Almost working: Pi3 Domoticz + RFXcom 433.92 +Somfy Oxim RTS = fun?
RemcoSmit
Post by RemcoSmit »
I recently bought a RFXCom RFXtrx433E (433.92Mhz) Transceiver and connected it to my PI3 w/ Domesticz. I got all my switches, devices etc set up just fine. I can even do fun stuff with my smoke detectors, something that HomeWizard does not let me.
One thing that I would like to get working is controlling my Somfy outdoor rolling shutters (not sure how these things are called in English. In Dutch they are called a 'rolluik').
On the Net I read here and there that it should be possible but I haven't found a clear how-to that fits my set up. I tried to learn the codes from the existing remotes, but the tranceiver does not pick up any signal from both remotes (I have two shutters). Is that a sign that it will never work?
Is there someone out there that is willing to help me out?
Regards,
Remco.
b_weijenberg
Re: Pi3 Domoticz + RFXcom 433.92 +Somfy Oxim RTS = fun?
Post by b_weijenberg »
The somfy remote is not received for security reasons and it would make the Somfy remote useless if the same code is used.
You can add the RFXtrx433E as an additional remote in the Somfy motor.
See http://www.domoticz.com/forum/viewtopic.php?f=44&t=2567
and chapter 12 in the RFXtrx User Guide.
RFXtrx433, RFXtrx433E, RFXtrx433XL, RFX433XL, RFX868XL
RemcoSmit
Post by RemcoSmit »
I feel I am getting closer now. I managed to program the RFXCom and secondary remotes for both shutters using a windows laptop.
Now, with the transceiver connected to the windows laptop, using the RFXmngr they go up,stop and down.
However, after I connected the transceiver back to the Pi again, rebooted the Pi, added a Dummy device and then manually added two switches of type Blinds, RFY using the same ID's a on the windows laptop nothing happens!
I do see the switches in the console but nothing responds to the signals sent.
Any suggestions?
SoerenBM
Domoticz version: 3.5169
Re: Almost working: Pi3 Domoticz + RFXcom 433.92 +Somfy Oxim RTS = fun?
Post by SoerenBM »
Have you added the rfxtrx under hardware in Domoticz? If not do that. Then add your blinds again using the rfxtrx hardware, same place you selected RFY and ID.
BR Søren
Sent using Tapatalk
SoerenBM
Post by SoerenBM »
BR Søren
Sent using Tapatalk
SoerenBM
Post by SoerenBM »
BR Søren
Sent using Tapatalk
SoerenBM
Post by SoerenBM »
Remember to push test when you have selected correct id and unit code. The blind will bump down/up.
Hope this helps.
BR Søren
Sent using Tapatalk
Amsterdam020
Domoticz version: 3.5629
Post by Amsterdam020 »
Hi Remco,
Did you find a solution?
Please let me know, because i also have trouble with getting Somfy work, see http://www.domoticz.com/forum/viewtopic.php?f=6&t=13278
Rp3, youlesss, rfxcom, philips hue, dsb1820
Users browsing this forum: Bing [Bot] and 0 guests
