P1-wifi gateway (ESPEasy based)
romix
Domoticz version: Latest
Post by romix »
I have designed a small shield for the Wemos D1 mini to interface to the (Dutch) P1 Smart Meter port (see romix.macuser.nl). The Wemos board runs ESPEasy (either the Ser2Net plug-in, or my own, more customized to P1 datagrams, plug-in). On the Domoticz side, it uses the 'P1 Smart Meter with LAN interface' hardware pplug-in.
For a while, this works fine.
This is what the log shows:
2016-05-18 08:54:29.140 (serialtest) P1 Smart Meter (Power new)
2016-05-18 08:54:39.203 (serialtest) P1 Smart Meter (Power new)
2016-05-18 08:54:49.239 (serialtest) P1 Smart Meter (Power new)
Then, for unknown reasons this happens:
2016-05-18 08:33:00.383 Error: serialtest hardware (11) thread seems to have ended unexpectedly
When we're in this stage, both ESP and Domoticz need to be restarted.
Anyone have an idea how to find out what's wrong and how to fix it?
The datagrams produced by the ESP module seem fine (and are only sent when complete).
Ronald
hemarsys
Re: P1-wifi gateway (ESPEasy based)
Post by hemarsys »
Same issues here.
Anyone have an idea how to solve this problem?
Regards,
hemarsys
Mediacj
Post by Mediacj »
I have no solution for this problem but with this bridge on a esp8266 it all works perfect for more then a half year at the moment within Domoticz.
https://github.com/beckdac/ESP8266-transparent-bridge
piotr
Post by piotr »
romix wrote: Then, for unknown reasons this happens:
Ronald
I've ordered this board from you, I may assume that the board comes with this issue fixed ?
hemarsys
Post by hemarsys »
is there any news about a fix?
piotr
Post by piotr »
I received my board this week, followed the instructions but I haven't got it to work yet. I have created the "serial server" but I cannot connect to it.
Softwareregi
Post by Softwareregi »
If you have a Kaifa MA105: set baudrate 115200 8N1, esp easy serial server.... and it works !
Bye
piotr
Post by piotr »
I have a Kaifa, I'm using the recommended settings. It runs. For 10 minutes, then everything crashes. In my opinion this is not beta, this is experimental. I think I'll revert to rpi+p1 usb. Ran for years without crashing a single time.
piotr
Post by piotr »
I gave up on this, I had 20+ crashes per day. I've changed my setup to a slave instance of Domoticz with a P1 USB cable. It never crashed since.
mvdbro
Post by mvdbro »
piotr wrote:I have a Kaifa, I'm using the recommended settings. It runs. For 10 minutes, then everything crashes. In my opinion this is not beta, this is experimental. I think I'll revert to rpi+p1 usb. Ran for years without crashing a single time.
As mentioned on the Wiki for the Serial Server plugin:
Information on this page is based on preliminary development. Beware that functionality may be incomplete, not fully tested and subject to change.
You could also read: experimental.
romix
Post by romix »
New plug is is available on ESP Easy github (https://github.com/ESP8266nu/ESPEasyPlu ... ateway.ino).
This version verifies checksum and drops corrupt datagrams. Stability seems fine now.
egkman
Domoticz version: 2021.1
Post by egkman »
I can confirm: running over 1 month now with new plug-in / firmware and no hick-ups whatsoever. Seems to be really stable now. Neat solution.
