More css styles needed
michmis
Post by michmis »
Im currently designing new css theme for domoticz and I find one thing really hard to work with- there are too many things hardcoded. I attached screenshot so I'd like to explain. There is yellow color hardcoded for td element with id name so now css looks like this:
<table id="itemtablesmall" cellspacing="0" cellpadding="0" border="0">
<tbody>
<tr>
<td id="name" style="background-color: #DDDF2D;">Pollin</td>
<td id="bigtext">0.0 mm</td>
<td id="img">
<td id="status">0.0 mm</td>
<td id="lastupdate">2016-09-28 17:38:49</td>
</tr>
There are no classes in <tr> tag. Just imagine how useful it would be to give classes so it would look like this instead:
<tbody>
<tr class="weather, norain, connectionlost">
<td id="name">Pollin</td>
<td id="bigtext" class="rain">0.0 mm</td>
<td id="img">
</tr>
with that classes css designers could style every item better way, with no colors hardcoded and also, if there are classes in <tr> element it is easy to style anything inside this specific element.
groovy
Re: More css styles needed
Post by groovy »
+1
And not only colors are hardcoded. There is, for example, the text "Last Seen" hardcoded in "style.css", which gets overwritten at every update when I manually change it to reflect my language.
BTW: Is there a simple way to change the date-format from YYYY-MM-DD to, let's say, DD.MM.YYYY?
stlaha2007
Post by stlaha2007 »
+1
I second that it would be based on IDs and Classes.
For example. Add an id to the Header rows [scene/switch/temp etc] and add that id to style css...
Before last update i modified the index.html and added it myself to hide the header row.
Perhaps in settings an option to enable/disable header rows?
Sent from my D6603 using Tapatalk
