Multiple email recipients error
- Domoticz version: 4.10854
Under "Email settings"
If I add 2 emails under "To" like this: [email protected];[email protected]
Instructions says "(Separate by a semicolon, For Example: [email protected];[email protected])"
But when I press test I get this error message:
"A part following ´@´ should not contain the symbol ´;´"
But the mail is delivered so it works.
But why the error message?
- gizmocuz
Re: Multiple email recipients error
could it be the extra space begind the first email ?
No there is no extra space. I have written it as the examle. "(Separate by a semicolon, For Example: [email protected];[email protected])gizmocuz wrote:could it be the extra space begind the first email ?
I dont know why there is a space between com and ; when I paste the text. There is NO space in the example in Domoticz
If I paste the example text in the "To" field I get the same error
- gizmocuz
I see a space after [email protected]
Just tested here with two email recipients... working good
Nope. I still get the same error message with a space. And with the space I get credential error and no mail is sentgizmocuz wrote:I see a space after [email protected]
- jvdz
- Domoticz version: 4.107
I get the same Error when pressing the test button and having 2 emailadresses in the To field, but they both do arrive. (running v3.4834)
Jos
Jos
- gizmocuz
#jvdz, That is a very old domoticz version
@niclasc, i do not follow you... what is with this space ? remove the space as said, is it working then ?
- jvdz
Latest production ...right?gizmocuz wrote:#jvdz, That is a very old domoticz version
- gizmocuz
No, last production is from this morning ... rename the beta to stable if you wish *log*
If I add this: "[email protected];[email protected]"gizmocuz wrote:#jvdz, That is a very old domoticz version
I get error "A part following ´@´ should not contain the symbol ´;´" but mail is sent
If I add this: "[email protected] ;[email protected]" <---- Notice the space between com and ;
I get error "A part following ´@´ should not contain the symbol ´;´" AND a credential error an no mail is sent
- gizmocuz
Both have a space, come on...!
And can you show me the error ? as i do not believe it is from domoticz, but rather from your browser (which we can still fix...)
If I add this: [email protected] ;[email protected]
If I add this: [email protected] ;[email protected] <---- Notice the space between com and ;
- jvdz
Seems the forum adds the space in front of the ";" causing the confusion.
Yes the forum adds a space before the ; sign. If you check my post now it should be OKjvdz wrote:Seems the forum adds the space in front of the ";" causing the confusion.
Above I have used Chome
When I try in Firefox I get this:
I get error "Please enter an email address" but mail is sent
I get error "Please enter an email address" AND a credential error an no mail is sent
- gizmocuz
Can you post a screenshot of the errors ?
Cant take a screenshot. When I try to take a screen shot the error message disapearsgizmocuz wrote:Can you post a screenshot of the errors ?
- gizmocuz
on windows, press the print-screen button, control-v (paste) this into an image viewer/saver like 'irfanview'
For osx i suspect the same
