Domotest – A Lua rock to aid testing Domoticz event scripts
nxsteveo
Post by nxsteveo »
I made a little Lua library/script to help with unit testing Domoticz event scripts. It hides a lot of the boilerplate required to get standard Domoticz-compatible Lua scripts loaded into a test environment (such as Busted).
Useful if you don't have actual devices and want to get a script up and running, or if you want/need the security of having your event scripts covered by tests.
require 'domotest'
require 'busted.runner'()
describe('Bathroom motion sensor', function()
  describe('detects motion at night', function()
    it('turns on the light', function()
      commandArray = domotest('script_device_bathroommotion.lua', {
        devicechanged = { ['Bathroom Motion'] = 'On' },
        timeofday = { ['Nighttime'] = true }
      assert.are.same({
        ['Bathroom Lights'] = 'On'
      }, commandArray)
    end)
  end)
end)
Installation is simple with luarocks:
luarocks install domotest
:D
There's a bit more info on the blog post here: http://stevewilford.co.uk/2016/10/domotest-launch/
And even more info, and examples, in the git repo: https://github.com/NxSoftware/domotest
Hope this is of use to someone...
remb0
Re: Domotest – A Lua rock to aid testing Domoticz event scripts
Post by remb0 »
thanks for sharing!
