(lua_state, 2) || lua_isnumber(lua_state, 2)) && lua_isstring(lua_state, 3))
			// Extract the parameters from the lua 'updateDevice' function
			int ideviceId = (int)lua_tointeger(lua_state, 1);
			std::string nvalue = lua_tostring(lua_state, 2);
			std::string svalue = lua_tostring(lua_state, 3);
			if (((lua_isstring(lua_state, 3) && nvalue.empty()) && svalue.empty()))
				_log.Log(LOG_ERROR, "CLuaHandler (updateDevice from LUA) : nvalue and svalue are empty ");
				return 0;
			// Parse
			int invalue = (!nvalue.empty()) ? atoi(nvalue.c_str()) : 0;
			int signallevel = 12;
			if (nargs >= 4 && lua_isnumber(lua_state, 4))
				signallevel = (int)lua_tointeger(lua_state, 4);
			int batterylevel = 255;
			if (nargs == 5 && lua_isnumber(lua_state, 5))
				batterylevel = (int)lua_tointeger(lua_state, 5);
			_log.Log(LOG_NORM, "CLuaHandler (updateDevice from LUA) : idx=%d nvalue=%s svalue=%s invalue=%d signallevel=%d batterylevel=%d", ideviceId, nvalue.c_str(), svalue.c_str(), invalue, signallevel, batterylevel);
			// Get the raw device parameters
			std::vector<std::vector<std::string> > result;
			result = m_sql.safe_query("SELECT HardwareID, DeviceID, Unit, Type, SubType FROM DeviceStatus WHERE (DeviceID==%d)", ideviceId);
			if (result.empty())
				return 0;
			std::string hid = result[0][0];
			std::string did = result[0][1];
			std::string dunit = result[0][2];
			std::string dtype = result[0][3];
			std::string dsubtype = result[0][4];
			int HardwareID = atoi(hid.c_str());
			std::string DeviceID = did;
			int unit = atoi(dunit.c_str());
			int devType = atoi(dtype.c_str());
			int subType = atoi(dsubtype.c_str());
			std::stringstream sstr;
			unsigned long long ulIdx;
			sstr << ideviceId;
			sstr >> ulIdx;
			m_mainworker.UpdateDevice(HardwareID, DeviceID, unit, devType, subType, invalue, svalue, signallevel, batterylevel);
			_log.Log(LOG_ERROR, "CLuaHandler (updateDevice from LUA) : Incorrect parameters type");
		_log.Log(LOG_ERROR, "CLuaHandler (updateDevice from LUA) : Not enough parameters");
	return 0;
Number8
Post by Number8 »
Is anyboby willing to have a look at what seems to be a bug? (reported also here : http://www.domoticz.com/forum/viewtopic ... 604#p92604
Thank you
FrBoulli
Post by FrBoulli »
Number8
Post by Number8 »
Thanks FrBoulli. Does that mean that it will be fixed in the next build?
