I have a camera HEDEN HD ref CAMHD03FX0 whom I do not manage to run with the Raspberry pi 3 while the same camera works under Windows 7.
Release Domiticz Windows 7 : v3.48.34
Release Domoticz Raspberry Pi 3 : v3.48.34 (domoticz-raspberrypi-sdcard-4834.7z)
Edit Camera (Release Windows 7 and Raspberry Pi3)
IP : 192.168.X.XX
Port : 80
Username : camera
Password : ………….
ImageURL : tmpfs/snap.jpg?
Test connection it’s OK
The display of preview is not visible
L’affichage d’apercu n’est visible
Take Snashop it is not ok
Stream video it is not ok
That it is the problem with the Raspberry Pi3 ?
Problem preview will be on camera HEDEN
bobjones62
bobjones62
Re: Problem preview will be on camera HEDEN
Somebody would have a solution to my problem of display ?
KingOfNuls
Same problem here with another model.
Cam works ok on RPI 2 (debian wheezy 7.11 = $ cat /etc/debian_version) but not on RPI 3 (jessie 8.0).
Domoticz 3.5623 on both RPI.
Last edited by KingOfNuls on Thursday 15 September 2016 13:34, edited 1 time in total.
RPI B - domotiga connected to my visonic alarm
RPI 2 - domoticz connected to 1 wire temp sensors and teleinfo ("power smartmeter")
RPI 3 - domoticz master with mysensors and RFLink gateways
KingOfNuls
Problem solved on my side.
Solution : add credentials in the URL (credentials in the cam parameters don't need to be true)
URL : snapshot.cgi?user=xxxxx&pwd=xxxxxx
edit: Test connection isn't OK but it has never works on my systems and it is not important.
Cam model : Wanscam JW0008
