How to change the refresh rate of domoticz?
vaibhav
Post by vaibhav »
Hello everyone,
I have connected temperature sensor DS18B20 to domoticz using MySensors library.
Temperature sensor is sending the temperature values once every 2 seconds but the value is being updated on domoticz once about 10 seconds.
How can I make it update the values faster?
Thank You,
Vaibhav
cogliostrio
Re: How to change the refresh rate of domoticz?
Post by cogliostrio »
You should probably look into a custom frontpage. I have seen some around here that I think updates more often than the standard domo interface.
On the other hand, what is it that your monitoring that is so critical you need updates so often?
vaibhav
Post by vaibhav »
cogliostrio wrote:You should probably look into a custom frontpage. I have seen some around here that I think updates more often than the standard domo interface.
I am working on a plant project that needs monitoring of few parameters like temp and humidity pretty fast. Which custom frontpage are you talking about? Can you direct me to it?
Also is there a way to force update by a click of a button or something?
cogliostrio
Sorry, I cant remember any specifics, you'd have to look around the forum.
A script/blockly event runs every second, acting on whatever input domotcz has then, so you could stil automate water/air etc needed based on your input. Or are you manually going to monitor the web interface, then do something based on temp/hum? Seems like a weird thing to do on an automation forum :P
vaibhav
Post by vaibhav »
:D
I know. Requirements state that the readings should be monitored quicker but 10sec is too much for the professors.
I'll look around for the custom front-page. There scripts your stew talking about, do we have to write them ourselves? Is there any tutorial or guide on how to do it?
