Want my wall-tablet to say "lights on" ect
Evelen
Domoticz version: 2.4538
Post by Evelen »
Is it any way I can get my wall tablet to say things based on actions in Domoticz?
Like "Fire in bedroom", "Home-mode activated", "Outside door opened".
I know the mobile app "Tasker" kan say things, but i don't know any way to tell tasker when to say somthing when eks a door is open.
Is this posible?
I have payd for this programs, maybe they can help:
- Tasker
- Imperihome
- Pushover
BakSeeDaa
Re: Want my wall-tablet to say "lights on" ect
Post by BakSeeDaa »
You can use AutoRemote together with Tasker for that. It works very well. You can send the text to be spoken as an argument to Your autoremote command.
Here are some functions that I use.
MyDomo.lua
local function MyDomo()
	local utils = require('scripts/lua/Utils')
	local self = {
		['utils'] = utils,
		['PRIORITY_LOW'] = -2,
		['PRIORITY_MODERATE'] = -1,
		['PRIORITY_NORMAL'] = 0,
		['PRIORITY_HIGH'] = 1,
		['PRIORITY_EMERGENCY'] = 2,
		['ALARMSTATE_ALERT'] = 'Alert',
		['ALARMSTATE_ARMHOME'] = 'Arm Home',
		['ALARMSTATE_ARMAWAY'] = 'Arm Away',
		['ALARMSTATE_ERROR'] = 'Error',
		['ALARMSTATE_DISARMED'] = 'Disarmed',
		['ALARMSTATE_TRIPPED'] = 'Tripped'
	local EMPTYSTRING = 'Empty String'
	self.localhost = uservariables['DomoticzUsername']..':'..uservariables['DomoticzPassword']..'@'..uservariables['DomoticzHostname']..':'..uservariables['DomoticzPort']
	if (self.localhost == ':@:') then self.localhost = 'localhost:8080' end
	function self.setVar(uservariablename, uservariablevalue, uservariabletype)
		-- uservariabletype:  0 = Integer, 1 = Float, 2 = String, 3 = Date in format DD/MM/YYYY, 4 = Time in 24 hr format HH:MM
		uservariabletype = uservariabletype or 2 -- Defaults to 2
		if (uservariablename ~= nil) then
			if (uservariablevalue == nil or uservariablevalue == '') then
				if (uservariabletype == 0) then uservariablevalue = 0
				elseif (uservariabletype == 1) then uservariablevalue = 0.0
				elseif (uservariabletype == 2) then uservariablevalue = EMPTYSTRING -- Empty strings are problematic in an URL
				elseif (uservariabletype == 3) then uservariablevalue = os.date ('%x')
				elseif (uservariabletype == 4) then uservariablevalue = os.date ('%H:%M')
					utils.log('Invalid uservariabletype passed to setVar function', utils.LOG_ERROR)
					return
			if (uservariables[uservariablename] == nil) then
				--print('Create a new User Variable: '..uservariablename..' Value: ' ..uservariablevalue..' Type: ' ..uservariabletype)
				self.OpenURL('http://'..self.localhost..'/json.htm?type=command&param=saveuservariable&vname='..uservariablename..'&vtype='..uservariabletype..'&vvalue='..utils.urlencode(uservariablevalue))
				--print('http://'..self.localhost..'/json.htm?type=command&param=saveuservariable&vname='..uservariablename..'&vtype='..uservariabletype..'&vvalue='..utils.urlencode(uservariablevalue))
				--print('The User Variable '..uservariablename..' already exists, just update it')
				commandArray['Variable:'..uservariablename] = tostring(uservariablevalue)
	function self.getVar(uservariablename)
		local v
		v = uservariables[uservariablename]
		if v == EMPTYSTRING then -- Newly created string variable that needs to be set to ''
			commandArray['Variable:'..uservariablename] = ''
			v = ''
		return v
	function self.homeAwake()
		return (otherdevices_svalues['Z1 Alarm'] == self.ALARMSTATE_DISARMED and true or false)
	function self.getSecurityState()
		return otherdevices_svalues['Z1 Alarm']
	function self.blinkLight(light, times)
		times = times or 2
		local cmd1 = 'Off'
		local cmd2 = 'On'
		local pause = 0
		if (otherdevices[light] == 'Off') then
			cmd1 = 'On'
			cmd2 = 'Off'
		for i = 1, times do
			commandArray[#commandArray + 1]={[light]=cmd1..' AFTER '..pause }
			pause = pause + 3
			commandArray[#commandArray + 1]={[light]=cmd2..' AFTER '..pause }
			pause = pause + 3
	function self.OpenURL(url)
		-- The commandArray also supports nested tables to send the same command type multiple times.
		-- To do this, give the command a numeric index
		commandArray[#commandArray + 1]={['OpenURL']=url }
	function self.setTextDevice(idx, sValue)
		self.OpenURL("http://"..self.localhost.."/json.htm?type=command&param=udevice&idx="..idx.."&nvalue=0&svalue="..utils.urlencode(sValue))
	function self.AutoRemote(arMessage, deliverTo)
		local url
		if ((deliverTo == '') or (deliverTo == nil) or (deliverTo == 'Narva2')) then deliverTo = 'Default' end
		if (otherdevices['Internet'] == 'On') then -- We have Internet access, use GCM Server for delivery
			url = 'https://autoremotejoaomgcd.appspot.com/sendmessage?key='
			url = url .. (deliverTo == 'MastersCellPhone' and self.getVar('ARKey1') or (deliverTo == 'SonsCellPhone' and self.getVar('ARKey2') or (deliverTo == 'Uth' and self.getVar('ARKey4') or self.getVar('ARKey3')))) .. '&message=' .. utils.urlencode(arMessage) .. '&password=' .. self.getVar('ARPassw') .. '&sender=Vera'
		elseif (deliverTo == 'Default') then -- No Internet but Use LAN access to device for inhouse Speaker
			url = 'http://vera-voice.private.narva2:1817/?message=' .. utils.urlencode(arMessage) .. '&password=' .. self.getVar('ARPassw') .. '&sender=Vera'
		else -- No Internet access for externa host so delivery is not possible
			return
		self.OpenURL(url)
	function self.speak(speakMessage, deliverTo, canSpeakAtNight)
		local NOTHINGTOSAY = 'Inget att säga' -- You may translate this into your own language
		speakMessage = speakMessage or NOTHINGTOSAY
		canSpeakAtNight = canSpeakAtNight or 0
		--if ((deliverTo == '') or (deliverTo == nil)) then deliverTo = self.getVar('RecDef') end
		if ((not self.homeAwake()) and canSpeakAtNight == 0) or ((otherdevices['Mobiltelefon JMC'] == 'Off') and (otherdevices['Mobiltelefon JMC på Guest VLAN'] == 'Off') and deliverTo == 'SonsCellPhone' and canSpeakAtNight == 0) then
			return -- Not a good time to speak unless canSpeakAtNight flag was specified
		if (speakMessage ~= '') then
			self.AutoRemote('SpeakIt=:=' .. speakMessage, deliverTo)
	-- SMS messages are sent by making HTTP calls through the Clickatell API
	function self.sendSMS(SMSText, PhoneNumber)
		if ((PhoneNumber == '') or (PhoneNumber == nil) or (PhoneNumber == 'SMS-Away')) then PhoneNumber = uservariables['SMS-Away'] end
		self.OpenURL('https://api.clickatell.com/http/sendmsg?user='..uservariables['ClickatellAPIUser']..'&password='..uservariables['ClickatellAPIPassw']..'&api_id='..uservariables['ClickatellAPIId']..'&from=+'..uservariables['ClickatellSender']..'&to='..PhoneNumber..'&text='.. utils.smsEncode(SMSText))
		utils.log('Sending out SMS to ' .. PhoneNumber, utils.LOG_DEBUG)
	-- Notifications are sent by making HTTP calls through the NMA API
	function self.sendNotification(event, description, priority)
		priority = priority or 0
		self.OpenURL('https://www.notifymyandroid.com/publicapi/notify?apikey='..uservariables['NMAapikey']..'&application=Domoticz&event='..utils.urlencode(event)..'&description='..utils.urlencode(description)..'&priority='..priority)
	return self
return MyDomo
Utils.lua
local self = {
	LOG_ERROR = 1,
	LOG_EXEC_INFO = 2, -- Default unless overridden locally. Higher numbers won't show.
	LOG_INFO = 3,
	LOG_DEBUG = 4,
function self.fileExists(name)
	local f=io.open(name,'r')
	if f~=nil then
		io.close(f)
		return true
		return false
function self.osExecute(cmd)
	os.execute(cmd)
function self.runcommand(command)
	h=io.popen(command)
	response=h:read('*a')
	h:close()
	return(response)
function self.print(msg)
	print(msg)
function self.log(msg, level, logPre)
	level = level or self.LOG_INFO
	logPre = logPre or 'MyDomo'
	local lLevel = _G.logLevel==nil and 2 or _G.logLevel
	if (level <= lLevel) then
		self.print((level < 2 and '(Error) ' or (level < 3 and '(Exec info) ' or (level < 4 and '(info) ' or '(debug) ')))..logPre..': '..(level < 2 and '<span class="logerror">' or '')..msg..(level < 2 and '</span>' or ''))
function self.smsEncode(str)
	-- Convert to GSM 03.38 character set and URL-encode
	local utf8Chars={'%%','\n',' ','"','&',',','%.','/',':',';','<','=','>','?','¡','£','#','¥','§','Ä','Å','à','ä','å','Æ','Ç','É','è','é','ì','Ñ','ñ','ò','ö','Ø','Ö','Ü','ù','ü','ß', '\\', '*', '\'', '%(', '%)', '@', '%+', '%$', '%[', '%]', '%^', '{', '|',  '}', '~'}
	local gsmChars={'%%25','%%0D','%%20','%%22','%%26','%%2C','%%2E','%%2F','%%3A','%%3B','%%3C','%%3D','%%3E','%%3F','%%A1','%%A3','%%A4','%%A5','%%A7','%%C4','%%C5','%%E0','%%E4','%%E5','%%C6','%%C7','%%C9','%%E8','%%E9','%%EC','%%D1','%%F1','%%F2','%%F6','%%D8','%%D6','%%DC','%%F9','%%FC','%%DF','%%5C','%%2A','%%27','%%28','%%29','%%40','%%2B','%%24','%%5B','%%5D','%%5E','%%7B','%%7C','%%7D','%%7E'}
	for i = 1, #utf8Chars, 1 do
		str = string.gsub(str, utf8Chars[i], gsmChars[i])
	return str
function self.urlencode(str)
	if (str) then
		str = string.gsub (str, '\n', '\r\n')
		str = string.gsub (str, '([^%w ])',
		function (c) return string.format ('%%%02X', string.byte(c)) end)
		str = string.gsub (str, ' ', '+')
	return str
-- Return a Unix Timestamp
function self.normalize(a)
		local m,d,y,h,mi,n=a:match('(%d+)/(%d+)/(%d+)%s+(%d+):(%d+)%s+(%w+)')
		if n=='PM' then h=h+12 end
		return string.format('%04d%02d%02d%02d%02d',y,m,d,h,mi)
function self.timedifference(s)
	year = string.sub(s, 1, 4)
	month = string.sub(s, 6, 7)
	day = string.sub(s, 9, 10)
	hour = string.sub(s, 12, 13)
	t1 = os.time()
	difference = os.difftime (t1, t2)
	return difference
return self
script_device_test.lua
local logPre = 'script_device_test'
if (devicechanged['script_device_test'] == 'On') then
	local MyDomo = require('scripts/lua/MyDomo'); mydomo = MyDomo()
	_G.logLevel = mydomo.utils.LOG_DEBUG -- Override the default logging level
	mydomo.utils.log('Try to talk', mydomo.utils.LOG_DEBUG, logPre)
	mydomo.speak("This is the spiderpig talking saying moo moo")
The above requires a few uservariables to be set up but you might figure it out ...
Cheers!
