blackdog65 wrote:I'd much prefer Google Home and I think it'll be better in the long term... but still not released!
BTW you can play google music on Amazon... kinda. It needs to be downloaded from GM then uploaded to AM. A bit of a pain, but I've made a start with my most played tracks.
Bugger that... I have about 40Gb of music in Google
It also depends on when Google Home is released and what it supports... If its not out until November (UK) then I might cancel the Dot but keep the Echo... If its not coming over here until 2017 then I will get the Dot as well..The Home also is much bigger than the Dot which I plan on celling mounting and running over POE.
The home if all it supports is google services (and whatever half baked home automation they think we want) then I might get a couple around the house... Hoping for Hue support so the HA Bridge option can be run in parallel with the Echo.
This for me is definitely the missing link for my automation. Original plan was a pi and touch screen in each room but voice will be way easier... The only worry I have is relying on third party support (HA Bridge) to keep it all tied together. Amazon or Philips could probably break it should they wish.
I have my google music streaming to kodi so I am trying to see if I can control that remotely
