I have a Fibaro FGS221 controlling the lights in my garden cabin - outside and inside. This has previously worked flawlessly without any issues.
However, for some reason, the outside light works fine and can be controlled and seen by Domoticz no problem, but the inside light just returns an error when I try to do anything with it - "2016-09-05 10:37:08.303 Error: ZWave: Node not found! (NodeID: 11, 0x0b)"
This is one physical device, with two switches. In the Hardware setup on Domoticz it shows as:
In Devices, the two devices show as:011 (0x0b) Cabin lights FIBARO System FGS221 Double Relay Switch 2x1.5kW FIBARO System 0x100a 0x0200 2016-09-05 10:55:14 No
When I toggle the outside light, it works fine, and the log file shows:108 ZWave 00000B02 1 Cabin lights inside Light/Switch Switch On - - 2016-06-19 20:09:14
107 ZWave 00000B01 1 Cabin lights outside Light/Switch Switch Off - - 2016-09-05 10:55:12
When I try the same with the inside light, it fails and the log shows:2016-09-05 11:31:01.282 OpenZWave: Domoticz has send a Switch command! NodeID: 11 (0x0b)
2016-09-05 11:31:01.285 (ZWave) Light/Switch (Cabin lights outside)
Any suggestions how I can go about resolving this?2016-09-05 11:31:47.496 User: derek initiated a switch command
2016-09-05 11:31:47.497 Error: ZWave: Node not found! (NodeID: 11, 0x0b)
Thanks!!
