I am quite unfamiliar with Bash and I have managed to make a rudi-mental script for what I want, however it doesn't always work.
What I want:
when I flick a (virtual) switch, I want the following to happen:
1) switch on a KAKA switch
2) wait for my Harmony Hub to come online (preferably via ping)
3) wait 5 seconds
4) select the right program for the Hub (TV and surround on and at right channels etc)
5) wait 5 seconds
6) Wake my HTPC
Right now I have set up a script that does step 1,4 and 6 via a curl command and the rest via sleep. However I have not managed to check for the Hub via Bash, so right now I wait 2 minutes, however, this occasionally does not work, so I'd like to send the commands when the Hub is online.
Anybody able to help me?
Cheers,
Freek
BASH and events
nosehook
BASH and events
Pi3 Domoticz | RFXcom 433E | KAKU/COCO |Harmony Hub | Samsung TV | HS100 | HS110| HUE | Tradfri | Tado| Xiaomi |sensors | scripts| Pi3 Node Red | Pi2 SDS_011 + MH-Z19B | PiAware (zero) | Pi2 breadboard with Node red and Domoticz
- Egregius
- Domoticz version: v2024.7
Re: BASH and events
Does the hub have a api you can call? Like json or something?
nosehook
Re: BASH and events
No not that I am aware no, however Domoticz can communicate with it
- Egregius
Re: BASH and events
In step 4 you do a curl. That should be a api.
What is the url? What is the output if you open that url in a browser?
nosehook
Re: BASH and events
I don't know if it can be done with an API, therefore I use the url and therefore I want to check via a ping if the Hub is online.
IF it is doable via an API, where do I find the info?
