Add adjustment value for Voltage type sensor
nmaster
Domoticz version: 3.6304
Post by nmaster »
I got a zwave wall plug from Neo Coolcam that reports false voltage values.
Comparing the log of the sensor, I see it is always about 14 volts higher than my UPS APC and my DMM even if voltage is varying
An option to adjust the value by adding -14 like on temp sensors would correct the reporting.
It would be great if such option could be enabled for voltage sensors.
