Nefit Easy™
jannl
- Domoticz version: 2025.5.x
Re: Nefit Easy™
Exactly, that is exactly what is stated in the conditions of Bosch. (As that it is forbidden to reverse engineer [WINKING FACE])
geezerrr
Nefit Easy™
Finally I managed to get the easy server running the way I want, struggled with the crortab which wasn't working as it should. Now using pm2, And can confirm it works even after reboot. Thanks everyone!
Now I was trying to use the boiler status to trigger a virtual switch using block
Unfortunately I'm not able to use the sValue,
Anyone having another way to use the sValue of the boiler status?
- Dutchsea
- Domoticz version: v2023.2
Re: Nefit Easy™
Hi, I really appreciatean updated post on how to install the Nefit Easy for Domoticz. The info is now so fragmenten and often outdated that its hard for novice user to make a start. Especially as the instruction in the initial post is not working anymore.
Also can someone explain me the pro's and con's between the 2 options: http server and php.
Many thanks.
Many thanks.
Raspberry PI 3B on USB drive, Debian version: 12 (bookworm), Domoticz 2024.7
Aeon Z-Wave G5 stick, RFXCOM, Sonof Zigbee 3.0 Dongle plus E, Nefit Easy, Fritzbox, Buienradar, Sonos
SweetPants
Re: Nefit Easy™
After working for several months in a row without any problems, last two nights (20/7 04:35 and 21/7 02:35), the backend stopped working (timeouts). Also Nefit app stopped working. After reset (off/on) Nefit Easy Connect adapter everything works again. Looking at the time this might be maintenance on the sever side!!!!
edit: today (22/07) 00:35 it happend again, watch the time difference (2 hours) between every day.
noway666
Re: Nefit Easy™
I second this. As a relative newbie regarding linux I would very much like to see a comprehensive guide to make the Easy visible in domoticz. Can anyone guide us through? (I don't want to mess up my domoticz setup with wrong commandsDutchsea wrote:Hi, I really appreciatean updated post on how to install the Nefit Easy for Domoticz. The info is now so fragmenten and often outdated that its hard for novice user to make a start. Especially as the instruction in the initial post is not working anymore.
Re: Nefit Easy™
Hmm... My Domoticz will stop working after some while if I enable the Nefit Easy Server. If I dont use this my Domoticz works just fine.
Anybody has some suggestions where to start with troubleshooting?
Already have the latest beta and updates/upgrades.
My RASPI is still functional when Domoticz is offline.
jurgen
- Domoticz version: stable
Re: Nefit Easy™
Dear all,
Today I have installed domoticz with easy-http server on my synology. I could not find a complete tutorial so i decided to document and share the steps that I did to get this working. I hope that you can use it.
Tutorial
Nefit easy on synology with DSM 6.0.2
Install node.js v4.2.6-0158 using package center from publisher Synology.inc
Install nefit easy http server on synology nas using ssh
npm i nefit-easy-http-server -g
Run the nefit easy http server as test
easy-server --serial=serialnumber --access-key=enteryourkey --password=enteryourpassword
Check if you can reach the http server using the following command:
curl http://127.0.0.1:3000/bridge/ecus/rrc/uiStatus
Go to domoticz which is running on my synology server
Add new hardware
Nefit easy http server over lan interface
Remote address: 127.0.0.1
poort: 3000
Go to Devices and check if there are nefit devices available and add the devices to the dashboard!
if there are no devices available check the logging in domoticz and verify with curl if the easy http server is running.
Create Startup script called easy-server.sh and place it in the directory /usr/local/etc/rc.d/
Reboot the nas and check that the process is running.
ps -aux | grep easy-http
@thanks to mvveelen
I edit the scriptname directory because of the change in DSM 6.0.2
Tutorial
Add new hardware
poort: 3000
@thanks to mvveelen
#! /bin/sh
### BEGIN INIT INFO
# Provides: nefit easy http server
# Required-Start: $network $remote_fs $syslog
# Required-Stop: $network $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: nefit-easy-http-server
# Description: This daemon will start the nefit-easy-http-server for use by Domoticz
### END INIT INFO
# Do NOT "set -e"
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
DESC="Nefit Easy HTTP Server"
NAME=easy-server
USERNAME=root
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/usr/local/etc/rc.d/$NAME
NEFIT_SERIAL_NUMBER=enterserial
NEFIT_ACCESS_KEY=enterkey
NEFIT_PASSWORD=enterpassword
NEFIT_HOST=127.0.0.1
NEFIT_PORT=3000
DAEMON=/usr/local/bin/$NAME
DAEMON_ARGS="$DAEMON_ARGS --serial=$NEFIT_SERIAL_NUMBER"
DAEMON_ARGS="$DAEMON_ARGS --access-key=$NEFIT_ACCESS_KEY"
DAEMON_ARGS="$DAEMON_ARGS --password=$NEFIT_PASSWORD"
DAEMON_ARGS="$DAEMON_ARGS --host=$NEFIT_HOST"
DAEMON_ARGS="$DAEMON_ARGS --port=$NEFIT_PORT"
# Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
# Function that starts the daemon/service
do_start()
nohup $DAEMON $DAEMON_ARGS &
echo `ps w | grep ${DAEMON} | grep -v -E 'grep' | awk '{print $1}' > $PIDFILE`
wait_for_status ()
counter=$2
while [ ${counter} -gt 0 ]; do
do_status
[ $? -eq $1 ] && return
let counter=counter-1
sleep 1
done
return 1
# Function that stops the daemon/service
do_stop()
# Kill the application
kill `cat ${PIDFILE}`
wait_for_status 1 20 || kill -9 `cat ${PIDFILE}`
rm -f ${PIDFILE}
do_status ()
if [ -f ${PIDFILE} ] && kill -0 `cat ${PIDFILE}` > /dev/null 2>&1; then
return
fi
rm -f ${PIDFILE}
return 1
case "$1" in
start)
do_start
stop)
do_stop
restart)
do_stop
do_start
echo "Usage: $SCRIPTNAME {start|stop|restart}" >&2
exit 3
esac
- gizmocuz
Re: Nefit Easy™
Maybe it's a nice idea to create a wiki page about this ?
I see there is already a wiki:
http://www.domoticz.com/wiki/NefitEasy
But maybe add a section for the Synology ?
jurgen
Re: Nefit Easy™
That would be a great idea!
- mvveelen
Re: Nefit Easy™
Great work on documenting it for DSM6 on the Synology. I'm still running DSM5, but maybe....someday,...jurgen wrote:Dear all,
Tutorial
Add new hardware
poort: 3000
Go to Devices and check if there are nefit devices available and add the devices to the dashboard!![]()
@thanks to mvveelen
I edit the scriptname directory because of the change in DSM 6.0.2Code: Select all
#! /bin/sh ### BEGIN INIT INFO # Provides: nefit easy http server # Required-Start: $network $remote_fs $syslog # Required-Stop: $network $remote_fs $syslog # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: nefit-easy-http-server # Description: This daemon will start the nefit-easy-http-server for use by Domoticz ### END INIT INFO # Do NOT "set -e" PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin DESC="Nefit Easy HTTP Server" NAME=easy-server USERNAME=root PIDFILE=/var/run/$NAME.pid SCRIPTNAME=/usr/local/etc/rc.d/$NAME NEFIT_SERIAL_NUMBER=enterserial NEFIT_ACCESS_KEY=enterkey NEFIT_PASSWORD=enterpassword NEFIT_HOST=127.0.0.1 NEFIT_PORT=3000 DAEMON=/usr/local/bin/$NAME DAEMON_ARGS="$DAEMON_ARGS --serial=$NEFIT_SERIAL_NUMBER" DAEMON_ARGS="$DAEMON_ARGS --access-key=$NEFIT_ACCESS_KEY" DAEMON_ARGS="$DAEMON_ARGS --password=$NEFIT_PASSWORD" DAEMON_ARGS="$DAEMON_ARGS --host=$NEFIT_HOST" DAEMON_ARGS="$DAEMON_ARGS --port=$NEFIT_PORT" # Exit if the package is not installed [ -x "$DAEMON" ] || exit 0 # # Function that starts the daemon/service # do_start() { nohup $DAEMON $DAEMON_ARGS & echo `ps w | grep ${DAEMON} | grep -v -E 'grep' | awk '{print $1}' > $PIDFILE` } wait_for_status () { counter=$2 while [ ${counter} -gt 0 ]; do do_status [ $? -eq $1 ] && return let counter=counter-1 sleep 1 done return 1 } # # Function that stops the daemon/service # do_stop() { # Kill the application kill `cat ${PIDFILE}` wait_for_status 1 20 || kill -9 `cat ${PIDFILE}` rm -f ${PIDFILE} } do_status () { if [ -f ${PIDFILE} ] && kill -0 `cat ${PIDFILE}` > /dev/null 2>&1; then return fi rm -f ${PIDFILE} return 1 } case "$1" in start) do_start ;; stop) do_stop ;; restart) do_stop do_start ;; *) echo "Usage: $SCRIPTNAME {start|stop|restart}" >&2 exit 3 ;; esac :
Are you going to add a wiki-page ?
preetyjess01
Re: Nefit Easy™
Amazing and very informative. I try this in my Raspberry Pi robot kits project. This is very helpful for me. Thanks.
Kochmeister
Re: Nefit Easy™
I could not find this using the search, but is it possible to switch on and off warm water as well?
That would be great!
- mvveelen
Re: Nefit Easy™
Hmmm, curious too.
cvdb
Re: Nefit Easy™
Tutorial
Add new hardware
poort: 3000
@thanks to mvveelen
Hello all,
Just installed Domoticz on my Synology, and got it working with some switches
Now i really would like to connect to my Nefit easy as well, but after a few evenings trying, its not that easy for me... because i am not so familiar with this code.
i am glad some people are, and thanks for puting it on this forum, and i hope they can help me in the right direction.
my configuration:
Synology DS412+ DSM 6.0.2-8451
installed node.js v4.2.6-0158
I am trying to follow the steps from the tutoral, but got lost..
I am connecting to Synology with PuTTY SSH
I changed the npm install directory to ~/.npm-global ( because it generated some errors on permissions.. )
https://docs.npmjs.com/getting-started/ ... ermissions
and when i do:
admin@DiskStation:~$ npm i nefit-easy-http-server -g
/var/services/homes/admin/.npm-global/bin/easy-server -> /var/services/homes/admin/.npm-global/lib/node_modules/nefit-easy-http-server/bin/easy-server
[email protected] /var/services/homes/admin/.npm-global/lib/node_modules/nefit-easy-http-server
+-- [email protected]
+-- [email protected] ([email protected])
+-- [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected])
+-- [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
+-- [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
+-- [email protected] ([email protected], [email protected])
admin@DiskStation:~$ easy-server
-sh: easy-server: command not found
admin@DiskStation:~$ curl http://127.0.0.1:3000/bridge/ecus/rrc/uiStatus
curl: (7) Failed to connect to 127.0.0.1 port 3000: Connection refused
So please help me with where i go wrong
- BartdaMan
Re: Nefit Easy™
Yes! Today our new Nefit Trendline has been installed, with Easy thermostat.
For installation of the easy server onto RasPi the Wiki is not 100% right, but with the help of the above posts (thank you all!) and good old friend Mr. Google, I just succeeded to get it all running in Domoticz.
I really like my new home automation hobby!
jurgen
Re: Nefit Easy™
cvdb wrote:jurgen wrote:Dear all,
Tutorial
Add new hardware
poort: 3000
@thanks to mvveelen
Hello all,
my configuration:
and when i do:
admin@DiskStation:~$ npm i nefit-easy-http-server -g /var/services/homes/admin/.npm-global/bin/easy-server -> /var/services/homes/admin/.npm-global/lib/node_modules/nefit-easy-http-server/bin/easy-server [email protected] /var/services/homes/admin/.npm-global/lib/node_modules/nefit-easy-http-server +-- [email protected] +-- [email protected] ([email protected]) +-- [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected]) +-- [email protected] +-- [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected]) +-- [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected]) +-- [email protected] ([email protected], [email protected])Its not starting the easy server...Code: Select all
admin@DiskStation:~$ easy-server -sh: easy-server: command not found admin@DiskStation:~$ admin@DiskStation:~$ curl http://127.0.0.1:3000/bridge/ecus/rrc/uiStatus curl: (7) Failed to connect to 127.0.0.1 port 3000: Connection refused admin@DiskStation:~$
Hi cvdb,
Before installing the nefit easy server using nmp, i think that you need to use the command "sudo -i" this will give you root permission.
after that try the commands again.
Greetz!
cvdb
Re: Nefit Easy™
Thanks Jurgen, will try that soon.
cvdb
Re: Nefit Easy™
Hi Jurgen,
the sudo -i did it, i have it running, and can see the new devices in domoticz
many thanks.
I have a second question about:
Kind regards
CvdB
I placed an easy-server.sh file (with my serial #, access key and passwd) in the /usr/local/etc/rc.d directory, and rebooted the nas, but the process is not running.. any idea ?Create Startup script called easy-server.sh and place it in the directory /usr/local/etc/rc.d/
Kind regards
CvdB
cvdb
Re: Nefit Easy™
I did a chmod 755 of the easy-server.sh file, rebooted the nas, and now its running
Many thanks to you all
- felix63
- Domoticz version: 2020.1
Re: Nefit Easy™
Trying to find an answer to a simple question. Went through the wiki/forum but couldn't find a clear answer.
If I connect a Nefit Easy to Domoticz what functionality do I get?
Can anyone give me some insights?
Cheers,
Lex
Cheers,
Lex
