Virtual switch to tell nest thermostat we're away?
n1c0l45
Domoticz version: V3.4834
Post by n1c0l45 »
Finally I found a brand new nest gen2 sealed in its box for 100usd....so.... I get it :D
Now, I don't want to use the GPS position on my wife and I phones to tell nest I'm away but we both have Bluetooth Beacon on our chainkey to tell domoticz we're out. I would like to know if there's a way to make a virtual switch in domoticz that change the nest status to away?
Thanks for your help
Nic
safi78
Domoticz version: LastBeta
Re: Virtual switch to tell nest thermostat we're away?
Post by safi78 »
It's probably not the most fun answer, but the Nest does that automagically:
1. With the motion sensor it has on-board;
2. In the App you can use your GPS-location of your phone as well to determine home/away.
So, why build something that's already there ;) (I know, I know, this is way less fun :P)
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
n1c0l45
Post by n1c0l45 »
lol, thanks for the answer, I know that but as i said, i don't want to use the gps position on the app to tell i'm away, because it drains battery and also because my son doesn't have a sell phone, just a bluetooth beacon on its schoolbag ;)
Egregius
Domoticz version: v2024.7
Post by Egregius »
A fast Google search shows that it must be possible with a curl: https://developers.nest.com/documentati ... -structure
n1c0l45
Post by n1c0l45 »
thanks for that! i didn't find this page!
safi78
Post by safi78 »
n1c0l45 wrote: i don't want to use the gps position on the app to tell i'm away
When you add your Nest to Domoticz it's will represent the state of the on-board motionsensor of the Nest (what it uses to determine home/away) by an 'On/Off' sensor which you could use as a motion sensor in Domoticz.
Works brilliantly here :)
