OpenVPN on RaspberryPi
- havnegata
- Domoticz version: V4.10162
I have the Asus RT-N66U router with OpenVPN support. Previously I was on Windows with my Domoticz, but now I am on a Raspberry Pi. On Windows it was pretty easy. Just export the client file and put in respective Windows folder. I have been searching the forum and googling and the results I get is using the PI as an OpenVPN SERVER. But I just want to use my router as server and install something on the PI as a client. Anyone who can provide some steps here?
Re: OpenVPN on RaspberryPi
just google on "raspberry pi openvpn client configuration" You will find numerous examples on how to setup a client on raspbian
- Domoticz version: Stable
- Domoticz version: 3.5877
+1 for Pi vpn from Jan. I literally just found it last night and installed it. it did everything automatically minus installing some needed applications correctly. It tried to but failed so I had to do it manually but this was down to my pi apt-get sources were out of date so when it issused a apt-get upgrade it didn't find any updates because it needed to do an apt-get update first which the script doesn't do. After I made a backup of the sd card I upgraded then redid the install script everything went wonderfully now I am on my vpn as a write this
