I am looking for some cheap 433 MHZ temperature sensors that do not need any soldering or something like that.
Any advice ?
temperature sensor
- sincze
- Domoticz version: 2024.4
Re: temperature sensor
You mean like battery operated?? A complete device that can be used inside and outdoors??
Or separate items like
- 433 mhz sender
- temp humid sensor
- 433 mhz sender
- temp humid sensor
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
gennapium
- Domoticz version: Stable
Take a look here:
Temperature & Humidity Sensor compatible with RFXCOM/Domoticz
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
gennapium
search the forum "Banggood"
Thank you all. Why couldn't I find it myself
