[suggestion][poll] High resolution DC LED Dimmer with 8bit or 16bit steps,
Do you want a higher resolution LED Dimmer?
Yes: 8 bits would be nice (range from 0 to 256)
4
80%
Yes: 10 bits would be nice (range from 0 to 1025)
1
20%
No: I don't have custom LED dimmers. or Mine work on 230/110 VAC.
0
No votes
No: Because....
0
No votes
Total votes: 5
Joerideman
Post by Joerideman »
My platform: Raspberry pi 1B
My gateway: Mysensors serial gateway
My dimmers: Mysensors Dimmable LED dimmer, or a custom variant.
The current AC Dimmer is a low resolution dimmer and from what I can tell, one that conforms perfectly with standard dimmer modules they have 16 possible dimmer values.
In my home I use LED's powered by a 12V or 24V DC power supply. This means that I can very easily dim them in 255 or 1024 steps if I use a custom controller. (like the mysensors) It does require that Domotic gives a value.
The reason I want this: LED's show a significant change in intensity on the first 100 steps (on a scale from o to 255). It ain't lineair.
I've searched the forum and found two other topics with the same request.
viewtopic.php?f=42&t=11029&p=83873&hilit=dimmer#p83873
viewtopic.php?f=31&t=4759&hilit=dimmer+resolution
Did a lot of editing on this question. The poll is new and my specifications.
Joerideman
Re: [suggestion][poll] High resolution DC LED Dimmer with 8bit or 16bit steps,
I might be interested in creating this switch. Though I glanced at many lines of code for the current switch. It might not be that easy.
Joerideman
I would like to bump this one up. Hopefully more people will vote.
Joerideman
Boop :roll:
It's been a while. And perhaps it can have some more attention.
