Recently purchased a Domitech ZBulb ZB22UK. I had to do an ./updaterelease in order for Domoticz to recognise it. The bulb is showing up as a dimmer etc however when you come to use it, the switch in Domoticz doesn't function as expected.
When you turn it on via Domoticz the dimmer slider shows as 1%, when you press the switch via Domoticz the bulb goes off but the GUI shows the bulb as on. I have to press the bulb again to show the bulb in a off state.
Any ideas?
Domoticz version V3.5756
Zwave,Me UZB1 controller
Domitech ZBulb ZB22UK Quirks
