Best practices for Domoticz logfile?
shkaff
- Domoticz version: Stable
Re: Best practices for Domoticz logfile?
Gentlemen are you sure that HUP signal does its job?
In my case any attempts to run
/usr/bin/killall -HUP /home/pi/domoticz/domoticz
/usr/bin/killall -SIGHUP /home/pi/domoticz/domoticz
cause no visible effects in /var/log/domoticz.txt so I am not sure that this signal is handled by the domoticz at all
jake
I moved the log file to a RAM-drive and need to use logrotate to keep the size under control. I therefore used the given file in the /domoticz/scripts/logrotate folder and only modified the location of the log file to /tmp/log/domoticz.log
To do a test run with a forced logrotate
This gives the following result:
This is strange because both the folder /tmp and subfolder ./log and the domoticz.log file are owned by and part of the group 'root'
When I add 'su root root' to a new 2nd line in the configuration file for logrotate, I get the following message:
When I check the content of the /tmp/log/ folder, I only find a domoticz.log.1 file which is in use as the current log file, the original (and specified) domoticz.log file is transfered to this domoticz.log.1 file
Only when I restart the domoticz service, the domoticz.log file is recreated
What goes wrong here? The current situation doesn't help anything, my RAM disk stays just as full. Fail2ban won't work anymore, since the specified domoticz.log file is no longer there
What actually does the postrotate part of the script do?
Conifguration file for logrotate as given as example (and modfied with location and 'su root root' by me):
sudo logrotate -f /etc/logrotate.d/domoticzCode: Select all
error: skipping "/tmp/log/domoticz.log" because parent directory has insecure permissions (It's world writable or writable by group which is not "root") Set "su" directive in config file to tell logrotate which user/group should be used for rotation.When I add 'su root root' to a new 2nd line in the configuration file for logrotate, I get the following message:
error: error running non-shared postrotate script for /tmp/log/domoticz.log of '/tmp/log/domoticz.log 'Only when I restart the domoticz service, the domoticz.log file is recreated
tmp/log/domoticz.log {
su root root
missingok
weekly
rotate 7
compress
notifempty
postrotate
if [ -x /usr/sbin/invoke-rc.d ]; then \
invoke-rc.d domoticz reload > /dev/null; \
else \
/etc/init.d/domoticz reload > /dev/null; \
fi
endscript
jake
Still didn't find a solution. I wonder about the postrotate section. I have no clue what it means, but shouldn'tjake wrote: Wednesday 23 August 2017 21:00 Conifguration file for logrotate as given as example (and modfied with location and 'su root root' by me):Code: Select all
tmp/log/domoticz.log { su root root missingok weekly rotate 7 compress notifempty postrotate if [ -x /usr/sbin/invoke-rc.d ]; then \ invoke-rc.d domoticz reload > /dev/null; \ else \ /etc/init.d/domoticz reload > /dev/null; \ fi endscript }
invoke-rc.d domoticz reload > /dev/null; \Code: Select all
invoke-rc.d domoticz restart > /dev/null; \Code: Select all
error: error running non-shared postrotate script for /tmp/log/domoticz.log of '/tmp/log/domoticz.log 'Re: Best practices for Domoticz logfile?
In case other people still need an answer, I got it to work by using another postrotate command:
This is on Raspbian GNU/Linux 8
/tmp/log/domoticz.log {
missingok
weekly
rotate 7
size 1M
compress
notifempty
postrotate
service domoticz.sh restart
endscript
- waaren
I have a cron job that copies/var/log/domoticz.log to $logdir/domoticz_$timestamp.log. When successful, I do a sudo truncate -s 0 /var/log/domoticz.log
No need to stop / start domoticz
- Mick
Just sharing my working logrotate conf for domoticz (the key settings here being su and copytruncate):
In my case:
* domoticz is running non root, as its own user and group
* the log file is in a dir located on a RAM backed mount (/tmp)
* this dir and the the log file are owned by the the domoticz user and group
/your_path/to/domoticz.log {
#replace the above path with the path to your domoticz logfile
su (your_domoticz_logfile_user) (your_domoticz_logfile_group)
#replace the above user and group with the ones who own the logfile (use ls -la on the logfile)
missingok
notifempty
daily
rotate 7
size 1M
compress
copytruncate
pikapt
Thanks a lot Mick, I ended up with a very similar one. copytruncate option is the key
- rbisschops
- Domoticz version: 2.2563
Hi Thanks for this. Just one question. Does this work with restarting the Domoticz instance? I have Monit running, so a restart will trigger a warning.Mick wrote: Sunday 18 February 2018 3:18 Just sharing my working logrotate conf for domoticz (the key settings here being su and copytruncate):
In my case:Code: Select all
/your_path/to/domoticz.log { #replace the above path with the path to your domoticz logfile su (your_domoticz_logfile_user) (your_domoticz_logfile_group) #replace the above user and group with the ones who own the logfile (use ls -la on the logfile) missingok notifempty daily rotate 7 size 1M compress copytruncate }
Thx
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
The use of copytruncate doesn't require a restart. It does involve a race condition which could lead to loss of (log)data. Any data written between the copy and the truncate will get lost.
jake
As of my upgrade from 'Stretch' to 'Buster' logrotate doesn't work anymore for domoticz on a daily base. I did the upgrade on Feb 9, therefore the regular weekly log rotations haven't taken place yet, so I can't judge whether this a generic issue.
My logrotate configuration for domoticz, that used to work for 2 years fine:
Running the logrotate manually (--force), works just fine. It creates by re-running it again the setted max. 2 logiles and delete the oldest one on a 3rd run .
I checked the log file of logrotate itself in
There it shows 2020-2-19 as latest date, except domoticz, there the date stamp is from my manual forced run.
Logrotate.conf content:
The daily cron job:
I read that as of 'Buster' logrotate is run from systemd (don't know exactly why/wat that is, but anyway) instead of cron:
/etc/systemd/system/timers.target.wants/logrotate.timer:
I've tried everything I could find only, but did not find the root cause yet unfortunately. Help appreciated!
su root root
missingok
maxsize 7M
daily
copytruncate
# keep 3 days worth of backlogs
rotate 2
compress
# delaycompress
notifempty
postrotate
# if [ -x /usr/sbin/invoke-rc.d ]; then \
# invoke-rc.d domoticz restart > /dev/null; \
# else \
# /etc/init.d/domoticz restart > /dev/null; \
# fi
endscript
}Code: Select all
sudo logrotate -f /etc/logrotate.d/domoticzI checked the log file of logrotate itself in
cat /var/lib/logrotate/status Logrotate.conf content:
# see "man logrotate" for details
# rotate log files weekly
weekly
# keep 4 weeks worth of backlogs
rotate 4
# create new (empty) log files after rotating old ones
create
# use date as a suffix of the rotated file
#dateext
# uncomment this if you want your log files compressed
#compress
# packages drop log rotation information into this directory
include /etc/logrotate.d
# system-specific logs may be also be configured hereCode: Select all
sudo nano /etc/cron.daily/logrotate
#!/bin/sh
# skip in favour of systemd timer
if [ -d /run/systemd/system ]; then
exit 0
fi
# this cronjob persists removals (but not purges)
if [ ! -x /usr/sbin/logrotate ]; then
exit 0
fi
/usr/sbin/logrotate /etc/logrotate.conf
EXITVALUE=$?
if [ $EXITVALUE != 0 ]; then
/usr/bin/logger -t logrotate "ALERT exited abnormally with [$EXITVALUE]"
fi
exit $EXITVALUE/etc/systemd/system/timers.target.wants/logrotate.timer:
[Unit]
Description=Daily rotation of log files
Documentation=man:logrotate(8) man:logrotate.conf(5)
[Timer]
OnCalendar=daily
AccuracySec=12h
Persistent=true
[Install]
WantedBy=timers.target-
jake
Additonal to my previous post, here right above this one:
I checked the content of /var/log and found many proves of logrotate working properly, weekly logrotates were done today as I updated to Buster on Feb 9. Other logs, like syslog, have been rotated on a daily base, as specificied in it's config file.
So:
- logrotate seems to run fine by itself.
- It logrotates domoticz fine when done by hand, but not automatically.
The only remaining thing that I can think of now: Before, the log was rotated at 06:25 as specificied by cron.daily. Now systemd is handling it, it rotates all logs at 0:00. Is it possible that this is the main source of my problem? If so, I'd expect other users have the same problem.
So:
jake
I still don't get logrotate to work automatically since my upgrade to Buster. Running ma nually: fine, running automatically: not.
I added the same command line to the root crontab, but it doesn't want to run.
I checked permissions, but both /tmp /tmp/log and /tmp/log/domoticz.log are owned by root. It is very frustrating not finding the root cause of failure of the automaic process. All help still very much appreciated!
jake
I found one more difference: access rights to /tmp and /tmp/log were not equal to other folders with log files. with chmod 755 I was able to correct that for both folders. I can now also skip the "su root root" from the /etc/logrotate.d/domoticz file while it still runs fine manually. However, no luck in automatic runs.jake wrote:I still don't get logrotate to work automatically since my upgrade to Buster. Running manually: fine, running automatically: not.
# su root root
missingok
maxsize 7M
daily
copytruncate
# keep 2 days worth of backlogs
rotate 2
compress
# delaycompress
notifempty
postrotate
# else \
# fi
endscript
jake
Since I am out of options why Buster doesn't logrotate my domoticz log file, I try to keep the logfile in mind and do a manual logrotate once and a while, hoping that the RAM-disk is not (too)full to handle the rotate. This is what the output of the manual run is:
What to do?
- Spoiler: show
What to do?
dressie
- Domoticz version: V2020.2
I just installed this option, and indeed it won't work. Curious is anyone else has a working logrotation.
For now I put the " sudo logrotate -v /etc/logrotate.d/domoticz" in crontab.
jake
Does the crontab option work for you? For me it doesn't work either.dressie wrote:I just installed this option, and indeed it won't work. Curious is anyone else has a working logrotation.
dressie
I'll let you know within 24h.jake wrote: Monday 20 April 2020 9:04Does the crontab option work for you? For me it doesn't work either.dressie wrote:I just installed this option, and indeed it won't work. Curious is anyone else has a working logrotation.
dressie
Good news! It works on my side. Last night, or rather this morning a new file was created. I did change a few things in the script:jake wrote: Monday 20 April 2020 9:04Does the crontab option work for you? For me it doesn't work either.dressie wrote:I just installed this option, and indeed it won't work. Curious is anyone else has a working logrotation.
- Spoiler: show
10 0 * * * sudo logrotate -v /etc/logrotate.d/domoticz
EDIT: I also set up an test Raspberry without the crontab command, and it does work. I wonder why it does work on the test and not on my production PI. If I figured it out, I'll let you know.
jake
Well, i hoped you added some magic stuff in your rotate file. Howver it is identical to the one I have, except that I blocked both the lines 'post rotate' and end script above and beneath the already blocked script part. I now added the 'create 644 root root' to it. Quite a few other logrotate configurations have it as well. Let's see what it does tomorrow.dressie wrote:Good news! It works on my side. Last night, or rather this morning a new file was created. I did change a few things in the script:jake wrote: Monday 20 April 2020 9:04Does the crontab option work for you? For me it doesn't work either.dressie wrote:I just installed this option, and indeed it won't work. Curious is anyone else has a working logrotation.
In crontab:
- Spoiler: show
dressie
I got it to work!
I changed the following:
-moved the log file location from "/tmp" to "/var/log" (changed this in the /etc/init.d/domoticz.sh file)
- Created a new logrotation file:
Good luck, I hope this will work for you too!
P.S. this worked without the line in crontab -e.
/var/log/domoticz.log {
su root root
missingok
daily
copytruncate
rotate 2
compress
delaycompress
notifempty
postrotate
endscript
