Find the code
patouleboncoin91400
Find the code
Post by patouleboncoin91400 »
Hello I bought 2 aii taken and the frequency of 433hz and compatible domoticz . But more indication or remote , is there any software that will control each code one by one and lit the lamp plugged top end
cordially
b_weijenberg
Re: Find the code
Post by b_weijenberg »
Which device?
Check with RFXmngr if you receive codes with Lighting4 enabled.
RFXtrx433, RFXtrx433E, RFXtrx433XL, RFX433XL, RFX868XL
wolfguru
Re: Find the code
Post by wolfguru »
I have a similar issue. I can see the device is PT2262, Lighting 4, and the unit ID is for example 861434. But even though Domoticz can see this device, it cannot control it (it cannot switch it on or off).
I checked the RFXmgr and I can see it is alternating between 2 codes for the ON and 2 codes for the OFF, so the 1st ON has one code, the 2nd ON has a different code, then the 3rd ON has the same code as the 1st, and 4th ON has the same code as 2nd, and so on. Same for the OFF.
Anyone have experience with this? or can help with it? I can provide data from RFXmgr or logs if needed. Just ask.
Thanks.
ColinBresser
Re: Find the code
Post by ColinBresser »
I have same issue .. I can see code (Lighting 4) in RFXmgr also Domoticz, but I can not control the socket (Unitec 48111- device PT2262).
I think is problem with RFXcom (fw 1009), because with rpi-rf 0.9.6(https://pypi.python.org/pypi/rpi-rf) I can read and control the socket.
