icon size on dashboard
dadarara
Post by dadarara »
setting the icon scale affects ALL icons on the floorplan in dashboard.
What if I want some icons to be bigger then others ?
importing my own icons sets them to the size of up to 48x48
tried to make them bigger but Domoticz presents them as 48x48.
is there a way to show diffrent ICON size in dashboard?
Reason: I use the picture of the family members as the ON status icon when they are home. the sensor is IP Ping. icons are located on the dashboard.
but in order to get bigger icons I need to create a second floorplan with diff scale . not very user friendly to move between the floorplans in dashboard.
thanks for any ideas.
Dnpwwo
Re: icon size on dashboard
Post by Dnpwwo »
The current scaling functionality caters for the fact that people will have differing resolutions for their floorplans so it allows people to make them a sensible size so that they are readable, useable and not stupidly large.
The change you are asking for is not trivial because the data model would need to be changed.
If this is really important to you then you could create a duplicate set of the standard icons and make them bigger with a transparent surround. That would cause them to look smaller in the floorplan for a given scale.
