RFlink firmware R43 is available now!
- Stuntteam
Release 43 is available!
- New Device: MiLight WW/CW remote & Bulbs
- New Device: WH3 temperature sensors
- New Device: Alecto 1300 Wireless Plant Monitor
- New Device: Unitec W235 Climate sensor
- New Device: Jula / Marquant 943134 temperature sensor
- New Device: Inovalley SM200
- New Device: DC250 motor controller
- New Device: Maplin Weather Station N96GY, Fine Offset WH1080, Fine Offset WH1081, Watson W-8681,
Digitech XC0348 Weather Station, PCE-FWS 20, Elecsa AstroTouch 6975, Froggit WH1080
- New Device: Loh Electronics 02812 Temperature and Humidity sensor
- New Device: Excelvan weather station
- New Device: Master Electrician RC-012-1-TR-009
- New Device: Home Confort STHI 100 temperature/humidity sensor
- New Device: Ditec Garage Door remote control
- New Device: Acurite 609TXC (alternative protocol)
- New Device: WS7000-27, WS7000-28 Thermometer
- New Device: WS7000-25 Thermo/Humidity, WS7000-22 Thermo/Humidity
- New Device: WS7000-19 Brightness Luxmeter
- New Device: Holtek HT6P20 (and compatible) Door, Window and PIR sensors (Thanks: Douglas Gazineu)
- New Device: Ambient Weather / Frogit F007TH
- New Device: Ambient Weather / Frogit F007PF
- New Device: SelectPower switchset
- New Device: Profile led dasegno
- New Device: KERUI D026 Door Window Sensor
- New Device: LaCrosse TXT141-BV2
- New Device: Baldr B0317
- New Device: Atlantic MC-335 PIR
- New Device: RTS sensor protocol / Soliris
- New Device: RTS Extended protocol / Eolis 3D
- Fixed: Removed slash (/) from device names
- Fixed: Removed RTS and other debug data
- Fixed: Avidsen switch issue
- Fixed: Avidsen temperature data detection
- Fixed: Blyss & Avidsen pairing working correctly
- Fixed: AB440R signal detection
- Fixed: Chuango signal detection
- Fixed: Improved Promax detection
- Fixed: Additional check to make sure Milight send is not used when Milight support is disabled
- Fixed: WS2500-19 now correctly reporting Lux value
- Fixed: Milight RGBW Remote and WW/CW (Dual) Remote Control operating simultaneously with RGBW
- Fixed: Livolo On/Off state
- Fixed: Brel timing
- Fixed: Novatys detection
- Fixed: AMST606 detection issues
- Fixed: SelectRemote doorbell retransmission
- Fixed: Byron SX doorbell retransmissions
- Fixed: Byron SX doorbell recognition
- Fixed: Further improved the RF Environment Optimization System
- Fixed: improved the detection of Acurite devices
- Fixed: improved the detection of Cresta devices
- Fixed: improved the detection of Atlantic devices
- Added: NRF24L01 hardware detection, activating MiLight without NRF will result in MiLight being disabled
- Added: Smarthome YC-4000B protocol variant
- Added: New Brel protocol version
- Added: WS7000 protocol variant
Available on the download page at:
www.nemcon.nl/blog2
Enjoy!
www.nemcon.nl/blog2
Enjoy!
Re: RFlink firmware R43 is available now!
thanks!!
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
Thanks and wait for correct code for SOMFY which i send to you and write on forum...
- Stuntteam
make a new debug log with r43 and mail that..!
OK
But also found next problem. On new FW 43 i can not ON MiLight. Still show that no NRF24L01 and MiLight is OFF after click on button ON
This is log:
On FW 42 works ok.
Tell me also what is command for pair and switch Milight WHITE ? On your web site i only found command for RGB and RGBW. Please update manual also for MiLight White.
This is log:
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R43;
20;01;MiLight=OFF;NO NRF24L01;
10;version;
20;02;VER=1.1;REV=43;BUILD=0a;
10;milightnrf=on;
- sincze
- Domoticz version: 2024.4
tnx. Will wait for MILIGHT answer
currently running R42 without problems.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Stuntteam
There is a hardware detection to make sure the NRF24L01 is present. If it is not found Milight is disabled.
The detection routine has been tested and has not caused any issues. What module are you using and how did you wire it?
Perhaps not a NRF24L01+ module?
Also, on http://www.nemcon.nl/blog2/faq the faq, under Q: how to pair Milight bulbs without the original Milight remote control in Domoticz?
There are 3 options given, I figure you have option 1 the "Dual White" (warm white/cold white) bulb.
hi
I use NRF24L01 connect on the board RFLink. When ibwrite FW 42 and On Milight it show in logs ok that is On. But when i write FW43 and On Milight it show that activate but statusbin log is still that is OFF and NO NRF24L01
- Stuntteam
If RFlink disables Milight, it means the routine radio.isPVariant() has failed to detect your NRF module.
Check your NRF module and post exactly what is printed on the NRF chip
I think you are using a NRF24L01, not a NRF24L01+.. Please verify
hi
I check it. I use NRF which i buy with RFLink some months ago. It is NRF24L01+
And why on FW42 ok recognized NRF and show correct status ON/OFF ?
- Stuntteam
Your log indicates that your somfy is properly recognized.
You should follow the guides to pair and use it.
You NRF24L01+ is not detected. So far noone else has reported any problems and the detection routine is commonly used.
We will look into that later.
but why NRF24L01+ is not detected ? I buy RFlink withbthis module and why not working ? on Fw 42 show that works ok. how i can repaire it ?
- Domoticz version: BETA
Is there perhaps a option that:
https://nl.aliexpress.com/item/2016-Dig ... 102.OQFfAD
A nice and cheap compact outside sensor..
Incl a small display.
I do have 1 @ home
Please some tell me how?
I do have 1 @ home
No visonic no chacon power meter
Fronius plugin
https://github.com/ayasystems/froniusHttp
Solax plugin
https://github.com/ayasystems/SolaxHTTP
Openevse plugin
https://github.com/ayasystems/OpenEVSEPlugin
Solax plugin
Openevse plugin
can anybofy check that on FW43 working NRF24L01 and it working with milight white or RGBW ? please
please check that in serial logs after enable NRF24L01 show in log that module is ON. For me still show that is off.
But on FW42 show ok after enable that module is ON.
- Stuntteam
See PM.Derik wrote:Is there perhaps a option that:
Chacon / Efergy powermeter is using FSK modulation which can not reliably be received with a ASK receiver module.ayasystems wrote:No visonic no chacon power meter
Besides that it transmits with a 6 second interval which will influence the available bandwidth.
It will not be included for now.
Visonic implementation is still under development.
This has been verified already by many users. Both the NRF24L01+ detection and the Milight White, RGB as well as RGBW are working.piokuc wrote:can anybofy check that on FW43 working NRF24L01 and it working with milight white or RGBW ? please
We will look into your issue soon.
- Stuntteam
RFLink firmware was correct. You do not have a NRF24L01 wired for Milight use!
The wiring page on our site has the exact connection details for Milight use.
R43 works fine with Milight.
My Milights work fine with R43, both RGBW and Dual white.
osmc@osmc:~$ cat < /dev/ttyUSB0
20;8C;PONG;
20;8D;PONG;
20;8E;VER=1.1;REV=43;BUILD=0a;
20;8F;PONG;
20;01;MiLight=ON;
20;02;PONG;
