Vocal announcement - Good Morning Script
jmleglise
- Domoticz version: 2022.1
Re: Vocal announcement - Good Morning Script
Another idea :
Announce special event of the day, like first day of spring, labor day ... with a small definition.
I have found a perfect web page for french guys for that : http://www.dromadaire.com/calendrier
All that remains is to code a web scraper...
Did someone have something for that ?
Another idea :
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
KMTronic USB relay
pvm
- Domoticz version: 4.10538
I've put some info on Bluetooth audio on the wiki some time ago. Might answer your questions
micbou
Under what name is the wiki posted? I cant find it... thanks
pvm
Nautilus
I had a working good morning announcement until I changed from 3.5mm jack to HDMI. Every file that I've tested (example.mp3 etc) plays fine but there is no sound when playing the speak.mp3 produced with this script. I'm puzzled
Tried omxplayer, mpg123 - no sound. Tried different audio formats - no sound. If I copy the speak.mp3 to my computer it plays fine. Any idea what could be the issue?
edit: I even tried now the izsynth script and the example provided in wiki. This also created an mp3 file that I can play on my laptop but not with RPi2, at least via HDMI..
edit2: Correction to above that the player software (e.g. mpg123, omxplayer) does not give any error, just that there is no sound from the speakers
rtna
I have a working setup now, announing erverything on my Sonos Playbar. One problem however. When the temperature is 19.3 degrees for example it the scripts announces (in Dutch): It is 19 march degrees. When the temperature is 19.4 degrees it announces: It is 19 april degrees. It translates the decimal degrees to the name of the month for some reason.
free_nsc
Can you share your script please if you don't mind?rtna wrote:I have a working setup now, announing erverything on my Sonos Playbar. One problem however. When the temperature is 19.3 degrees for example it the scripts announces (in Dutch): It is 19 march degrees. When the temperature is 19.4 degrees it announces: It is 19 april degrees. It translates the decimal degrees to the name of the month for some reason.
Apexdv
This script is fantastic - thank you! I have my Pi located behind a bookshelf with a computer speaker set attached to the audio-out port(2 speakers and the bass) as I also use it for streaming radio and making particular status announcements using izsynth therefore this script was the perfect addition.
Forecast.io is much more accurate where I am located in the Pacific Northwest of the US so I modified the script to pull from their API along with a few other changes such as allowing it to run most anytime of the day but still only once. I still have the remnants of WU but will be removing this once I return from vacation.
I added a rounding function as temperature, humidity and the like are often delivered to the hundredths which is not handled easily by the TTS output. My trash/recycling is handled by the building so I've no need for a reminder on this and have removed that particular code.
I travel on occasion and will typically have a friend house-sit to care for the plants, etc so I am working on an additional section that will 1) greet the house-sitter upon their first arrival (triggered by the front room/living room PIR) and remind them to water the plants, take in the mail, etc etc. I'll post the finalized version when completed.
Thanks again for the script! It's been turning heads and causing "oh my goodness!!" remarks ever since
indexCommand=1
function round(num, idp)
local mult = 10^(idp or 0)
return math.floor(num * mult + 0.5) / mult
local timeNow= os.date("*t")
currently= os.date
lastrun=otherdevices_lastupdate['PIRar9FrontRoom']
greet=(uservariables['Greeting']) -- morning, afternoon or evening
if devicechanged['PIRar9FrontRoom'] == 'On' and
timeNow.hour >= 6 and -- earliest hour the script should run
timeNow.hour <= 23 and -- latest hour the script should run
string.sub(uservariables['goodMorning'],9,10) ~= os.date("%d") -- Only one time per day
then
local sentence="Good "..greet.." to you. Today is "..(os.date("%A"))..", "..(os.date("%B")).." "..(os.date("%d"))..". "
-- ############# WEATHER UNDERGROUND API CALL #################
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local city = "Seattle"
local wuAPIkey = "XXXXXXXXXXX" -- Your Weather Underground API Key
local file=assert(io.popen('curl http://api.wunderground.com/api/'..wuAPIkey..'/forecast/q/WA/'..city..'.json'))
local raw = file:read('*all')
file:close()
local jsonForecast = json:decode(raw)
prevision=jsonForecast.forecast.txt_forecast.forecastday[1].fcttext -- complete prevision
--## Let's replace the wind directions with words as it is not spoken properly via TTS##
local t = {
[" ENE "] = " East to North East ",
[" NNE "] = " North to North East ",
[" NE "] = " North East ",
[" N "] = " North ",
[" NNW "] = " North to North West ",
[" NW "] = " North West ",
[" SSE "] = " South to South East ",
[" SE "] = " South East ",
[" S "] = " South ",
[" SSW "] = " South to South West ",
[" SW "] = " South West ",
[" W "] = " West ",
[" E "] = " East "}
for k, v in pairs (t) do
prevision = string.gsub(prevision, k, v)
sentence=sentence.."The weather forecast for today is "..prevision
-- ############# FORECAST.IO API CALL #################
local latlong = "47.XXXXXX,-122.XXXXXXX"
local fioAPIkey = "XXXXXXXXXXX" -- Forecast.io API Key
local file=assert(io.popen('curl https://api.forecast.io/forecast/'..fioAPIkey..'/'..latlong..''))
file:close()
forecastiohourly=jsonForecast.hourly.summary -- hourly summary
forecastiodaily=jsonForecast.daily.summary -- daily summary
forecastiocurrently=jsonForecast.currently.summary -- current summary, clouds/sky
forecastiocurrentlytemp=jsonForecast.currently.temperature -- current summary, temperature
forecastiocurrentlyhumidity=jsonForecast.currently.humidity -- current summary, humidity
forecastiocurentlycloudcover=jsonForecast.currently.cloudCover -- current summary, cloud cover percentage in decimal
forecastiocurrentlyprecipprob=jsonForecast.currently.precipProbability -- current summary, precipitaion probability
forecastiominutelysummary=jsonForecast.minutely.summary -- summary for the next hour
-- commandArray['CloudCover'] = forecastiocurentlycloudcover --This will be used eventually as an Ogmet oktet replacement: I'll covert the percentage to oktets to determine lux
simpletemp=(round(forecastiocurrentlytemp,0))
simpleprecipprob=(round(forecastiocurrentlyprecipprob,0))
sentence=sentence..". The forecast indicates "..forecastiohourly
sentence=sentence..". The extended outlook calls for "..forecastiodaily
sentence=sentence..". Currently, it is "..simpletemp.." degrees with a "..simpleprecipprob.." percent chance of rain. It will be "..forecastiominutelysummary.." with "..forecastiohourly.."." -- current conditions
-- And finally, it is processed and announced with or without a lovely music bed
print ("--------------------------------")
print("Announcement: "..sentence)
os.execute ("/home/pi/domoticz/scripts/izsynth -r -m /home/pi/sounds/mp3/piano.mp3 "..sentence.." &") --Music bed
-- os.execute ("/home/pi/domoticz/scripts/izsynth -r "..sentence.." &") -- use the "-r" switch to remove the generated file as it is not needed. No music bed on this one
commandArray[indexCommand]={['Variable:goodMorning']=lastrun} -- something to update "lastupdate"
indexCommand=indexCommand+1
return commandArrayI travel on occasion and will typically have a friend house-sit to care for the plants, etc so I am working on an additional section that will 1) greet the house-sitter upon their first arrival (triggered by the front room/living room PIR) and remind them to water the plants, take in the mail, etc etc. I'll post the finalized version when completed.
jmleglise
Thanx for your feedback and for sharing,
KMTronic USB relay
KMTronic USB relay
gawel31
I try to use jmleglise's script. During first install, i had this message:
Naturally, it doesn't work. Script is launched, but no sound...
What could i do please??
edekoss
Hello all
can someone write me what to do step by step to run this script? I don't know at all scripted and I would like to do when motion is detected in the living room to receive information such as weather. I write what I did until now.
1. i go to /home/pi/domoticz/scripts/lua/
2. I entered the command sudo nano script_device_switch.lua
3. I pasted there
indexCommand=1
if devicechanged['Sensor'] == 'On' and --Motion sensor Living Room ManualLaunchScript
timeNow.hour >6 and
string.sub(uservariables_lastupdate['goodMorning'], 9, 10) ~= os.date("%d") -- Only one time per day
then
local sentence="Hello"..tonumber(os.date("%d")) -- Good morning, today we are the ..
-- ############# TEMPERATURE & WEATHER FORECAST #################
sentence=sentence..". La température extérieure est de "..otherdevices_svalues['Sonde Solaire2'].." degré." -- outdoor temperature
json = (loadfile "/home/pi/domoticz/scripts/lua/json.lua")()
local city = "Paris"
local wuAPIkey = "Apikey" -- Your Weather Underground API Key
local file=assert(io.popen('curl http://api.wunderground.com/api/'..wuAP ... ty..'.json'))
file:close()
prevision=jsonForecast.forecast.txt_forecast.forecastday[1].fcttext_metric -- complete prevision
--prevision=jsonForecast.forecast.simpleforecast.forecastday[1].conditions -- small forecast
if tonumber(string.sub(otherdevices_svalues['Alerte Meteo'], 1, 1))==3 then -- Only for FRANCE. Weather Vigilance http://domogeek.entropialux.com/static/ ... tVigilance
sentence=sentence.."La météo est en vigilance orange :".. string.sub(otherdevices_svalues['Alerte Meteo'], 11)
elseif tonumber(string.sub(otherdevices_svalues['Alerte Meteo'], 1, 1))==4 then
sentence=sentence.."La météo est en vigilance rouge :".. string.sub(otherdevices_svalues['Alerte Meteo'], 11)
sentence=sentence.."Le temps de la journée sera "..prevision
-- ############# TRASH DAY #################
month=tonumber(os.date("%m"))
day=tonumber(os.date("%d"))
-- TRash day : Mardi vegetaux & ordure / jeudi recyclage & encombrant (pair) ou verre (impair) / samedi ordure
numOfWeek=tonumber(os.date("%V"))
numOfDay=os.date("%w")
if (numOfDay == '4') then -- thursday
if (numOfWeek % 2 ==0) then
sentence=sentence.."Les encombrants et la poubelle jaune sont rammassés ce matin." --pair
sentence=sentence.."Le verre et la poubelle jaune sont rammassés ce matin." --impair
elseif (numOfDay == '2') then -- Tuesday
if (month==3 and day>=15) or -- Vegetables trash between the 15 March and the 15 december
(month==12 and day<=15) or
(month>3 and month<12)
then
sentence=sentence.."Les vegetaux et "
sentence=sentence.."les poubelles sont ramassées ce matin."
elseif (numOfDay == '6') then -- Saturday
--print("talk:"..sentence)
os.execute ("/usr/bin/tts "..sentence.." &")
commandArray[indexCommand]={['Variable:goodMorning']="On"} -- something to update "lastupdate"
4. next command sudo chmod 644 script_device_switch.lua
5. Check rights with ls -l
In the script i changed only the name of the sensor, and I put my key api
Now when the sensor detects motion console shows up this information:
2016-10-27 10:23:01.627 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_switch.lua:/home/pi/domoticz/scripts/lua/script_device_switch.lua:9: bad argument #1 to 'sub' (string expected, got nil)
Please help and forgive total amateur
3. I pasted there
indexCommand=1
timeNow.hour >6 and
then
file:close()
then
jmleglise
I regret to inform that this script is not "Ready to use". You will need some Lua skills to achieve.
Your error seems to be about the goodMorning uservariable. Did you create it ?
KMTronic USB relay
KMTronic USB relay
ziaziung
Hi. I try to make work the script but I get this error :
Error: EventSystem: /home/pi/domoticz/scripts/lua/script_time_presence.lua:35: attempt to call a nil value
and the line 35 is this one :
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() --mettre le script json.lua dans le chemin indiqué
local wuAPIkey = "****************" -- Your Weather Underground API Key
file:close()
sentenceprev="Le temps de la journée sera "..prevision
os.execute ("/usr/bin/tts " ..sentenceprev.."&" )
Do I have the good JSON.lua?
Do I have to give special rights to this file?
Any idea?
file:close()
-- -*- coding: utf-8 -*-
-- Simple JSON encoding and decoding in pure Lua.
-- Copyright 2010-2016 Jeffrey Friedl
-- http://regex.info/blog/
-- Latest version: http://regex.info/blog/lua/json
-- This code is released under a Creative Commons CC-BY "Attribution" License:
-- http://creativecommons.org/licenses/by/3.0/deed.en_US
-- It can be used for any purpose so long as the copyright notice above,
-- the web-page links above, and the 'AUTHOR_NOTE' string below are
-- maintained. Enjoy.
local VERSION = 20160916.19 -- version history at end of file
local AUTHOR_NOTE = "-[ JSON.lua package by Jeffrey Friedl (http://regex.info/blog/lua/json) version 20160916.19 ]-"
-- The 'AUTHOR_NOTE' variable exists so that information about the source
-- of the package is maintained even in compiled versions. It's also
-- included in OBJDEF below mostly to quiet warnings about unused variables.
local OBJDEF = {
VERSION = VERSION,
AUTHOR_NOTE = AUTHOR_NOTE,
-- JSON definition: http://www.json.org/
-- JSON = assert(loadfile "JSON.lua")() -- one-time load of the routines
-- local lua_value = JSON:decode(raw_json_text)
-- local raw_json_text = JSON:encode(lua_table_or_value)
-- local pretty_json_text = JSON:encode_pretty(lua_table_or_value) -- "pretty printed" version for human readability
-- DECODING (from a JSON string to a Lua table)
-- If the JSON text is for an object or an array, e.g.
-- { "what": "books", "count": 3 }
-- or
-- [ "Larry", "Curly", "Moe" ]
-- the result is a Lua table, e.g.
-- { what = "books", count = 3 }
-- or
-- { "Larry", "Curly", "Moe" }
-- The encode and decode routines accept an optional second argument,
-- "etc", which is not used during encoding or decoding, but upon error
-- is passed along to error handlers. It can be of any type (including nil).
-- ERROR HANDLING
-- With most errors during decoding, this code calls
-- JSON:onDecodeError(message, text, location, etc)
-- with a message about the error, and if known, the JSON text being
-- parsed and the byte count where the problem was discovered. You can
-- replace the default JSON:onDecodeError() with your own function.
-- The default onDecodeError() merely augments the message with data
-- about the text and the location if known (and if a second 'etc'
-- argument had been provided to decode(), its value is tacked onto the
-- message as well), and then calls JSON.assert(), which itself defaults
-- to Lua's built-in assert(), and can also be overridden.
-- For example, in an Adobe Lightroom plugin, you might use something like
-- function JSON:onDecodeError(message, text, location, etc)
-- LrErrors.throwUserError("Internal Error: invalid JSON data")
-- end
-- or even just
-- function JSON.assert(message)
-- LrErrors.throwUserError("Internal Error: " .. message)
-- end
-- If JSON:decode() is passed a nil, this is called instead:
-- JSON:onDecodeOfNilError(message, nil, nil, etc)
-- and if JSON:decode() is passed HTML instead of JSON, this is called:
-- JSON:onDecodeOfHTMLError(message, text, nil, etc)
-- The use of the fourth 'etc' argument allows stronger coordination
-- between decoding and error reporting, especially when you provide your
-- own error-handling routines. Continuing with the the Adobe Lightroom
-- plugin example:
-- local note = "Internal Error: invalid JSON data"
-- if type(etc) = 'table' and etc.photo then
-- note = note .. " while processing for " .. etc.photo:getFormattedMetadata('fileName')
-- end
-- LrErrors.throwUserError(note)
-- end
-- for i, photo in ipairs(photosToProcess) do
-- local data = JSON:decode(someJsonText, { photo = photo })
-- end
-- DECODING AND STRICT TYPES
-- Because both JSON objects and JSON arrays are converted to Lua tables,
-- it's not normally possible to tell which original JSON type a
-- particular Lua table was derived from, or guarantee decode-encode
-- round-trip equivalency.
-- However, if you enable strictTypes, e.g.
-- JSON = assert(loadfile "JSON.lua")() --load the routines
-- JSON.strictTypes = true
-- then the Lua table resulting from the decoding of a JSON object or
-- JSON array is marked via Lua metatable, so that when re-encoded with
-- JSON:encode() it ends up as the appropriate JSON type.
-- (This is not the default because other routines may not work well with
-- tables that have a metatable set, for example, Lightroom API calls.)
-- ENCODING (from a lua table to a JSON string)
-- local custom_pretty = JSON:encode(lua_table_or_value, etc, { pretty = true, indent = "| ", align_keys = false })
-- On error during encoding, this code calls:
-- JSON:onEncodeError(message, etc)
-- which you can override in your local JSON object.
-- The 'etc' in the error call is the second argument to encode()
-- and encode_pretty(), or nil if it wasn't provided.
-- ENCODING OPTIONS
-- An optional third argument, a table of options, can be provided to encode().
-- encode_options = {
-- -- options for making "pretty" human-readable JSON (see "PRETTY-PRINTING" below)
-- pretty = true,
-- indent = " ",
-- align_keys = false,
-- -- other output-related options
-- null = "\0", -- see "ENCODING JSON NULL VALUES" below
-- stringsAreUtf8 = false, -- see "HANDLING UNICODE LINE AND PARAGRAPH SEPARATORS FOR JAVA" below
-- json_string = JSON:encode(mytable, etc, encode_options)
-- For reference, the defaults are:
-- pretty = false
-- null = nil,
-- PRETTY-PRINTING
-- Enabling the 'pretty' encode option helps generate human-readable JSON.
-- pretty = JSON:encode(val, etc, {
-- pretty = true,
-- indent = " ",
-- encode_pretty() is also provided: it's identical to encode() except
-- that encode_pretty() provides a default options table if none given in the call:
-- { pretty = true, align_keys = false, indent = " " }
-- For example, if
-- JSON:encode(data)
-- produces:
-- {"city":"Kyoto","climate":{"avg_temp":16,"humidity":"high","snowfall":"minimal"},"country":"Japan","wards":11}
-- then
-- JSON:encode_pretty(data)
-- produces:
-- "city": "Kyoto",
-- "climate": {
-- "avg_temp": 16,
-- "humidity": "high",
-- "snowfall": "minimal"
-- "country": "Japan",
-- "wards": 11
-- The following three lines return identical results:
-- JSON:encode_pretty(data, nil, { pretty = true, align_keys = false, indent = " " })
-- JSON:encode (data, nil, { pretty = true, align_keys = false, indent = " " })
-- An example of setting your own indent string:
-- JSON:encode_pretty(data, nil, { pretty = true, indent = "| " })
-- produces:
-- | "city": "Kyoto",
-- | "climate": {
-- | | "avg_temp": 16,
-- | | "humidity": "high",
-- | | "snowfall": "minimal"
-- | "country": "Japan",
-- | "wards": 11
-- An example of setting align_keys to true:
-- JSON:encode_pretty(data, nil, { pretty = true, indent = " ", align_keys = true })
-- produces:
-- "city": "Kyoto",
-- "climate": {
-- "avg_temp": 16,
-- "wards": 11
-- which I must admit is kinda ugly, sorry. This was the default for
-- encode_pretty() prior to version 20141223.14.
-- HANDLING UNICODE LINE AND PARAGRAPH SEPARATORS FOR JAVA
-- If the 'stringsAreUtf8' encode option is set to true, consider Lua strings not as a sequence of bytes,
-- but as a sequence of UTF-8 characters.
-- Currently, the only practical effect of setting this option is that Unicode LINE and PARAGRAPH
-- separators, if found in a string, are encoded with a JSON escape instead of being dumped as is.
-- The JSON is valid either way, but encoding this way, apparently, allows the resulting JSON
-- to also be valid Java.
-- AMBIGUOUS SITUATIONS DURING THE ENCODING
-- During the encode, if a Lua table being encoded contains both string
-- and numeric keys, it fits neither JSON's idea of an object, nor its
-- idea of an array. To get around this, when any string key exists (or
-- when non-positive numeric keys exist), numeric keys are converted to
-- strings.
-- For example,
-- JSON:encode({ "one", "two", "three", SOMESTRING = "some string" }))
-- produces the JSON object
-- {"1":"one","2":"two","3":"three","SOMESTRING":"some string"}
-- To prohibit this conversion and instead make it an error condition, set
-- JSON.noKeyConversion = true
-- ENCODING JSON NULL VALUES
-- Lua tables completely omit keys whose value is nil, so without special handling there's
-- no way to get a field in a JSON object with a null value. For example
-- JSON:encode({ username = "admin", password = nil })
-- produces
-- {"username":"admin"}
-- In order to actually produce
-- {"username":"admin", "password":null}
-- one can include a string value for a "null" field in the options table passed to encode()....
-- any Lua table entry with that value becomes null in the JSON output:
-- JSON:encode({ username = "admin", password = "xyzzy" }, nil, { null = "xyzzy" })
-- produces
-- Just be sure to use a string that is otherwise unlikely to appear in your data.
-- The string "\0" (a string with one null byte) may well be appropriate for many applications.
-- The "null" options also applies to Lua tables that become JSON arrays.
-- JSON:encode({ "one", "two", nil, nil })
-- produces
-- ["one","two"]
-- while
-- NULL = "\0"
-- JSON:encode({ "one", "two", NULL, NULL}, nil, { null = NULL })
-- produces
-- ["one","two",null,null]
-- HANDLING LARGE AND/OR PRECISE NUMBERS
-- Without special handling, numbers in JSON can lose precision in Lua.
-- For example:
-- T = JSON:decode('{ "small":12345, "big":12345678901234567890123456789, "precise":9876.67890123456789012345 }')
-- print("small: ", type(T.small), T.small)
-- print("big: ", type(T.big), T.big)
-- print("precise: ", type(T.precise), T.precise)
-- produces
-- small: number 12345
-- big: number 1.2345678901235e+28
-- precise: number 9876.6789012346
-- Precision is lost with both 'big' and 'precise'.
-- This package offers ways to try to handle this better (for some definitions of "better")...
-- The most precise method is by setting the global:
-- JSON.decodeNumbersAsObjects = true
-- When this is set, numeric JSON data is encoded into Lua in a form that preserves the exact
-- JSON numeric presentation when re-encoded back out to JSON, or accessed in Lua as a string.
-- (This is done by encoding the numeric data with a Lua table/metatable that returns
-- the possibly-imprecise numeric form when accessed numerically, but the original precise
-- representation when accessed as a string. You can also explicitly access
-- via JSON:forceString() and JSON:forceNumber())
-- Consider the example above, with this option turned on:
-- This now produces:
-- small: table 12345
-- big: table 12345678901234567890123456789
-- precise: table 9876.67890123456789012345
-- However, within Lua you can still use the values (e.g. T.precise in the example above) in numeric
-- contexts. In such cases you'll get the possibly-imprecise numeric version, but in string contexts
-- and when the data finds its way to this package's encode() function, the original full-precision
-- representation is used.
-- Even without using the JSON.decodeNumbersAsObjects option, you can encode numbers
-- in your Lua table that retain high precision upon encoding to JSON, by using the JSON:asNumber()
-- function:
-- T = {
-- imprecise = 123456789123456789.123456789123456789,
-- precise = JSON:asNumber("123456789123456789.123456789123456789")
-- print(JSON:encode_pretty(T))
-- This produces:
-- "precise": 123456789123456789.123456789123456789,
-- "imprecise": 1.2345678912346e+17
-- A different way to handle big/precise JSON numbers is to have decode() merely return
-- the exact string representation of the number instead of the number itself.
-- This approach might be useful when the numbers are merely some kind of opaque
-- object identifier and you want to work with them in Lua as strings anyway.
-- This approach is enabled by setting
-- JSON.decodeIntegerStringificationLength = 10
-- The value is the number of digits (of the integer part of the number) at which to stringify numbers.
-- Consider our previous example with this option set to 10:
-- This produces:
-- big: string 12345678901234567890123456789
-- The long integer of the 'big' field is at least JSON.decodeIntegerStringificationLength digits
-- in length, so it's converted not to a Lua integer but to a Lua string. Using a value of 0 or 1 ensures
-- that all JSON numeric data becomes strings in Lua.
-- Note that unlike
-- this stringification is simple and unintelligent: the JSON number simply becomes a Lua string, and that's the end of it.
-- If the string is then converted back to JSON, it's still a string. After running the code above, adding
-- print(JSON:encode(T))
-- produces
-- {"big":"12345678901234567890123456789","precise":9876.6789012346,"small":12345}
-- which is unlikely to be desired.
-- There's a comparable option for the length of the decimal part of a number:
-- JSON.decodeDecimalStringificationLength
-- This can be used alone or in conjunction with
-- to trip stringification on precise numbers with at least JSON.decodeIntegerStringificationLength digits after
-- the decimal point.
-- This example:
-- JSON.decodeDecimalStringificationLength = 5
-- produces:
-- precise: string 9876.67890123456789012345
-- SUMMARY OF METHODS YOU CAN OVERRIDE IN YOUR LOCAL LUA JSON OBJECT
-- assert
-- onDecodeError
-- onDecodeOfNilError
-- onDecodeOfHTMLError
-- onEncodeError
-- If you want to create a separate Lua JSON object with its own error handlers,
-- you can reload JSON.lua or use the :new() method.
local default_pretty_indent = " "
local default_pretty_options = { pretty = true, align_keys = false, indent = default_pretty_indent }
local isArray = { __tostring = function() return "JSON array" end } isArray.__index = isArray
local isObject = { __tostring = function() return "JSON object" end } isObject.__index = isObject
function OBJDEF:newArray(tbl)
return setmetatable(tbl or {}, isArray)
function OBJDEF:newObject(tbl)
return setmetatable(tbl or {}, isObject)
local function getnum(op)
return type(op) == 'number' and op or op.N
local isNumber = {
__tostring = function(T) return T.S end,
__unm = function(op) return getnum(op) end,
__concat = function(op1, op2) return tostring(op1) .. tostring(op2) end,
__add = function(op1, op2) return getnum(op1) + getnum(op2) end,
__sub = function(op1, op2) return getnum(op1) - getnum(op2) end,
__mul = function(op1, op2) return getnum(op1) * getnum(op2) end,
__div = function(op1, op2) return getnum(op1) / getnum(op2) end,
__mod = function(op1, op2) return getnum(op1) % getnum(op2) end,
__pow = function(op1, op2) return getnum(op1) ^ getnum(op2) end,
__lt = function(op1, op2) return getnum(op1) < getnum(op2) end,
__eq = function(op1, op2) return getnum(op1) == getnum(op2) end,
__le = function(op1, op2) return getnum(op1) <= getnum(op2) end,
isNumber.__index = isNumber
function OBJDEF:asNumber(item)
if getmetatable(item) == isNumber then
-- it's already a JSON number object.
return item
elseif type(item) == 'table' and type(item.S) == 'string' and type(item.N) == 'number' then
-- it's a number-object table that lost its metatable, so give it one
return setmetatable(item, isNumber)
-- the normal situation... given a number or a string representation of a number....
local holder = {
S = tostring(item), -- S is the representation of the number as a string, which remains precise
N = tonumber(item), -- N is the number as a Lua number.
return setmetatable(holder, isNumber)
-- Given an item that might be a normal string or number, or might be an 'isNumber' object defined above,
-- return the string version. This shouldn't be needed often because the 'isNumber' object should autoconvert
-- to a string in most cases, but it's here to allow it to be forced when needed.
function OBJDEF:forceString(item)
if type(item) == 'table' and type(item.S) == 'string' then
return item.S
return tostring(item)
-- return the numeric version.
function OBJDEF:forceNumber(item)
if type(item) == 'table' and type(item.N) == 'number' then
return item.N
return tonumber(item)
local function unicode_codepoint_as_utf8(codepoint)
-- codepoint is a number
if codepoint <= 127 then
return string.char(codepoint)
elseif codepoint <= 2047 then
-- 110yyyxx 10xxxxxx <-- useful notation from http://en.wikipedia.org/wiki/Utf8
local highpart = math.floor(codepoint / 0x40)
local lowpart = codepoint - (0x40 * highpart)
return string.char(0xC0 + highpart,
0x80 + lowpart)
elseif codepoint <= 65535 then
-- 1110yyyy 10yyyyxx 10xxxxxx
local highpart = math.floor(codepoint / 0x1000)
local remainder = codepoint - 0x1000 * highpart
local midpart = math.floor(remainder / 0x40)
local lowpart = remainder - 0x40 * midpart
highpart = 0xE0 + highpart
midpart = 0x80 + midpart
lowpart = 0x80 + lowpart
-- Check for an invalid character (thanks Andy R. at Adobe).
-- See table 3.7, page 93, in http://www.unicode.org/versions/Unicode5.2.0/ch03.pdf#G28070
if ( highpart == 0xE0 and midpart < 0xA0 ) or
( highpart == 0xED and midpart > 0x9F ) or
( highpart == 0xF0 and midpart < 0x90 ) or
( highpart == 0xF4 and midpart > 0x8F )
then
return "?"
return string.char(highpart,
midpart,
lowpart)
-- 11110zzz 10zzyyyy 10yyyyxx 10xxxxxx
local highpart = math.floor(codepoint / 0x40000)
local remainder = codepoint - 0x40000 * highpart
local midA = math.floor(remainder / 0x1000)
remainder = remainder - 0x1000 * midA
local midB = math.floor(remainder / 0x40)
local lowpart = remainder - 0x40 * midB
return string.char(0xF0 + highpart,
0x80 + midA,
0x80 + midB,
0x80 + lowpart)
function OBJDEF:onDecodeError(message, text, location, etc)
if text then
if location then
message = string.format("%s at char %d of: %s", message, location, text)
message = string.format("%s: %s", message, text)
if etc ~= nil then
message = message .. " (" .. OBJDEF:encode(etc) .. ")"
if self.assert then
self.assert(false, message)
OBJDEF.onDecodeOfNilError = OBJDEF.onDecodeError
OBJDEF.onDecodeOfHTMLError = OBJDEF.onDecodeError
function OBJDEF:onEncodeError(message, etc)
if etc ~= nil then
if self.assert then
local function grok_number(self, text, start, options)
-- Grab the integer part
local integer_part = text:match('^-?[1-9]%d*', start)
or text:match("^-?0", start)
if not integer_part then
self:onDecodeError("expected number", text, start, options.etc)
local i = start + integer_part:len()
-- Grab an optional decimal part
local decimal_part = text:match('^%.%d+', i) or ""
i = i + decimal_part:len()
-- Grab an optional exponential part
local exponent_part = text:match('^[eE][-+]?%d+', i) or ""
i = i + exponent_part:len()
local full_number_text = integer_part .. decimal_part .. exponent_part
if options.decodeNumbersAsObjects then
return OBJDEF:asNumber(full_number_text), i
-- If we're told to stringify under certain conditions, so do.
-- We punt a bit when there's an exponent by just stringifying no matter what.
-- I suppose we should really look to see whether the exponent is actually big enough one
-- way or the other to trip stringification, but I'll be lazy about it until someone asks.
if (options.decodeIntegerStringificationLength
and
(integer_part:len() >= options.decodeIntegerStringificationLength or exponent_part:len() > 0))
or
(options.decodeDecimalStringificationLength
and
(decimal_part:len() >= options.decodeDecimalStringificationLength or exponent_part:len() > 0))
then
return full_number_text, i -- this returns the exact string representation seen in the original JSON
local as_number = tonumber(full_number_text)
if not as_number then
self:onDecodeError("bad number", text, start, options.etc)
return as_number, i
local function grok_string(self, text, start, options)
if text:sub(start,start) ~= '"' then
self:onDecodeError("expected string's opening quote", text, start, options.etc)
local i = start + 1 -- +1 to bypass the initial quote
local text_len = text:len()
local VALUE = ""
while i <= text_len do
local c = text:sub(i,i)
if c == '"' then
return VALUE, i + 1
if c ~= '\\' then
VALUE = VALUE .. c
i = i + 1
elseif text:match('^\\b', i) then
VALUE = VALUE .. "\b"
i = i + 2
elseif text:match('^\\f', i) then
VALUE = VALUE .. "\f"
i = i + 2
elseif text:match('^\\n', i) then
VALUE = VALUE .. "\n"
i = i + 2
elseif text:match('^\\r', i) then
VALUE = VALUE .. "\r"
i = i + 2
elseif text:match('^\\t', i) then
VALUE = VALUE .. "\t"
i = i + 2
local hex = text:match('^\\u([0123456789aAbBcCdDeEfF][0123456789aAbBcCdDeEfF][0123456789aAbBcCdDeEfF][0123456789aAbBcCdDeEfF])', i)
if hex then
i = i + 6 -- bypass what we just read
-- We have a Unicode codepoint. It could be standalone, or if in the proper range and
-- followed by another in a specific range, it'll be a two-code surrogate pair.
local codepoint = tonumber(hex, 16)
if codepoint >= 0xD800 and codepoint <= 0xDBFF then
-- it's a hi surrogate... see whether we have a following low
local lo_surrogate = text:match('^\\u([dD][cdefCDEF][0123456789aAbBcCdDeEfF][0123456789aAbBcCdDeEfF])', i)
if lo_surrogate then
i = i + 6 -- bypass the low surrogate we just read
codepoint = 0x2400 + (codepoint - 0xD800) * 0x400 + tonumber(lo_surrogate, 16)
-- not a proper low, so we'll just leave the first codepoint as is and spit it out.
VALUE = VALUE .. unicode_codepoint_as_utf8(codepoint)
-- just pass through what's escaped
VALUE = VALUE .. text:match('^\\(.)', i)
i = i + 2
self:onDecodeError("unclosed string", text, start, options.etc)
local function skip_whitespace(text, start)
local _, match_end = text:find("^[ \n\r\t]+", start) -- [http://www.ietf.org/rfc/rfc4627.txt] Section 2
if match_end then
return match_end + 1
return start
local grok_one -- assigned later
local function grok_object(self, text, start, options)
if text:sub(start,start) ~= '{' then
self:onDecodeError("expected '{'", text, start, options.etc)
local i = skip_whitespace(text, start + 1) -- +1 to skip the '{'
local VALUE = self.strictTypes and self:newObject { } or { }
if text:sub(i,i) == '}' then
return VALUE, i + 1
local key, new_i = grok_string(self, text, i, options)
i = skip_whitespace(text, new_i)
if text:sub(i, i) ~= ':' then
self:onDecodeError("expected colon", text, i, options.etc)
i = skip_whitespace(text, i + 1)
local new_val, new_i = grok_one(self, text, i, options)
VALUE[key] = new_val
-- Expect now either '}' to end things, or a ',' to allow us to continue.
if c == '}' then
return VALUE, i + 1
if text:sub(i, i) ~= ',' then
self:onDecodeError("expected comma or '}'", text, i, options.etc)
self:onDecodeError("unclosed '{'", text, start, options.etc)
local function grok_array(self, text, start, options)
if text:sub(start,start) ~= '[' then
self:onDecodeError("expected '['", text, start, options.etc)
local i = skip_whitespace(text, start + 1) -- +1 to skip the '['
local VALUE = self.strictTypes and self:newArray { } or { }
if text:sub(i,i) == ']' then
return VALUE, i + 1
local VALUE_INDEX = 1
local val, new_i = grok_one(self, text, i, options)
-- can't table.insert(VALUE, val) here because it's a no-op if val is nil
VALUE[VALUE_INDEX] = val
VALUE_INDEX = VALUE_INDEX + 1
-- Expect now either ']' to end things, or a ',' to allow us to continue.
if c == ']' then
return VALUE, i + 1
self:onDecodeError("expected comma or '['", text, i, options.etc)
self:onDecodeError("unclosed '['", text, start, options.etc)
grok_one = function(self, text, start, options)
-- Skip any whitespace
start = skip_whitespace(text, start)
if start > text:len() then
self:onDecodeError("unexpected end of string", text, nil, options.etc)
if text:find('^"', start) then
return grok_string(self, text, start, options.etc)
elseif text:find('^[-0123456789 ]', start) then
return grok_number(self, text, start, options)
elseif text:find('^%{', start) then
return grok_object(self, text, start, options)
elseif text:find('^%[', start) then
return grok_array(self, text, start, options)
elseif text:find('^true', start) then
return true, start + 4
elseif text:find('^false', start) then
return false, start + 5
elseif text:find('^null', start) then
return nil, start + 4
self:onDecodeError("can't parse JSON", text, start, options.etc)
function OBJDEF:decode(text, etc, options)
-- If the user didn't pass in a table of decode options, make an empty one.
if type(options) ~= 'table' then
options = {}
-- If they passed in an 'etc' argument, stuff it into the options.
-- (If not, any 'etc' field in the options they passed in remains to be used)
if etc ~= nil then
options.etc = etc
if type(self) ~= 'table' or self.__index ~= OBJDEF then
OBJDEF:onDecodeError("JSON:decode must be called in method format", nil, nil, options.etc)
if text == nil then
self:onDecodeOfNilError(string.format("nil passed to JSON:decode()"), nil, nil, options.etc)
elseif type(text) ~= 'string' then
self:onDecodeError(string.format("expected string argument to JSON:decode(), got %s", type(text)), nil, nil, options.etc)
if text:match('^%s*$') then
return nil
if text:match('^%s*<') then
-- Can't be JSON... we'll assume it's HTML
self:onDecodeOfHTMLError(string.format("html passed to JSON:decode()"), text, nil, options.etc)
-- Ensure that it's not UTF-32 or UTF-16.
-- Those are perfectly valid encodings for JSON (as per RFC 4627 section 3),
-- but this package can't handle them.
if text:sub(1,1):byte() == 0 or (text:len() >= 2 and text:sub(2,2):byte() == 0) then
self:onDecodeError("JSON package groks only UTF-8, sorry", text, nil, options.etc)
-- apply global options
if options.decodeNumbersAsObjects == nil then
options.decodeNumbersAsObjects = self.decodeNumbersAsObjects
if options.decodeIntegerStringificationLength == nil then
options.decodeIntegerStringificationLength = self.decodeIntegerStringificationLength
if options.decodeDecimalStringificationLength == nil then
options.decodeDecimalStringificationLength = self.decodeDecimalStringificationLength
local success, value = pcall(grok_one, self, text, 1, options)
if success then
return value
-- if JSON:onDecodeError() didn't abort out of the pcall, we'll have received the error message here as "value", so pass it along as an assert.
if self.assert then
self.assert(false, value)
-- and if we're still here, return a nil and throw the error message on as a second arg
return nil, value
local function backslash_replacement_function(c)
if c == "\n" then
return "\\n"
elseif c == "\r" then
return "\\r"
elseif c == "\t" then
return "\\t"
elseif c == "\b" then
return "\\b"
elseif c == "\f" then
return "\\f"
elseif c == '"' then
return '\\"'
elseif c == '\\' then
return '\\\\'
return string.format("\\u%04x", c:byte())
local chars_to_be_escaped_in_JSON_string
.. '"' -- class sub-pattern to match a double quote
.. '%\\' -- class sub-pattern to match a backslash
.. '%z' -- class sub-pattern to match a null
.. '\001' .. '-' .. '\031' -- class sub-pattern to match control characters
local LINE_SEPARATOR_as_utf8 = unicode_codepoint_as_utf8(0x2028)
local PARAGRAPH_SEPARATOR_as_utf8 = unicode_codepoint_as_utf8(0x2029)
local function json_string_literal(value, options)
local newval = value:gsub(chars_to_be_escaped_in_JSON_string, backslash_replacement_function)
if options.stringsAreUtf8 then
-- This feels really ugly to just look into a string for the sequence of bytes that we know to be a particular utf8 character,
-- but utf8 was designed purposefully to make this kind of thing possible. Still, feels dirty.
-- I'd rather decode the byte stream into a character stream, but it's not technically needed so
-- not technically worth it.
newval = newval:gsub(LINE_SEPARATOR_as_utf8, '\\u2028'):gsub(PARAGRAPH_SEPARATOR_as_utf8,'\\u2029')
return '"' .. newval .. '"'
local function object_or_array(self, T, etc)
-- We need to inspect all the keys... if there are any strings, we'll convert to a JSON
-- object. If there are only numbers, it's a JSON array.
-- If we'll be converting to a JSON object, we'll want to sort the keys so that the
-- end result is deterministic.
local string_keys = { }
local number_keys = { }
local number_keys_must_be_strings = false
local maximum_number_key
for key in pairs(T) do
if type(key) == 'string' then
table.insert(string_keys, key)
elseif type(key) == 'number' then
table.insert(number_keys, key)
if key <= 0 or key >= math.huge then
number_keys_must_be_strings = true
elseif not maximum_number_key or key > maximum_number_key then
maximum_number_key = key
self:onEncodeError("can't encode table with a key of type " .. type(key), etc)
if #string_keys == 0 and not number_keys_must_be_strings then
-- An empty table, or a numeric-only array
if #number_keys > 0 then
return nil, maximum_number_key -- an array
elseif tostring(T) == "JSON array" then
return nil
elseif tostring(T) == "JSON object" then
return { }
-- have to guess, so we'll pick array, since empty arrays are likely more common than empty objects
return nil
table.sort(string_keys)
local map
-- If we're here then we have either mixed string/number keys, or numbers inappropriate for a JSON array
-- It's not ideal, but we'll turn the numbers into strings so that we can at least create a JSON object.
if self.noKeyConversion then
self:onEncodeError("a table with both numeric and string keys could be an object or array; aborting", etc)
-- Have to make a shallow copy of the source table so we can remap the numeric keys to be strings
map = { }
for key, val in pairs(T) do
map[key] = val
table.sort(number_keys)
-- Throw numeric keys in there as strings
for _, number_key in ipairs(number_keys) do
local string_key = tostring(number_key)
if map[string_key] == nil then
table.insert(string_keys , string_key)
map[string_key] = T[number_key]
self:onEncodeError("conflict converting table with mixed-type keys into a JSON object: key " .. number_key .. " exists both as a string and a number.", etc)
return string_keys, nil, map
-- Encode
-- 'options' is nil, or a table with possible keys:
-- pretty -- If true, return a pretty-printed version.
-- indent -- A string (usually of spaces) used to indent each nested level.
-- align_keys -- If true, align all the keys when formatting a table.
-- null -- If this exists with a string value, table elements with this value are output as JSON null.
-- stringsAreUtf8 -- If true, consider Lua strings not as a sequence of bytes, but as a sequence of UTF-8 characters.
-- (Currently, the only practical effect of setting this option is that Unicode LINE and PARAGRAPH
-- separators, if found in a string, are encoded with a JSON escape instead of as raw UTF-8.
-- to also be valid Java.)
local encode_value -- must predeclare because it calls itself
function encode_value(self, value, parents, etc, options, indent, for_key)
-- keys in a JSON object can never be null, so we don't even consider options.null when converting a key value
if value == nil or (not for_key and options and options.null and value == options.null) then
return 'null'
elseif type(value) == 'string' then
return json_string_literal(value, options)
elseif type(value) == 'number' then
if value ~= value then
-- NaN (Not a Number).
-- JSON has no NaN, so we have to fudge the best we can. This should really be a package option.
return "null"
elseif value >= math.huge then
-- Positive infinity. JSON has no INF, so we have to fudge the best we can. This should
-- really be a package option. Note: at least with some implementations, positive infinity
-- is both ">= math.huge" and "<= -math.huge", which makes no sense but that's how it is.
-- Negative infinity is properly "<= -math.huge". So, we must be sure to check the ">="
-- case first.
return "1e+9999"
elseif value <= -math.huge then
-- Negative infinity.
-- JSON has no INF, so we have to fudge the best we can. This should really be a package option.
return "-1e+9999"
return tostring(value)
elseif type(value) == 'boolean' then
elseif type(value) ~= 'table' then
self:onEncodeError("can't convert " .. type(value) .. " to JSON", etc)
elseif getmetatable(value) == isNumber then
-- A table to be converted to either a JSON object or array.
local T = value
options = {}
if type(indent) ~= 'string' then
indent = ""
if parents[T] then
self:onEncodeError("table " .. tostring(T) .. " is a child of itself", etc)
parents[T] = true
local result_value
local object_keys, maximum_number_key, map = object_or_array(self, T, etc)
if maximum_number_key then
-- An array...
local ITEMS = { }
for i = 1, maximum_number_key do
table.insert(ITEMS, encode_value(self, T[i], parents, etc, options, indent))
if options.pretty then
result_value = "[ " .. table.concat(ITEMS, ", ") .. " ]"
result_value = "[" .. table.concat(ITEMS, ",") .. "]"
elseif object_keys then
-- An object
local TT = map or T
local KEYS = { }
local max_key_length = 0
for _, key in ipairs(object_keys) do
local encoded = encode_value(self, tostring(key), parents, etc, options, indent, true)
if options.align_keys then
max_key_length = math.max(max_key_length, #encoded)
table.insert(KEYS, encoded)
local key_indent = indent .. tostring(options.indent or "")
local subtable_indent = key_indent .. string.rep(" ", max_key_length) .. (options.align_keys and " " or "")
local FORMAT = "%s%" .. string.format("%d", max_key_length) .. "s: %s"
local COMBINED_PARTS = { }
for i, key in ipairs(object_keys) do
local encoded_val = encode_value(self, TT[key], parents, etc, options, subtable_indent)
table.insert(COMBINED_PARTS, string.format(FORMAT, key_indent, KEYS[i], encoded_val))
result_value = "{\n" .. table.concat(COMBINED_PARTS, ",\n") .. "\n" .. indent .. "}"
local PARTS = { }
local encoded_val = encode_value(self, TT[key], parents, etc, options, indent)
local encoded_key = encode_value(self, tostring(key), parents, etc, options, indent, true)
table.insert(PARTS, string.format("%s:%s", encoded_key, encoded_val))
result_value = "{" .. table.concat(PARTS, ",") .. "}"
-- An empty array/object... we'll treat it as an array, though it should really be an option
result_value = "[]"
parents[T] = false
return result_value
function OBJDEF:encode(value, etc, options)
OBJDEF:onEncodeError("JSON:encode must be called in method format", etc)
options = {}
return encode_value(self, value, {}, etc, options)
function OBJDEF:encode_pretty(value, etc, options)
OBJDEF:onEncodeError("JSON:encode_pretty must be called in method format", etc)
-- If the user didn't pass in a table of decode options, use the default pretty ones
options = default_pretty_options
function OBJDEF.__tostring()
return "JSON encode/decode package"
OBJDEF.__index = OBJDEF
function OBJDEF:new(args)
local new = { }
if args then
for key, val in pairs(args) do
new[key] = val
return setmetatable(new, OBJDEF)
return OBJDEF:new()
-- Version history:
-- 20160916.19 Fixed the isNumber.__index assignment (thanks to Jack Taylor)
-- 20160730.18 Added JSON:forceString() and JSON:forceNumber()
-- 20160728.17 Added concatenation to the metatable for JSON:asNumber()
-- 20160709.16 Could crash if not passed an options table (thanks jarno heikkinen <[email protected]>).
-- Made JSON:asNumber() a bit more resilient to being passed the results of itself.
-- 20160526.15 Added the ability to easily encode null values in JSON, via the new "null" encoding option.
-- (Thanks to Adam B for bringing up the issue.)
-- Added some support for very large numbers and precise floats via
-- Added the "stringsAreUtf8" encoding option. (Hat tip to http://lua-users.org/wiki/JsonModules )
-- 20141223.14 The encode_pretty() routine produced fine results for small datasets, but isn't really
-- appropriate for anything large, so with help from Alex Aulbach I've made the encode routines
-- more flexible, and changed the default encode_pretty() to be more generally useful.
-- Added a third 'options' argument to the encode() and encode_pretty() routines, to control
-- how the encoding takes place.
-- Updated docs to add assert() call to the loadfile() line, just as good practice so that
-- if there is a problem loading JSON.lua, the appropriate error message will percolate up.
-- 20140920.13 Put back (in a way that doesn't cause warnings about unused variables) the author string,
-- so that the source of the package, and its version number, are visible in compiled copies.
-- 20140911.12 Minor lua cleanup.
-- Fixed internal reference to 'JSON.noKeyConversion' to reference 'self' instead of 'JSON'.
-- (Thanks to SmugMug's David Parry for these.)
-- 20140418.11 JSON nulls embedded within an array were being ignored, such that
-- ["1",null,null,null,null,null,"seven"],
-- would return
-- {1,"seven"}
-- It's now fixed to properly return
-- {1, nil, nil, nil, nil, nil, "seven"}
-- Thanks to "haddock" for catching the error.
-- 20140116.10 The user's JSON.assert() wasn't always being used. Thanks to "blue" for the heads up.
-- 20131118.9 Update for Lua 5.3... it seems that tostring(2/1) produces "2.0" instead of "2",
-- and this caused some problems.
-- 20131031.8 Unified the code for encode() and encode_pretty(); they had been stupidly separate,
-- and had of course diverged (encode_pretty didn't get the fixes that encode got, so
-- sometimes produced incorrect results; thanks to Mattie for the heads up).
-- Handle encoding tables with non-positive numeric keys (unlikely, but possible).
-- If a table has both numeric and string keys, or its numeric keys are inappropriate
-- (such as being non-positive or infinite), the numeric keys are turned into
-- string keys appropriate for a JSON object. So, as before,
-- JSON:encode({ "one", "two", "three" })
-- produces the array
-- ["one","two","three"]
-- but now something with mixed key types like
-- instead of throwing an error produces an object:
-- To maintain the prior throw-an-error semantics, set
-- 20131004.7 Release under a Creative Commons CC-BY license, which I should have done from day one, sorry.
-- 20130120.6 Comment update: added a link to the specific page on my blog where this code can
-- be found, so that folks who come across the code outside of my blog can find updates
-- more easily.
-- 20111207.5 Added support for the 'etc' arguments, for better error reporting.
-- 20110731.4 More feedback from David Kolf on how to make the tests for Nan/Infinity system independent.
-- 20110730.3 Incorporated feedback from David Kolf at http://lua-users.org/wiki/JsonModules:
-- * When encoding lua for JSON, Sparse numeric arrays are now handled by
-- spitting out full arrays, such that
-- JSON:encode({"one", "two", [10] = "ten"})
-- returns
-- ["one","two",null,null,null,null,null,null,null,"ten"]
-- In 20100810.2 and earlier, only up to the first non-null value would have been retained.
-- * When encoding lua for JSON, numeric value NaN gets spit out as null, and infinity as "1+e9999".
-- Version 20100810.2 and earlier created invalid JSON in both cases.
-- * Unicode surrogate pairs are now detected when decoding JSON.
-- 20100810.2 added some checking to ensure that an invalid Unicode character couldn't leak in to the UTF-8 encoding
-- 20100731.1 initial public release
Any idea?
jmleglise
You have the right json.lua file.
Did you named your script : "script_time_presence.lua" ?!? Our vocal script shall be a device script.
Are you sure that you aren't mixing everything ?
KMTronic USB relay
KMTronic USB relay
timbiker
Hello, I am trying to implement this script to my domoticz under windows. The speech can be enable by opening http://127.1.0.0:8888/?TTS=blablablajmleglise wrote:Hi,
But I got a lot of error on the script that I can't get out... Like EventSystem: in test: [string "indexCommand=1..."]:28: bad argument #1 to 'sub' (string expected, got nil)
Could you help me please ?
Here are the script used :
indexCommand=1
if devicechanged['Libre2'] == 'On' and --Motion sensor Living Room ManualLaunchScript
timeNow.hour >19 and
then
local curl = 'C:\\curl\\bin\\curl.exe '
sentence=sentence..". La température extérieure est de "..otherdevices_svalues['Température extérieure'].." degré." -- outdoor temperature
json = (loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\JSON.lua")()
local city = "Dijon"
local wuAPIkey = "xxx" -- Your Weather Underground API Key
local file=assert(io.popen(curl.. 'http://api.wunderground.com/api/'..wuAPIkey..'/forecast/lang:FR/q/France/'..city..'.json'))
file:close()
-- if tonumber(string.sub(otherdevices_svalues['Alerte Meteo'], 1, 1))==3 then -- Only for FRANCE. Weather Vigilance http://domogeek.entropialux.com/static/doc/index.html#api-Domogeek-GetVigilance
then
oss = "curl.. 'http://127.0.0.1:8888/?tts="..sentence.." &"
os.execute(oss)
return commandArray-
jmleglise
Hi dijon
This script is not "ready to use". If you don't understand and don't have the skill to complete the script , just delete the part line 26 to 30.
If you want to persist for the "weather vigilance", then you have to implement this another script (only for France):
https://easydomoticz.com/forum/viewtopi ... lance#p800
KMTronic USB relay
KMTronic USB relay
ziaziung
@ jmieglise : Hi. Thank you for your answer.
Yes your right, I've named my script : "script_time_presence.lua" and, now, I'm sure that I have mixed everything.
Well, I'm trying to have Temperature and wrather forecast when my ip address phone is detected. Here is my script:
How cann I use the json.lua file and get weather forecast this way?
function os.capture(cmd)
local f = assert(io.popen(cmd, 'r'))
local s = assert(f:read('*a'))
f:close()
return s
local today = os.date("%A")
local ojourdui = os.capture("export LANG=\"fr_FR.UTF-8\" && date \"+%A %d %B %Y\"")
local TempOuest = otherdevices_svalues["Temp Ouest"]:match("([^;]+)")
local TempFigeac = otherdevices_svalues["TempHumF"]:match("([^;]+)")
local TempSalon = otherdevices_svalues["Salon"]:match("([^;]+)")
local sentence = "Nous sommes le "..ojourdui
local sentence2 = "il est "..os.date("%H").." heure "..os.date("%M")..". Dehors il fait"..TempOuest.." degré,"..TempSalon.." dans le salon. Et à F "..TempFigeac
--Cette fonction calcule la différence de temps (en secondes) entre maintenant
--et la date passée en paramètre.
function timedifference (s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = os.difftime (t1, t2)
return difference
print(ojourdui)
--os.execute ("/usr/bin/tts " ..sentence.."&" )
--os.execute ("/usr/bin/tts " ..sentence2.."&" )
--print("1212221")
--os.execute("date")
local wuAPIkey = "64fd1d3dcdce6af3" -- Your Weather Underground API Key
local file=assert(io.popen('curl http://api.wunderground.com/api/'..wuAPIkey..'/forecast/lang:FR/q/France/'..city..'.json'))
file:close()
--Si le téléphone n'est pas détecté ou qu'il est présent depuis plus de 10 minutes (600 secondes),
--alors on vérifie à nouveau sa présence
if (otherdevices['Presence']=='Off') then
ping_success_tel1=os.execute('ping -c1 192.168.1.121')
if ping_success_tel1 then
commandArray['Presence']='On'
os.execute ("/usr/bin/tts Bonjour" )
elseif timedifference(otherdevices_lastupdate['Presence']) > 600 then
if ping_success_tel1 then commandArray['Presence']='On' else commandArray['Presence']='Off' end
timbiker
Hello jmleglise !jmleglise wrote:Hi dijon![]()
I am sure that I am already using one of your script as your username is not unknown for me !
You're right I don't have the skills and I am learning in trying to adapt the script I find to my needs and to windows. After reading another time the script, I understood the mistake for the meteo alert... Silly me !
I am now facing an issue that I can't understand...
I saved the script as a device script into the Domoticz script editor and I am not getting error again but I am getting... nothing !
Just a question regarind the goodMorning user value. I set it as a "entier" value and set it to 3 for the beginning
Am I right ?
indexCommand=1
timeNow.hour >14 and
then
local wuAPIkey = "xxxxx" -- Your Weather Underground API Key
file:close()
if tonumber(string.sub(otherdevices_svalues['Risque de givre'], 1, 1))==3 then -- Only for FRANCE. Weather Vigilance http://domogeek.entropialux.com/static/doc/index.html#api-Domogeek-GetVigilance
sentence=sentence.."il y a peut etre du givre".. string.sub(otherdevices_svalues['Alerte Meteo'], 11)
elseif tonumber(string.sub(otherdevices_svalues['Risque de givre'], 1, 1))==4 then
sentence=sentence.."Attention il y a du givre".. string.sub(otherdevices_svalues['Alerte Meteo'], 11)
sentence=sentence.."Le temps de la journée sera "..previsionEDIT : I saved the script as a device script into the Domoticz script editor and I am not getting error again but I am getting... nothing !
Am I right ?
timbiker
Well, I manage to get something but the SARAH windows app I used with http request for TTS does not like the "." as well as the space and the ";" and so...
@jmleglise : do you know if izsynth works under windows ? I am searching a way to bypass the space and whatever restriction for SARAH
Or a way to encode space and dots... with JSON ?
ziaziung
Hi. I try to make work this script (named script_device_forecast.lua, in ~/domoticz/scripts/lua, where on can find the file json.lua) :
When I push on the DIO54700_1 device I get :
2016-12-23 17:14:12.150 Error: EventSystem: /home/pi/domoticz/scripts/lua/script_device_forecast.lua:8: attempt to call a nil value
do you know where I've made an error?
if devicechanged['DIO54700_1'] == 'On'
then
local sentence="Bonjour, nous sommes aujourd'hui le "..tonumber(os.date("%d")) -- Good morning, today we are the ..
sentence=sentence..". La température extérieure est de "..otherdevices_svalues['Temp Ouest'].." degré." -- outdoor temperature
local wuAPIkey = "12aa25aa22aa55aa55aa" -- Your Weather Underground API Key
file:close()
