Find My iPhone implementation in LUA script
mvzut
Re: Find My iPhone implementation in LUA script
Post by mvzut »
mcmikev wrote:Just discovered that It is not the switch name but device name of the iphone :shock: :shock:
Changed that and now I get more :-)
But get error from line 53
2016-09-14 12:16:19.411 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_checkphones.lua: /home/pi/domoticz/scripts/lua/script_time_checkphones.lua:53: bad argument #1 to 'sub' (string expected, got nil)
Ah, that's another thing that apparently needs some polishing. I wanted to only update the text devices when their location has changed significantly (I use the "radius" variable for that again). I get the "old" distance from the text device itself. However, new text devices automatically contain the text "Hello world!", so you won't find any distance in there, and the script stops because LUA doesn't want to work with empty strings. I tried to solve it with the 'if prev_distance == nil then prev_distance = 1000 end" line, to give it an initial value that is large enough so that the text device gets updated, but it doesn't even get to that point apparently. You could change the contents of the text field into something like "(1000 km)" by hand, but I don't find that a very elegant solution. I think I found a better solution now:
Please change these lines
prev_dist = tonumber(string.sub(string.match(otherdevices['Position ' .. user], '%(.*%)'), 2,-5))
into this
prev_distance_str = string.match(otherdevices['Position ' .. user], '%(.*%)') or '(1000 km)'
prev_dist = tonumber(string.sub(prev_distance_str, 2,-5))
Last edited by mvzut on Wednesday 14 September 2016 13:38, edited 1 time in total.
mcmikev
Post by mcmikev »
Tried this, but same results however.
mvzut
Post by mvzut »
mcmikev wrote:Tried this, but same results however.
What is the error code now? In which line (ideally give me the contents of that line)?
cattoo
Domoticz version: 2.3072
Post by cattoo »
into this
prev_distance_str = string.match(a, '%(.*%)')
if prev_distance_str == nil then prev_distance_str = '(1000 km)' end
Changed to that, but ill still got error
Error: EventSystem: in Check_iphone: [string "-- Script to check the location of multiple i..."]:54: bad argument #1 to 'match' (string expected, got nil)
mcmikev
Post by mcmikev »
Same here.
Error :
2016-09-14 13:38:05.117 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_checkphones.lua: /home/pi/domoticz/scripts/lua/script_time_checkphones.lua:53: bad argument #1 to 'match' (string expected, got nil)
Line:
mvzut
Post by mvzut »
mcmikev wrote:Same here.
Error :
Line:
Ouch, I feel like a fool, I used a temporary variable "a" to test the new code, but forgot to change that again. I have updated my post (five messages ago), plus the original post, for the correct syntax. Sorry!
Last edited by mvzut on Wednesday 14 September 2016 13:43, edited 1 time in total.
mcmikev
Post by mcmikev »
That did it. Working now !!
mvzut
Post by mvzut »
mcmikev wrote:That did it. Working now !!
Great! Sorry that it took some fiddling, but let's look at it from the positive side: your problems helped to improve the script, and hopefully prevent others from having the same issues ;-)
mcmikev
Post by mcmikev »
That is true. I really was thinking that I was doing it wrong ;-)
I like this idea and how you can use this.
Thanks!!!
cattoo
Post by cattoo »
Is the original script updated? So i could let go for the moment and fix everything after work?
mvzut
Post by mvzut »
cattoo wrote:Is the original script updated? So i could let go for the moment and fix everything after work?
Yes, I updated it. Please let me know if it works now!
cattoo
Post by cattoo »
Okey, i took the script now from the first post, and i still got errors..
 Error: EventSystem: in Check_iphone: [string "-- Script to check the location of multiple i..."]:53: bad argument #1 to 'match' (string expected, got nil)
2016-09-14 14:35:30.046 H
mvzut
Post by mvzut »
cattoo wrote:Okey, i took the script now from the first post, and i still got errors..
That probably means you don't have a text device called "Position Person1" for each person (replacing Person1 by the names that you put in the "user" array for every user, i.e. the names you replaced "Person1" etc with). Could that be the case? I could build in a check to avoid that the script stops because it can't find the text device (I probably will indeed add that) but that doesn't help you directly: I guess you want the text devices to display the current position, right?
If you DO have text devices named in exactly the right way, there is one last thing you could try: change
into
prev_distance_str = string.match(otherdevices_svalues['Position ' .. user], '%(.*%)') or '(1000 km)'
That seemed to help for at least one user.
cattoo
Post by cattoo »
Thank you, completely missed "Position Person1" text switch. My bad! Hopefully the "home" switch will activate when i get home :D
Egregius
Domoticz version: v2024.7
Post by Egregius »
Yes, 5 minutes later :P
mvzut
Post by mvzut »
Egregius wrote:Yes, 5 minutes later :P
To be precise: somewhere between 0:01 and 4:59 minutes later Image
deejc
Domoticz version: 3.5641
Post by deejc »
hi,
i got this to work 1 time, but it wont fire any more.
restarted domoticz etc, resaved an event to reset the events system but it does not fire, nothing in the log etc.. very strange.. any ideas if i can force it to run to see if it logs anything ?
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
mvzut
Post by mvzut »
deejc wrote:hi,
If your position doesn't change no device will update and you won't see anything in the log. Are you really sure the script is not running? You can check by putting a "print('test')" command in the top, directly after "commandArray = {}". If you don't see this in your log, and you named the script correctly (i.e. script_time_something.lua) then I'm afraid I'm out of advice to give...
deejc
Post by deejc »
mvzut wrote: If your position doesn't change no device will update and you won't see anything in the log. Are you really sure the script is not running? You can check by putting a "print('test')" command in the top, directly after "commandArray = {}". If you don't see this in your log, and you named the script correctly (i.e. script_time_something.lua) then I'm afraid I'm out of advice to give...
Blimey.. thats good, it is working, well it prints the test at any rate.
i expected to see some lat,long output in the log, guess i'll find out tomorrow when i leave :D
thanks a lot
deejc
Post by deejc »
i actually read the thread start to finish and found the line
print('iPhone ' .. user .. ': ' .. math.floor(distance*100+0.5)/100 .. ' km from home')
so i enabled it and i see the output!
working perfectly, nice one, i came from Vera and i know the plugin this mimics, that plugin has some logic that shortens or lengthens the ping time based on the distance away from home, that would be great addition.
