I'm sorry, I cannot. It uses some linux specifics. But hopefully it will soon.toups wrote:could you pls confirm if dzVents could run directly on Windows ?dannybloe wrote:I will make a version in the coming days that will support multiple devices. It will be based on dzVents though because that allows me to check previous readings more easily. And it is much easier to support multiple 'rooms/devices'.
Lua script for controlling humidity in the bathroom Topic is solved
Re: Lua script for controlling humidity in the bathroom
Hi.
Any progress on the new version?
Ah... you got me
Didn't have the time yet.. will do in the coming days. Sorry
- Domoticz version: 2.4547
Hi Danny,dannybloe wrote:Ah... you got me
Any luck on this one?
I am hoping to spend my holidays to transfer to dZVents and this would be a nice starting point.
I have seen some comments on using dZVents in the internal lua editor (the one in the browser) but can't seem to find it anymore, any clue?
Thanks for all the hard work on this one!
BR,
Bram
JustME125 wrote:Hi Danny,dannybloe wrote:Ah... you got me
BR,
Bram
Mmm.. summer and vacation drove me out of the house and away from the computer and my home systems. Sorry about that.
The internal editor doesn't work with dzVents unfortunately.
Re: RE: Re: Lua script for controlling humidity in the bathroom
No problem, Invested some time in it last week and wrote it myself. Nice piece of work by the waydannybloe wrote:JustME125 wrote:Hi Danny,dannybloe wrote:Ah... you got me
BR,
Bram![]()
Verstuurd vanaf mijn HTC One_M8 met Tapatalk
- Lange1975
Hi Danny,
First of all thank you for your humidity control script.
But the script is behaving a bit strange. The user variable “humCounter” is refreshing every second and not every minute as you mention.
Also the fan stops within 5 minutes even when the humidity is still increasing.
Is there something that I might overlook?
Thank you in advance.
- Lange1975
It works perfect. But somehow after a couple of minutes it all stops. And I don't know why
franzelare wrote:I based my script on the script in the wiki, the difference is that I want 2 trip levels for humidity change, one for when someone takes a bath and one for the shower.
I have a 3 stage fanbox for my central exhaust system (always running on 1st stage) plus one additional build in pipe fan inside the chanel to the bathroom (because that used to stay moist with the normal fan or my kitchen exhaust flow was to low to get rid of all smells)
when someone takes a bath I only want to start the fanbox at stage 3, but when a shower also needs to trigger the additional fan.
this is where I ended up with, and is working fine for a few months now
commandArray = {} -- declare some constants -- adjust to your specific situation SAMPLE_INTERVAL = 5 -- time in minutes when a the script logic will happen FAN_DELTA_TRIGGER = 3 -- rise in humidity needed for a bath that will trigger the fan FAN_DELTA_TRIGGER2 = 6 -- rise in humidity needed for a shower that will trigger the fan FAN_MAX_TIME = 20 -- maximum amount of sample cycles the fan can be on, -- in case we never reach the target humidity TARGET_OFFSET = 2 -- ventilator goes off if target+offset is reached FAN_NAME = 'Ventilator 2' -- exact device name of the switch turning on/off the ventilator 2 (itho fan box stand 2) FAN_NAME2 = 'Ventilator 3' -- exact device name of the switch turning on/off the ventilator 3 (itho fan box stand 3) FAN_NAME3 = 'Ventilator 4' -- exact device name of the switch turning on/off the ventilator 4 (additional bathroom fan) SENSOR_NAME = 'Badkamer' -- exact device name of the humidity sensor TEST_MODE = false -- when true TEST_MODE_HUMVAR is used instead of the real sensor TEST_MODE_HUMVAR = 'testHumidity' -- fake humidity value, give it a test value in domoticz/uservars PRINT_MODE = false -- when true wil print output to log and send notifications if PRINT_MODE == true then print('Fan control') end -- get the global variables: -- this script runs every minute, humCounter is used to create SAMPLE_INTERVAL periods humCounter = tonumber(uservariables['humCounter']) humidityTmin5 = tonumber(uservariables['humidityTmin5']) -- youngest reading humidityTmin10 = tonumber(uservariables['humidityTmin10']) -- oldest reading targetFanOffHumidity = tonumber(uservariables['targetFanOffHumidity']) -- target humidity fanMaxTimer = tonumber(uservariables['fanMaxTimer']) fanFollowsProgram = tonumber(uservariables['fanFollowsProgram']) -- marker indicating that the programm is runing for a bath fan3FollowsProgram = tonumber(uservariables['fan3FollowsProgram']) -- marker indicating that the programm is runing for a shower target = 0 -- will hold the target humidity when the program starts -- get the current humidity value if (TEST_MODE) then current = tonumber(uservariables[TEST_MODE_HUMVAR]) else current = otherdevices_humidity[SENSOR_NAME] end -- check if the sensor is on or has some weird reading if (current == 0 or current == nil) then print('current is 0 or nil. Skipping this reading') return commandArray end if PRINT_MODE == true then print('Current humidity:' .. current) print('targetFanOffHumidity:' .. targetFanOffHumidity) print('humidityTmin5: ' .. humidityTmin5) print('humidityTmin10: ' .. humidityTmin10) print('fanMaxTimer: ' .. fanMaxTimer) print('humCounter:' .. humCounter) print('fanFollowsProgram:' .. fanFollowsProgram) print('fan3FollowsProgram:' .. fan3FollowsProgram) end -- increase cycle counter humCounter = humCounter + 1 if (humCounter >= SAMPLE_INTERVAL) then if (humidityTmin5 == 0) then -- initialization, assume this is the first time humidityTmin5 = current humidityTmin10 = current end humCounter = 0 -- reset the cycle counter -- pick the lowest history value to calculate the delta -- this also makes sure that two relative small deltas in the past 2*interval minutes are treated as one larger rise -- and therefore will still trigger the ventilator -- I don't want to use a longer interval instead because I want the ventilator to start as soon as possible -- (so rather after 5 minutes instead of after 15 minutes because the mirrors in the bathroom become kinda useless ;-) delta = current - math.min(humidityTmin10, humidityTmin5) if PRINT_MODE == true then print('Delta: ' .. delta) end -- pick the lowest history value target = math.min(humidityTmin10, humidityTmin5) + TARGET_OFFSET -- shift the previous measurements humidityTmin10 = humidityTmin5 -- and store the current humidityTmin5 = current if (otherdevices[FAN_NAME]=='Off' or (otherdevices[FAN_NAME]=='On' and fanFollowsProgram==0)) then -- either the fan is off or it is on but the decrease program has not started -- in that latter case we start the program anyway. This could happen if someone turns on the ventilator -- manually because he/she is about to take a shower and doesn't like damp mirrors. -- I don't do this because the ventilator removes heat from the bathroom and I want this to happen -- as late as possible ;-) if (fanFollowsProgram == 1 and otherdevices[FAN_NAME]=='Off') then -- likely someone turned off the ventilator while the program was running fanFollowsProgram = 0 end -- see if we have to turn it on for the shower if (delta >= FAN_DELTA_TRIGGER2) then -- time to start the extra fan commandArray[FAN_NAME] = 'On' commandArray[FAN_NAME2] = 'On' commandArray[FAN_NAME3] = 'On' targetFanOffHumidity = target fanFollowsProgram = 1 fan3FollowsProgram = 1 -- set the safety stop fanMaxTimer = FAN_MAX_TIME if PRINT_MODE == true then print('Large rise in humidity. Turning on the exra vent. Delta: ' .. delta) print('Target humidity for turning the ventilator: ' ..targetFanOffHumidity) commandArray['SendNotification'] = 'Ventilator is on#The extra ventilator was activated at humidity level ' .. current .. '#0' end end -- see if we have to turn it on for the bath if (delta >= FAN_DELTA_TRIGGER) then -- time to start the fan commandArray[FAN_NAME] = 'On' commandArray[FAN_NAME2] = 'On' targetFanOffHumidity = target fanFollowsProgram = 1 -- set the safety stop fanMaxTimer = FAN_MAX_TIME if PRINT_MODE == true then print('Rise in humidity. Turning on the vents. Delta: ' .. delta) print('Target humidity for turning the ventilator: ' ..targetFanOffHumidity) commandArray['SendNotification'] = 'Ventilator is on#The ventilator was activated at humidity level ' .. current .. '#0' end end else if (fanMaxTimer > 0) then -- possible that someone started the ventialator manually fanMaxTimer = fanMaxTimer - 1 end if (fanFollowsProgram == 1) then -- not manually started if (delta >= FAN_DELTA_TRIGGER) then -- ok, there is another FAN_DELTA_TRIGGER rise in humidity -- when this happen we reset the fanMaxTimer to a new count down -- because we have to ventilate a bit longer due to the extra humidity if PRINT_MODE == true then print('Another large increase detected, resetting max timer. Delta: ' .. delta) end fanMaxTimer = FAN_MAX_TIME end -- first see if it can be turned off if (current <= targetFanOffHumidity or fanMaxTimer==0) then commandArray[FAN_NAME] = 'Off' commandArray[FAN_NAME2] = 'Off' commandArray[FAN_NAME3] = 'Off' msg = '' if (fanMaxTimer == 0 and current > targetFanOffHumidity) then msg = 'Target not reached but safety time-out is triggered.' if PRINT_MODE == true then print(msg) end else msg = 'Target humidity reached' if PRINT_MODE == true then print(msg) end end if PRINT_MODE == true then print('Turning off the ventilator') msg = msg .. '\nTurning off the ventilator' end targetFanOffHumidity = 0 fanMaxTimer = 0 fanFollowsProgram = 0 fan3FollowsProgram = 0 -- reset history in this case.. we start all over -- Tmin10 is still in the 'ventilator=On'-zone humidityTmin10 = humidityTmin5 if PRINT_MODE == true then commandArray['SendNotification'] = 'Ventilator is off#' .. msg .. '#0' end else -- we haven't reached the target yet if PRINT_MODE == true then print('Humidity delta: ' .. delta) end end end end if PRINT_MODE == true then print('New values >>>>>>>>>>>') print('humidityTmin5: ' .. humidityTmin5) print('humidityTmin10: ' .. humidityTmin10) print('fanMaxTimer: ' .. fanMaxTimer) print('humCounter:' .. humCounter) print('fanFollowsProgram:' .. fanFollowsProgram) print('fan3FollowsProgram:' .. fan3FollowsProgram) print('------ target: ' .. targetFanOffHumidity) end end -- save the globals commandArray['Variable:humCounter'] = tostring(humCounter) commandArray['Variable:humidityTmin10'] = tostring(humidityTmin10) commandArray['Variable:humidityTmin5'] = tostring(humidityTmin5) commandArray['Variable:targetFanOffHumidity'] = tostring(targetFanOffHumidity) commandArray['Variable:fanMaxTimer'] = tostring(fanMaxTimer) commandArray['Variable:fanFollowsProgram'] = tostring(fanFollowsProgram) commandArray['Variable:fan3FollowsProgram'] = tostring(fan3FollowsProgram) return commandArray
Re: RE: Re: RE: Re: Lua script for controlling humidity in the bathroom
This is my code, please note that it is modified because I have more programs on my ventilation system running so this is part of a bigger picture.JustME125 wrote:No problem, Invested some time in it last week and wrote it myself. Nice piece of work by the waydannybloe wrote:JustME125 wrote:
Hi Danny,
BR,
Bram![]()
This script checks the humidity level in the bathtroom to detect showering activity
When the humidify program is running, it sets the fanProgram variable to 1 (0 for manual and 2 for automatic mode)
This script runs every 5 minutes and compares it against the previous reading, when the delta is exceeds a threshold we can assume somebody is taking a shower
return{
active = true,
on = {['timer'] = 'every 5 minutes'},
data = { humidity = { history = true, maxItems = 2 }, targetFanOffHumidity = { initial = 100}, previousVentilationStatus = {initial = 99} }, -- we now have the t-5 and t-10 values in the history
execute = function(domoticz)
-- devices
local sensor = domoticz.devices['Badkamer']
local fan = domoticz.devices['$Ventilation Control']
local ventilation = domoticz.devices['Ventilation']
-- variables
local humTmin5 = domoticz.data.humidity.get(1) -- get the data with timestamp
local humTmin10 = domoticz.data.humidity.get(2) -- get the data with timestamp
humTmin5 = humTmin5.data
humTmin10 = humTmin10.data
local currentHumidity
local delta
local target
local fanMode = domoticz.variables['fanMode']
-- constants
TARGET_OFFSET = 2
TEST_MODE = false
TEST_MODE_HUMVAR = 10
-- TEST mode
if(TEST_MODE) then
currentHumidity = TEST_MODE_HUMVAR
domoticz.log("Test mode active", domoticz.LOG_INFO)
currentHumidity = sensor.humidity
if(humTmin5 == 0 or humTmin5 == nil) then -- initialization, assume this is the first time
humTmin5 = currentHumidity
humTmin10 = currentHumidity
delta = currentHumidity - math.min(humTmin10,humTmin5)
target = math.min(humTmin10, humTmin5) + TARGET_OFFSET
-- write the history, this pushes the current into history 1, which will become t-5 in the next run
-- and pushes the current history 1 to history 2 which will become t-10 in the next run
domoticz.data.humidity.add(currentHumidity)
-- Now we have figured out the delta humidity so we can decide what to do
if(fan.state == 'Off' or (fan.state ~= 'Off' and fanMode.value == 0) or (fan.state ~= 'Off' and fanMode.value == 2)) then
-- Either the fan is off or the fan is on but the humidity program is not running (manual mode or automatic mode)
-- in the last two cases we start with the humidity program anyway
-- This could happen if someone turns on the ventilator
-- see if we need to turn on the fan
if(delta >= FAN_DELTA_TRIGGER) then
-- turn it on and set the fanMode
domoticz.data.targetFanOffHumidity = target
domoticz.data.previousVentilationStatus = ventilation.state -- save the current control state before changing so we can give control back when ready
fan.switchSelector(30)
domoticz.variables['fanMode'].set(1)
if (fanMode.value == 1) then
domoticz.log("Ventilator was already on but we start the de-humidifying program", domoticz.LOG_INFO)
domoticz.log("Rise in humidity. Turning on the fan. Delta: " .. delta, domoticz.LOG_INFO)
domoticz.log("Target humidity for turning the ventilator off: " ..domoticz.data.targetFanOffHumidity, domoticz.LOG_INFO)
if (fanMode.value == 1) then -- not manually started
-- ok, another rise in humidity detected
-- when this happens we restart the whole program
-- so we have new 2 hours time frame
domoticz.log("Another large increase detected, resetting max timer. Delta: " .. delta, domoticz.LOG_INFO)
-- first check if we can turn off the fan
if(currentHumidity <= domoticz.data.targetFanOffHumidity or fan.lastUpdate.minutesAgo > 120) then
-- we can, so we revert to the state before the program started
if(domoticz.data.previousVentilationStatus == 'Off') then
ventilation.switchSelector(0)
if(domoticz.data.previousVentilationStatus == 'Low') then
ventilation.switchSelector(10)
if(domoticz.data.previousVentilationStatus == 'Medium') then
ventilation.switchSelector(20)
if(domoticz.data.previousVentilationStatus == 'High') then
ventilation.switchSelector(30)
if(domoticz.data.previousVentilationStatus == 'Automatic') then
ventilation.switchSelector(40)
-- now we want to log what happened
if(fan.lastUpdate.minutesAgo > 120 and currentHumidity > domoticz.data.targetFanOffHumidity) then
domoticz.log("Target not reached but safety time-out is triggered", domoticz.LOG_INFO)
domoticz.log("Target humidity reached", domoticz.LOG_INFO)
domoticz.log("Reverting back to: " ..domoticz.data.previousVentilationStatus .. " mode", domoticz.LOG_INFO)
domoticz.data.targetFanOffHumidity = 0
domoticz.log("Humidity delta: " ..delta .."%", domoticz.LOG_INFO)
Unfortunately I don't have much time lately to look into this very thoroughly but I would be very surprised if the script is run every second as this is not how Domoticz works. Unless you renamed the script and made it an event-based script instead of a time-based script. Make sure the filename of the script if script_time_<name>.lua and not script_device_<name>.lua. In the later case it will be executed everytime some device triggers the eventsystem which can be every second.JustME125 wrote:This is my code, please note that it is modified because I have more programs on my ventilation system running so this is part of a bigger picture.JustME125 wrote:No problem, Invested some time in it last week and wrote it myself. Nice piece of work by the waydannybloe wrote:
Verstuurd vanaf mijn HTC One_M8 met TapatalkCode: Select all
--[[ This script checks the humidity level in the bathtroom to detect showering activity When the humidify program is running, it sets the fanProgram variable to 1 (0 for manual and 2 for automatic mode) This script runs every 5 minutes and compares it against the previous reading, when the delta is exceeds a threshold we can assume somebody is taking a shower --]] return{ active = true, on = {['timer'] = 'every 5 minutes'}, data = { humidity = { history = true, maxItems = 2 }, targetFanOffHumidity = { initial = 100}, previousVentilationStatus = {initial = 99} }, -- we now have the t-5 and t-10 values in the history execute = function(domoticz) -- devices local sensor = domoticz.devices['Badkamer'] local fan = domoticz.devices['$Ventilation Control'] local ventilation = domoticz.devices['Ventilation'] -- variables local humTmin5 = domoticz.data.humidity.get(1) -- get the data with timestamp local humTmin10 = domoticz.data.humidity.get(2) -- get the data with timestamp humTmin5 = humTmin5.data humTmin10 = humTmin10.data local currentHumidity local delta local target local fanMode = domoticz.variables['fanMode'] -- constants TARGET_OFFSET = 2 FAN_DELTA_TRIGGER = 3 TEST_MODE = false TEST_MODE_HUMVAR = 10 -- TEST mode if(TEST_MODE) then currentHumidity = TEST_MODE_HUMVAR domoticz.log("Test mode active", domoticz.LOG_INFO) else currentHumidity = sensor.humidity end if(humTmin5 == 0 or humTmin5 == nil) then -- initialization, assume this is the first time humTmin5 = currentHumidity humTmin10 = currentHumidity end -- pick the lowest history value to calculate the delta -- this also makes sure that two relative small deltas in the past 2*interval minutes are treated as one larger rise -- and therefore will still trigger the ventilator -- I don't want to use a longer interval instead because I want the ventilator to start as soon as possible -- (so rather after 5 minutes instead of after 15 minutes because the mirrors in the bathroom become kinda useless ;-) delta = currentHumidity - math.min(humTmin10,humTmin5) -- pick the lowest history value target = math.min(humTmin10, humTmin5) + TARGET_OFFSET -- write the history, this pushes the current into history 1, which will become t-5 in the next run -- and pushes the current history 1 to history 2 which will become t-10 in the next run domoticz.data.humidity.add(currentHumidity) -- Now we have figured out the delta humidity so we can decide what to do if(fan.state == 'Off' or (fan.state ~= 'Off' and fanMode.value == 0) or (fan.state ~= 'Off' and fanMode.value == 2)) then -- Either the fan is off or the fan is on but the humidity program is not running (manual mode or automatic mode) -- in the last two cases we start with the humidity program anyway -- This could happen if someone turns on the ventilator -- manually because he/she is about to take a shower and doesn't like damp mirrors. -- I don't do this because the ventilator removes heat from the bathroom and I want this to happen -- as late as possible ;-) -- see if we need to turn on the fan if(delta >= FAN_DELTA_TRIGGER) then -- turn it on and set the fanMode domoticz.data.targetFanOffHumidity = target domoticz.data.previousVentilationStatus = ventilation.state -- save the current control state before changing so we can give control back when ready fan.switchSelector(30) domoticz.variables['fanMode'].set(1) if (fanMode.value == 1) then domoticz.log("Ventilator was already on but we start the de-humidifying program", domoticz.LOG_INFO) end domoticz.log("Rise in humidity. Turning on the fan. Delta: " .. delta, domoticz.LOG_INFO) domoticz.log("Target humidity for turning the ventilator off: " ..domoticz.data.targetFanOffHumidity, domoticz.LOG_INFO) end else if (fanMode.value == 1) then -- not manually started if(delta >= FAN_DELTA_TRIGGER) then -- ok, another rise in humidity detected -- when this happens we restart the whole program -- so we have new 2 hours time frame fan.switchSelector(30) domoticz.log("Another large increase detected, resetting max timer. Delta: " .. delta, domoticz.LOG_INFO) domoticz.variables['fanMode'].set(1) end -- first check if we can turn off the fan if(currentHumidity <= domoticz.data.targetFanOffHumidity or fan.lastUpdate.minutesAgo > 120) then -- we can, so we revert to the state before the program started if(domoticz.data.previousVentilationStatus == 'Off') then ventilation.switchSelector(0) end if(domoticz.data.previousVentilationStatus == 'Low') then ventilation.switchSelector(10) end if(domoticz.data.previousVentilationStatus == 'Medium') then ventilation.switchSelector(20) end if(domoticz.data.previousVentilationStatus == 'High') then ventilation.switchSelector(30) end if(domoticz.data.previousVentilationStatus == 'Automatic') then ventilation.switchSelector(40) end -- now we want to log what happened if(fan.lastUpdate.minutesAgo > 120 and currentHumidity > domoticz.data.targetFanOffHumidity) then domoticz.log("Target not reached but safety time-out is triggered", domoticz.LOG_INFO) else domoticz.log("Target humidity reached", domoticz.LOG_INFO) end domoticz.log("Reverting back to: " ..domoticz.data.previousVentilationStatus .. " mode", domoticz.LOG_INFO) domoticz.data.targetFanOffHumidity = 0 -- reset history in this case.. we start all over -- Tmin10 is still in the 'ventilator=On'-zone humidityTmin10 = humidityTmin5 else -- we haven't reached the target yet domoticz.log("Humidity delta: " ..delta .."%", domoticz.LOG_INFO) end end end end }
Re: RE: Re: RE: Re: RE: Re: Lua script for controlling humidity in the bathroom
Mine is running every 5 minutes, no issue with it at all. I think you would want to comment on the other questiondannybloe wrote:Unfortunately I don't have much time lately to look into this very thoroughly but I would be very surprised if the script is run every second as this is not how Domoticz works. Unless you renamed the script and made it an event-based script instead of a time-based script. Make sure the filename of the script if script_time_<name>.lua and not script_device_<name>.lua. In the later case it will be executed everytime some device triggers the eventsystem which can be every second.JustME125 wrote:This is my code, please note that it is modified because I have more programs on my ventilation system running so this is part of a bigger picture.JustME125 wrote: No problem, Invested some time in it last week and wrote it myself. Nice piece of work by the way
Ah, crap, you're rightJustME125 wrote:Mine is running every 5 minutes, no issue with it at all. I think you would want to comment on the other questiondannybloe wrote:Unfortunately I don't have much time lately to look into this very thoroughly but I would be very surprised if the script is run every second as this is not how Domoticz works. Unless you renamed the script and made it an event-based script instead of a time-based script. Make sure the filename of the script if script_time_<name>.lua and not script_device_<name>.lua. In the later case it will be executed everytime some device triggers the eventsystem which can be every second.JustME125 wrote: This is my code, please note that it is modified because I have more programs on my ventilation system running so this is part of a bigger picture.
. This was just FYI post.
Unfortunately I don't have much time lately to look into this very thoroughly but I would be very surprised if the script is run every second as this is not how Domoticz works. Unless you renamed the script and made it an event-based script instead of a time-based script. Make sure the filename of the script if script_time_<name>.lua and not script_device_<name>.lua. In the later case it will be executed every time some device triggers the event-system which can be every second.Lange1975 wrote:Hi Danny,
- Lange1975
Danny I Found the problem. It was exact as you described below. It was event-based and NOT time-based.
Thank you for your help.
A minor other question. Do you have experience with Nest Protect V2?
I’m curious to know if Domoticz is able to see/read the CO and CO2 values that the Nest sensors can pick up. If so then there is the option to use the Nest sensors to trigger the fan if the CO2 levels are getting high.
dannybloe wrote:Unfortunately I don't have much time lately to look into this very thoroughly but I would be very surprised if the script is run every second as this is not how Domoticz works. Unless you renamed the script and made it an event-based script instead of a time-based script. Make sure the filename of the script if script_time_<name>.lua and not script_device_<name>.lua. In the later case it will be executed every time some device triggers the event-system which can be every second.Lange1975 wrote:Hi Danny,
Good to hear. I was suspecting that. But no, I don't have any nests at home except my home itselfLange1975 wrote:Danny I Found the problem. It was exact as you described below. It was event-based and NOT time-based.
not with nest but working to get NH3 sensing also installed since I have a toilet in the bathroom and want to do some smell control in case needed...Lange1975 wrote:Danny I Found the problem. It was exact as you described below. It was event-based and NOT time-based.
will post that when it is finished, that will be mysensor based for the NH3 and using 2 sensor nodes and some tube fans to control the flow from the toilets/bathroom/kitchen
- Lange1975
What's a Nh3 season?franzelare wrote:not with nest but working to get NH3 sensing also installed since I have a toilet in the bathroom and want to do some smell control in case needed...Lange1975 wrote:Danny I Found the problem. It was exact as you described below. It was event-based and NOT time-based.
Verstuurd vanaf mijn SM-G935F met Tapatalk
sorry, methane, was working on an NH3 related issue for my work at the same timeLange1975 wrote:What's a Nh3 season?
using an MQ-4 sensor
The temperature part of sensor is more sensitive than the humidity part. I am thinking of re-writing the code and use the rise of temperature as trigger. Before I go into this: has anybody done this already?
(I don't like the current trigger mechanism. Allthough I narrowed the treshold, the fan start too late or not at all)
I had that thought myselfs too. Maybe you can start with my improved script? See here below.renerene wrote:The temperature part of sensor is more sensitive than the humidity part. I am thinking of re-writing the code and use the rise of temperature as trigger. Before I go into this: has anybody done this already?
