galadril
Domoticz version: latest
Re: Domoticz app 2.0
Post by galadril »
mlamie wrote:
galadril wrote:
mlamie wrote:In the Play store the 4 latest comments did report the same issue after the update. Can someone have a look soonest?
Can you create a view-only account for me and pm me the details?
I don't know what you mean with a view-only account. So far I know the issue is in the Android app, not the Domoticz installation it selfs. If you have some instructions or suggestions I can try to provide you details to troubleshoot.
P.s. I already cleared the caches and removed the app and reinstalled it. Did not help.
Did you import or export the settings? Or did you manually reconfigured the app?
On your Domoticz system, you can create a new account.. Only with view rights (so that i can't turn switches on or off).
If you then give me via PM the ip + user + pass.. then I can remote debug
mlamie
Domoticz version: 3.5877
Post by mlamie »
I'm not at home and the Domoticz server can only be accessed locally. The issue I see in the android app is like below. I deleted the app, no backup, reinstalled and made new server settings manually. It did not work.
12-9-2016 9-41-49.png (24.35 KiB) Viewed 18243 times
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
galadril
Post by galadril »
mlamie wrote:I'm not at home and the Domoticz server can only be accessed locally. The issue I see in the android app is like:
Remove app settings, clear cache.. Don't import old settings!!
Manuall reconnect your app settings via the startup screens
piokuc
Post by piokuc »
Galadrill and what with alligment on grid dashboard ?
galadril
Post by galadril »
piokuc wrote:Galadrill and what with alligment on grid dashboard ?
Not working on yet.
Have a bigger list then you points only, don't spam!
mlamie
Post by mlamie »
Sorry for all the forum posts. I retried it from work with the following parameters and now it works.… :oops:
12-9-2016 10-24-12.png (29.25 KiB) Viewed 18230 times
galadril
Post by galadril »
mlamie wrote:Sorry for all the forum posts. I retried it from work with the following parameters and now it works.… :oops:
No problemo, happy that it works now!!
piokuc
Post by piokuc »
I have latest beta and i have a big problem on my Galaxy S6 with Android 6.0.1 with enable fingerprint security. When i enable this and have assigned fingerprint i run app domoticz and very offten i can not open app domoticz because when i touch my finger app will be closed. Sometimes i run ok but more time i can not run
galadril
Post by galadril »
piokuc wrote:Yes. Some naming is center and is ok but some is not center..
Should be better in next beta
piokuc
Post by piokuc »
Ok i am waiting to test it.
piokuc
Post by piokuc »
Ok i test and with fingerprint is still very big problem. Now i can not run app. I clear memory and config again and problem is still. I touch finger sensor and not reconized my finger. In android works ok.
Next bug is After creator wizard when finish app will closed and i must open again. Should automatical reopen.
galadril
Post by galadril »
piokuc wrote:Ok i test and with fingerprint is still very big problem. Now i can not run app. I clear memory and config again and problem is still. I touch finger sensor and not reconized my finger. In android works ok.
Fingerprint dialog also has a password failover if your fingers are not recognized...
PS, i use the Fingerpint SDK of Android.. Samsung build in their own sdk/api for fingerprints (sucks!!)
piokuc
Post by piokuc »
No looks good. Sometimes recognized but more time not reconized.
Monki77
Post by Monki77 »
The new version of the app is acting crazy on my S7.
Quick points -
Slow to respond.
Switches list disappears and then reappears (after taking ages to load).
Widgets are pretty much useless. The status doesn't update between the app and the widget.
One thing it was doing last night was repeating multiple commands over and over again. For example..
I turned my kitchen Philips Hue light from red to white: The app didn't respond. I then turned the bulb off and then back on again: the app didn't respond.
Then, after about a minute, the light started turning on and off, and changing from white to red multiple times. It did this non stop for about 2 minutes.
The exact same thing happened with my bathroom Hue bulb 30 mins later when i tried it.
Timdgr
Post by Timdgr »
I got an old Alcatel Pixi 3 phone from a friend that would make a nice control thingie for mounting on the wall in the livingroom. But i get the same message that the app is not compatible with my device. I guess that it could be the low resolution, it is only 320x480. It runs Android 4.4
I also saw a new Alcatel Pixi 4 at a local store for only 49 euro. Resolution 480x800. Running Android Marshmellow.
But how can i check if it can run this app before i spend money on it. It is cheap but if it does not work it's still a waste of money.
What are the specs for this app?
galadril
Post by galadril »
Monki77 wrote:The new version of the app is acting crazy on my S7.
Do you have the latest version of Domoticz system?
Monki77
Re: RE: Re: Domoticz app 2.0
Post by Monki77 »
Beta or Standard?
I'm currently on 5613. There's a beta update showing as 5640, but if I turn it to only show standard updates there's nothing.
Sent from my SM-G930F using Tapatalk
Monki77
Post by Monki77 »
Timdgr wrote:I got an old Alcatel Pixi 3 phone from a friend that would make a nice control thingie for mounting on the wall in the livingroom. But i get the same message that the app is not compatible with my device. I guess that it could be the low resolution, it is only 320x480. It runs Android 4.4
It may be best for you to load the dashboard in a browser instead of the app?
galadril
Post by galadril »
Monki77 wrote:I'm currently on 5613. There's a beta update showing as 5640, but if I turn it to only show standard updates there's nothing.
Should be good. Have you cleared cache and reconfigure?
Monki77
Re: RE: Re: RE: Re: Domoticz app 2.0
Post by Monki77 »
I've uninstalled and reinstalled the app twice so I think that should clear the cache on removal of the app?
